HMCCU 5.0 Beta verfügbar
Begonnen von zap, 05 Januar 2020, 19:49:52
Maista
OK.
Dazu muss ich an den PC. Dauert noch ein paar Minuten.
Das HF-Modul taucht ebenfalls in der Liste auf.
Aber keine Ahnung ob es dazu sinnvolle Daten zum Anzeigen gibt.
Ich musste dann unterbrechen.
Sind dann Irish Pub essen gegangen ;)
Danke und Gruß
Gerd
Maista
Wetterstation zum Abgleich:
DEV HmIP-SWO-PR 00185BE9A57631 00185BE9A57631 interface=HmIP-RF type=HmIP-SWO-PR
CHN 00185BE9A57631:0 HmIP-SWO-PR 00185BE9A57631:0
   0.CONFIG_PENDING = false {b} [RE]
   0.DUTY_CYCLE = false {b} [RE]
   0.ERROR_CODE = 192 {n} [RE]
   0.ERROR_WIND_COMMUNICATION = true {b} [RE]
   0.ERROR_WIND_NORTH = true {b} [RE]
   0.INSTALL_TEST = true {b} [RW]
   0.LOW_BAT = false {b} [RE]
   0.RSSI_DEVICE = 202 {n} [RE]
   0.RSSI_PEER = 0 {n} [RE]
   0.TEMPERATURE_OUT_OF_RANGE = false {b} [RE]
   0.UNREACH = false {b} [RE]
   0.UPDATE_PENDING = false {b} [RE]
CHN 00185BE9A57631:1 HmIP-SWO-PR 00185BE9A57631:1
   1.ACTUAL_TEMPERATURE = 21.800000 {f} [RE]
   1.ACTUAL_TEMPERATURE_STATUS = 0 {i} [RE]
   1.HUMIDITY = 55 {i} [RE]
   1.HUMIDITY_STATUS = 0 {i} [RE]
   1.ILLUMINATION = 197.300000 {f} [RE]
   1.ILLUMINATION_STATUS = 0 {i} [RE]
   1.RAINING = false {b} [RE]
   1.RAIN_COUNTER = 2.400000 {f} [RE]
   1.RAIN_COUNTER_OVERFLOW = false {b} [RE]
   1.RAIN_COUNTER_STATUS = 0 {i} [RE]
   1.SUNSHINEDURATION = 6 {i} [RE]
   1.SUNSHINEDURATION_OVERFLOW = false {b} [RE]
   1.SUNSHINE_THRESHOLD_OVERRUN = false {b} [RE]
   1.WIND_DIR =  {f} [RE]
   1.WIND_DIR_RANGE =  {f} [RE]
   1.WIND_DIR_RANGE_STATUS = 1 {i} [RE]
   1.WIND_DIR_STATUS = 1 {i} [RE]
   1.WIND_SPEED = 0.000000 {f} [RE]
   1.WIND_SPEED_STATUS = 0 {i} [RE]
   1.WIND_THRESHOLD_OVERRUN = false {b} [RE]
   svHmIPSunshineCounterYesterday_1609 = 0.000000 {f} [RWE]
   svHmIPSunshineCounterToday_1609 = 6.000000 {f} [RWE]
   svHmIPRainCounterYesterday_1609 = 1.200000 {f} [RWE]
   svHmIPRainCounterToday_1609 = 1.200000 {f} [RWE]
Device detection:
No state datapoint detected
No control datapoint detected
Failed to detect device settings. Device must be configured manually.
Current state datapoint = .
Current control datapoint = .
