Multiple rooms
Begonnen von Guest, 21 Januar 2012, 17:53:55
Guest
Hello,
I'm using the attribute room to place devices in multiple rooms. With
pgm2 I notices that it matters in what order this attribute is filled.
For instance:
Attr fht1 room living, heating
Attr fht2 room heating
This will create two different rooms in the pgm2 web, both named
heating.
If I change this to:
Attr fht2 room bath, heating
Then I've got as expected only one room named 'heating'.
Is this a known problem or am I doing something wrong?
Thanks,
Alex
Oskar
Am 21.01.2012 um 17:53 schrieb Alex van Hoboken:
> Hello,
> For instance:
> heating.
No, one is named "heating", and the other one is named " heating".
No, you get one room named ' heating'.
For me, both.  just avoid blanks in the attributes, write
Attr fht1 room living,heating
Cheers
   Oskar
fhem geht auch auf mac os x
Guest
Hmm, that was easily solved, thanks. It works.
> > Hello,
> > For instance:
> > heating.
> Cheers
>         Oskar
