JSONMETER mit Youless - Fehler im LOG
Begonnen von Heimweh, 25 November 2016, 11:21:09
Heimweh
Hallo, ich habe festgestellt dass beim einlesen meines LS110 von Youless bei jeder Abfrage ein Fehler im LOG entsteht.
habe mal zur Analyse das Verbose auf 5 gesetzt:
Auszug aus dem Logfile:
2016.11.25 11:08:34 1: JSONMETER EnergieEG: ReadFromUrl.461 Could not open connection to ip 192.168.178.242 port 80
2016.11.25 11:09:34 1: JSONMETER EnergieEG: ReadFromUrl.461 Could not open connection to ip 192.168.178.242 port 80
2016.11.25 11:10:35 1: Timeout for JSONMETER_GetJsonFile reached, terminated process 30431
2016.11.25 11:10:35 1: JSONMETER EnergieEG: UpdateAborted.664 Timeout when connecting to host 192.168.178.242
2016.11.25 11:11:34 1: JSONMETER EnergieEG: ReadFromUrl.461 Could not open connection to ip 192.168.178.242 port 80
2016.11.25 11:12:34 1: JSONMETER EnergieEG: ReadFromUrl.461 Could not open connection to ip 192.168.178.242 port 80
2016.11.25 11:13:25 4: JSONMETER EnergieEG: ReadFromUrl.451 opening socket to host 192.168.178.242 port 80
2016.11.25 11:13:32 4: JSONMETER EnergieEG: ReadFromUrl.468 Get json file from http://192.168.178.242:80/a?f=j
2016.11.25 11:13:35 1: Timeout for JSONMETER_GetJsonFile reached, terminated process 30454
2016.11.25 11:13:35 1: JSONMETER EnergieEG: UpdateAborted.664 Timeout when connecting to host 192.168.178.242
2016.11.25 11:14:25 4: JSONMETER EnergieEG: ReadFromUrl.451 opening socket to host 192.168.178.242 port 80
2016.11.25 11:14:34 1: JSONMETER EnergieEG: ReadFromUrl.461 Could not open connection to ip 192.168.178.242 port 80
2016.11.25 11:15:25 4: JSONMETER EnergieEG: ReadFromUrl.451 opening socket to host 192.168.178.242 port 80
2016.11.25 11:15:34 1: JSONMETER EnergieEG: ReadFromUrl.461 Could not open connection to ip 192.168.178.242 port 80
2016.11.25 11:16:25 4: JSONMETER EnergieEG: ReadFromUrl.451 opening socket to host 192.168.178.242 port 80
Definition:
define EnergieEG JSONMETER LS110 192.168.178.242 60
attr EnergieEG alias Energieverbrauch EG
attr EnergieEG event-min-interval statElectricityConsumed_kWhDay:3600,statElectricityConsumed_kWhDayLast:3600,statElectricityConsumed_kWhHourLast:3600
attr EnergieEG group Energiezaehler_Verbraucher
attr EnergieEG icon measure_power
attr EnergieEG room Stromzähler
attr EnergieEG stateFormat {sprintf("Zählerstand: %.1f kWh , Aktuell: %s Watt",(ReadingsVal($name,"electricityConsumed_kWh",0)), ReadingsVal($name,"electricityPower",0))}
attr EnergieEG userReadings electricityConsumed_kWh:electricityConsumed.* {ReadingsVal("EnergieEG","electricityConsumed",0)*0.001}
das list von EnergieEG:
   DEF        LS110 192.168.178.242 60
   HOST       192.168.178.242
   INTERVAL   60
   NAME       EnergieEG
   NOTIFYDEV  global
   NR         509
   PORT       80
   STATE      Zählerstand: 66486.1 kWh , Aktuell: 431 Watt
   TYPE       JSONMETER
   deviceType LS110
   urlPath    a?f=j
   Readings:
     2016-11-25 06:58:08   electricityConsumed 66486106
     2016-11-25 06:58:08   electricityConsumed_kWh 66486.106
     2016-11-25 06:58:08   electricityPower 431
     2016-11-25 11:16:57   statElectricityConsumed_kWh Hour: 0.000 Day: 2.106 Month: 377.560 Year: 656.226 (since: 2016-10-10 )
     2016-11-25 11:16:57   statElectricityConsumed_kWhDay 2.106
     2016-11-24 23:59:55   statElectricityConsumed_kWhDayLast 11.667
     2016-11-25 11:16:57   statElectricityConsumed_kWhHour 0.000
     2016-11-25 10:59:55   statElectricityConsumed_kWhHourLast 0.000
     2016-11-25 10:59:55   statElectricityConsumed_kWhLast Hour: 0.000 Day: 11.667 Month: 278.666 Year: - (since: 2016-10-10 )
