isn't numeric in numeric
Begonnen von chq, 05 März 2019, 08:42:22
chq
ich bekomme in meinem Logfile bei einem meiner DOIFs folgende Fehlermeldungen:
2019.03.05 08:18:49 1: PERL WARNING: Argument "" isn't numeric in numeric ge (>=) at (eval 27334) line 1.
2019.03.05 08:18:49 3: eval: doif_rolloWohnzimmer: warning in condition c03
2019.03.05 08:18:49 1: PERL WARNING: Argument "" isn't numeric in numeric lt (<) at (eval 27335) line 1.
2019.03.05 08:18:49 3: eval: doif_rolloWohnzimmer: warning in condition c04
2019.03.05 08:20:41 1: PERL WARNING: Argument "" isn't numeric in numeric ge (>=) at (eval 27394) line 1.
2019.03.05 08:20:41 3: eval: doif_rolloWohnzimmer: warning in condition c02
2019.03.05 08:20:41 1: PERL WARNING: Argument "" isn't numeric in numeric ge (>=) at (eval 27395) line 1.
2019.03.05 08:20:41 3: eval: doif_rolloWohnzimmer: warning in condition c03
2019.03.05 08:20:41 1: PERL WARNING: Argument "" isn't numeric in numeric lt (<) at (eval 27396) line 1.
2019.03.05 08:20:41 3: eval: doif_rolloWohnzimmer: warning in condition c04
2019.03.05 08:22:01 1: PERL WARNING: Argument "" isn't numeric in numeric ge (>=) at (eval 27437) line 1.
2019.03.05 08:22:01 3: eval: doif_rolloWohnzimmer: warning in condition c02
2019.03.05 08:22:01 1: PERL WARNING: Argument "" isn't numeric in numeric ge (>=) at (eval 27438) line 1.
2019.03.05 08:22:01 3: eval: doif_rolloWohnzimmer: warning in condition c03
2019.03.05 08:22:01 1: PERL WARNING: Argument "" isn't numeric in numeric lt (<) at (eval 27439) line 1.
2019.03.05 08:22:01 3: eval: doif_rolloWohnzimmer: warning in condition c04
2019.03.05 08:22:33 1: PERL WARNING: Argument "" isn't numeric in numeric ge (>=) at (eval 27467) line 1.
2019.03.05 08:22:33 3: eval: doif_rolloWohnzimmer: warning in condition c02
2019.03.05 08:22:33 1: PERL WARNING: Argument "" isn't numeric in numeric ge (>=) at (eval 27468) line 1.
2019.03.05 08:22:33 3: eval: doif_rolloWohnzimmer: warning in condition c03
Müssen da bei den Zahlen evtl. die Gänsefüßchen weg?
Gruß Chris
Hier ein list des DOIFs:
   DEF        ## ==eq !=ne <lt >gt le<= ge>=
## and [HM_markise:state] eq "closed"
([00:00]) () ## idle
DOELSEIF ([06:30-09:00] and !$we and ([Wetterstation:luminosity] > "0" or [Wetterstation:UVR] >= "2.5") and [wettervorhersage:fc1_high_c] >= "24" and [?Wetterstation:temperature] > "0") (set HM_rolloWohnzimmer pct 27)
DOELSEIF ([06:30-09:00] and !$we and ([Wetterstation:luminosity] > "0" or [Wetterstation:UVR] >= "2.5") and [wettervorhersage:fc1_high_c] >= "17" and [wettervorhersage:fc1_high_c] < "24" and [?Wetterstation:temperature] > "0") (set HM_rolloWohnzimmer pct 77)
DOELSEIF ([06:30-09:00] and !$we and ([Wetterstation:luminosity] > "0" or [Wetterstation:UVR] >= "2.5") and [wettervorhersage:fc1_high_c] < "17" and [?Wetterstation:temperature] > "0") (set HM_rolloWohnzimmer pct 100)
DOELSEIF ([07:30-09:00] and $we and ([Wetterstation:luminosity] > "0" or [Wetterstation:UVR] >= "2.5") and [wettervorhersage:fc1_high_c] >= "24" and [?Wetterstation:temperature] > "0") (set HM_rolloWohnzimmer pct 27)
DOELSEIF ([07:30-09:00] and $we and ([Wetterstation:luminosity] > "0" or [Wetterstation:UVR] >= "2.5") and [wettervorhersage:fc1_high_c] >= "17" and [wettervorhersage:fc1_high_c] < "24" and [?Wetterstation:temperature] > "0") (set HM_rolloWohnzimmer pct 77)
DOELSEIF ([07:30-09:00] and $we and ([Wetterstation:luminosity] > "0" or [Wetterstation:UVR] >= "2.5") and [wettervorhersage:fc1_high_c] < "17" and [?Wetterstation:temperature] > "0") (set HM_rolloWohnzimmer pct 100)
DOELSEIF ([{sunset("HORIZON=-2.2",0,"16:00","23:59")}-24:00] and [Wetterstation:luminosity] == "0" and [Wetterstation:UVR] <= "2.6" and [HM_rolloWohnzimmer:control] > "0") (set HM_rolloWohnzimmer pct 0)
