(Gelöst] 2 CUL's + 1 JeeLInk Fhem funktioniert auf einmal nicht mehr richtig
Begonnen von Gueco315, 22 September 2019, 10:17:05
Gueco315
Also, ich hatte am Raspi überhaupt nichts geändert, im Log fand ich nur das hier:
2019.09.22 08:35:07 3: CUL_HM set Rollo_Wzlinks on
2019.09.22 08:35:07 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_1)
2019.09.22 08:35:08 1: /dev/ttyACM0 reappeared (CUL_1)
2019.09.22 08:35:12 3: CUL_HM set Rollo_Hausarbeit on
2019.09.22 08:35:15 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_1)
2019.09.22 08:35:16 1: /dev/ttyACM0 reappeared (CUL_1)
2019.09.22 08:35:17 3: CUL_HM set Rollo_SZ on
2019.09.22 08:49:57 3: CUL_HM set Zirkulation on-for-timer 180
2019.09.22 08:51:37 3: CUL_HM set Zirkulation on-for-timer 180
2019.09.22 08:59:47 3: CUL_HM set Zirkulation on-for-timer 180
2019.09.22 09:00:30 3: CUL_HM set Rollo_Erker on
2019.09.22 09:00:31 3: CUL_HM set Rollo_WC on
2019.09.22 09:00:31 3: CUL_HM set Rollo_Kueche on
2019.09.22 09:00:31 3: CUL_HM set Rollo_Buero on
2019.09.22 09:00:31 3: CUL_HM set Rollo_ErkerL on
2019.09.22 09:00:31 3: CUL_HM set Rollo_ErkerM on
2019.09.22 09:00:32 3: CUL_HM set Rollo_ErkerR on
2019.09.22 09:00:32 1: Perfmon: possible freeze starting at 09:00:31, delay is 1.03
2019.09.22 09:00:33 3: CUL_HM set Rollo_Hausarbeit on
2019.09.22 09:00:33 3: CUL_HM set Rollo_SZ on
2019.09.22 09:00:34 3: CUL_HM set Rollo_Wzrechts on
2019.09.22 09:00:35 3: CUL_HM set Rollo_Wzlinks on
2019.09.22 09:00:44 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_1)
2019.09.22 09:00:44 1: /dev/ttyACM0 reappeared (CUL_1)
2019.09.22 09:00:52 1: Perfmon: possible freeze starting at 09:00:51, delay is 1.004
2019.09.22 09:00:53 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_1)
2019.09.22 09:02:13 1: Perfmon: possible freeze starting at 09:02:09, delay is 4.294
2019.09.22 09:02:17 1: Perfmon: possible freeze starting at 09:02:14, delay is 3.79
Ein Reboot brachte nichts.
Was könnte denn die Ursache für das disconnecten sein?
Danach habe ich auf by-Path, wie von KölnSolar empfohlen, umgestellt.
Hier die Lists:
   CMDS       ABbCeFGhiKkLlMmNRTtUuVWXxYZ
   CUL_1_MSGCNT 166
   CUL_1_TIME 2019-09-23 10:30:39
   Clients    :CUL_HM:HMS:CUL_IR:STACKABLE_CC:TSSTACKED:STACKABLE:
   DEF        /dev/serial/by-path/platform-3f980000.usb-usb-0:1.2:1.0@9600 1034
   DeviceName /dev/serial/by-path/platform-3f980000.usb-usb-0:1.2:1.0@9600
   FD         11
   FHTID      1034
   FUUID      5c8a0353-f33f-940c-eca1-4155e0498d7e2017
   NAME       CUL_1
   NR         40
   NR_CMD_LAST_H 6
   PARTIAL
   RAWMSG     A0F5A86106392520000000A24B60C00401F
   RSSI       -58.5
   STATE      Initialized
   TYPE       CUL
   VERSION    V 1.67 CUL868
   initString X21
Ar
   MatchList:
     1:CUL_HM   ^A....................
     8:HMS      ^810e04....(1|5|9).a001
     D:CUL_IR   ^I............
