TellStick.pm (InterTechno, KlikAanKlikUit usw.)
Begonnen von Guest, 23 Januar 2012, 23:06:08
Guest
(English version below)
Heiko überließ mir kurzzeitig seinen TellStick und ich habe grade die erste Version von 70_TellStick.pm eingecheckt.
Ist kein Wunderwerk an Eleganz (und setzt eine funktionierende Telldus-Core-Umgebung voraus), aber vielleicht kann's ja wer gebrauchen ;)
Da Heiko seinen Stick verständlicherweise wieder zurück haben möchte, wäre ich an kurzfristigem Feedback sehr interessiert.
Heiko sent me his TellStick so I could write a module to interface Telldus' TellStick with FHEM; I just checked in the initial, "works for me" version of 70_TellStick.pm.
It's not pretty and requires a working telldus-core environment, but maybe it's usefull for someone anyway.
As Heiko expects his TellStick back, I'm rather interessted in some feedback from other TellStick owners.
Ciao,
-kai
Guest
Hi Kai,
can it receive InterTechno ? Do you have access to the RF-Part of the stick?
Are you connecting via a socket, or via USB ?
Thanks,
best,
Olaf
Am 23.01.2012 23:06, schrieb Kai 'wusel' Siering:
> Hi,
> Hi,
> Ciao,
> -kai
Prof. Dr. Olaf Droegehorn
General Manager              Tel.  : +49-2244-918-4080
DHS - Computertechnik GmbH   Fax.  : +49-2244-918-4082
Wilhelm-Liebertz-Str. 2c     E-Mail: O.Droegehorn@dhs-
                                        computertechnik.de
D-53639 Koenigswinter        WEB:    www.dhs-computertechnik.de
Guest
The one I have access to is the send-only one. The TellStick Duo is capable of receiving some 433 MHz protocols, but is currently out of stock.
 From my perspective, a TellStick (Duo) is a CUL433 type of device, the telldus-core software interfaces with it like FHEM e. g. with a CUL. And no, one does not have direct access to the HW.
As I said, I connect via "tdtool", which uses the, IIRC, open-sourced libraries to talk to the stick. One could interact directly with the stick, but AFAIK not with the RF part, only with the TellStick firmware.
Regards,
-kai
On 23.01.2012 23:16, Olaf Droegehorn wrote:
> Hi Kai,
Guest
Hallo, ich besitze nun auch einen Telstick Duo.
Wie kann ich diesen nun an meiner Fritz Box mit FHEm ans laufen bekommen.
Wo bekomme ich das Tool?
MfG Jens
Am Montag, 23. Januar 2012 23:06:08 UTC+1 schrieb Kai 'wusel' Siering:
> Hi,
> Hi,
> Ciao,
> -kai
