Bewegungsmelder HM-SEC-MDIR-2 aktualisiert brightness nicht
Begonnen von desmoloch, 10 April 2017, 21:16:51
desmoloch
Ich habe seit ein paar Tagen​ den Bewegungsmelder HM-SEC-MDIR-2. Dieser meldet ja auch die brightness. Allerdings habe ich immer nur einen Wert zwischen 32 und 33.
Anbei ein List vom Gerät:
   CHANGED
   DEF        516795
   HMLAN1_MSGCNT 1671
   HMLAN1_RAWMSG E516795,0000,17FDF3C3,FF,FFCC,9F84105167952573A20601210E
   HMLAN1_RSSI -52
   HMLAN1_TIME 2017-04-10 20:56:29
   IODev      HMLAN1
   LASTInputDev HMLAN1
   MSGCNT     1671
   NAME       FL_Bewegungsmelder
   NOTIFYDEV  global
   NR         145
   NTFY_ORDER 50-HM_516795
   STATE      noMotion
   TYPE       CUL_HM
   lastMsg    No:9F - t:10 s:516795 d:2573A2 0601210E
   protLastRcv 2017-04-10 20:56:29
   protResnd  1 last_at:2017-04-07 22:46:10
   protSnd    590 last_at:2017-04-10 19:40:36
   protState  CMDs_done
   rssi_at_HMLAN1 cnt:1671 lst:-52 max:-40 min:-71 avg:-52.65
   Readings:
     2017-04-07 23:00:25   Activity        alive
     2017-04-07 23:09:19   CommandAccepted yes
     2017-04-07 23:00:25   D-firmware      1.6
     2017-04-07 23:00:25   D-serialNr      NEQ1462236
     2017-04-07 23:09:20   PairedTo        0x2573A2
     2017-04-07 23:09:20   R-brightFilter  7
     2017-04-07 23:09:20   R-captInInterval off
     2017-04-04 21:19:34   R-evtFltrNum    1
     2017-04-04 21:19:34   R-evtFltrPeriod 1 s
     2017-04-07 23:09:20   R-minInterval   30
     2017-04-07 22:54:15   R-pairCentral   0x2573A2
     2017-04-07 22:50:49   R-sabotageMsg   on
     2017-04-04 21:19:34   R-sign          off
     2017-04-07 23:09:20   RegL_00.          02:01 0A:25 0B:73 0C:A2 10:01 00:00
     2017-04-07 23:09:20   RegL_01.          01:12 02:71 08:00 22:00 00:00
     2017-04-10 20:56:29   battery         ok
     2017-04-10 20:56:29   brightness      33
     2017-04-10 20:56:29   cover           open
     2017-04-10 19:41:08   motion          off
     2017-04-10 19:40:36   motionCount     163_next:30s
     2017-04-10 19:41:08   motionDuration  124
     2017-04-07 22:52:32   powerOn         2017-04-07 22:52:32
     2017-04-10 20:56:29   recentStateType info
     2017-04-10 19:41:08   state           noMotion
     2017-04-10 19:33:09   statw           0
     2017-04-10 19:40:36   trigDst_2573A2  noConfig
     2017-04-10 19:40:36   trigger_cnt     163
   Helper:
     HM_CMDNR   159
     PONtest    0
     cSnd       012573A251679501040000000001,012573A25167950103
     mId        00C0
     peerIDsRaw ,00000000
     rxType     28
     supp_Pair_Rep 0
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newCh      1
       newChn     +516795,00,00,00
       nextSend   1491850589.25641
       prefIO
       rxt        2
       vccu
       p:
         516795
         00
         00
         00
     Mrssi:
       mNo        9F
       Io:
         HMLAN1     -50
     Prt:
       bErr       0
       sProc      0
       sleeping   0
       try        1
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rssi:
       At_hmlan1:
         avg        -52.6576900059844
         cnt        1671
         lst        -52
         max        -40
         min        -71
     Shadowreg:
     Tmpl:
   IODev      HMLAN1
   actCycle   000:20
   actStatus  alive
   autoReadReg 4_reqStatus
   event-on-change-reading .*
   expert     2_defReg+raw
   firmware   1.6
   model      HM-SEC-MDIR-2
   peerIDs    00000000,
   room       Flur
   serialNr   NEQ1462236
   showtime   1
   subType    motionDetector
Ich habe den Bewegungsmelder auch bereits auf Werkseinstellung zurückgesetzt und ungepeert, aber das hat keine Veränderung gebracht. Die brightness ändert sich nicht, egal ob hell oder dunkel.
brightFilter habe ich bereits schon auf Werte zwischen 0 und 7 gesetzt. Es ändert sich nichts.
Hat noch jemand eine Idee? Gerät vielleicht defekt?
Desmo
Wetterhexe
ich habe zwei von den Teilen hier im Einsatz ... funktionieren prächtig. brightFilter steht bei mir auf 7 (default), und bei intensiver Einstrahlung erhalte ich Werte bis 250.
Entweder ist es bei dir seeeehr dunkel, oder das Ding ist defekt  ;D
darkness
Hallo.
Wie ist denn der Sensor verbaut? Evtl. zu sehr im schatten oder in einer "dunklen Ecke"?
desmoloch
Verdammt der ist also echt defekt :( danke! Hab einen neuen bestellt.
Zitat von: darkness am 11 April 2017, 06:51:38
Hallo.
Der Sensor steht im Flur auf einem Schrank. Selbst wenn ich  den Sensor in die Sonne stelle, bleibt der Wert bei 32.