     H:STACKABLE_CC ^\*
     M:TSSTACKED ^\*
     N:STACKABLE ^\*
     2019-09-23 10:22:37   cmds             A B b C e F G h i K k L l M m N R T t U u V W X x Y Z
     2019-09-23 10:30:39   state           Initialized
   XMIT_TIME:
     1569227055.07971
     1569227055.44367
     1569227055.8794
     1569227056.72996
     1569227057.83413
     1569227059.23046
   helper:
     185359:
       QUEUE:
     2CCEFB:
       QUEUE:
     3B6140:
       QUEUE:
     402435:
       QUEUE:
     40BB51:
       QUEUE:
     40EDE6:
       QUEUE:
     44D03A:
       QUEUE:
     455152:
       QUEUE:
     4E426C:
       QUEUE:
     52BCF3:
       QUEUE:
     5338A9:
       QUEUE:
     54A908:
       QUEUE:
     56EB42:
       QUEUE:
     56EB7A:
       QUEUE:
     581404:
       QUEUE:
     5E8757:
       QUEUE:
     6686ED:
       QUEUE:
     6686F1:
       QUEUE:
     688E7A:
       QUEUE:
   hmId       FF2345
   model      CUL
   rfmode     HomeMatic
   room       CUL_HM
   verbose    1
   CUL_0_MSGCNT 87
   CUL_0_TIME 2019-09-23 10:31:47
   DEF        /dev/serial/by-path/platform-3f980000.usb-usb-0:1.5:1.0@9600 1134
   DeviceName /dev/serial/by-path/platform-3f980000.usb-usb-0:1.5:1.0@9600
   FD         10
   FHTID      1134
   FUUID      5c8a0353-f33f-940c-c858-45b904072635b8e0
   NAME       CUL_0
   NR         36
   PARTIAL
   RAWMSG     A0FD286104DAC740000000A24CA0E004029
   RSSI       -53.5
   STATE      Initialized
   TYPE       CUL
   initString X21
Ar
   MatchList:
     H:STACKABLE_CC ^\*
     M:TSSTACKED ^\*
     N:STACKABLE ^\*
     2019-09-23 10:13:29   cmds             A B b C e F G h i K k L l M m N R T t U u V W X x Y Z
     2019-09-23 08:00:00   raw             No answer
     2019-09-23 10:31:47   state           Initialized
   model      CUL
   rfmode     HomeMatic
   room       CUL_HM
und der JeeLInk. Der geht auf einmal auch überhaupt nicht mehr, ist auch vom Raspi abgezogen...
   Clients    :PCA301:EC3000:RoomNode:LaCrosse:ETH200comfort:CUL_IR:HX2272:FS20:AliRF:Level:EMT7110:KeyValueProtocol
   DEF        /dev/ttyUSB0@57600
   DeviceName /dev/ttyUSB0@57600
   FUUID      5c8a035b-f33f-940c-52ff-e31d34f96a9d0cf2
   NAME       myJeeLink
   NR         535
   NR_CMD_LAST_H 3
   PARTIAL
   STATE      disconnected
   TYPE       JeeLink
   initMessages
   model      LaCrosseITPlusReader.10.1s
   settings   (RFM12B f:868300 t:30~5)
   MatchList:
     1:PCA301   ^\S+\s+24
     2:EC3000   ^\S+\s+22
     3:RoomNode ^\S+\s+11
     4:LaCrosse ^(\S+\s+9 |OK\sWS\s)
     5:AliRF    ^\S+\s+5
     6:EMT7110  ^OK\sEMT7110\s
     7:KeyValueProtocol ^OK\sVALUES\s
     2019-09-23 10:20:44   state           disconnected
   XMIT_TIME:
     1569226931.04179
     1569226936.16047
     1569226937.83382
   flashCommand avrdude -p atmega328P -c arduino -P [PORT] -D -U flash:w:[HEXFILE] 2>[LOGFILE]
   initCommands 30t 5m v
   room       CUL_HM
Kann es sein, dass ein Aktor wie wild funkt und den / die CUL'a blockiert? Das hatte ich schon einmal
Fhem 6.0, JeeLink, CUL 868 auf Raspi 4, Buster, IT-1500, 4x SB_Player, Squeezebox auf Raspi 4, 3x Fritzbox,  WIFI Light, EGPM2LAN, ENIGMA, Sec-SCO,CC-RT-DN,TC-IT-WM-W-EU,SEN-Wa-Od,ES-PMSw1-PW,HM-SE, Sonoff, Shelly,SMA
Stell mal bitte die beiden CUL wieder auf die "ttyACMx"-Variante um (das sind zwei 868-er, da ist es m.E. egal, wenn die sich vertauschen....) und den Jeelink auf "by-id".
Dann klemme einen aktiven USB-Hub dazwischen. Ist evtl. ein Stromversorgungsthema.
Ansonsten könnte es auch ein Hardwaredefekt an einem der CUL sein. Nutzt du den auch für's Senden @433MHz (seit längerem und ständig?)? Dann könnte der EEPROM am CC1101 hinüber sein.
Gueco315
Hallo Beta-User,
Umstellung wie beschrieben gemacht.
Immer noch sehr viele IOerr und Missing Acks. Befehle kommen nur sehr sporadisch durch. Ging ja schon mal alles problemlos.
Was auffällig ist, der Jeelink funkte immer Blau, das hat er mittlerweile ganz eingestellt. Kann es nicht am Pi liegen??
AKtiv Hub muss ich erst noch  besorgen ..
Gueco315
Lösung gefunden: Ein Aktor war auf Dauersendung!!!!!!!!!!!!!!!!!!!
Meine Erfahrung daraus, Logging auf Verbose 5 setzen sollte man im 2. Schritt.
Im ersten Schritt unbeidingt erst einmal auf den EventMonitor schauen, das hatte ich leider nicht gemacht.
Hier ist mir ganz schnell aufgefallen, das folgende Fehlermeldung erschienen ist: CUL ERR:CCA
Das hatte ich schon einmal, da muss man sich halt auf die Suche machen. Ich gehe dann Stockwerkweise vor, schalte die Unterverteilung stromlos und dann bei allen Aktoren mit Batterie, die Batterien rausnehmen. Immer wieder mal testen ob Besserung eingetreten ist. Zum Glück bin ich im DG gleich fündig geworden, und jetzt gehen wieder beide CUL's und der Jeelink.
Danke euch für die Unterstützung!
Gruß Günter
