Failure using templates
Begonnen von tomaszG, 20 Dezember 2018, 11:48:28
tomaszG
Great job on FHEM it's great to use
I am experiencing a small problem on the template object
I create the following template
define %mqtt_name% MQTT_BRIDGE %device_name%
attr %mqtt_name% publishReading_setpointTempSet enocean/%topic_name%/setpointTempSet
when I type in the command in the web interface
template mqtt_bridge_simple.templ mqtt_name=mq_EnO_01A60F81 device_name=EnO_01A60F81 topic_name=EnO_01A60F81
it successfully create the object without error, but then the object never publishes on MQTT. If i look at the object page (attached as pic) I see that it looks almost fine except that the device does seem to be linked in the NOTIFYDEV field.
If i creat the same object by typing directly
define mqt004 MQTT_BRIDGE EnO_01A60F81
attr mqt004 publishReading_setpointTempSet enocean/EnO_01A60F81/setpointTempSet
It works. thats exactly the commands the template is supposed to produce. this time,(see attached), it is correctly linked and dooes publish on MQTT.
Please let me know a solution or pleasant workaround (already found a heavy workaround that I would like to avoid)
Best
Hi tomaszG,
sorry for the troubles you ran into.
Rather than using multiple MQTT_BRIDGE devices, I'd suggest to use just one MQTT_GERNERIC_BRIDGE.
Then all mqtt specific configuration off your %device_name% devices  can be done without any additional definition (just attributes to the %device_name%). See examples section of MQTT_GENERIC_BRIDGE in commandref.
Note: MQTT2_CLIENT and MQTT2_SERVER are now also valid IO devices for Gen. Bridge.
Kind regards
tomaszG