DOELSEIF ([{sunset("HORIZON=-2.2",0,"16:00","23:59")}-24:00] and [Wetterstation:luminosity] == "0" and [Wetterstation:UVR] <= "2.6" and [HM_rolloWohnzimmer:control] == "0") () ## closed
   MODEL      FHEM
   NAME       doif_rolloWohnzimmer
   NR         63
   NTFY_ORDER 50-doif_rolloWohnzimmer
   STATE      open
   TYPE       DOIF
     2019-03-05 08:37:13   Device          Wetterstation
     2019-03-05 06:48:42   cmd             4
     2019-03-05 06:48:42   cmd_event       Wetterstation
     2019-03-05 06:48:42   cmd_nr          4
     2019-03-05 06:49:23   e_HM_rolloWohnzimmer_control 100
     2019-03-05 08:36:57   e_Wetterstation_UVR 266.974414809537
     2019-03-05 08:35:21   e_Wetterstation_luminosity 4427.14779826265
     2019-03-04 18:50:29   mode            enabled
     2019-03-05 06:48:42   state           open
     2019-03-05 00:00:00   timer_01_c01    06.03.2019 00:00:00
     2019-03-04 18:50:30   timer_02_c02    05.03.2019 06:30:00
     2019-03-04 18:50:30   timer_03_c02    05.03.2019 09:00:00
     2019-03-04 18:50:30   timer_04_c03    05.03.2019 06:30:00
     2019-03-04 18:50:30   timer_05_c03    05.03.2019 09:00:00
     2019-03-04 18:50:30   timer_06_c04    05.03.2019 06:30:00
     2019-03-04 18:50:30   timer_07_c04    05.03.2019 09:00:00
     2019-03-04 18:50:30   timer_08_c05    05.03.2019 07:30:00
     2019-03-04 18:50:30   timer_09_c05    05.03.2019 09:00:00
     2019-03-04 18:50:30   timer_10_c06    05.03.2019 07:30:00
     2019-03-04 18:50:30   timer_11_c06    05.03.2019 09:00:00
     2019-03-04 18:50:30   timer_12_c07    05.03.2019 07:30:00
     2019-03-04 18:50:30   timer_13_c07    05.03.2019 09:00:00
     2019-03-05 00:00:00   timer_14_c08    05.03.2019 18:22:16
     2019-03-05 00:00:00   timer_15_c08    06.03.2019 00:00:00
     2019-03-05 00:00:00   timer_16_c09    05.03.2019 18:22:16
     2019-03-05 00:00:00   timer_17_c09    06.03.2019 00:00:00
     2019-03-05 08:36:57   warning         condition c04: Argument "" isn't numeric in numeric lt (<)
   Regex:
   attr:
     cmdState:
       0:
         idle
       1:
         27
       2:
         77
       3:
         open
       4:
         27
       5:
         77
       6:
         open
       7:
         closed
       8:
         closed
     wait:
     waitdel:
   condition:
     0          ::DOIF_time_once($hash,0,$wday)
     1          ::DOIF_time($hash,1,2,$wday,$hms) and !$we and (::ReadingValDoIf($hash,'Wetterstation','luminosity') > "0" or ::ReadingValDoIf($hash,'Wetterstation','UVR') >= "2.5") and ::ReadingValDoIf($hash,'wettervorhersage','fc1_high_c') >= "24" and ::ReadingValDoIf($hash,'Wetterstation','temperature') > "0"
     2          ::DOIF_time($hash,3,4,$wday,$hms) and !$we and (::ReadingValDoIf($hash,'Wetterstation','luminosity') > "0" or ::ReadingValDoIf($hash,'Wetterstation','UVR') >= "2.5") and ::ReadingValDoIf($hash,'wettervorhersage','fc1_high_c') >= "17" and ::ReadingValDoIf($hash,'wettervorhersage','fc1_high_c') < "24" and ::ReadingValDoIf($hash,'Wetterstation','temperature') > "0"
     3          ::DOIF_time($hash,5,6,$wday,$hms) and !$we and (::ReadingValDoIf($hash,'Wetterstation','luminosity') > "0" or ::ReadingValDoIf($hash,'Wetterstation','UVR') >= "2.5") and ::ReadingValDoIf($hash,'wettervorhersage','fc1_high_c') < "17" and ::ReadingValDoIf($hash,'Wetterstation','temperature') > "0"
     4          ::DOIF_time($hash,7,8,$wday,$hms) and $we and (::ReadingValDoIf($hash,'Wetterstation','luminosity') > "0" or ::ReadingValDoIf($hash,'Wetterstation','UVR') >= "2.5") and ::ReadingValDoIf($hash,'wettervorhersage','fc1_high_c') >= "24" and ::ReadingValDoIf($hash,'Wetterstation','temperature') > "0"
     5          ::DOIF_time($hash,9,10,$wday,$hms) and $we and (::ReadingValDoIf($hash,'Wetterstation','luminosity') > "0" or ::ReadingValDoIf($hash,'Wetterstation','UVR') >= "2.5") and ::ReadingValDoIf($hash,'wettervorhersage','fc1_high_c') >= "17" and ::ReadingValDoIf($hash,'wettervorhersage','fc1_high_c') < "24" and ::ReadingValDoIf($hash,'Wetterstation','temperature') > "0"