     2016-11-25 11:16:57   statElectricityConsumed_kWhMonth 377.560
     2016-10-31 23:59:56   statElectricityConsumed_kWhMonthLast 278.666
     2016-11-25 11:16:57   statElectricityConsumed_kWhYear 656.226
     2016-11-25 11:16:57   state           Can't connect to ip 192.168.178.242 port 80
   Fhem:
     jsonInterpreter
     modulVersion $Date: 2016-09-29 20:35:21 +0200 (Thu, 29 Sep 2016) $
   Helper:
     _98_statistics EnergieEGstatkWh
     Running_pid:
       abortFn    JSONMETER_UpdateAborted
       arg        EnergieEG
       bc_pid     1131
       finishFn   JSONMETER_ParseJsonFile
       fn         JSONMETER_GetJsonFile
       pid        30515
       timeout    10
       Abortarg:
   icon       measure_power
   room       Stromzähler
Hat jemand ähnliche Erfahrungen bzw. eine Lösung?[/code]
RaspberryPi, 8 x Intertechnosteckdosen, ETA PU15 über HTTPMOD, Youless Eneergiemonitor, 8 x Technoline Funk Temperatur / Feuchtesensoren über jeeLink, Fritzbox Anbindung, Homematic Rolladen Aktoren, MAX Heizkörperventile + Cube, SONOFF S20, S26, POW, 4ch, OWD, Alexa-fhem, enOcean / Eltako,
Burny4600
@Heimweh
Wie hast du den Fehler beseitigt?
Ich habe diesen Fehler bei mir ebenfalls festgestellt.
2017.11.05 19:48:54.918 1: Timeout for JSONMETER_GetJsonFile reached, terminated process 5086
2017.11.05 19:48:54.919 1: JSONMETER EnergieAB: UpdateAborted.664 Timeout when connecting to host 192.168.17.243
2017.11.05 19:48:54.971 1: Timeout for JSONMETER_GetJsonFile reached, terminated process 5087
2017.11.05 19:48:54.973 1: JSONMETER EnergieEG: UpdateAborted.664 Timeout when connecting to host 192.168.17.240
2017.11.05 19:48:54.994 1: Timeout for JSONMETER_GetJsonFile reached, terminated process 5088
2017.11.05 19:48:54.996 1: JSONMETER EnergieOG1: UpdateAborted.664 Timeout when connecting to host 192.168.17.241
2017.11.05 19:48:55.015 1: Timeout for JSONMETER_GetJsonFile reached, terminated process 5089
2017.11.05 19:48:55.016 1: JSONMETER EnergieOG2: UpdateAborted.664 Timeout when connecting to host 192.168.17.242
2017.11.05 19:48:55.036 1: Timeout for JSONMETER_GetJsonFile reached, terminated process 5090
2017.11.05 19:48:55.037 1: JSONMETER EnergiePV: UpdateAborted.664 Timeout when connecting to host 192.168.17.244
2017.11.05 19:48:55.458 1: Timeout for SYSMON_blockingCall reached, terminated process 5085
LIST
   CFGFN      /media/hdd/fhem/mycfg/YouLess/Stromzaehler_rasp01.cfg
   CHANGED
   DEF        LS110 192.168.17.243 60
   HOST       192.168.17.243
   INTERVAL   60
   NAME       EnergieAB
   NOTIFYDEV  global
   NR         2932
   PORT       80
   STATE      Aktuell: 90 Watt
   TYPE       JSONMETER
   deviceType LS110
   urlPath    a?f=j
     2017-11-06 12:35:24   electricityConsumed 1886819
     2017-11-06 12:35:24   electricityPower 90
     2017-11-06 12:35:24   state           Connected
   fhem:
     jsonInterpreter 1 3 electricityConsumed 3 1 cnt|1 3 electricityPower 1 0 pwr
   helper:
   alias      Energieverbrauch AB
   event-on-change-reading electricityPower
   icon       measure_power
   room       AB-Fitnessraum,AB-Pool,AB-Sauna,_Statistiken
   stateFormat {sprintf("Aktuell: %s Watt",ReadingsVal("$name","electricityPower",0))}
   userReadings electricityPower
   verbose    1
LG Chris
Devices: APC, Eastron, FS20, IT, Homematic, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, S.USV, TEK603, WMR200, YouLess
herrmannj
so wie ich das interpretiere kann fhem Deine device (zb 192.168.17.243) nicht erreichen. Das wird wohl was mit Deinem Netzwerk zu tun haben.
