Revision 17043: 96_SIP: add readings caller_name and caller_nr, support for phonebook, ...
Begonnen von System, 28 Juli 2018, 20:15:50
System
96_SIP: add readings caller_name and caller_nr, support for phonebook, calllist Forum : ​https://forum.fhem.de/index.php/topic,67443.msg819027.html#msg819027
Source: Revision 17043: 96_SIP: add readings caller_name and caller_nr, support for phonebook, ...