     6          ::DOIF_time($hash,11,12,$wday,$hms) and $we and (::ReadingValDoIf($hash,'Wetterstation','luminosity') > "0" or ::ReadingValDoIf($hash,'Wetterstation','UVR') >= "2.5") and ::ReadingValDoIf($hash,'wettervorhersage','fc1_high_c') < "17" and ::ReadingValDoIf($hash,'Wetterstation','temperature') > "0"
     7          ::DOIF_time($hash,13,14,$wday,$hms) and ::ReadingValDoIf($hash,'Wetterstation','luminosity') == "0" and ::ReadingValDoIf($hash,'Wetterstation','UVR') <= "2.6" and ::ReadingValDoIf($hash,'HM_rolloWohnzimmer','control') > "0"
     8          ::DOIF_time($hash,15,16,$wday,$hms) and ::ReadingValDoIf($hash,'Wetterstation','luminosity') == "0" and ::ReadingValDoIf($hash,'Wetterstation','UVR') <= "2.6" and ::ReadingValDoIf($hash,'HM_rolloWohnzimmer','control') == "0"
   days:
   devices:
     1           Wetterstation wettervorhersage
     2           Wetterstation wettervorhersage
     3           Wetterstation wettervorhersage
     4           Wetterstation wettervorhersage
     5           Wetterstation wettervorhersage
     6           Wetterstation wettervorhersage
     7           Wetterstation HM_rolloWohnzimmer
     8           Wetterstation HM_rolloWohnzimmer
     all         Wetterstation wettervorhersage HM_rolloWohnzimmer
   do:
     0:
       0
     1:
       0          set HM_rolloWohnzimmer pct 27
     2:
       0          set HM_rolloWohnzimmer pct 77
     3:
       0          set HM_rolloWohnzimmer pct 100
     4:
     5:
     6:
     7:
       0          set HM_rolloWohnzimmer pct 0
     8:
       0
     9:
   helper:
     event      wind_speed: 13.7
     globalinit 1
     last_timer 17
     sleeptimer -1
     timerdev   Wetterstation
     timerevent wind_speed: 14.8,wind_gust: 20.2,UVR: 266.974414809537
     triggerDev Wetterstation
     DOIF_eventas:
       cmd_nr: 4
       cmd: 4
       cmd_event: Wetterstation
       state: open
     timerevents:
       wind_speed: 14.8
       wind_gust: 20.2
     timereventsState:
       wind_speed: 14.8
       wind_gust: 20.2
     triggerEvents:
       wind_speed: 13.7
     triggerEventsState:
       wind_speed: 13.7
   internals:
   interval:
     1          -1
     10         9
     11         -1
     12         11
     13         -1
     14         13
     15         -1
     16         15
     2          1
     3          -1
     4          3
     5          -1
     6          5
     7          -1
     8          7
     9          -1
   intervalfunc:
   intervaltimer:
   itimer:
   localtime:
     0          1551826800
     1          1551763800
     10         1551772800
     11         1551767400
     12         1551772800
     13         1551806536
     14         1551826800
     15         1551806536
     16         1551826800
     2          1551772800
     3          1551763800
     4          1551772800
     5          1551763800
     6          1551772800
     7          1551767400
     8          1551772800
     9          1551767400
   readings:
     1           Wetterstation:luminosity Wetterstation:UVR wettervorhersage:fc1_high_c
     2           Wetterstation:luminosity Wetterstation:UVR wettervorhersage:fc1_high_c
     3           Wetterstation:luminosity Wetterstation:UVR wettervorhersage:fc1_high_c
     4           Wetterstation:luminosity Wetterstation:UVR wettervorhersage:fc1_high_c
     5           Wetterstation:luminosity Wetterstation:UVR wettervorhersage:fc1_high_c
     6           Wetterstation:luminosity Wetterstation:UVR wettervorhersage:fc1_high_c
     7           Wetterstation:luminosity Wetterstation:UVR HM_rolloWohnzimmer:control
