Fehlermeldung seit ein paar Tagen
Begonnen von Luigi, 14 September 2017, 20:08:10
Luigi
ich bekomm seit einem Update vor 2 Tagen folgenden Fehler:
Uncaught TypeError: Cannot read property 'longpoll' of undefined
    at eval (eval at <anonymous> (fhem-tablet-ui.js:1238), <anonymous>:1:25)
    at HTMLDivElement.<anonymous> (fhem-tablet-ui.js:1238)
    at Function.each (jquery.min.js:2)
    at r.fn.init.each (jquery.min.js:2)
    at Object.updateBindElements (fhem-tablet-ui.js:1234)
    at Object.update (fhem-tablet-ui.js:289)
    at checkReading (fhem-tablet-ui.js:846)
    at Object.<anonymous> (fhem-tablet-ui.js:863)
    at i (jquery.min.js:2)
    at Object.fireWith [as resolveWith] (jquery.min.js:2)
widget_pagebutton.js:30 fetch content: 11.9951171875ms
widget_link.js:166 init link
fhem-tablet-ui.js:695 initPage: 219.77392578125ms
fhem-tablet-ui.js:802 get jsonlist2: 145.674072265625ms
index_tablet.html#page1.html:1 Uncaught TypeError: Cannot read property 'longpoll' of undefined
widget_pagebutton.js:30 fetch content: 5.387939453125ms
fhem-tablet-ui.js:695 initPage: 316.489013671875ms
fhem-tablet-ui.js:802 get jsonlist2: 108.32177734375ms
widget_pagebutton.js:30 fetch content: 5.52490234375ms
fhem-tablet-ui.js:695 initPage: 45.368896484375ms
fhem-tablet-ui.js:802 get jsonlist2: 111.01806640625ms
    at Object.<anonymous> (fhem-tablet-ui.js:861)
List des Webdevice:
   CONNECTS   1031
   DEF        8083 global
   FD         7
   NAME       WEB
   NR         86
   NTFY_ORDER 50-WEB
   PORT       8083
   STATE      Initialized
   TYPE       FHEMWEB
   CORS       1
   JavaScripts codemirror/fhem_codemirror.js
   SVGcache   1
   codemirrorParam { "theme":"blackboard", "lineNumbers":true }
   csrfToken  none
   fwcompress 0
   hiddenroom DashboardRoom
   iconPath   openautomation:default:dark
   longpoll   websocket
   longpollSVG 0
   menuEntries Update TUI,/fhem?cmd=update%20all%20https://raw.githubusercontent.com/knowthelist/fhem-tablet-ui/master/controls_fhemtabletui.txt,Update SB,/fhem?cmd=update%20all%20https://raw.githubusercontent.com/ChrisD70/FHEM-Modules/master/autoupdate/sb/controls_squeezebox.txt
   plotfork   1
index_tablet.html:
    <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no" />
    <meta name="widget_base_width" content="50">
    <meta name="widget_base_height" content="25">
    <meta name="mobile-web-app-capable" content="yes">
    <meta name="apple-mobile-web-app-capable" content="yes">
    <meta name="gridster_disable" content="1">
    <meta name="longpoll_type" content="websocket">
    <!-- 1=longpoll;0=shortpoll every 30sec -->
    <meta name="debug" content="0">
    <!-- verbose level 1-6 = output to console;0 = not output -->
    <meta http-equiv="Cache-Control" content="no-store">
    <meta name="fhemweb_url" content="http://192.168.0.163:8083/fhem">
    <meta name="longpoll_maxage" content="240">
Vor dem Update hat es so funktioniert.
Wer kann helfen?
Luigi
