FB_CALLMONITOR trotz disabeld 1 , blockiert Fhem ca 3 Sekunden
Begonnen von LuckyDay, 21 Oktober 2016, 13:51:46
LuckyDay
Meine FB ist gerade nicht existent, deswegen steht das Modul auf disable
aktuell behelfe ich mir, das ich das Modul lösche.
   DEF        192.168.2.1
   DeviceName 192.168.2.1:1012
   NAME       Anrufliste
   NEXT_OPEN  1477049862.3877
   NR         502
   NTFY_ORDER 50-Anrufliste
   PARTIAL
   STATE      disconnected
   TYPE       FB_CALLMONITOR
   Readings:
     2016-10-21 13:36:42   state           disconnected
   Helper:
     Bm:
       Fb_callmonitor_attr:
         cnt        1
         dmx        0
         mAr
         max        0
         tot        0
       Fb_callmonitor_get:
         cnt        8
         dmx        0
         mAr
         max        0
         tot        0
       Fb_callmonitor_notify:
         cnt        2632
         dmx        0
         max        10
         tot        10
         mAr:
           HASH(0x1aa9688)
           HASH(0x131f780)
       Fb_callmonitor_ready:
         cnt        18186
         dmx        0
         max        3012
         tot        440646
         mAr:
           HASH(0x1aa9688)
       Fb_callmonitor_set:
         cnt        20
         dmx        0
         mAr
         max        0
         tot        0
   answMachine-is-missed-call 1
   disable    1
   room       Test
   stateFormat state<br>last missed_call
2016.10.21 13:37:45.395 1: Perfmon: possible freeze starting at 13:37:43, delay is 2.395
2016.10.21 13:36:42.395 1: Perfmon: possible freeze starting at 13:36:40, delay is 2.395
2016.10.21 13:35:39.395 1: Perfmon: possible freeze starting at 13:35:37, delay is 2.394
2016.10.21 13:34:36.397 1: Perfmon: possible freeze starting at 13:34:34, delay is 2.397
2016.10.21 13:33:33.395 1: Perfmon: possible freeze starting at 13:33:31, delay is 2.395
2016.10.21 13:32:30.395 1: Perfmon: possible freeze starting at 13:32:28, delay is 2.395
2016.10.21 13:31:27.395 1: Perfmon: possible freeze starting at 13:31:25, delay is 2.394
2016.10.21 13:30:24.395 1: Perfmon: possible freeze starting at 13:30:22, delay is 2.395
2016.10.21 13:29:21.397 1: Perfmon: possible freeze starting at 13:29:19, delay is 2.396
2016.10.21 13:28:18.395 1: Perfmon: possible freeze starting at 13:28:16, delay is 2.395
2016.10.21 13:27:15.395 1: Perfmon: possible freeze starting at 13:27:13, delay is 2.395
2016.10.21 13:26:12.395 1: Perfmon: possible freeze starting at 13:26:10, delay is 2.395
2016.10.21 13:25:09.395 1: Perfmon: possible freeze starting at 13:25:07, delay is 2.394
2016.10.21 13:24:06.395 1: Perfmon: possible freeze starting at 13:24:04, delay is 2.395
2016.10.21 13:23:03.397 1: Perfmon: possible freeze starting at 13:23:01, delay is 2.397
2016.10.21 13:22:00.395 1: Perfmon: possible freeze starting at 13:21:58, delay is 2.395
2016.10.21 13:20:57.395 1: Perfmon: possible freeze starting at 13:20:55, delay is 2.394
2016.10.21 13:19:54.395 1: Perfmon: possible freeze starting at 13:19:52, delay is 2.394
2016.10.21 13:18:51.395 1: Perfmon: possible freeze starting at 13:18:49, delay is 2.395
2016.10.21 13:17:48.395 1: Perfmon: possible freeze starting at 13:17:46, delay is 2.395
2016.10.21 11:04:27.099 1: Perfmon: possible freeze starting at 11:04:24, delay is 3.099
2016.10.21 11:03:24.008 1: Perfmon: possible freeze starting at 11:03:21, delay is 3.008
Auch das FRITZBOX Modul lebt noch trotz disable, allerdings blockiert es nicht länger einer Sekunde.
define FritzBox FRITZBOX 192.168.2.1
attr FritzBox allowTR064Command 1
attr FritzBox disable 1
attr FritzBox event-on-change-reading .*
attr FritzBox room Test
PS. Update Fhem heute
Markus Bloch
Hallo Hary,
ich habe FB_CALLMONITOR soeben auf Non-Blocking Connect umgestellt, so dass der Verbindungsaufbau in diesem Fall keinen Freeze verursacht. Desweiteren wird die Verbindung nun geschlossen, wenn das Device disabled ist.
Gibt es ab morgen.
Markus
LuckyDay
