[GELÖST] readingsGroup Status Fenster gesucht für HM-TC-IT-WM-W-EU / HM-CC-RT-DN
Begonnen von Burny4600, 26 November 2017, 18:47:07
Burny4600
Bin auf der Suche nach dem Reading das die Geräte HM-TC-IT-WM-W-EU und HM-CC-RT-DN den Status Fenster geöffnet ausgeben.
Ergänzung 2017.11.27
Wie kann ich für den Fenstersensor HM-SEC-SCo den Status in der readingsGroup darstellen.
define Heizung readingsGroup <%sani_heating>,<Sollwert>,<Sollwert neu>,<Istwert>,<Ventil | Feuchte>,<Modus>,<Lock>,<Batteriestatus>,<Fensterstatus>\
EG_WZ_HZG_TC_Climate:desired-temp,<sollsetz>,measured-temp,humidity,controlMode,R-btnLock@EG_WZ_HZG_TC,batteryLevel@EG_WZ_HZG_TC,Fenster:state
attr Heizung valueIcon {'controlMode.manual' => 'sani_heating_manual@795CFF',\
'controlMode.auto' => 'sani_heating_automatic@FFC13A',\
'controlMode.boost' => 'sani_heating_boost@FB0C02',\
'humidity' => 'humidity@6FD9FB',\
'R-btnLock.on' => 'secur_locked@F7301D',\
'R-btnLock.off' => 'secur_open@0CFB0C',\
'ValvePosition.0' => 'sani_heating_level_0@002AE0', \
'ValvePosition.10' => 'sani_heating_level_10@F8D53D',\
'ValvePosition.20' => 'sani_heating_level_20@FF9341',\
'ValvePosition.30' => 'sani_heating_level_30@F17F3F',\
'ValvePosition.40' => 'sani_heating_level_40@E46C3C',\
'ValvePosition.50' => 'sani_heating_level_50@DE3B3A',\
'ValvePosition.60' => 'sani_heating_level_60@A30D2D',\
'ValvePosition.70' => 'sani_heating_level_70@B40A23',\
'ValvePosition.80' => 'sani_heating_level_80@C40619',\
'ValvePosition.90' => 'sani_heating_level_90@D4030F',\
'ValvePosition.100' => 'sani_heating_level_100@E50005',\
'batteryLevel.100' => 'measure_battery_100@0CFB0C',\
'batteryLevel.75' => 'measure_battery_75@42BC0A',\
'batteryLevel.50' => 'measure_battery_50@F5FF10',\
'batteryLevel.25' => 'measure_battery_25@FB5909',\
'batteryLevel.0' => 'measure_battery_0@E50005',\
'controlMode.set_boost' => 'hourglass',\
'controlMode.set_auto' => 'hourglass',\
'controlMode.set_manual' => 'hourglass',\
'R-btnLock.set_on' => 'hourglass',\
'R-btnLock.set_off' => 'hourglass',\
'winOpenReporting.off' => 'fts_window_1w_tilt@red',\
'winOpenReporting.on' => 'fts_window_1w@lightgreen',\
'state.closed' => 'fts_window_1w_tilt@red',\
'state.open' => 'fts_window_1w@lightgreen'}
Ich habe es mit winOpenReporting des Reglers und den state des Fenstersensor probiert, aber ich bekomme den Status des Fenster nicht via ICON angezeigt.
Wo muss ich noch Korrekturen ausführen.
LG Chris
Devices: APC, Davis, Eastron, FS20, Homematic, IT, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, SkyWind, TEK603
