icon fhemweb not toggle
Begonnen von Guest, 08 Mai 2012, 21:36:33
Guest
I'm using an fs20rsu for my shutters, and just update fhem yesterday.
I use now floorplan, but I noticed that the shutter only did 1 action,
that is on. So the icon, doesn't work as toggle anymore. I noticed
that in default fhemweb it also not change and always set to on, with
the icon?
any ideas?
regards Richard
Guest
It only appears when you have eventmap definied, for example
attr Garage eventMap on:Down off:Up
On May 8, 9:36 pm, kroonen wrote:
> Hi,
> the icon?
> any ideas?
> regards Richard
Guest
Hi, ich habe das Problem mmit den Dummys auch - sowohl im Everything, als
auch im Floorplan.
#FLOORPLANDUMMYS
define AQDM dummy
attr AQDM eventMap on:on off:off
attr AQDM fp_Erdgeschoss 285,495,0,
attr AQDM room hidden
define AQDMOn notify AQDM.on {fhem ("set AQ K1on")}
attr AQDMOn room hidden
define AQDMOff notify AQDM.off {fhem ("set AQ K1off")}
attr AQDMOff room hidden
Es tritt mit definierter und ohne definierte Eventmap auf.
Gruß Andreas
I changed to work also if eventMap is set, although i think it did not worked
before, so it is not a fix.
I've tested it with/without eventMap, with/without webCmd, with/without
longpoll  on normal and smallScreen, and I do not see any problems, although it
was sometimes dead with longpoll, before the browser reloaded everything again.
If it still does not work, then I need a small fhem.cfg with _exact_
instructions on how to reproduce the problem.
Guest
Hi Rudi,
bei mir besteht das Problem auch weiterhin :-(.
Hier mal meine fhem.cfg etwas abgekürzt mit Gerätebespielen, die toggle
nicht durchführen bei Klick auf das Symbol
attr global holiday2we Bremen
attr global logfile ./log/fhem-%Y-%m.log
attr global modpath .
attr global port 7072 global
attr global room System
attr global statefile ./log/fhem.save
attr global title Zu Hause
attr global userattr Wohnzimmer building fm_fav fm_groups fm_name fm_order
fp_Erdgeschoss icon structexclude webCmd
attr global verbose 3
## Globale Attribute und Einstellungen von FHEM             ##
define Logfile FileLog ./log/fhem-%Y-%m.log fakelog
attr Logfile room System
attr WEB room System
attr WEB stylesheetPrefix dark
define WEBphone FHEMWEB 8084 global
attr WEBphone room System
attr WEBphone smallscreen 1
attr WEBtablet room System
attr WEBtablet touchpad 1
define autocreate autocreate
attr autocreate autosave 1
attr autocreate device_room NEUES_GERÄT
attr autocreate filelog ./log/%NAME-%Y.log
attr autocreate room System
attr autocreate weblink 1
attr autocreate weblink_room NEUES_GERÄT
define initialUsbCheck notify global:INITIALIZED usb create
attr initialUsbCheck room System
## Section für den Floorplan und eingebundene weblinks      ##
define Erdgeschoss FLOORPLAN
attr Erdgeschoss fp_arrange 0
attr Erdgeschoss fp_default 1
attr Erdgeschoss fp_noMenu 1
attr Erdgeschoss fp_stylesheetPrefix darkbenji
attr Erdgeschoss room System
## Einbindung des CUL an der Fritzbox                       ##
define Zentrale CUL /dev/ttyACM0@9600 430A
attr Zentrale room System
## Das Wohnzimmer                                           ##
define Fernseher FS20 12344321 10
attr Fernseher eventMap on:Ein off:Aus
attr Fernseher fm_fav 1
attr Fernseher fm_order 1
attr Fernseher fp_Erdgeschoss 680,265,1,
attr Fernseher group Steckdosen
attr Fernseher model fs20st
attr Fernseher room Wohnzimmer
define Esstisch IT 000000000F 01 10
attr Esstisch IODev Zentrale
attr Esstisch eventMap on:Ein off:Aus
attr Esstisch fm_order 1
