Jede menge Perl Warnungen im log.
Begonnen von Badflex, 23 Januar 2017, 18:05:31
Badflex
Ich hab seit dem neu aufsetzen von fhem sehr viele Perl Warnungen im Log und ich weiß nicht was da falsch läuft.
schaut mal:
2017.01.23 17:37:28 1: Including fhem.cfg
2017.01.23 17:37:31 1: PERL WARNING: ICal::Entry::getNextMonthlyDateByDay() called too early to check prototype at ./FHEM/57_Calendar.pm line 1196, <$fh> line 852.
2017.01.23 17:37:31 1: stacktrace:
2017.01.23 17:37:31 1:     main::__ANON__                      called by ./FHEM/57_Calendar.pm (1196)
2017.01.23 17:37:31 1:     (eval)                              called by fhem.pl (2334)
2017.01.23 17:37:31 1:     (eval)                              called by fhem.pl (2333)
2017.01.23 17:37:31 1:     main::CommandReload                 called by fhem.pl (1749)
2017.01.23 17:37:31 1:     main::LoadModule                    called by fhem.pl (1811)
2017.01.23 17:37:31 1:     main::CommandDefine                 called by fhem.pl (1107)
2017.01.23 17:37:31 1:     main::AnalyzeCommand                called by fhem.pl (976)
2017.01.23 17:37:31 1:     main::AnalyzeCommandChain           called by fhem.pl (1242)
2017.01.23 17:37:31 1:     main::CommandInclude                called by fhem.pl (521)
2017.01.23 17:37:34 1: PERL WARNING: Prototype mismatch: sub main::deg2rad ($;$) vs none at /usr/share/perl/5.20/Exporter.pm line 66, <DATA> line 129.
2017.01.23 17:37:34 1: stacktrace:
2017.01.23 17:37:34 1:     main::__ANON__                      called by /usr/share/perl/5.20/Exporter.pm (66)
2017.01.23 17:37:34 1:     Exporter::import                    called by ./FHEM/59_Moon.pm (6)
2017.01.23 17:37:34 1:     main::BEGIN                         called by ./FHEM/59_Moon.pm (6)
2017.01.23 17:37:34 1:     (eval)                              called by ./FHEM/59_Moon.pm (6)
2017.01.23 17:37:34 1:     (eval)                              called by fhem.pl (2334)
2017.01.23 17:37:34 1:     (eval)                              called by fhem.pl (2333)
2017.01.23 17:37:34 1:     main::CommandReload                 called by fhem.pl (1749)
2017.01.23 17:37:34 1:     main::LoadModule                    called by fhem.pl (1811)
2017.01.23 17:37:34 1:     main::CommandDefine                 called by fhem.pl (1107)
2017.01.23 17:37:34 1:     main::AnalyzeCommand                called by fhem.pl (976)
2017.01.23 17:37:34 1:     main::AnalyzeCommandChain           called by fhem.pl (1242)
2017.01.23 17:37:34 1:     main::CommandInclude                called by fhem.pl (521)
2017.01.23 17:37:34 1: PERL WARNING: "my" variable $host masks earlier declaration in same scope at ./FHEM/30_MilightBridge.pm line 72, <$fh> line 1122.
2017.01.23 17:37:34 1:     main::__ANON__                      called by ./FHEM/30_MilightBridge.pm (72)
2017.01.23 17:37:35 1: PERL WARNING: Argument "23:02" isn't numeric in division (/) at ./FHEM/99_SUNRISE_EL.pm line 92, <$fh> line 1152.
