[abgelaufen] Sammelbestellung eBus Adapter V2.2 Herbst 2019
Begonnen von Reinhart, 04 Oktober 2019, 18:17:23
BratwurstHH
ich bin etwas verwirrt... was ist denn noch verfügbar? Alles verkauft?
Danke!
PeMue
Reinhart
Danke!
warum bis du verwirrt, steht doch überall dabei "ausverkauft"!
FHEM auf Raspy5 mit Bullseye + SSD, Homematic, ESP8266, ESP32, Sonoff, eBus, NanoCUL, MapleCUL, , MQTT2, Alexa
BratwurstHH
Z.B. weil unter "Bausatz Basis + Erweiterung  (34.- € inkl Porto EU)" noch 4 Slots frei sind.
Hast du einen Tipp wo ich irgendeinen Adapter herbekommen kann?
darekpawel
#140
Zitat von: PeMue am 05 November 2019, 16:54:06
USR-TCP232-T2 should work, please adjust in advance the desired baud rate and port with the tool from USRIOT.
Regards Peter
O.K. I'll follow that 1st... Which tool/software you mean? As there are few to download:
https://www.usriot.com/support/downloads/application-software/
Maybe this one? -> [USR-TCP-Test] USR-TCP232-Test-V1.3
Or this? -> [Setup Software] USR-TCP232-T24-V5.1.1.20.exe
chons
#141
Hello,
Regards Peter
That's not correct Peter, we did a lot of tests with different LAN Adapters like USR-TCP232-T2, USR-K2 and USR-K3 with the result that there are not applicable with our eBus Adapter because of high interrupt latency, so there are no LAN Interface that will be supported at the moment.
Please use "only" supportet Interfaces otherwise you get trouble wit the eBus Adapter.
PeMue
#142
Hello chons,
thanks for the correction, I did not know, that latency is a problem with eBus.
Regards Peter
darekpawel
Dear - it is still not clear for me... So the 'eBus' module works great with 'ESP8266'; but there is NO 'Ethernet' equivalent?
In case someone wants to have wired connection...
john30
unfortunately that's how it is, because we couldn't find a very low latency serial-ethernet bridge so far. that's why ebusd-esp was developed initially: to get the lowest possible latency
author of ebusd
Reinhart
@darekpawel
The eBus protocol is very sensitive to latency!
The best variant is Raspberry Pi with the serial driver "ttyebus". The second variant is a UART (cp2102) and the third variant is a Wemos with the software "ebusd-esp".
You can see here and here is the scheme with the three variants!
Reinhart
Ja, die oben erwähnten Bausätze sind für die Solo Platinen von John gewesen, die sind zwar komplett aber ohne Platinen!
Warte noch etwas, wir sind gerade beim diskutieren ob wir nicht doch eine Verlängerung durchführen wollen!
Schaue einfach öfters in den Thread herein!
Reinhart
darekpawel
Reinhart
#148
Sammelbestellung verlängert!
Wir haben uns intern abgesprochen und Aufgrund der extrem hohen Nachfrage werden wir eine erneute Sammelbestellung des RPI Adapters durchführen!
Nochmals zur Aufklärung, am RPI Adapter könnt ihr auch einen Wemos/Uart anschließen und "Stand alone" betreiben (ohne Raspberry) , aber eine Erweiterungsplatine (für zusätzliche Features wie Displays etc.) kann nur an der Basisplatine und nicht an der RPI-Platine angeschlossen werden. Der I2C Anschluß ist aber auch an der RPI Platine vorhanden!
Die Platinen sind bestellt, aber es wird nach unserer Schätzung bis in die ersten Dezemberwochen dauern bevor wir wieder ausliefern können!
Bei Interesse bitte im Bestellthread posten und einen Adapter reservieren!
John hat ebenfalls schon angekündigt Basis + Erweiterungsplatinen anzubieten!
Reinhart
