Revision 18872: Meta.pm: Use decimal versions for generated version numbers, making ...
Begonnen von System, 12 März 2019, 10:30:52
System
Meta.pm: Use decimal versions for generated version numbers, making dotted-integer versions / semver optional.
Source: Revision 18872: Meta.pm: Use decimal versions for generated version numbers, making ...