Device description
Device 00185BE9A57631 HmIP-SWO-PR 00185BE9A57631 [HmIP-SWO-PR]
  AES_ACTIVE: 1
  AVAILABLE_FIRMWARE: 0.0.0
  CHILDREN: 00185BE9A57631:0,00185BE9A57631:1,00185BE9A57631:2,00185BE9A57631:3,00185BE9A57631:4,00185BE9A57631:5,00185BE9A57631:6,00185BE9A57631:7,00185BE9A57631:8
  DIRECTION: NONE
  FIRMWARE: 1.0.18
  FIRMWARE_UPDATE_STATE: UP_TO_DATE
  FLAGS: Visible
  PARAMSETS: MASTER,SERVICE
  RF_ADDRESS: 3622484
  ROAMING: 0
  RX_MODE: CONFIG
  SUBTYPE: SWO-PR
  UPDATABLE: 1
Channel 00185BE9A57631:0 HmIP-SWO-PR 00185BE9A57631:0 [MAINTENANCE]
  AES_ACTIVE: 1
  DIRECTION: NONE
  FLAGS: Visible
  PARAMSETS: MASTER,VALUES,SERVICE
  PARENT: 00185BE9A57631
  PARENT_TYPE: HmIP-SWO-PR
  RF_ADDRESS: 0
  ROAMING: 0
  RX_MODE:
  UPDATABLE: 1
Channel 00185BE9A57631:1 HmIP-SWO-PR 00185BE9A57631:1 [WEATHER_TRANSMIT] known
  AES_ACTIVE: 1
  DIRECTION: NONE
  FLAGS: Visible
  RF_ADDRESS: 0
  ROAMING: 0
  RX_MODE:
  UPDATABLE: 1
Channel 00185BE9A57631:2 HmIP-SWO-PR 00185BE9A57631:2 [COND_SWITCH_TRANSMITTER_WIND_SPEED]
  AES_ACTIVE: 1
  DIRECTION: SENDER
  FLAGS: Visible
  LINK_SOURCE_ROLES: CONDITIONAL_SWITCH
  PARAMSETS: MASTER,VALUES,LINK,SERVICE
  RF_ADDRESS: 0
  ROAMING: 0
  RX_MODE:
  UPDATABLE: 1
Channel 00185BE9A57631:3 HmIP-SWO-PR 00185BE9A57631:3 [COND_SWITCH_TRANSMITTER_TEMPERATURE]
  AES_ACTIVE: 1
  DIRECTION: SENDER
  FLAGS: Visible
  RF_ADDRESS: 0
  ROAMING: 0
  RX_MODE:
  UPDATABLE: 1
Channel 00185BE9A57631:4 HmIP-SWO-PR 00185BE9A57631:4 [COND_SWITCH_TRANSMITTER_HUMIDITY]
  AES_ACTIVE: 1
  DIRECTION: SENDER
  FLAGS: Visible
  RF_ADDRESS: 0
  ROAMING: 0
  RX_MODE:
  UPDATABLE: 1
Channel 00185BE9A57631:5 HmIP-SWO-PR 00185BE9A57631:5 [COND_SWITCH_TRANSMITTER_BRIGHTNESS]
  AES_ACTIVE: 1
  DIRECTION: SENDER
  FLAGS: Visible
  RF_ADDRESS: 0
  ROAMING: 0
  RX_MODE:
  UPDATABLE: 1
Channel 00185BE9A57631:6 HmIP-SWO-PR 00185BE9A57631:6 [COND_SWITCH_TRANSMITTER_RAIN_QUANTITY]
  AES_ACTIVE: 1
  DIRECTION: SENDER
  FLAGS: Visible
  RF_ADDRESS: 0
  ROAMING: 0
  RX_MODE:
  UPDATABLE: 1
Channel 00185BE9A57631:7 HmIP-SWO-PR 00185BE9A57631:7 [COND_SWITCH_TRANSMITTER_RAIN_DROP]
  AES_ACTIVE: 1
  DIRECTION: SENDER
  FLAGS: Visible
  RF_ADDRESS: 0
  ROAMING: 0
  RX_MODE:
  UPDATABLE: 1
Channel 00185BE9A57631:8 HmIP-SWO-PR 00185BE9A57631:8 [COND_SWITCH_TRANSMITTER_WIND_DIRECTION]
  AES_ACTIVE: 1
  DIRECTION: SENDER
  FLAGS: Visible
  RF_ADDRESS: 0
  ROAMING: 0
  RX_MODE:
  UPDATABLE: 1
Defaults
Support for role(s) WEATHER_TRANSMIT of device type HmIP-SWO-PR is built in.
