[gelöst] Fehler nach fhem update: "missed to call readingsBeginUpdate first."
Begonnen von FhemPiUser, 16 Februar 2017, 19:32:04
FhemPiUser
Ich bekomme seit meinem fhem update folgende Fehlermeldung:
readingsUpdate(dwd,alert_headline,Amtliche WARNUNG vor FROST  ) missed to call readingsBeginUpdate first.
2017.02.16 07:08:30.788 1: stacktrace:
2017.02.16 07:08:30.789 1:     main::readingsBulkUpdate            called by fhem.pl (4134)
2017.02.16 07:08:30.789 1:     main::readingsEndUpdate             called by ./FHEM/55_GDS.pm (1029)
2017.02.16 07:08:30.789 1:     main::decodeCAPData                 called by ./FHEM/55_GDS.pm (541)
2017.02.16 07:08:30.789 1:     main::GDS_Get                       called by fhem.pl (3302)
2017.02.16 07:08:30.790 1:     main::CallFn                        called by fhem.pl (1714)
2017.02.16 07:08:30.790 1:     main::CommandGet                    called by fhem.pl (1107)
2017.02.16 07:08:30.790 1:     main::AnalyzeCommand                called by fhem.pl (976)
2017.02.16 07:08:30.790 1:     main::AnalyzeCommandChain           called by ./FHEM/91_notify.pm (102)
2017.02.16 07:08:30.791 1:     main::notify_Exec                   called by fhem.pl (3302)
2017.02.16 07:08:30.791 1:     main::CallFn                        called by fhem.pl (3223)
2017.02.16 07:08:30.791 1:     main::DoTrigger                     called by ./FHEM/55_GDS.pm (1246)
2017.02.16 07:08:30.791 1:     main::_finishedCAPDATA              called by (eval 79188) (1)
2017.02.16 07:08:30.792 1:     (eval)                              called by fhem.pl (1028)
2017.02.16 07:08:30.792 1:     main::AnalyzePerlCommand            called by fhem.pl (1048)
2017.02.16 07:08:30.793 1:     main::AnalyzeCommand                called by fhem.pl (976)
2017.02.16 07:08:30.793 1:     main::AnalyzeCommandChain           called by ./FHEM/98_telnet.pm (269)
2017.02.16 07:08:30.793 1:     main::telnet_Read                   called by fhem.pl (3302)
2017.02.16 07:08:30.794 1:     main::CallFn                        called by fhem.pl (674)
Auslöser scheint folgendes userReadings vom GDS device "dwd" zu sein, was ich aber schon ganz lange habe und vor dem Update ohne Fehlermeldung lief.
attr dwd userReadings alert_headline { ReadingsVal("dwd","a_0_headline","Keine Unwetterwarnung")." ".ReadingsVal("dwd","a_1_event","")." ".ReadingsVal("dwd","a_2_event","");;;; },alert_headline_exists { (ReadingsVal("dwd","a_0_headline","Keine Unwetterwarnung") eq "Keine Unwetterwarnung") ? 0 : 1;;;; }
Jemand eine Ahnung was die Ursache ist und wie ich das Problem beheben kann?
ZitatJemand eine Ahnung was die Ursache ist
Das Modul 55_GDS.pm benimmt sich in manchen Situation nicht vorbildlich.
Zitatund wie ich das Problem beheben kann?
Den Autor auf das Problem aufmerksam machen. Da das Modul aber aus contrib (== unsupported) stammt, kann sein, dass er mit den Schultern zuckt, das ist sein gutes Recht.
FhemPiUser
hmm, komisch. Eigentlich ist es ja nur ein userReadings attr vom GDS. Ich frage aber betateilchen nochmal.
Ich sehe auch gerade, dass es die Fehlermeldungen auch schon vor dem fhem update gabe, neu ist nur der stacktrace...
zap
Kann bestätigen, dass es am GDS Modul liegt.
Problem ist wohl die Verwendung von readingsSingleUpdate innerhalb eines readingsBeginUpdate/readingsEndUpdate Blocks in der GDS Funktion decodeCAPData
na na na... das hat sich aber letztes Jahr erheblich gebessert :)
Ja, und zwar am Besten im richtigen Forumbereich!
Eigentlich habe ich noch nie mit den Schultern gezuckt, wenn sowas auftrat.
Welche Modulversion habt Ihr im Einsatz?
zap
Ich habe die aktuelle Version aus dem contrib. Fehler ist in den Zeilen 1019 und 1026. Hier verwendest Du readingSingleUpdate statt readingBulkUpdate.
Habe es bei mir lokal korrigiert. Der Fehler tritt dann nicht mehr auf.
FhemPiUser
#6
danke, geht bei mir jetzt auch...
danke auch an betateilchen,rudolf und zap!
zap
cwagner
Raspbian 12, Perl 5.36.0, FHEM 6.4 auf PI5
320Devices in MariaDB: Steuerung Heizkessel & Speicher, FBH, Solarthermie, kontroll. Lüftung mit WRG
HMCUL, 1-Wire (FT232RL ; DS2480B), EnOcean (TCM ESP3), MQTT2, Shelly, SMA (eC2, PV, HM, HS)
DOIF (Perl/uiTable), PID20,Micropelt IRTV, SolarForecast,
