Revision 18308: mqtt2.template: add zigbee2mqtt temp hum pressure sensor Forum: #94495 ...
Begonnen von System, 18 Januar 2019, 08:15:35
System
mqtt2.template: add zigbee2mqtt temp hum pressure sensor Forum: #94495 #msg890157
Source: Revision 18308: mqtt2.template: add zigbee2mqtt temp hum pressure sensor Forum: #94495 ...