Der Windrichtungszeiger ist noch nicht kalibriert und aufgesetzt.
Taster HM-PB-2-WM55-2:
DEV HM-PB-2-WM55-2 LTK0043889 LTK0043889 interface=BidCos-RF type=HM-PB-2-WM55-2
CHN LTK0043889:0 HM-PB-2-WM55-2 LTK0043889:0
   0.STICKY_UNREACH = false {b} [RWE]
   0.LOWBAT = false {b} [RE]
   0.RSSI_DEVICE = 1 {n} [RE]
   0.RSSI_PEER = 203 {n} [RE]
   0.AES_KEY = 0 {n} [R]
CHN LTK0043889:1 HM-PB-2-WM55-2 LTK0043889:1
   1.PRESS_SHORT = false {b} [WE]
   1.PRESS_LONG = false {b} [WE]
   1.INSTALL_TEST = false {b} [E]
   1.PRESS_CONT =  {b} [E]
   1.PRESS_LONG_RELEASE = false {b} [E]
CHN LTK0043889:2 HM-PB-2-WM55-2 LTK0043889:2
   2.PRESS_SHORT = false {b} [WE]
   2.PRESS_LONG =  {b} [WE]
   2.INSTALL_TEST = false {b} [E]
   2.PRESS_CONT =  {b} [E]
   2.PRESS_LONG_RELEASE =  {b} [E]
Device detection:
StateDatapoint = 1.PRESS_SHORT [KEY]
StateDatapoint = 2.PRESS_SHORT [KEY]
ControlDatapoint = 1.PRESS_SHORT [KEY]
ControlDatapoint = 2.PRESS_SHORT [KEY]
Recommended module for device definition: HMCCUCHN
Current state datapoint = 1.PRESS_SHORT
Current control datapoint = 1.PRESS_SHORT
Device description
Device LTK0043889 HM-PB-2-WM55-2 LTK0043889 [HM-PB-2-WM55-2]
  CHILDREN: LTK0043889:0,LTK0043889:1,LTK0043889:2
  FIRMWARE: 1.4
  FLAGS: Visible
  INTERFACE: QEQ0683445
  PARAMSETS: MASTER
  RF_ADDRESS: 2940399
  ROAMING: 0
  RX_MODE: LAZY_CONFIG,BURST
  UPDATABLE: 0
Channel LTK0043889:0 HM-PB-2-WM55-2 LTK0043889:0 [MAINTENANCE]
  AES_ACTIVE: 0
  DIRECTION: NONE
  FLAGS: Visible,Internal
  PARENT: LTK0043889
  PARENT_TYPE: HM-PB-2-WM55-2
Channel LTK0043889:1 HM-PB-2-WM55-2 LTK0043889:1 [KEY] known
  AES_ACTIVE: 1
  DIRECTION: SENDER
  FLAGS: Visible
  GROUP: LTK0043889:2
  LINK_SOURCE_ROLES: KEYMATIC,REMOTECONTROL_RECEIVER,SWITCH,WINMATIC
  PARAMSETS: LINK,MASTER,VALUES
  PARENT: LTK0043889
Channel LTK0043889:2 HM-PB-2-WM55-2 LTK0043889:2 [KEY] known
  AES_ACTIVE: 1
  DIRECTION: SENDER
  FLAGS: Visible
  GROUP: LTK0043889:1
  PARENT: LTK0043889
Defaults
Support for role KEY of device type HM-PB-2-WM55-2 is built in.
