[gelöst]Logfile lauter Fehlermeldungen
Begonnen von T1mo, 10 März 2017, 10:50:45
T1mo
Hallo ,
vielleicht kann mir jemand helfen , mein ganzer Logfile ist voller Fehlermeldungen
2017.03.10 10:42:16 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 733) line 1.
2017.03.10 10:42:16 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 734) line 1.
2017.03.10 10:42:16 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 735) line 1.
2017.03.10 10:42:16 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 736) line 1.
2017.03.10 10:42:16 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 737) line 1.
2017.03.10 10:42:16 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 738) line 1.
2017.03.10 10:42:16 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 739) line 1.
2017.03.10 10:42:16 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 740) line 1.
2017.03.10 10:42:16 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 741) line 1.
2017.03.10 10:42:16 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 742) line 1.
2017.03.10 10:42:16 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 743) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 753) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 754) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 755) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 756) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 757) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 758) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 759) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 760) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 761) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 762) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 763) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 764) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 765) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 766) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 767) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 768) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 769) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 770) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 771) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 772) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 773) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 774) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 775) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 776) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 777) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 778) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 779) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 780) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 781) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 782) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 783) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 784) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 785) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 786) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 787) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 788) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 789) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 790) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 791) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 792) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 793) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 794) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 795) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 796) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 797) line 1.
2017.03.10 10:43:20 2: Undefined subroutine &main::wrapLine called at (eval 798) line 1.
War gerade dabei von Homematic einen Rolladenaktor anzulernen
Vieln Dank
T1mo
2017.03.10 11:01:14 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 1941) line 1.
2017.03.10 11:01:14 1: stacktrace:
2017.03.10 11:01:14 1:     main::__ANON__                      called by (eval 1941) (1)
2017.03.10 11:01:14 1:     (eval)                              called by ./FHEM/33_readingsGroup.pm (343)
2017.03.10 11:01:14 1:     main::lookup2                       called by ./FHEM/33_readingsGroup.pm (526)
2017.03.10 11:01:14 1:     main::readingsGroup_value2html      called by ./FHEM/33_readingsGroup.pm (1066)
2017.03.10 11:01:14 1:     main::readingsGroup_2html           called by ./FHEM/33_readingsGroup.pm (1165)
2017.03.10 11:01:14 1:     main::readingsGroup_detailFn        called by ./FHEM/01_FHEMWEB.pm (1823)
2017.03.10 11:01:14 1:     main::FW_showRoom                   called by ./FHEM/01_FHEMWEB.pm (1043)
2017.03.10 11:01:14 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (535)
2017.03.10 11:01:14 1:     main::FW_Read                       called by fhem.pl (3312)
2017.03.10 11:01:14 1:     main::CallFn                        called by fhem.pl (675)
2017.03.10 11:01:14 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 1942) line 1.
2017.03.10 11:01:14 1:     main::__ANON__                      called by (eval 1942) (1)
2017.03.10 11:01:14 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 1943) line 1.
2017.03.10 11:01:14 1:     main::__ANON__                      called by (eval 1943) (1)
2017.03.10 11:01:14 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 1944) line 1.
2017.03.10 11:01:14 1:     main::__ANON__                      called by (eval 1944) (1)
2017.03.10 11:01:14 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 1945) line 1.
2017.03.10 11:01:14 1:     main::__ANON__                      called by (eval 1945) (1)
2017.03.10 11:01:14 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 1946) line 1.
2017.03.10 11:01:14 1:     main::__ANON__                      called by (eval 1946) (1)
2017.03.10 11:01:14 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 1947) line 1.
2017.03.10 11:01:14 1:     main::__ANON__                      called by (eval 1947) (1)
2017.03.10 11:01:14 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 1948) line 1.
2017.03.10 11:01:14 1:     main::__ANON__                      called by (eval 1948) (1)
2017.03.10 11:01:14 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 1949) line 1.
2017.03.10 11:01:14 1:     main::__ANON__                      called by (eval 1949) (1)
2017.03.10 11:01:14 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 1950) line 1.
2017.03.10 11:01:14 1:     main::__ANON__                      called by (eval 1950) (1)
2017.03.10 11:01:14 1: PERL WARNING: Use of uninitialized value $wert in string eq at (eval 1951) line 1.
2017.03.10 11:01:14 1:     main::__ANON__                      called by (eval 1951) (1)
mit attr global stacktrace 1 kommt das raus
Thorsten Pferdekaemper
sieht nach readingsGroup aus. Kannst Du mal ein list von der/den readingsGroup(s) auf der Seite liefern?
   Thorsten
FUIP
T1mo
Danke für deine Hilfe!
den ersten Fehler hab ich beheben können , lag an der readingsGroup für Batterystatus.
kommt nur noch das
2017.03.10 11:49:09 2: Undefined subroutine &main::wrapLine called at (eval 1076) line 1.
2017.03.10 11:49:09 2: Undefined subroutine &main::wrapLine called at (eval 1077) line 1.
2017.03.10 11:49:09 2: Undefined subroutine &main::wrapLine called at (eval 1078) line 1.
2017.03.10 11:49:09 2: Undefined subroutine &main::wrapLine called at (eval 1079) line 1.
2017.03.10 11:49:09 2: Undefined subroutine &main::wrapLine called at (eval 1080) line 1.
2017.03.10 11:49:09 2: Undefined subroutine &main::wrapLine called at (eval 1081) line 1.
2017.03.10 11:49:09 2: Undefined subroutine &main::wrapLine called at (eval 1082) line 1.
2017.03.10 11:49:09 2: Undefined subroutine &main::wrapLine called at (eval 1083) line 1.
Gibt es ein Befehl wo man sich alle readingsGroups anzeigen lassen kann?
durch list TYPE=readingsGroup
kommt nur
TV_ProgrammPT_Next
TV_Programm_Next
Ich habe ja noch Wetter,Kalender und Spritpreismonitor.
Gruß Timo
T1mo
Ich hab jetzt doch noch was gefunden.
https://forum.fhem.de/index.php?topic=68269.0
Hier ist die Lösung des Problems
