Re: issue with gplot configuration
Begonnen von Guest, 23 Oktober 2012, 16:38:24
Guest
Sorry, I didn't explain myself correctly.
ftf55.gplot is completely the same as temp4.gplot. I created a copy to work
on it.
So to answer your question I tried with  temp4.gplot, but the graph is
empty.
Then, in my copy, I reduced the conditions to the minimum  #FileLog 4:::,
but it doesn't work neither.
Except with the telnet command provided in the wiki, I don't really know
how to debug that.
Le mardi 23 octobre 2012 16:07:53 UTC+2, dou...@m1n1.de a écrit :
> Hope I got it right, but there isn't a gplot file like ftf55.gplot
> At least there isn't one on my installation. If you haven't createt it,
> then there should be an error when trying to plot the graph.
> Have you tried temp4.gplot already? Maybe it's worth giving it a try.
> BR
> Ralf
Guest
Ok, I solved my problem. I started from scratch and I've done some debug
with egrep and all seems fine now.
Thanks again for your help.
Regards,
Bernard
> work on it.
> empty.
> how to debug that.
>> BR
>> Ralf
