FHT8v and CUNO
Begonnen von Guest, 23 Dezember 2011, 21:03:41
Guest
update...
I decided that it was easier to buy an additional CUL than try to fix
the timing
I hope to receive my CC1101-USB-Lite 868MHz next week and get these
FHT8V properly working.
On 30 dec 2011, 14:15, Alex van Hoboken wrote:
> Ok thanks. I hope I can confirm your theory some day :)
> On 30 dec, 13:03, Rudolf Koenig wrote:
> > > Sounds easy but where can I find information how to do that?
> > In the culfw source and in some books like K&R. No more help from me in this
> > case.- Tekst uit oorspronkelijk bericht niet weergeven -
> - Tekst uit oorspronkelijk bericht weergeven -
tostmann
The issue has been fix and commited to svn.
See:
http://groups.google.com/group/cul-fans/browse_thread/thread/83b55bbfec7904a0
Guest
Thanks. I guess I have to compile the sources before this will have
any effect on my CUNO. I tried this offcourse but failed to get all
the neccesary packages installed on my ubuntu system. Can someone help
me out here and create a updated CUNO.hex for me?
Thanks,
Alex
> See:http://groups.google.com/group/cul-fans/browse_thread/thread/83b55bbf...
tostmann
Follow the link to the cul-fans group. There is a hex file of current firmware attached!
Am 21.01.2012 um 17:34 schrieb Alex van Hoboken:
> Thanks,
> Alex
Guest
Is that version (CUNO2) also compatible with the first generation
CUNO?
> > Thanks,
> > Alex
tostmann
Am 21.01.2012 um 17:46 schrieb Alex van Hoboken:
> CUNO?
Of course not, but CUNO V1 shouldn't have had this timing problem as it does not support Infrared at all ... ?!?!
The CUNO / CUNO2 hex files in svn contain the patch now - just try those.
Guest
I tried the new files from the svn and flashed my CUNO again but the
problem remains. Using a CUL I've got no problem controlling a FHT8v
directly but on a CUNO it seems that there is still a timing problem.
Messages are send approx every 118s instead of 117.
Does anyone has this working combination (CUNOv1/FHT8V) working?
Thanks,
Alex
> > CUNO?
tostmann
Am 23.01.2012 um 15:48 schrieb Alex van Hoboken:
CUNO v1 has no crystal osc.
You should try manually re-calibrating a CUNO oscillator following the steps:
* run CUNO in Bootloader mode by powering it up with button on its back pressed
* Connect to it with a 38400 baud terminal
* Press 'S' to see if something gets returned
* Then: Press 'C' (capital c) serveral times, or hold it for 5 seconds. This will return something like: "B9 00D0 B8"
* repeat the previous step until the number in the middle is: "?? 00D0 ??"
Than your CUNO osc runs at correct speed to allow proper serial communication with your host.
* Recycle power on CUNO - firmware won't be touched
