AWS update Zertifikate, ist was zu tun?
Begonnen von franky08, 06 Januar 2018, 10:16:17
franky08
Hallo, hatte heute eine Mail von Amazon AWS:
ZitatUpcoming Changes to SSL Certificates in Amazon CloudWatch Logs
ZitatHello,
We will be updating the certificate authority (CA) for the certificates used by Amazon CloudWatch Logs domain(s), between 8 January 2018 and 22 January 2018. After the updates complete, the SSL/TLS certificates used by Amazon CloudWatch Logs will be issued by Amazon Trust Services (ATS), the same certificate authority (CA) used by AWS Certificate Manager. The update means that customers accessing AWS webpages via HTTPS (for example, the Amazon CloudWatch Console, customer portal, or homepage) or accessing Amazon CloudWatch Logs API endpoints, whether through browsers or programmatically, will need to update the trusted CA list on their client machines if they do not already support any of the following CAs:
- "Amazon Root CA 1"
- "Starfield Services Root Certificate Authority - G2"
- "Starfield Class 2 Certification Authority"
This upgrade notice covers the following endpoints:
logs.ap-northeast-1.amazonaws.com
logs.ap-northeast-2.amazonaws.com
logs.ap-south-1.amazonaws.com
logs.ap-southeast-1.amazonaws.com
logs.ap-southeast-2.amazonaws.com
logs.ca-central-1.amazonaws.com
logs.eu-central-1.amazonaws.com
logs.eu-west-1.amazonaws.com
logs.eu-west-2.amazonaws.com
logs.eu-west-3.amazonaws.com
logs.us-east-1.amazonaws.com
logs.us-east-2.amazonaws.com
logs.us-west-1.amazonaws.com
logs.us-west-2.amazonaws.com
logs.sa-east-1.amazonaws.com
If your clients already trust ANY of the above three CAs then they will trust our certificates and no action is required. However, if you do not already trust any of the above CAs and do not add them to your trusted CA list by 22 January 2018, HTTPS connections to the Amazon CloudWatch Logs APIs will not be established. For more information about this AWS update, please visit this blog post:
VG
Frank
mit FHEM aktuell
justme1968
franky08
Danke Andre, scheint sich ja auch nur um log´s zu handeln :-)
VG
Frank
mit FHEM aktuell