     8           Wetterstation:luminosity Wetterstation:UVR HM_rolloWohnzimmer:control
     all         Wetterstation:luminosity Wetterstation:UVR wettervorhersage:fc1_high_c HM_rolloWohnzimmer:control
   realtime:
     0          00:00:00
     1          06:30:00
     10         09:00:00
     11         07:30:00
     12         09:00:00
     13         18:22:16
     14         00:00:00
     15         18:22:16
     16         00:00:00
     2          09:00:00
     3          06:30:00
     4          09:00:00
     5          06:30:00
     6          09:00:00
     7          07:30:00
     8          09:00:00
     9          07:30:00
   time:
     0          00:00:00
     1          06:30:00
     10         09:00:00
     11         07:30:00
     12         09:00:00
     13         {sunset("HORIZON=-2.2",0,"16:00","23:59")}
     14         24:00:00
     15         {sunset("HORIZON=-2.2",0,"16:00","23:59")}
     16         24:00:00
     2          09:00:00
     3          06:30:00
     4          09:00:00
     5          06:30:00
     6          09:00:00
     7          07:30:00
     8          09:00:00
     9          07:30:00
   timeCond:
     0          0
     1          1
     10         5
     11         6
     12         6
     13         7
     14         7
     15         8
     16         8
     2          1
     3          2
     4          2
     5          3
     6          3
     7          4
     8          4
     9          5
   timer:
     0          0
     1          0
     10         0
     11         0
     12         0
     13         0
     14         0
     15         0
     16         0
     2          0
     3          0
     4          0
     5          0
     6          0
     7          0
     8          0
     9          0
   timers:
     0           0
     1           1  2
     2           3  4
     3           5  6
     4           7  8
     5           9  10
     6           11  12
     7           13  14
     8           15  16
   trigger:
   triggertime:
     1551772800:
       localtime  1551772800
       hash:
     1551806536:
       localtime  1551806536
       hash:
     1551826800:
       localtime  1551826800
       hash:
   uiState:
   uiTable:
   alias      doif_Rollo Wohnzimmer
   cmdState   idle|27|77|open|27|77|open|closed|closed
Edit: Ich glaub ich hab's, bin mir jedoch (noch) nicht sicher. [wettervorhersage:fc1_high_c] >= "24" wertet nicht mehr richtig aus, da ich das UWZ-Modul ("wettervorhersage" benannt) mangels Zuverlässigkeit gelöscht habe.
So einfach wie möglich, so kompliziert wie nötig
Christoph Morrison
>=, >, <, <= sind numerische Vergleichsoperatoren, die du aber auf Strings (in ") anwendest.
Es müsste reichen >= durch ge etc. zu ersetzen (der String-Vergleichsoperator steht in der Fehlermeldung hinten, ge, lt etc.).
Wenn du aber weißt, dass du ein Wert nicht mehr lesen kannst (wettervorhersage:fc1_high_c), dann solltest du die auch aus dem DOIF entfernen.
Ellert
In verschiedenen Vergleichen wird ein leerer Wert (Argument) zurück geliefert bei den in Klammern angegebenen Verleichsoperatoren. Du könntest Ersatzwerte verwenden, s. https://commandref.fhem.de/commandref_DE.html#DOIF_Inhaltsuebersicht
Per
Du hast sämtliche Zahlen in "" gesetzt, damit sind es Strings und werden auch als solche behandelt. Achtung: bei Strings gilt "8" gt "11"!
chq
Sind wirklich ganz tolle Antworten zusammengekommen.
Alles hilfreich- vielen Dank!
Werd jetzt bei Zahlen immer die " weglassen und mit > usw. vergleichen. Strings dann dementsprechend immer in " und gt usw.
Die DOIFs, die ich bisher so umgebaut habe, funktionieren jedenfalls immernoch.
Gruß Chris
Damian
hier nochmal eine Klarstellung, warum Vergleich nicht immer so funktionieren, wie man denkt: https://forum.fhem.de/index.php/topic,51661.msg915143.html#msg915143
