Button to trigger shell script file
Begonnen von Guest, 14 Februar 2011, 17:32:41
Guest
Hello,
Can anyone please help.
I have FHEM running on my Linux media server controlling several FHT
room thermostats through a CUL, I am using pgm2 web front end at the
moment.
I am a Linux novice but have enough knowlage to write a script which
will send a series of commands to FHEM. The script will contain
several 'set' comands to set the temperature in several rooms, for
example to set them all to 6 Deg or off or many other combinations.
I would like to know if it is possible to have a button on the pgm2
web front end to trigger the shell script, none of the helper modules
seem to do this.
Thankyou
Alan
Sie haben diese Nachricht erhalten, da Sie der Google Groups-Gruppe FHEM users beigetreten sind.
Wenn Sie Nachrichten in dieser Gruppe posten möchten, senden Sie eine E-Mail an fhem-users@googlegroups.com.
Wenn Sie aus dieser Gruppe austreten möchten, senden Sie eine E-Mail an fhem-users+unsubscribe@googlegroups.com.
Besuchen Sie die Gruppe unter http://groups.google.com/group/fhem-users?hl=de, um weitere Optionen zu erhalten.
Dr. Boris Neubert
Hello Alan,
Am 14.02.2011 17:32, schrieb aam:
> seem to do this.
please check out the commandref.html, especially the documentation on
- dummy
- notify
- Perl specials
If dummy devices are not shown in pgm2 please use a FS20 device with
unused housecode/button as dummy.
Regards,
Boris
Globaler Moderator, Developer, aktives Mitglied des FHEM e.V. (Marketing, Verwaltung)
> > seem to do this.
define MyBtn FS20 9999 99
attr MyBtn dummy
define MyNotify notify MyBtn "/local/bin/mypgm %"
Guest
Hi Alan,
You could also use an EOF statement. PLease see this example:
http://www.daniweb.com/forums/thread134747.html
The example
   1. telnet 150.236.18.66 25 <   2. HELO
   3. whatever else you need to send the mail
   4. EOF
will execute all commands between line 1 and line 4
2011/2/14 Rudolf Koenig
> > > seem to do this.
> attr MyBtn dummy
> erhalten.
Guest
Thankyou for your help,
I will try your suggestions later today.
Cheers
Alan
On Feb 14, 7:56 pm, Ernst Cozijnsen wrote:
> Hi Alan,
> The example
>    1. telnet 150.236.18.66 25 <>    2. HELO
>    4. EOF
> > > > seem to do this.
> > attr MyBtn dummy
> > erhalten.
Guest
Thankyou again for all your suggestions.
I am trying out your suggestions but thought I would have a look at
alternative web front ends at the same time. I came across phyFHEM
which does most of what I want to do and looks great on my mobile.
However it would be better (for me) if there was an english version,
or if it is possible to edit the text in some way.
Does anybody know if this is possible
Thankyou
Alan
> Cheers
> Alan
> > Hi Alan,
> > The example
> >    1. telnet 150.236.18.66 25 <> >    2. HELO
> >    4. EOF
> > > > > seem to do this.
> > > attr MyBtn dummy
> > > erhalten.
