new 59_Weather
Begonnen von Guest, 20 September 2012, 11:56:20
Guest
Hi
I used updatefhem to get the new 59_Weather. It works now, but I get the
German texts, like "bewölkt" instead of the Dutch. Is this a bug or do I
have to change something?
My definition is:
define myWeather Weather 3600 nl
{HT}
Guest
the new version does not check the language (yet). It uses  the german
captions, no matter which language is set.
As a workaround, you could copy the Array "@YahooCodes_us" change the name
to @YahooCodes_nl and translate all the captions to dutch.
After that change this line (205):
my $text = $YahooCodes_de[$code];
to this:
my $text = $YahooCodes_nl[$code];
If you can live with the english captions temporary, it should suffice, to
change the line to
my $text = $YahooCodes_us[$code];
Am Donnerstag, 20. September 2012 11:56:20 UTC+2 schrieb dudler:
> Hi
> My definition is:
> {HT}
Guest
Thanks for the quick answer. I can live with the german captions too. So no
reason to hurry anything.
If it is necessary to translate the captions in dutch, I volunteer for that.
{HT}
Op donderdag 20 september 2012 12:25:05 UTC+2 schreef Carsten het volgende:
> Hi,
> name to @YahooCodes_nl and translate all the captions to dutch.
> to this:
> change the line to
>> Hi
>> My definition is:
>> {HT}
Dr. Boris Neubert
Am 20.09.2012 12:31, schrieb dudler:
> that.
I would be glad to receive it in dutch. Just put the array with the
translation into an e-mail. I will then integrate it into a multilingual
version of the module.
Kind regards
Boris
Globaler Moderator, Developer, aktives Mitglied des FHEM e.V. (Marketing, Verwaltung)
Guest
Bitte:
my @YahooCodes_nl = (
       'tornado', 'zware storm', 'orkaan', 'hevig onweer', 'onweer',
'regen en sneeuw',
       'regen en ijzel', 'sneeuw en ijzel', 'aanvriezende motregen',
'motregen', 'aanvriezende regen' ,'regenbuien',
       'buien', 'sneeuw windstoten', 'lichte sneeuwbuien',
'stuifsneeuw', 'sneeuw', 'hagel',
       'ijzel', 'stof', 'mist', 'waas', 'smog', 'heftig',
       'winderig', 'koud', 'bewolkt',
       'overwegend bewolkt', # night
       'overwegend bewolkt', # day
       'gedeeltelijk bewolkt', # night
       'gedeeltelijk bewolkt', # day
       'helder', #night
       'zonnig',
       'bewolkt', #night
       'bewolkt', #day
       'regen en hagel',
       'heet', 'plaatselijk onweer', 'af en toe onweer', 'af en toe
onweer', 'af en toe regenbuien', 'hevige sneeuwval',
       'af en toe sneeuwbuien', 'hevige sneeuwval', 'deels bewolkt',
'onweersbuien', 'sneeuwbuien', 'af en toe onweersbuien');
But I would like at the german translation again. I am not sure about
every translation in dutch but very sure not all translations in
german are correct.
{HT}
2012/9/21 Dr. Boris Neubert :
> Hi,
>> that.
> Kind regards
> Boris
Dr. Boris Neubert
Am 21.09.2012 20:16, schrieb Harry Thijssen:
Thank you. Could you also please translate the following arrays and
hashes to dutch?
my %pressure_trend_txt_nl = ( 0 => "steady", 1 => "rising", 2 =>
"falling" );
my @directions_txt_nl = ('N', 'NNE', 'NE', 'ENE', 'E', 'ESE', 'SE',
'SSE', 'S', 'SSW', 'SW', 'WSW', 'W', 'WNW', 'NW', 'NNW');
my %wdays_txt_nl = ('Mon' => 'Mon', 'Tue' => 'Tue', 'Wed'=> 'Wed', 'Thu'
=> 'Thu', 'Fri' => 'Fri', 'Sat' => 'Sat', 'Sun' => 'Sun');
> german are correct.
I changed some of them but I am not a meteorologist.
Ist hier jemand, der sich mit den offiziellen Bezeichnungen für
Wetterbedingungen auf Deutsch auskennt?
Kind regards
Boris
Dr. Boris Neubert
Hi there,
a refined and multilingual (en, de, incomplete nl) version of the
Weather module is now available in SVN.
Kind regards,
Boris
Guest
2012/9/22 Dr. Boris Neubert
> hashes to dutch?
> "falling" );
my %pressure_trend_txt_nl = ( 0 => "stabiel", 1 => "stijgend", 2 => "dalend" );
my @directions_txt_nl = ('N', 'NNO', 'NO', 'ONO', 'O', 'OZO', ZO',
 'ZZO', 'Z', 'ZZW', 'ZW', 'WZW', 'W', 'WNW', 'NW', 'NNW');
my %wdays_txt_nl = ('Maa' => 'Maa', 'Din' => 'Din', 'Woe'=> 'Woe', 'Don'
 => 'Don', 'Vri' => 'Vri', 'Zat' => 'Zat', 'Zon' => 'Zon');
This is the same for me for the dutch translations. Does anybody no
the correct/better words?
{HT}
Dr. Boris Neubert
Am 23.09.2012 20:25, schrieb Harry Thijssen:
> "dalend" ); my @directions_txt_nl = ('N', 'NNO', 'NO', 'ONO', 'O',
> 'OZO', ZO', 'ZZO', 'Z', 'ZZW', 'ZW', 'WZW', 'W', 'WNW', 'NW', 'NNW');
> 'Don' => 'Don', 'Vri' => 'Vri', 'Zat' => 'Zat', 'Zon' => 'Zon');
Thank you. It is all in the SVN repository now and you get it via update
tomorrow.
Boris
Guest
Hi
I had a quick look in the code.
" mit " should also be localized. In dutch it is " met ".
{HT}
2012/9/23 Dr. Boris Neubert :i
> tomorrow.
> Boris