2017.01.23 17:37:35 1: stacktrace:
2017.01.23 17:37:35 1:     main::__ANON__                      called by ./FHEM/99_SUNRISE_EL.pm (92)
2017.01.23 17:37:35 1:     main::sr_alt                        called by ./FHEM/99_SUNRISE_EL.pm (389)
2017.01.23 17:37:35 1:     main::sunrise                       called by (eval 125) (1)
2017.01.23 17:37:35 1:     (eval)                              called by ./FHEM/98_WeekdayTimer.pm (379)
2017.01.23 17:37:35 1:     main::WeekdayTimer_EchteZeit        called by ./FHEM/98_WeekdayTimer.pm (206)
2017.01.23 17:37:35 1:     main::WeekdayTimer_Profile          called by ./FHEM/98_WeekdayTimer.pm (170)
2017.01.23 17:37:35 1:     main::WeekdayTimer_Define           called by fhem.pl (3302)
2017.01.23 17:37:35 1:     main::CallFn                        called by fhem.pl (1831)
2017.01.23 17:37:35 1:     main::CommandDefine                 called by fhem.pl (1107)
2017.01.23 17:37:35 1:     main::AnalyzeCommand                called by fhem.pl (976)
2017.01.23 17:37:35 1:     main::AnalyzeCommandChain           called by fhem.pl (1242)
2017.01.23 17:37:35 1:     main::CommandInclude                called by fhem.pl (521)
2017.01.23 17:37:35 1: [Timer_Steckdose1] invalid time <31:35:15> HH:MM[:SS]
2017.01.23 17:37:35 1:     main::sunrise                       called by (eval 126) (1)
2017.01.23 17:37:35 1:     main::sunrise                       called by (eval 127) (1)
2017.01.23 17:37:35 1:     main::sunrise                       called by (eval 128) (1)
2017.01.23 17:37:35 1:     main::sunrise                       called by (eval 129) (1)
2017.01.23 17:37:35 1:     main::sunrise                       called by (eval 130) (1)
2017.01.23 17:37:35 1:     main::sunrise                       called by (eval 131) (1)
2017.01.23 17:37:35 1:     main::sunrise                       called by (eval 132) (1)
2017.01.23 17:37:35 1:     main::WeekdayTimer_EchteZeit        called by ./FHEM/98_WeekdayTimer.pm (216)
2017.01.23 17:37:35 1: Including ./log/fhem.save
2017.01.23 17:37:38 1: usb create starting
2017.01.23 17:37:44 1: usb create end
2017.01.23 17:37:44 1: Registering Netatmo webhook
2017.01.23 17:37:44 0: Featurelevel: 5.7
2017.01.23 17:37:44 0: Server started with 195 defined entities (fhem.pl:13142/2017-01-18 perl:5.020002 os:linux user:fhem pid:14536)
2017.01.23 17:37:49 1: 192.168.178.26:55000 reappeared (Tv)
2017.01.23 17:37:56 3: CUL_HM set Pflanzkuebel on
2017.01.23 17:37:56 3: CUL_HM Pflanzkuebel repeat, level 00 instead of C8
2017.01.23 17:38:31 1: PERL WARNING: Bareword found where operator expected at (eval 360) line 3, near ""content-type" content"
2017.01.23 17:38:31 1: stacktrace:
2017.01.23 17:38:31 1:     main::__ANON__                      called by (eval 360) (3)
2017.01.23 17:38:31 1:     (eval)                              called by ./FHEM/59_Twilight.pm (516)
2017.01.23 17:38:31 1:     main::Twilight_getWeatherHorizon    called by ./FHEM/59_Twilight.pm (419)
2017.01.23 17:38:31 1:     main::Twilight_WeatherCallback      called by FHEM/HttpUtils.pm (427)
2017.01.23 17:38:31 1:     main::__ANON__                      called by fhem.pl (671)
2017.01.23 17:38:31 1: PERL WARNING: (Missing operator before content?)
2017.01.23 17:38:31 1: PERL WARNING: Bareword found where operator expected at (eval 360) line 5, near "<title>Yahoo"
2017.01.23 17:38:31 1:     main::__ANON__                      called by (eval 360) (5)
2017.01.23 17:38:31 1: PERL WARNING: (Missing operator before Yahoo?)
2017.01.23 17:38:31 1: PERL WARNING: Bareword found where operator expected at (eval 360) line 5, near "201402200631.png"
2017.01.23 17:38:31 1: PERL WARNING: (Missing operator before png?)
2017.01.23 17:38:31 1: PERL WARNING: Number found where operator expected at (eval 360) line 5, near ") 50"
2017.01.23 17:38:31 1: PERL WARNING: (Missing operator before 50?)
2017.01.23 17:38:31 1: PERL WARNING: Number found where operator expected at (eval 360) line 9, near "300 18"
2017.01.23 17:38:31 1:     main::__ANON__                      called by (eval 360) (9)
2017.01.23 17:38:31 1: PERL WARNING: (Missing operator before  18?)
2017.01.23 17:38:31 1: PERL WARNING: Bareword found where operator expected at (eval 360) line 9, near "18px"
2017.01.23 17:38:31 1: PERL WARNING: (Missing operator before px?)
