Nach Update Abstände falsch
Begonnen von lenn1, 08 September 2017, 16:05:26
lenn1
Hallo, nach dem letzen Update sind die Abstände zwischen den Zeilen aber ganz schön groß geworden. Vorher passte das da rein.:
<li data-row="6" data-col="10" data-sizex="3" data-sizey="3"><header>M&uuml;ll</header> <br />
<div class="row">
<div data-type="label" data-device="muellTermineView" data-get="t_001_daysleftLong" data-colors='["green","red",""]' data-limits='["morgen","heute","(?![morgen]|[heute]).+"]'
class=" col big  thin"></div>
<div class="col big thin" data-type="label" data-device="muellTermineView" data-get="t_001_summary" data-substitution="toString().split('(')[0].split('tonne')[0]"></div>
</div> <br />
<div class="row">
<div data-type="label" data-colors='["green","red",""]' data-limits='["morgen","heute","(?![morgen]|[heute]).+"]' data-device="muellTermineView" data-get="t_002_daysleftLong"
class="col big thin"></div>
<div data-type="label" data-device="muellTermineView" data-get="t_002_summary" data-substitution="toString().split('(')[0].split('tonne')[0]" class="col big thin "></div>
</div> <br />
<div class="row">
<div data-type="label" data-colors='["green","red",""]' data-limits='["morgen","heute","(?![morgen]|[heute]).+"]' data-device="muellTermineView" data-get="t_003_daysleftLong"
<div data-type="label" data-device="muellTermineView" data-get="t_003_summary" data-substitution="toString().split('(')[0].split('tonne')[0]" class="col big thin  "></div>
</div> <br />
<div class="row">
<div data-type="label" data-device="muellTermineView" data-get="t_004_bdate" class="big thin col "></div>
<div data-type="label" data-device="muellTermineView" data-get="t_004_summary" data-substitution="toString().split('(')[0].split('tonne')[0]" class="col big thin   "></div>
</div> <br />
<div class="row">
<div data-type="label" data-device="muellTermineView" data-get="t_005_bdate" class="big thin col "></div>
<div data-type="label" data-device="muellTermineView" data-get="t_005_summary" data-substitution="toString().split('(')[0].split('tonne')[0]" class="col big thin  "></div>
</div></li>
setstate
Die <br/> sind falsch
Die row werden jetzt in den vorhandenen Platz aufgeteilt. Damit sind solche künstlichen "Spacer" nicht mehr nötig.
lenn1
Danke!, Hab jetzt auch das ultra coole flexible Design gesehen. Dann hab ich ja wieder was zu tun am Wochenende!