Burny4600
Am Netzwerk kann es nicht liegen.
Zum Einem scheinen am Netzwerkswitch für die verwendeten Ports keine Fehlermeldungen auf, und zum Anderen kann ich die LS110 Geräte direkt ohne Probleme erreichen.
Auch am Netzwerkport des betreffenden Raspberry gibt es am Switch keine Fehlermeldungen.
Was auffällt ist das dieser Raspberry sehr träge via Web erreichbar ist. Darum bin ich unter anderem bei der Fehlersuche im LOG auf diese Meldungen gestoßen.
Es gibt zudem auch mit den SSL/HTTPS Verbindungen sehr viel Fehlermeldungen.
2017.11.05 19:50:20.841 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.186)
2017.11.05 19:52:08.871 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.182)
2017.11.05 19:52:37.741 1: 192.168.17.186:40868 disconnected, waiting to reappear (nanoCUL868_AB_FR)
2017.11.05 19:52:37.991 1: Perfmon: possible freeze starting at 19:51:23, delay is 74.991
2017.11.05 19:52:42.667 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.184)
2017.11.05 19:53:55.078 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.185)
2017.11.05 19:55:07.817 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.186)
2017.11.05 19:55:57.693 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.184)
2017.11.05 19:56:57.606 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.182)
2017.11.05 19:57:37.988 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.131)
2017.11.05 19:57:58.897 1: Perfmon: possible freeze starting at 19:57:28, delay is 30.896
2017.11.05 19:58:07.321 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.185)
2017.11.05 19:58:54.481 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.186)
2017.11.05 19:59:23.251 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.184)
2017.11.05 19:59:41.219 1: Perfmon: possible freeze starting at 19:59:07, delay is 34.219
2017.11.05 19:59:42.907 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.131)
2017.11.05 19:59:56.048 1: Perfmon: possible freeze starting at 19:59:42, delay is 14.048
2017.11.05 20:00:11.016 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.182)
2017.11.05 20:00:18.867 1: Perfmon: possible freeze starting at 19:59:57, delay is 21.867
2017.11.05 20:00:41.404 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.186)
2017.11.05 20:00:49.983 1: Perfmon: possible freeze starting at 20:00:19, delay is 30.982
2017.11.05 20:01:04.675 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.185)
2017.11.05 20:01:04.778 1: Perfmon: possible freeze starting at 20:00:50, delay is 14.778
2017.11.05 20:01:09.744 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.186)
2017.11.05 20:01:37.923 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.186)
2017.11.05 20:01:51.590 1: Perfmon: possible freeze starting at 20:01:26, delay is 25.59
2017.11.05 20:01:57.639 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.131)
2017.11.05 20:02:10.738 1: Perfmon: possible freeze starting at 20:01:52, delay is 18.738
2017.11.05 20:02:11.956 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.186)
2017.11.05 20:02:12.129 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.186)
2017.11.05 20:02:12.195 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.182)
2017.11.05 20:02:12.269 1: telnet SSL/HTTPS error:  SSL connect accept failed because of handshake problems (peer: 192.168.17.186)
All dies kann nur im betreffenden Raspberry direkt mit FHEM was zu tun haben.
LG Chris
herrmannj
träge ist gut :) Hier:
war Dein fhem für sage und schreibe 75 Sekunden komplett im Stillstand. Keine Chance auf irgendwas zu reagieren.
Schau Dir mal apptime und taste Dich damit ran.
