Watchdog triggert nicht mehr
Begonnen von Nemo0815, 23 Oktober 2018, 08:30:26
Nemo0815
was mache ich hier falsch? Es hatte schonmal funktinoiert, jetzt löst der watchdog nicht mehr aus:
Zu überwachendes Device:
   CHANGED
   DEF        16 switch,powerMeter
   IODev      myFritzboxFBAHA
   LASTInputDev myFritzboxFBAHA
   MSGCNT     5183
   NAME       FBDECT_200_1
   NR         238
   STATE      off
   TYPE       FBDECT
   id         16
   myFritzboxFBAHA_MSGCNT 5183
   myFritzboxFBAHA_TIME 2018-10-23 08:29:08
   props      powerMeter,tempSensor,switch
   Helper:
     DBLOG:
       state:
         logdb:
           TIME       1540276088.81349
           VALUE      off
       temperature1:
         logdb:
           VALUE      23.0
     2018-10-23 08:29:08   AIN             -
     2018-10-23 08:29:08   FBNAME          FRITZ!DECT 200 #1
     2018-10-23 08:29:08   FBPROP          powerMeter,tempSensor,switch
     2018-10-23 08:29:08   FBTYPE          FRITZ!DECT 200
     2018-10-23 08:29:08   ID              16
     2017-02-26 18:37:00   control         on fn=1 > 0.00 delay:0sec do:state off
     2017-07-16 12:31:46   current         0.0000 A
     2018-10-23 08:29:08   devicelock      no
     2018-10-23 08:29:08   energy          0 Wh
     2018-10-23 08:29:08   fwversion       04.09
     2018-10-23 08:29:08   locked          no
     2018-10-23 08:29:08   mode            manuell
     2017-02-26 18:36:58   options         powerOnState:last,lock:none
     2018-10-23 08:29:08   power           0.00 W
     2017-07-16 12:31:46   powerFactor     0.000
     2018-10-23 08:29:08   present         yes
     2018-10-23 08:29:08   state           off
     2018-10-23 08:29:08   tempadjust      -1.5 C
     2018-10-23 08:29:08   temperature     23.0 C (measured)
     2018-10-23 08:29:08   temperature1    23.0
     2017-07-16 12:31:46   voltage         0.000 V
   helper:
     bm:
       FBDECT_Get:
         cnt        24
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        22.10. 10:43:50
         max        0.000173807144165039
         tot        0.0018467903137207
         mAr:
           HASH(0x3b8fc38)
           FBDECT_200_1
       FBDECT_Set:
         cnt        838
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        22.10. 10:49:37
         max        0.00963902473449707
         tot        0.575885772705078
         mAr:
           HASH(0x3b8fc38)
           FBDECT_200_1
           on
   DbLogInclude temperature1,state
   alias      Badheizung
   event-min-interval .*:120
   model      Dect200
   room       MyHome
   userReadings temperature1 {
my $temp=ReadingsVal($name, "temperature", 0);;
    $temp=(substr($temp, 0, (length($temp)-12)));;
return $temp;;
Watchdog dazu:
   CFGFN
   CMD        set FBDECT_200_1 off;trigger BadHeizungWatchdog
   DEF        FBDECT_200_1:on 00:30:00 SAME set FBDECT_200_1 off;trigger BadHeizungWatchdog
   NAME       BadheizungWatchdog
   NOTIFYDEV  BadheizungWatchdog,FBDECT_200_1
   NR         35220
   NTFY_ORDER 50-BadheizungWatchdog
   RE1        FBDECT_200_1:on
   RE2        FBDECT_200_1:on
   STATE      triggered
   TO         1800
   TYPE       watchdog
     2018-10-22 15:08:24   Activated       activated
     2018-10-22 15:38:24   Triggered       triggered
   helper:
     bm:
       watchdog_Attr:
         cnt        1
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        22.10. 10:50:57
         max        2.50339508056641e-05
         tot        2.50339508056641e-05
         mAr:
           set
           BadheizungWatchdog
           regexp1WontReactivate
           1
       watchdog_Define:
         cnt        2
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        22.10. 10:50:22
         max        0.000926017761230469
         tot        0.00142598152160645
         mAr:
           HASH(0x51a3018)
           BadheizungWatchdog watchdog FBDECT_200_1:on 00:30:00 SAME set FBDECT_200_1 off
       watchdog_Notify:
         cnt        641
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        22.10. 15:10:08
         max        0.00299501419067383
         tot        0.203458070755005
         mAr:
           HASH(0x51a3018)
           HASH(0x3b8fc38)
       watchdog_Set:
         cnt        49
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        22.10. 10:53:34
         max        0.000242948532104492
         tot        0.00396847724914551
         mAr:
           HASH(0x51a3018)
           BadheizungWatchdog
   regexp1WontReactivate 1
Frank_Huber
Nemo0815
Zitat von: Frank_Huber am 23 Oktober 2018, 08:34:15
Update der fritzbox gemacht?
Das schalten der FBDECT funktioniert ja über FHEM, nur der Watchdog kriegt davon nichts mit.
Brice
Trigger-Befehl ist unvollständig, da fehlt Leerzeichen und Punkt.
Zitattrigger <watchdogname> . aktiviert den Trigger wenn dessen Status defined ist und setzt ihn in den Status defined wenn sein status triggered oder aktiviert (Next:...) ist.
FHEM auf RPi 4 4GB (Buster) | produktiv) CUL 868 für FS20 | S300TH | KS300 | Max!Cube als CUN 868 für TechemWZ | HM-MOD-RPI-PCB für HM | Z-Wave ZME_UZB1 | FRITZ!DECT 200 | HUE | Lightify | Echo Dot | WS3080
Nemo0815
Danke, hatte ich nicht gesehen! Funktioniert hats aber nicht wegen dem SAME (falsche Logik). Keine Ahnung wieso's vorher mal ging...
Brice
Ich nutze den Trigger nicht, sondern
attr <Name watchdog> autoRestart 1