2017.01.23 17:38:31 1: PERL WARNING: String found where operator expected at (eval 360) line 9, near "px "helvetica neue""
2017.01.23 17:38:31 1: PERL WARNING: (Do you need to predeclare px?)
2017.01.23 17:38:31 1: PERL WARNING: Bareword found where operator expected at (eval 360) line 11, near "}
table"
2017.01.23 17:38:31 1:     main::__ANON__                      called by (eval 360) (11)
2017.01.23 17:38:31 1: PERL WARNING: (Missing operator before table?)
2017.01.23 18:01:47 1: PERL WARNING: Argument "" isn't numeric in subtraction (-) at ./FHEM/92_FileLog.pm line 704.
2017.01.23 18:01:47 1: stacktrace:
2017.01.23 18:01:47 1:     main::__ANON__                      called by ./FHEM/92_FileLog.pm (704)
2017.01.23 18:01:47 1:     main::FileLog_Get                   called by fhem.pl (3302)
2017.01.23 18:01:47 1:     main::CallFn                        called by fhem.pl (1714)
2017.01.23 18:01:47 1:     main::CommandGet                    called by fhem.pl (1107)
2017.01.23 18:01:47 1:     main::AnalyzeCommand                called by ./FHEM/01_FHEMWEB.pm (2372)
2017.01.23 18:01:47 1:     main::FW_fC                         called by ./FHEM/98_SVG.pm (1164)
2017.01.23 18:01:47 1:     main::SVG_getData                   called by ./FHEM/98_SVG.pm (1132)
2017.01.23 18:01:47 1:     main::SVG_doShowLog                 called by ./FHEM/98_SVG.pm (1020)
2017.01.23 18:01:47 1:     main::SVG_showLog                   called by ./FHEM/01_FHEMWEB.pm (852)
2017.01.23 18:01:47 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (524)
2017.01.23 18:01:47 1:     main::FW_Read                       called by fhem.pl (3302)
2017.01.23 18:01:47 1:     main::CallFn                        called by fhem.pl (674)
2017.01.23 18:02:08 1: PERL WARNING: Argument "" isn't numeric in subtraction (-) at ./FHEM/92_FileLog.pm line 704.
2017.01.23 18:02:08 1: stacktrace:
2017.01.23 18:02:08 1:     main::__ANON__                      called by ./FHEM/92_FileLog.pm (704)
2017.01.23 18:02:08 1:     main::FileLog_Get                   called by fhem.pl (3302)
2017.01.23 18:02:08 1:     main::CallFn                        called by fhem.pl (1714)
2017.01.23 18:02:08 1:     main::CommandGet                    called by fhem.pl (1107)
2017.01.23 18:02:08 1:     main::AnalyzeCommand                called by ./FHEM/01_FHEMWEB.pm (2372)
2017.01.23 18:02:08 1:     main::FW_fC                         called by ./FHEM/98_SVG.pm (1164)
2017.01.23 18:02:08 1:     main::SVG_getData                   called by ./FHEM/98_SVG.pm (1132)
2017.01.23 18:02:08 1:     main::SVG_doShowLog                 called by ./FHEM/98_SVG.pm (1020)
2017.01.23 18:02:08 1:     main::SVG_showLog                   called by ./FHEM/01_FHEMWEB.pm (852)
2017.01.23 18:02:08 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (524)
2017.01.23 18:02:08 1:     main::FW_Read                       called by fhem.pl (3302)
2017.01.23 18:02:08 1:     main::CallFn                        called by fhem.pl (674)
Raspberry Pi, CUL868(SlowRF), FB 7490, SmartVisu, fast nur HomeMatic wenig FS20, Netatmo
CoolTux
Das TuxNet Wiki:
https://www.cooltux.net
Badflex
#3
  • Du bist im falschen Forumbereich für das Kalendermodul.
  • Du kannst stacktrace wieder abschalten, denn die Perl Warnung ist ja schon eindeutig.
  • Das Problem ist im richtigen Forumbereich bereits beschrieben und wartet nur noch auf eine Lösung durch den Modulautor, ein Lösungsvorschlag steht auch schon dort.
  • Das ist keine Anfängerfrage.
  • Die Nutzung der Suchfunktion hier im Forum kann manchmal durchaus Sinn machen.
Badflex
