Use of uninitialized value in join or string at ./FHEM/10_CUL_HM.pm line 7997
Begonnen von MadMax-FHEM, 10 Oktober 2016, 22:36:20
MadMax-FHEM
habe gerade ein weiteres HM-Wandthermostat (HM-TC-IT-WM-W-EU) gepaired.
Hauptsystem mit HM-CFG-USB, PI 2B und vccu...
EDIT: hier noch die fhem Version(en):
Latest Revision: 12225
File                Rev   Last Change
fhem.pl             12192 2016-09-22 07:44:52Z rudolfkoenig
90_at.pm            12028 2016-08-21 12:08:28Z rudolfkoenig
98_autocreate.pm    11984 2016-08-19 12:47:50Z rudolfkoenig
10_CUL_HM.pm        12138 2016-09-11 15:21:08Z martinp876
98_dewpoint.pm       6757 2014-10-12 18:58:57Z joachim09876
98_dummy.pm         11984 2016-08-19 12:47:50Z rudolfkoenig
91_eventTypes.pm    11984 2016-08-19 12:47:50Z rudolfkoenig
01_FHEMWEB.pm       12007 2016-08-20 09:50:51Z rudolfkoenig
92_FileLog.pm       12193 2016-09-22 19:17:26Z rudolfkoenig
98_HMinfo.pm        12138 2016-09-11 15:21:08Z martinp876
00_HMLAN.pm         12138 2016-09-11 15:21:08Z martinp876
98_HTTPMOD.pm       12220 2016-09-29 18:25:09Z ststrobel
91_notify.pm        11984 2016-08-19 12:47:50Z rudolfkoenig
No Id found for 99_perfmon.pm
33_readingsGroup.pm 12137 2016-09-11 14:45:55Z justme1968
99_SUNRISE_EL.pm    11984 2016-08-19 12:47:50Z rudolfkoenig
98_SVG.pm           11984 2016-08-19 12:47:50Z rudolfkoenig
50_TelegramBot.pm   11714 2016-06-25 14:45:00Z viegener
99_Utils.pm         11984 2016-08-19 12:47:50Z rudolfkoenig
98_version.pm       11987 2016-08-19 17:13:41Z markusbloch
59_Weather.pm       11249 2016-04-16 17:03:47Z borisneubert
98_weblink.pm       11984 2016-08-19 12:47:50Z rudolfkoenig
Blocking.pm         11918 2016-08-07 16:51:00Z rudolfkoenig
DevIo.pm            11786 2016-07-12 08:44:10Z rudolfkoenig
HMConfig.pm         12083 2016-08-28 06:10:21Z martinp876
HttpUtils.pm        12174 2016-09-19 05:53:59Z rudolfkoenig
RTypes.pm           10476 2016-01-12 21:03:33Z borisneubert
SetExtensions.pm    11513 2016-05-24 17:56:05Z rudolfkoenig
TcpServerUtils.pm   11908 2016-08-06 15:09:55Z rudolfkoenig
YahooWeatherAPI.pm  11249 2016-04-16 17:03:47Z borisneubert
Device und Pairing(ergebnis) sieht gut aus.
Hier das List des Device:
   CFGFN
   DEF        453732
   IODev      hmusb
   LASTInputDev hmusb
   MSGCNT     149
   NAME       Wandthermostat_EssZi2
   NOTIFYDEV  global
   NR         1114
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 Wandthermostat_EssZi2_Weather
   channel_02 Wandthermostat_EssZi2_Climate
   channel_03 Wandthermostat_EssZi2_WindowRec
   channel_06 Wandthermostat_EssZi2_remote
   channel_07 Wandthermostat_EssZi2_SwitchTr
   hmusb_MSGCNT 149
   hmusb_RAWMSG E453732,0000,4DC77206,FF,FFCB,09847045373200000000DA35
   hmusb_RSSI -53
   hmusb_TIME 2016-10-10 22:25:25
   lastMsg    No:09 - t:70 s:453732 d:000000 00DA35
   protLastRcv 2016-10-10 22:25:25
   protResnd  1 last_at:2016-10-10 22:08:53
   protSnd    120 last_at:2016-10-10 22:09:16
   protState  CMDs_done
   rssi_at_hmusb avg:-52.83 min:-55 max:-51 lst:-53 cnt:149
   Readings:
     2016-10-10 22:08:34   Activity        alive
     2016-10-10 22:08:59   CommandAccepted yes
     2016-10-10 22:08:29   D-firmware      1.3
     2016-10-10 22:08:29   D-serialNr      NEQ0122536
     2016-10-10 22:08:59   PairedTo        0xAFFE11
     2016-10-10 22:08:34   R-btnLock       off
     2016-10-10 22:08:34   R-burstRx       on
     2016-10-10 22:08:34   R-cyclicInfoMsg on
     2016-10-10 22:08:34   R-cyclicInfoMsgDis 0
     2016-10-10 22:08:34   R-globalBtnLock off
     2016-10-10 22:08:34   R-localResDis   off
     2016-10-10 22:08:34   R-lowBatLimitRT 2.2 V
     2016-10-10 22:08:34   R-modusBtnLock  off
     2016-10-10 22:08:34   R-pairCentral   0xAFFE11
     2016-10-10 22:15:02   battery         ok
     2016-10-10 22:15:02   batteryLevel    2.8
     2016-10-10 22:15:02   desired-temp    17.0
     2016-10-10 22:15:02   measured-temp   21.8
     2016-10-10 22:09:17   state           CMDs_done
     2016-10-10 22:08:48   time-request    -
   Helper:
     HM_CMDNR   9
     cSnd       01AFFE114537320703,01AFFE1145373207040000000001
     mId        00AD
     rxType     6
     Expert:
       def        1
       det        1
       raw        0
       tpl        0
     Io:
       newChn     +453732,00,00,00
       nextSend   1476131125.72114
       prefIO
       rxt        0
       vccu
       p:
         453732
         00
         00
         00
     Mrssi:
       mNo        09
       Io:
         hmusb      -51
     Prt:
       awake      0
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
     Rssi:
       At_hmusb:
         avg        -52.8389261744966
         cnt        149
         lst        -53
         max        -51
         min        -55
     Shregw:
       07         02
     Shadowreg:
     Tmpl:
   IODev      hmusb
   IOgrp      vccu:hmusb
   actCycle   000:10
   actStatus  alive
   autoReadReg 4_reqStatus
   expert     1_allReg
   firmware   1.3
   model      HM-TC-IT-WM-W-EU
   msgRepeat  1
   room       Esszimmer 2
   serialNr   NEQ0122536
   subType    thermostat
   webCmd     getConfig:clear msgEvents
Allerdings sind mir im Log (mach ja immer eine Kontrolle) folgendes aufgefallen:
2016.10.10 22:08:18 3: CUL_HM set vccu hmPairForSec 60
2016.10.10 22:08:28 2: CUL_HM Unknown device HM_453732 is now defined
2016.10.10 22:08:28 2: autocreate: define HM_453732 CUL_HM 453732
2016.10.10 22:08:28 2: autocreate: define FileLog_HM_453732 FileLog ./log/HM_453732-%Y.log HM_453732
2016.10.10 22:08:29 3: Device HM_453732 added to ActionDetector with 000:10 time
2016.10.10 22:08:29 3: CUL_HM pair: HM_453732 thermostat, model HM-TC-IT-WM-W-EU serialNr
2016.10.10 22:08:29 1: my_SignalDeadDevice      DeviceEvt: HM_453732: alive
2016.10.10 22:08:29 1: my_SignalDeadDevice      Event: status_HM_453732: alive      Device: HM_453732        State: alive
2016.10.10 22:08:33 3: CUL_HM set HM_453732 getConfig
2016.10.10 22:08:34 3: Device HM_453732 added to ActionDetector with 000:10 time
2016.10.10 22:08:47 1: my_StoreBatteryStatus      ignoring Device: HM_453732
2016.10.10 22:08:52 3: YahooWeather: 0 result(s) retrieved
2016.10.10 22:08:58 3: CUL_HM set HM_453732 getConfig
2016.10.10 22:09:09 3: CUL_HM set Steckdose_FabiZi_SchreibTisch_Drucker_Sw statusRequest
2016.10.10 22:09:10 3: CUL_HM set Steckdose_FabiZi_SchreibTisch_RasPI_Sw statusRequest
2016.10.10 22:09:13 1: PERL WARNING: Use of uninitialized value in join or string at ./FHEM/10_CUL_HM.pm line 7997.
2016.10.10 22:09:13 3: stacktrace:
2016.10.10 22:09:13 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7997)
2016.10.10 22:09:13 3:     main::CUL_HM_TCITRTtempReadings     called by ./FHEM/10_CUL_HM.pm (7613)
2016.10.10 22:09:13 3:     main::CUL_HM_updtRegDisp            called by ./FHEM/10_CUL_HM.pm (3218)
2016.10.10 22:09:13 3:     main::CUL_HM_parseCommon            called by ./FHEM/10_CUL_HM.pm (1339)
2016.10.10 22:09:13 3:     main::CUL_HM_Parse                  called by fhem.pl (3382)
2016.10.10 22:09:13 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (777)
2016.10.10 22:09:13 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (602)
2016.10.10 22:09:13 3:     main::HMLAN_Read                    called by fhem.pl (3221)
2016.10.10 22:09:13 3:     main::CallFn                        called by fhem.pl (671)
2016.10.10
EDIT2: (war schon mal drin ist irgendwie zers
FHEM PI3 Buster (Test)
MadMax-FHEM
Hmmm, wohl zu viel Input... ;-)
Dann hier der Rest:
EDIT2: (war schon mal drin ist irgendwie zerschossen worden)
Einige Erläuterungen zu Logeinträgen (die wie ich denke nichts mit dem Problem/Warning zu tun haben sollten)...
CUL_HM set Steckdose_FabiZi_SchreibTisch_Drucker_Sw statusRequest: bzw. ..._RasPI sind Steckdosenzwischenstecker, die über eine weitere Steckdose bei Bedarf eingeschaltet werden, daher nicht immer erreichbar sind...
my_StoreBatteryStatus      ignoring Device: HM_453732: in der Funktion my_StoreBatteryStatus berechne und speichere ich Batteriezustände in einem dummy. Neu angelegte Geräte will ich da nicht speichern...
my_SignalDeadDevice      DeviceEvt: HM_453732: alive: my_SignalDeadDevice wird über einen notify auf den ActionDetector getriggert dort asse ich mich dann u.a. benachrichtigen, wenn ein Gerät ausgefallen ist...
StackTrace war (zufällig) noch an, da ich vor einiger Zeit ein Problem analysiert habe...
Wie gesagt es sieht (für mich) so aus als wäre trotzdem alles ok.
Wollte es nur mal posten, vielleicht schlummert ja doch was...
Gruß, Joachim
