Wie visualisiert Ihr Eure Jalousien?
Begonnen von bmwfan, 24 April 2017, 22:12:07
Fixel2012
ich habe mir vor längerem eine ganze Seite mit circlemenus gebaut. Wenn ich diese aufklappe, kann ich den Rollladen auf vor definierte Positionen fahren. Zusätzlich kann ich in der Mitte den Stand des Rollladen anhand eines icons ablesen.
Vorteil: relativ Platz sparend.
Nachteil: nicht so performant, trotz des Updates von setstate (es gibt die Möglichkeit beim circlemenu die Animation zu veringern)
Hier der Code:
<div data-type="circlemenu" data-transition="none" class="cell circlemenu large noshade">
<ul class="menu">
<li><div data-type="symbol"
data-device="EG.Wohnzimmer_Links"
data-get="state"
data-states='["off","down","up","on","dim 9[7-9]","dim [0-9]","dim 1[0-9]","dim 2[0-9]","dim 3[0-9]","dim 4[0-9]","dim 5[0-9]","dim 6[0-9]","dim 7[0-9]","dim 8[0-9]","dim 9[0-7]","off","down","9[7-9]","[0-9]","10","20","30","35","40","50","60","70","80","90"]'
data-icons='["oa-fts_shutter_100","oa-fts_shutter_100","oa-fts_window_2w","oa-fts_window_2w","oa-fts_window_2w","oa-fts_shutter_90","oa-fts_shutter_90","oa-fts_shutter_80","oa-fts_shutter_70","oa-fts_shutter_60","oa-fts_shutter_50","oa-fts_shutter_40","oa-fts_shutter_30","oa-fts_shutter_20","oa-fts_shutter_10","oa-fts_shutter_100","oa-fts_shutter_100","oa-fts_window_2w","oa-fts_shutter_90","oa-fts_shutter_90","oa-fts_shutter_80","oa-fts_shutter_70","oa-fts_shutter_70","oa-fts_shutter_60","oa-fts_shutter_50","oa-fts_shutter_40","oa-fts_shutter_30","oa-fts_shutter_20","oa-fts_shutter_10"]'
data-colors='["yellow","yellow","green","green","green","pink","#505050","#505050","#505050","#505050","#505050","#505050","#505050","#505050","#505050","yellow","yellow","green","pink","#505050","#505050","#505050","#505050","#505050","#505050","#505050","#505050","#505050","#505050"]'
></div></li>
<li><div data-type="push"
data-set-on="dim 35"
data-icon="oa-fts_shutter_70"></div></li>
data-set-on="down"
data-icon="fa-angle-down"></div></li>
data-set-on="70"
data-icon="oa-fts_shutter_30"></div></li>
data-set-on="50"
data-icon="oa-fts_shutter_50"></div></li>
data-set-on="up"
data-icon="fa-angle-up"></div></li>
</ul>
<div data-type="label" class= "small">WZ Links</div>
</div>
Im Anhang sind noch zwei Bider  :)
Fixel
Fhem 5.8 auf Raspi 3, HMLAN und 868MHz CUL mit einigen Komponenten, Z-Wave Rollladenaktoren, Tablet UI, 433 MHz CUL mit Baumarktsteckdosen und Temp Sensoren, Amazon Echo, Echo Dot, 2x SONOS  play1, 1x SONOS Connect AMP,  presence, HUE, Lightify
eki
Zitat von: NewMatic am 20 Dezember 2017, 10:16:28
Hi eki,
danke nochmal für deine unermüdliche Hilfe!
ich kann bei mir weder bei range-bar noch bei range-quantity irgendwas von der fhem-tablet-ui-user.css erkennen (siehe screenshots).
Das heißt er kann die custom css laden (sehe ich ja unter networks) aber verwendet sie nicht in der index.html?
Der head stimmt so oder (head.jpg), oder fehlt da noch was?
Danke,
Tobi
Hat es inzwischen geklappt? Falls nicht könntest Du mir einfach mal Deine html Datei mit Header etc. posten, dann kann ich noch mal nachschauen (ist meist einfacher als die Bilder zu analysieren).