HF-Modul RPI-RF-MOD:
DEV RPI-RF-MOD 001F5A4993D5B5 001F5A4993D5B5 interface=HmIP-RF type=RPI-RF-MOD
CHN 001F5A4993D5B5:0 RPI-RF-MOD 001F5A4993D5B5:0
   0.CARRIER_SENSE_LEVEL = 0.000000 {f} [RE]
   0.DUTY_CYCLE_LEVEL = 1.000000 {f} [RE]
   0.INCLUSION_UNSUPPORTED_DEVICE =  {s} [RE]
Device detection:
Device description
Device 001F5A4993D5B5 RPI-RF-MOD 001F5A4993D5B5 [RPI-RF-MOD]
  AES_ACTIVE: 1
  CHILDREN: 001F5A4993D5B5:0
  DIRECTION: NONE
  FIRMWARE: 4.2.14
  FLAGS: Visible,DontDelete
  RF_ADDRESS: 12114978
  ROAMING: 0
  RX_MODE:
  SUBTYPE: CCU
  UPDATABLE: 1
Channel 001F5A4993D5B5:0 RPI-RF-MOD 001F5A4993D5B5:0 [MAINTENANCE]
  AES_ACTIVE: 1
  DIRECTION: NONE
  FLAGS: Visible
  PARENT: 001F5A4993D5B5
  PARENT_TYPE: RPI-RF-MOD
  RF_ADDRESS: 0
  ROAMING: 0
  RX_MODE:
  UPDATABLE: 1
Defaults
Hier wird es wohl nichts verwertbares geben ?!
Danke und
Schönes Wochenende
Gerd
zap
#572
@Maista:
Wetterstation sollte nach dem nächsten Update automatisch erkannt werden.
Warum der HM-PB-2-WM55-2 nicht funktioniert, ist mir ein Rätsel. Laut der Ausgabe von get deviceinfo erkennt HMCCU das Gerät bzw. die Rolle "KEY". Der Befehl "get createDev" müsste eigentlich 2 HMCCUCHN Devices (je 1 für die beiden Schaltkanäle) anlegen.
Gibt es im fhem log Fehlermeldungen, wenn Du get createDev für dieses Gerät ausführst?
Maista
Hallo zap,
Teil1.
die Versuche mit dem Update und erzeugen mache ich gleich.
Mir ist jetzt aber aufgefallen das sich mein LOG füllt!
Zitat2021.07.05 20:47:37 4: HMCCURPCPROC [d_rpc178040BidCos_RF] RPC server CB2001178049178040 accepting connections
2021.07.05 20:47:37 4: HMCCURPCPROC [d_rpc178040HmIP_RF] RPC server CB2010178049178040 accepting connections
2021.07.05 20:47:38 4: HMCCURPCPROC [d_rpc178040BidCos_RF] RPC server CB2001178049178040 accepting connections
2021.07.05 20:47:38 4: HMCCURPCPROC [d_rpc178040HmIP_RF] RPC server CB2010178049178040 accepting connections
2021.07.05 20:47:39 4: HMCCURPCPROC [d_rpc178040BidCos_RF] RPC server CB2001178049178040 accepting connections
2021.07.05 20:47:39 4: HMCCURPCPROC [d_rpc178040HmIP_RF] RPC server CB2010178049178040 accepting connections
2021.07.05 20:47:40 4: HMCCURPCPROC [d_rpc178040BidCos_RF] RPC server CB2001178049178040 accepting connections
2021.07.05 20:47:40 4: HMCCURPCPROC [d_rpc178040HmIP_RF] RPC server CB2010178049178040 accepting connections
2021.07.05 20:47:41 4: HMCCURPCPROC [d_rpc178040BidCos_RF] RPC server CB2001178049178040 accepting connections
2021.07.05 20:47:41 4: HMCCURPCPROC [d_rpc178040HmIP_RF] RPC server CB2010178049178040 accepting connections
2021.07.05 20:47:42 4: HMCCURPCPROC [d_rpc178040BidCos_RF] RPC server CB2001178049178040 accepting connections
2021.07.05 20:47:42 4: HMCCURPCPROC [d_rpc178040HmIP_RF] RPC server CB2010178049178040 accepting connections
2021.07.05 20:47:43 4: HMCCURPCPROC [d_rpc178040BidCos_RF] RPC server CB2001178049178040 accepting connections