attr Esstisch fp_Erdgeschoss 675,395,1,Lampe Esstisch
attr Esstisch group Steckdosen
attr Esstisch model itswitch
attr Esstisch room Wohnzimmer
define Wohnzimmer structure room Fernseher Esstisch Couch
attr Wohnzimmer room Wohnzimmer
## Section für Bedingungen, notifies und ähnliches          ##
define FB_Temperature_sensor dummy
attr FB_Temperature_sensor comment Fritzbox device sensor
attr FB_Temperature_sensor room System
define w_WertListe1 weblink htmlCode {doWertListe1()}
attr w_WertListe1 fp_Erdgeschoss 470,550,0,
attr w_WertListe1 room System
define CUL_HOERMANN_41C0FB1D80 CUL_HOERMANN 41C0FB1D80
attr CUL_HOERMANN_41C0FB1D80 ignore 1
attr CUL_HOERMANN_41C0FB1D80 room System
define FileLog_CUL_HOERMANN_41C0FB1D80 FileLog
./log/CUL_HOERMANN_41C0FB1D80-%Y.log CUL_HOERMANN_41C0FB1D80
attr FileLog_CUL_HOERMANN_41C0FB1D80 logtype text
attr FileLog_CUL_HOERMANN_41C0FB1D80 room System
define fht_setdate notify fht_setdate { \
  if ( $year gt 2010 ) {\
    my @@fhts=devspec2array("TYPE=FHT");; \
    foreach(@@fhts) { \
      my $cmd="set ".$_." date time";;\
      fhem $cmd;;\
      Log 4, "sent cmd ".$cmd;;\
  } else {\
      Log 1, "error setting date for fhts: year <= 2010 - date invalid?!"\
define t_fht_setdate at *02:00:00 trigger fht_setdate
attr t_fht_setdate group Zeitsteuerung
attr t_fht_setdate room System
define wakeup at *05:00:00 {\
   if (!$we) {\
     {fhem("set Esstisch on") }\
attr wakeup fp_Erdgeschoss 735,405,0,Auto-An:
attr wakeup group Zeitsteuerung
attr wakeup room Wohnzimmer
define d_FB_Temperature at +*00:20:00 "(/bin/echo -n "`date
'+%Y-%m-%d_%H:%M:%S FB_Temperature measured-temp:'`
">>./log/Fritzbox7270.log & /usr/bin/ctlmgr_ctl r power
status/act_temperature >> ./log/Fritzbox7270.log )"
attr d_FB_Temperature group Zeitsteuerung
attr d_FB_Temperature room System
Guest
STORNO :-)
Obwohl ich 25x updatefhem gemacht habe, habe ich das ganze nun noch mal
manuell aus dem SVN eingespielt und nun geht es. Sorry für den Post.
Benjamin
Guest
Rudi,
It is working again, also with the evenmap. Thnx
regards Richard
Guest
> Hi,
bei mir besteht das Problem immernoch.
Das Konstrukt in der fhem .cfg sieht so aus:
define schalter dummy
attr schalter eventMap on:on off:off
attr schalter fp_EG 30,500,2,
attr schalter room hidden
Damit ist der Schalter in der fhemweb.pm bis vom 9.4 klickbar. In den
aktuellen Versionen nicht mehr.
Verursacht wird dies durch erstzen von:
  if(!$webCmd) {
    $hasOnOff = ($allSets =~ m/\bon\b/ && $allSets =~ m/\boff\b/);
    my $em = AttrVal($d, "eventMap", "");
    if($em) {
      if(!$hasOnOff) {
        $em .= " ";
        $hasOnOff = ($em =~ m/:on\b/ && $em =~ m/:off\b/);
      } else {
        (undef, $state) = ReplaceEventMap($d,[$d, $state],0);
durch:
$hasOnOff = (!$webCmd && $allSets =~ m/\bon\b/ && $allSets =~ m/\boff\b/);
im aktuellen Update.
Dadurch findet keine Abfrage statt ob Eventmap definiert ist und der Dummy
bleibt ohne Funktion.
Sobald man webcmd on:off definiert erscheinen zwar beide Links, man kann
aber mit dem Icon nur einschalten.
Dies ist in allen 3 Varianten 8083/4/5 so und besonders störend im
Floorplan.
Gibt es hierfür eine Lösung oder die Möglichkeit im regulären Update die
Prüfung auf Eventmap wieder einzubauen?
Gruß Andreas
Ich empfehle "attr schalter setList on off"
eventMap sollte zum Uebersetzen, nicht zum Auflisten der Befehle dienen.
Guest
Hallo und danke
war genau das was ich suchte. Ich hatte leider nur die Variante mit setList
state:on,off gefunden.
Gruß Andreas