Burny4600
Das apptime Ergebnis lautet:
name                                     function                               max  count    total  average maxDly TS Max call     param Max call
nanoCUL868_OG2                           CUL_Read                             28862    493  3026198  6138.33      0 07.11. 01:12:08 HASH(nanoCUL868_OG2)
nanoCUL868_WebCam                        CUL_Read                             28842    464  3040494  6552.79      0 07.11. 01:04:05 HASH(nanoCUL868_WebCam)
nanoCUL868_EG                            CUL_Read                             28799    474  3008444  6346.93      0 07.11. 01:05:45 HASH(nanoCUL868_EG)
nanoCUL868_OG1                           CUL_Read                             24067    459  2977775  6487.53      0 07.11. 01:38:32 HASH(nanoCUL868_OG1)
sduino                                   SIGNALduino_Read                     20489   6961  4905542   704.72      0 07.11. 01:02:17 HASH(sduino)
nanoCUL433_OG1                           CUL_Read                              9953   7741   528907    68.33      0 07.11. 01:02:43 HASH(nanoCUL433_OG1)
nanoCUL433_AB_GAW                        CUL_Read                              9922   4813   405419    84.23      0 07.11. 01:00:35 HASH(nanoCUL433_AB_GAW)
autocreate                               autocreate_Notify                     7881   6542  3054431   466.90      0 06.11. 23:18:28 HASH(autocreate); HASH(global)
nanoCUL433_AB_FR                         CUL_Read                              7436   5877   614723   104.60      0 07.11. 13:56:07 HASH(nanoCUL433_AB_FR)
nanoCUL433_OG2                           CUL_Read                              6784   3006   729167   242.57      0 06.11. 21:50:08 HASH(nanoCUL433_OG2)
nanoCUL433_EG                            CUL_Read                              5530   2629   290012   110.31      0 07.11. 13:28:13 HASH(nanoCUL433_EG)
WEB                                      FW_Read                               3422     23     4746   206.35      0 07.11. 15:47:11 HASH(WEB)
tmr-DOIF_SleepTrigger                    HASH(0x3aaa020)                       3412      1     3412  3412.00   4082 07.11. 06:58:16 HASH(Daylight_EG_ST)
tmr-DOIF_SleepTrigger                    HASH(0x3aaaae8)                       3007      1     3007  3007.00   7455 07.11. 06:58:19 HASH(Daylight_OG1_ST)
Daylight_EG_D                            dummy_Set                             2952      1     2952  2952.00      0 07.11. 06:58:16 HASH(Daylight_EG_D); Daylight_EG_D; on
Daylight_OG1_D                           dummy_Set                             2844      1     2844  2844.00      0 07.11. 06:58:19 HASH(Daylight_OG1_D); Daylight_OG1_D; on
tmr-GPIO4_DeviceUpdateLoop               HASH(0x25af588)                       2323   1074  1075162  1001.08  66060 07.11. 08:14:06 HASH(OG1_EDV_R_EDVVT)
tmr-GPIO4_DeviceUpdateLoop               HASH(0x25ada00)                       1900   1074  1070319   996.57  65962 07.11. 04:22:05 HASH(OG1_EDV_R_RT)
F2F_Rasp08                               FHEM2FHEM_Read                        1512     10    13484  1348.40      0 07.11. 09:09:57 HASH(F2F_Rasp08)
F2F_Rasp04                               FHEM2FHEM_Read                        1357    413   291924   706.84      0 06.11. 23:25:44 HASH(F2F_Rasp04)
tmr-HMUARTLGW_CheckCmdResp               HASH(0x216ab38)                       1248    604    37557    62.18  81374 07.11. 14:40:12 HASH(HmUART_OG1)
Nur wie hilft mir dieses Ergebnis weiter?
LG Chris
herrmannj
die Probleme müssen nicht zwangsweise miteinander zu tun haben. Aber irgendwo solltest Du halt anfangen.
Die beiden hier würde ich mir zuerst vornehmen und hoffen das sich damit auch der HM Uart löst
kannst Du die zuordnen (modul, device) ? Irgendwas mit GPIO ... (raspi vmtl...)
Burny4600
Das sind zwei 1Wire Raumfühler die aber keinen Fehler haben und Temperaturwerte sauber liefern.
LG Chris