2021.07.05 20:47:43 4: HMCCURPCPROC [d_rpc178040HmIP_RF] RPC server CB2010178049178040 accepting connections
2021.07.05 20:47:44 4: HMCCURPCPROC [d_rpc178040BidCos_RF] RPC server CB2001178049178040 accepting connections
2021.07.05 20:47:44 4: HMCCURPCPROC [d_rpc178040HmIP_RF] RPC server CB2010178049178040 accepting connections
2021.07.05 20:47:45 4: HMCCURPCPROC [d_rpc178040BidCos_RF] RPC server CB2001178049178040 accepting connections
2021.07.05 20:47:45 4: HMCCURPCPROC [d_rpc178040HmIP_RF] RPC server CB2010178049178040 accepting connections
2021.07.05 20:47:46 4: HMCCURPCPROC [d_rpc178040BidCos_RF] RPC server CB2001178049178040 accepting connections
2021.07.05 20:47:46 4: HMCCURPCPROC [d_rpc178040HmIP_RF] RPC server CB2010178049178040 accepting connections
Ich habe aber jetzt schon bei HMCCU und beiden HMCCURPCPROC Devices das Verbose auf 0 gesetzt. Das wird aber weiter erzeugt.
Ist das noch ein Rest Log den Du vergessen hast zu deaktivieren?
Gruss Gerd
zap
Bei verbose=4 ist das normal. Du musst die RPC Server stoppen und wieder starten. Das sind separate Prozesse. Die "erben" die Einstellungen vom FHEM Hauptprozess beim Start. Eine spätere Änderung von Attributen wird erst beim erneuten Start der RPC Server aktiv.
Für die HMCCURPCPROC Devices ist verbose = 2 vollkommen ausreichend.
Maista
Ok...
das Update liegt auf dem SVN?
Im Kopf des Moduls wurde das Datum aber nicht geändert.
Kann das sein?
Mit update all https://svn.fhem.de/trac/browser/trunk/fhem/contrib/HMCCU/controls_HMCCU.txt wird nichts geladen  :o
Maista
Okay, hat geklappt. Das Log war zwischenzeitlich 39MB gross ;)
Jetzt versuch ich mich am Update.
Das 88_HMCCUDEV.pm von heute habe ich runter geladen und spiele das jetzt ein.
Kam ja nix per Update.
Dann schaue ich ob er die Wetterstation erzeugt und was für eine Meldung beim erstellen des Taster kommt.
Maista
Mit der alten Version (wie gestern installiert) kommt folgendes beim Anlegen des Tasters:
Zitat2021.07.05 21:11:29 2: HMCCU [d_ccu] Define command failed HM_PB_2_WM55_2 LTK0043889_2 HMCCUCHN LTK0043889:2. Unknown module LTK0043889_2
2021.07.05 21:11:29 2: HMCCU [d_ccu] Define command failed HM_PB_2_WM55_2 LTK0043889_1 HMCCUCHN LTK0043889:1. Unknown module LTK0043889_1
HMCCU auf Verbose 5 , die zwei PROC auf Verbose 2.
Maista
#578
@zap,
wo steht die Aktualisierte Version?
Die Daten auf dem SVN sind gleich. Da hat sich nichts geändert?!
Hab die Dateien aus "trunk/fhem/contrib/HMCCU/FHEM@24703"
2021.07.05 21:23:34 1 : Downloading https://svn.fhem.de/trac/browser/trunk/fhem/contrib/HMCCU/controls_HMCCU.txt
2021.07.05 21:23:48 1 : backup tar: Entferne führende ,,/" von Elementnamen tar: Entferne führende ,,/" von Zielen harter Verknüpfungen
2021.07.05 21:23:48 1 : backup done: FHEM-20210705_212334.tar.gz (37018101 Bytes)
2021.07.05 21:23:48 1 : nothing to do...
