RSSI Monitor
Begonnen von Dr. Boris Neubert, 27 September 2010, 21:43:29
Dr. Boris Neubert
To whom it concerns:
I contributed a perl tool named RSSImonitor.pl to the contrib folder of
fhem. RSSImonitor.pl produces an overview of the signal strength of
devices received by CUL and CUN and can help to find the best location
for putting the receiver. Sample output:
       Device    Min    Max    Avg    StdDev
  0.hr.pewo.e    -87.5    -82.5    -85.5    0.8
    2.bad.hzg    -83.0    -60.0    -70.8    3.8
     2.og.hzg    -83.0    -64.0    -69.2    2.2
   0.hr.edv.e    -92.5    -85.0    -88.2    1.7
Regards,
Boris
Sie haben diese Nachricht erhalten, da Sie der Google Groups-Gruppe FHEM users beigetreten sind.
Wenn Sie Nachrichten in dieser Gruppe posten möchten, senden Sie eine E-Mail an fhem-users@googlegroups.com.
Wenn Sie aus dieser Gruppe austreten möchten, senden Sie eine E-Mail an fhem-users+unsubscribe@googlegroups.com.
Besuchen Sie die Gruppe unter http://groups.google.com/group/fhem-users?hl=de, um weitere Optionen zu erhalten.
Guest
Thanks Boris,
it works fine and is a very useful tool for me.
What means the result of standard deviation (StdDev)?
Martin
> Regards,
> Boris
Guest
Ok, I think the standard deviation is only the normal mathematic
"varianz" and has all in all no meaning for my fhem?!
On 28 Sep., 19:30, Martin Haas wrote:
> Thanks Boris,
> Martin
> > Regards,
> > Boris
Guest
Ok, I think the called "standard deviation" is only the normal
mathematic "Standardabweichung" without special meaning for my fhem.
> Thanks Boris,
> Martin
> > Regards,
> > Boris
Dr. Boris Neubert
Am 28.09.2010 21:03, schrieb Martin Haas:
Standard deviation is the square root of the variance of the readings
for a device. The variance is the mean squared deviation of the readings
from the average.
The standard deviation is a measure of how much the readings vary around
the average reading.
Regards,
Boris
P.S.: to integrate EM devices, the RSSI readings must be harmonized from
CUN_RSSI to RSSI. This is a todo for the next major release of fhem.
