CUL SlowRF: Unknown code
Begonnen von JarJar, 03 April 2019, 17:04:24
JarJar
Mahlzeit,
ich bekomme seit heute regelmäßig unregelmäßig vom CUL einen Unknown code ins Log.
Kann jemand etwas damit anfangen:
2019.04.03 16:47:36 3: CUL: Unknown code 1582AF0FFFF3F 0 0 080FFFFFF F 0 07F 054 1 0 0 0 0 0E0FFFFFFFFFFFFBFFBFF57 5 0 0 0FF 7FEFF, help me!
2019.04.03 16:47:54 3: CUL: Unknown code 1102A 0 0 0 07F20C07F55 0 0 0F89F3E7DFFFF60 0F0FFFF 3 0FEFFFF1FF8A7F4 7, help me!
2019.04.03 16:48:01 3: CUL: Unknown code 1582A32 02F145C1558F167B01FF9748F2AF055399FC0DFCAAAB2CE7150C0D9AF56EF 4AB42FEE1 F848C4271, help me!
2019.04.03 16:48:07 3: CUL: Unknown code 1086AF335A452AAAA8AA61894474555D5EA72CD2F8FB5AAAA229A64503E95AAAA5B64, help me!
2019.04.03 16:48:39 3: CUL: Unknown code 1582A 0 0FF 3FA9F3FC0AAC0FFFFF743FF 7 0FCFFFFD7FFFFD3FEA9 2FFFF 7 0 0F0FFFB 3FC7FFF 1F0FF, help me!
2019.04.03 16:49:10 3: CUL: Unknown code 1602AC0E7 FFFFFA0D17F55F8 FE0 0 056EBCFAA C40 3105B957EE1A822FFF18857ADCA82B3 7FB5F61AA267D, help me!
2019.04.03 16:49:42 3: CUL: Unknown code 1582A 230FF3EF0D0E980 3401E14F03F6A F 33F3F38437C523D54913FF993218422EBAFCAFFE3411FFF55F5, help me!
2019.04.03 16:50:13 3: CUL: Unknown code 1602AFEFF 0 12DA0D57F55FC3FE0FF5F5FDAFFAA 0 0 0FCFF1F 07F54E17F807F40 B29C1C4FF 080FF12 0 0, help me!
2019.04.03 16:50:45 3: CUL: Unknown code 1602A 0E0 FFFFEFF 07C557C80 198FB BF8FFFF1FC0 368 1FE7F54 1 0 0C35F5AF0FFAB 2 0FE3F 03F20FF, help me!
2019.04.03 16:51:16 3: CUL: Unknown code 158AA32209F89D7BF1E435518D08F12AB45E53FF5 03FD214AEAA2751D5 0 36F43A4AB109A7C7FB4F090559E, help me!
2019.04.03 16:52:19 3: CUL: Unknown code 1002A3CE0D094BC4A54 71A50C0354B2F4AF0FD5FC3EDB5B77A53 3CC5B7DAB8AFB, help me!
2019.04.03 16:52:51 3: CUL: Unknown code 1602AF3AF3F127156D5 733207E94E034554056A5 7 148F3AC1A7C8E CCC3BB1B2A2EABD2A F308F64992A5228, help me!
"... help me!"
Klar, gerne... Äh aber wie?
Schöne Grüße
JarJar
RaspberryPi B3 B3+ / Fritz!Box 7390 / Tradfri / Arduino nano CUL 433 V 1.26.03 a-culfw
Zitat von: JarJar am 03 April 2019, 17:04:24
"... help me!"
Hilft vielleicht:
1. Suchfunktion nutzen: bei mir z.B. erster Treffer mit "help me!" = https://forum.fhem.de/index.php/topic,78369.msg890772.html#msg890772
2. angepinnte Beiträge beachten, insbesondere https://forum.fhem.de/index.php/topic,71806.0.html
Hier fehlt z.B. ein list oder eine RAW-Definition des CUL.
JarJar
Das ist kein Problem  ;)
define CUL CUL /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A97JME41-if00-port0@38400 1234
setuuid CUL 5c73df5d-f33f-f239-2e1a-52ebb152f2e7f1ad
attr CUL devStateIcon .*:cul_cul
attr CUL rfmode SlowRF
CMDS                ABCeFfGiKLlMNRTtUVWXx
CUL_MSGCNT    24
CUL_TIME         2019-04-03 17:18:03
Clients              :FS20:FHT.*:KS300:USF1000:BS:HMS:FS20V: :CUL_EM:CUL_WS:CUL_FHTTK:CUL_HOERMANN:
                         :ESA2000:CUL_IR:CUL_TX:Revolt:IT:UNIRoll:SOMFY:
                         :STACKABLE_CC:TSSTACKED:STACKABLE:CUL_RFR::CUL_TCM97001:CUL_REDIRECT::OREGON::Hideki:
DEF                   /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A97JME41-if00-port0@38400 1234
DeviceName     /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A97JME41-if00-port0@38400
FD                    10
FHTID               1234
FUUID               5c73df5d-f33f-f239-2e1a-52ebb152f2e7f1ad
NAME               CUL
NR                   24
PARTIAL
RAWMSG        mAA00007FE05F044000FFFFFFFFFFFFFC07AA80000003F00015FFFC007FFFFF03C0001FFFFFFF80000400004B
STATE             Initialized
TIME              1554304683
TYPE              CUL
VERSION        V 1.26.03 a-culfw Build: private build (unknown) nanoCUL433 (F-Band: 433MHz)
initString       X21
Hmmm, also da kann ich dann vermutlich auch nicht wesentlich weiterhelfen, hier gab es mal auch was ähnliches (ebenfalls ungelöst) beim MalpeCUN: https://forum.fhem.de/index.php/topic,60458.msg908223.html#msg908223.
Vielleicht nimmst du SlowRF noch in den Thread-Titel auf, dann werden nicht andere auf die falsche Fährte (VCCU/Homematic) gelenkt und die SlowRF-Leute kommen eher da drauf (verschieben hilft evtl. auch, wenn sich hier länger keiner melden sollte). (Titel ändern kannst (fast nur) du selbst).
