Mysensors RGBW mit Color-Modul brauche Hilfe
Begonnen von hummeruli, 25 März 2018, 23:00:37
hummeruli
Hallo Leute,
habe leider ein Problem mit meiner Anbindung meines Mysensors RGBW Moduls. Es werden die einzelnen Kanäle per Percentage gesteuert, jedoch bin ich nicht in der Lage das mit einem Colorpicker anzusteuern.
Wobei Reading folgender Art aufgebaut sind:
3 = Rot
5 = Grün
6 = Blau
9 = Weiß
Hier das List des Devices:
   CFGFN      ./FHEM/Mysensors.cfg
   DEF        103
   IODev      Homenode_gw
   NAME       Wohnzimmerlampe
   NR         1183
   STATE      ???
   TYPE       MYSENSORS_DEVICE
   ack        1
   protocol   2.1.1
   radioId    103
   repeater   0
     2018-03-25 21:31:20   SKETCH_NAME     RGBW WoZi with OTA
     2018-03-25 21:31:20   SKETCH_VERSION  2.1
     2018-03-25 21:31:20   parentId        0
     2018-03-25 22:02:13   percentage9     31
   readingMappings:
     3:
       17:
         name       power3
       2:
         name       status3
       3:
         name       percentage3
     5:
       17:
         name       power5
       2:
         name       status5
       3:
         name       percentage5
     6:
       17:
         name       power6
       2:
         name       status6
       3:
         name       percentage6
     9:
       17:
         name       power9
       2:
         name       status9
       3:
         name       percentage9
   setcommands:
   sets:
     percentage3 slider,0,1,100
     percentage5 slider,0,1,100
     percentage6 slider,0,1,100
     percentage9 slider,0,1,100
     power3     1
     power5     1
     power6     1
     power9     1
     reboot
     status3    off,on
     status5    off,on
     status6    off,on
     status9    off,on
     time
   IODev      Homenode_gw
   alexaName  decken+lampe
   alexaRoom  wohnzimmer
   genericDeviceType light
   mapReading_percentage3 3 percentage
   mapReading_percentage5 5 percentage
   mapReading_percentage6 6 percentage
   mapReading_percentage9 9 percentage
   mapReading_power3 3 power
   mapReading_power5 5 power
   mapReading_power6 6 power
   mapReading_power9 9 power
   mapReading_status3 3 status
   mapReading_status5 5 status
   mapReading_status6 6 status
   mapReading_status9 9 status
   mode       node
   requestAck 1
   room       Alexa,Homenodes
   setReading_percentage3 slider,0,1,100
   setReading_percentage5 slider,0,1,100
   setReading_percentage6 slider,0,1,100
   setReading_percentage9 slider,0,1,100
   setReading_power3 1
   setReading_power5 1
   setReading_power6 1
   setReading_power9 1
   setReading_status3 off,on
   setReading_status5 off,on
   setReading_status6 off,on
   setReading_status9 off,on
   version    2.1.1
Danke schon mal für Eure Hilfe.
Uli
Beim Erstellen dieser Nachricht kamen weder Tiere zu Schaden, noch wurde Papier verschwendet. Alles von mir geschriebene ist biologisch abbaubar.
FHEM auf Debian Buster in einr Proxmox VM , LaCrosseGateway, AVR-NET-IO, Homematic, Alexa, S300TH, Signalduino..........
hummeruli
