armed and disarmed state different actions
Begonnen von Guest, 30 Januar 2011, 21:56:46
Guest
I'm getting more security sensors in fhem, like door sensor window
sensor, motion sensor.
The default action is that all the devices react and you can triggger
other devices lamp, sirenes.
It it possible by pressing a button of a remote control, that fhem
uses different actions.
For example.
When  home, fhem is in disarmed state, when a door is opened it's
logged and no lamp on
When I go out, I press a button of a remote, fhem counts down, and
after 30sec it goes in armed state.
When now a door is opened, a lamp or sirene is on.
Is this possible in fhem?
regards Richard
Sie haben diese Nachricht erhalten, da Sie der Google Groups-Gruppe FHEM users beigetreten sind.
Wenn Sie Nachrichten in dieser Gruppe posten möchten, senden Sie eine E-Mail an fhem-users@googlegroups.com.
Wenn Sie aus dieser Gruppe austreten möchten, senden Sie eine E-Mail an fhem-users+unsubscribe@googlegroups.com.
Besuchen Sie die Gruppe unter http://groups.google.com/group/fhem-users?hl=de, um weitere Optionen zu erhalten.
Guest
Hi Richard,
Pls. be aware that fhem and FS20 are not fully suitable for security
applications at all.
So the whole FS20 concept lacks of any security awareness and it is
vulnarable against replay
 attacks. (So an intruder needs just to snif the button code for
disarming and replay it whenever he wants,)
Yes, but you will need to have a bit knowledge of php programming
language and will be able to write simple notify scripts that will
check if the "arming" state has been set, if so, you will then switch
on lights, sirenes, etc.
But again... there is no guarantee that a switch command on your
remote control or fro fhem will also be received and understood by the
target (light, sirene) so it might be, that there is no light or
sirene even when fhem detects the intruder.
cu
Maz
Guest
On Jan 30, 10:18 pm, Maz wrote:
> Hi Richard,
I know, but I will use it also, if I go to bed I press a button, the
scheme of fhem changes and now the motion sensor trigger the lamps
It should be more nice to have it in fhem. You can define for example
2 different action schemes with trigger and of notify, and looks
general of the global state of fhem is armed of disarmed
> cu
> Maz
I think we had this already, but here is another (untested :) version:
attr global userattr armed triggered
define alarm_btn FS20 1234 50       # the button on the remote
define alarm_activate notify alarm_btn:on define alarm_delayed +00:00:30 \
  attr alarm_btn armed yes;; attr alarm_btn triggered no
define alarm_deactivate notify alarm_btn:off attr alarm_btn armed no
define piri.room1 FS20 1234 51
define piri.room2 FS20 1234 52
define alarm_trigger notify piri.* {\
  if($attr{alarm_btn}{armed} eq "yes" && $attr{alarm_btn}{triggered} eq "no") {\
    $attr{alarm_btn}{triggered} = "yes";;\
    fhem("set lamp,sirene on");;\
Guest
Rudolf,
I'm testing it. but I have a question
this part works (and I understand)
define alarm_btn FS20 4631 00       # the button on the remote
define alarm_activate notify alarm_btn:on define alarm_delayed at
+00:00:30 \
Then I want if there is motion and the state is armed It should put a
lamp on
Only that part I don't know how to set this. I have this
I have a motion sensor defined
define motion_sensor RFXX10REC ms14a L11 motion L12 light
fhem> l motion_sensor
   DEF        ms14a L11 motion L12 light
   IODev      RFXCOM
   NAME       motion_sensor
   NR         80
   RFXX10REC_deviceid L11
   RFXX10REC_deviceid2 L12
   RFXX10REC_devicelog motion
   RFXX10REC_devicelog2 light
   RFXX10REC_type ms14a
   STATE      alert
   TIME       2011-02-06 19:58:41
   TYPE       RFXX10REC
   Readings:
     2011-02-06 19:58:45   light           on
     2011-02-06 19:58:41   motion          alert
define alarm_trigger notify motion_sensor {\
eq "no") {\
    fhem("set Schemerlamp on");;\
Where must i put the read motion state alert etc?
regards Richard
> > after 30sec it goes inarmedstate.
> attr global userattrarmedtriggered
>   attr alarm_btnarmedyes;; attr alarm_btn triggered no
> define alarm_deactivate notify alarm_btn:off attr alarm_btnarmedno
Guest
I also have this. But whenever the state is armed of not, the
schemerlamp won't be triggered
fhem> l alarm_btn
   BTN        00
   CUL_MSGCNT 4
   CUL_RAWMSG F4631001107
   CUL_RSSI   -70.5
   CUL_TIME   2011-02-06 21:35:16
   DEF        4631 00
   IODev      CUL
   LASTIODev  CUL
   MSGCNT     4
   NAME       alarm_btn
   NR         98
   STATE      on
   TYPE       FS20
   XMIT       4631
   Code:
     1          4631 00
   Readings:
     2011-02-06 21:35:16   state           on
   armed      yes
   triggered  no
define testje FS20 4631 01
+00:00:30 \
define alarm_trigger notify testje {\
eq "no") {$attr{alarm_btn}{triggered} = "yes";;\
Are the attributes armed and triggered set correctly after the activate?
-> check it with list alarm_btn
If yes, please add some
  Log 1, "Hello";;\
to the alarm_trigger and then use "trigger testje on" to pinpoint the problem.
Guest
I get only errors
Rudolf
2011.02.07 21:37:40 2: FS20 testje on
2011.02.07 21:37:40 3: Unknown command {\
if($attr{alarm_btn}{armed}, try help
2011.02.07 21:37:40 3: Unknown command \, try help
if($attr{alarm_btn}{armed}, try helpUnknown command \, try helpUnknown
command \, try help
fhem> l alarm_trigger
   DEF        testje {\
"no") {\
$attr{alarm_btn}{triggered} = "yes";\
fhem("set Schemerlamp on");\
   NAME       alarm_trigger
   NR         102
   REGEXP     testje
   STATE      active
   TYPE       notify
>   Log 1, "Hello";;\
On Mon, Feb 07, 2011 at 12:39:52PM -0800, kroon040 wrote:
> I get only errors
There were some typos in the script. Please try the following fhem.cfg, it does
not need any attached hardware. This time I have tested it by starting fhem
from the fhem source directory.
attr global logfile -
attr global modpath .
attr global port 7073 global
attr global statefile ./fhem.state
attr global verbose 5
define dCUL CUL none 0000
define piri.room1 FS20 1234 51      # The motion sensor
define lamp       FS20 1234 52      # The alarm signal
define alarm_activate notify alarm_btn:on \
  define alarm_delayed at +00:00:03 \
define alarm_deactivate notify alarm_btn:off \
  attr alarm_btn armed no;; set lamp off
  if($attr{alarm_btn}{armed} eq "yes" && \
    fhem("set lamp on");;\
Telnet to fhem, and try following commands one by one and watch the log in the
fhem window:
fhem> trigger alarm_btn on
(wait 3 seconds)
fhem> trigger piri.room1 on
fhem> trigger alarm_btn off
Regards,
  Rudi
Guest
Rudolf,
That works, maybe a good option fot in the FAQ?
Richard
> > I get only errors
> fhem window:
> (wait 3 seconds)
> Regards,
>   Rudi
Even better: could you please make an entry in the fhemwiki?