Im GIT steht auch nichts neues.
Maista
#579
@zap
HMCCU-Version ist immer noch die 4.4.069.
Nur der Taster "HM_PB_2_WM55_2" erzeugt ein Logeintrag.
2021.07.05 21:44:42 2: HMCCU [d_ccu] Define command failed HM_PB_2_WM55_2 LTK0043889_1 HMCCUCHN LTK0043889:1. Unknown module LTK0043889_1
2021.07.05 21:44:42 2: HMCCU [d_ccu] Define command failed HM_PB_2_WM55_2 LTK0043889_2 HMCCUCHN LTK0043889:2. Unknown module LTK0043889_2
Die "HmIP-SWO-PR" erzeugt kein Logeintrag ?!
Bin dann morgen Abend erst wieder am PC.
Timmäää
Zap schrieb, dass es mit dem nächsten Update komme, du musst dich halt gedulden und auf das nächste Update warten. Wenn du nicht warten willst, zieh dir den aktuellen Stand doch einfach aus github und dann nicht aus dem Master branch sondern dem rc7 branch.
update all https://raw.githubusercontent.com/zapccu/HMCCU/RC7/controls_HMCCU.txt
zap
Eher nicht. RC7 hat einen üblen Bug.
zap
Zitat von: Maista am 05 Juli 2021, 21:46:53
@zap
Du hast noch einen Bug gefunden. Problem ist das Leerzeichen im Kanalnamen.
misux
#583
Zitat von: Jamo am 04 März 2021, 07:40:00
Ja, Du kannst aber "attr global exclude_from_update 88_HMCCURPCPROC.pm 88_HMCCUCHN.pm 88_HMCCUDEV.pm 88_HMCCU.pm 88_HMCCURPC.pm HMCCUConf.pm " setzen, damit verhinderst Du das Du wieder auf die alte 4.3 version wechselst. Damit sind die module vom update ausgenommen.
Sobald zap ein update von 4.4 macht, musst Du das attribut dann aber wieder loeschen, damit Du die neueren Dateien lädts.
Hallo Leute!  Genau das hatte ich seit Langer Zeit drin bis heute... Habe es raus gelöscht weil ich irgendwo gelesen habe das es ein Update auf 4.4 schon gibt... Naja, irgendwie nicht so wirklich... Weil seit dem Update das ich heute gemacht habe steht wieder die Version 4.3 bei mir drin und alle meine Devices sind false...
hilfeeeeee  :'( habe echt ne menge Devices konfiguriert gehabt.. Wie bekomme ich das wieder hin?
Die Installation der 4.4 aus dem ersten Post funktioniert irgendwie nicht...
Wenn ich update all https://raw.githubusercontent.com/zapccu/HMCCU/master/controls_HMCCU.txt durchführen,  sagt fhem nothing to Do und bleibt bei 4.3...
Und das schlimmste ist das nun Nix mehr funktioniert bei mir! HIIILFEEE!  :'(
Danke!
misux
#584
Hat niemand eine Idee woran es liegen kann warum ich die 4.4 Beta nicht mehr installiert bekomme? Oder wie ich die aktuellste installieren muss...
Mit der 4.3er kann ich nicht Arbeiten weil alle Devices sen Status false bekommen haben und ich sie mit Fhem nicht ansprechen kann...
Hoffe jemand kann helfen.. .
Habe es nun selbst herausgefunden.. Oh mann... Hab mich selbst ausgetrickst...
Nachdem ich die Attribute rausgelöscht hatte und 4.3 installiert habe habe ich ja einen Neustart gemacht..  Da ich aber nach dem Löschen der Attribute nicht gespeichert habe waren diese wieder drin... Deshalb konnte ich nicht wieder updaten oder installieren...
Ajajajaj... Hat n bisschen gedauert bis ich auf die Idee gekommen bin da mal zu schauen..
Naja... Nun geht wieder alles und ich habe die 4.4.069
Puh... Nochmal gut gegangen..
