FHEMSync (Alternative zu FHEM2FHEM/RFHEM)
Begonnen von dominik, 18 März 2020, 21:55:46
Maista
Ja. Genau.
Nach dem Frühstück Versuch ich's wen ich Zeit bekomme ;)
Maista
Moin Dominik,
so, etwas verzögert Zeit bekommen ;)
Sollte man das machen:
   │      New patch version of npm available! 6.14.4 → 6.14.5       │
   │   Changelog: https://github.com/npm/cli/releases/tag/v6.14.5   │
   │               Run npm install -g npm to update!                │
Oder geht dann wieder etwas in die Hose ;)?
FHEMSync scheint nun wieder zu funktionieren, Danke Dir! ;D
[10.5.2020, 11:43:23] [MAIN   ] Starting FHEMSync version 2.8.1...
[10.5.2020, 11:43:23] [MAIN   ] Options: {"version":"2.8.1","fhem":true,"port":true,"webname":true,"auth":true,"device":true,"selfSignedCert":true}
[10.5.2020, 11:43:24] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:24] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: BMP180
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: FA_26_A2D984000007
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: FIRMATA
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: FI_26_A3D984001605
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: HI_28_A2D984001677
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: KH_28_FF5A50811605
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: KH_28_FF715C811603
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: KH_28_FF8E8C811603
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: KH_28_FF976C811605
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: KH_28_FFA45D811604
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: LI_28_A3D984001605
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: Luefter
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: NAFT.002
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: NAVOC.002
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: TA_28_736020050000
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: TA_28_FF313C4E0400
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: UKW_12V
[10.5.2020, 11:43:24] [MAIN   ] Monitoring remote device: UKW_ON
[10.5.2020, 11:43:25] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:25] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:26] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:26] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:27] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:27] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:28] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:28] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:29] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:29] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:30] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:30] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:31] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:31] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:32] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:32] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:33] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:33] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:34] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:34] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:35] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:35] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:36] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:36] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:37] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:37] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:38] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:38] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:39] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:39] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:40] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:40] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:41] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:41] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:42] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:42] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:43] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:43] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:44] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:44] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:45] [SLAVE1 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:45] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:45] [SLAVE1 ] longpoll end: retry in: 30000msec
[10.5.2020, 11:43:46] [SLAVE2 ] longpoll end: retry in: 200msec
[10.5.2020, 11:43:46] [SLAVE2 ] longpoll end: retry in: 30000msec
[10.5.2020, 11:44:15] [SLAVE1 ] longpoll end: retry in: 30000msec
[10.5.2020, 11:44:16] [SLAVE2 ] longpoll end: retry in: 30000msec
[10.5.2020, 11:44:46] [SLAVE2 ] longpoll end: retry in: 30000msec
[10.5.2020, 11:45:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[10.5.2020, 11:45:16] [SLAVE2 ] longpoll end: retry in: 30000msec
Im Log könnte eventuell bei [Main   ] die Slave-Nummer mit dabei stehen. Dann sieht man auch gleich zu welcher Sklave die Daten gehören.
Dann schauen wir nun was der Speicher sagt.
Schönen Sonntag wünsch ich.
Gruss Gerd
Maista
dominik
npm Update kannst du immer wieder machen. Diese Meldung kommt direkt von npm, das prueft automatisch bei jeder Ausfuehrung ob eine Aktualisierung vorliegt.
Das Log kann ich anpassen, damit dort klarer hervor kommt von welchem Slave das Device kommt.
fhempy -  https://github.com/fhempy/fhempy: GoogleCast, Tuya, UPnP, Ring, EQ3BT, Nespresso, Xiaomi, Spotify, Object Detection, ...
Kaffeespende: https://paypal.me/todominik
Maista
#214
Hallo Dominik
Leider gab es heute um 2 Uhr erneut Fehler
Bekomme das leider nicht via mobilfone hier rein kopiert >:(
Muß bis morgen warten... >:(
Maista
So, am PC geht das besser  ::)
[11.5.2020, 01:53:18] [MAIN   ] Monitoring remote device: FA_26_A2D984000007
[11.5.2020, 01:53:18] [MAIN   ] Monitoring remote device: FIRMATA
[11.5.2020, 01:53:19] [MAIN   ] Monitoring remote device: FI_26_A3D984001605
[11.5.2020, 01:53:19] [MAIN   ] Monitoring remote device: HI_28_A2D984001677
[11.5.2020, 01:53:19] [MAIN   ] Monitoring remote device: KH_28_FF5A50811605
[11.5.2020, 01:53:19] [MAIN   ] Monitoring remote device: KH_28_FF715C811603
[11.5.2020, 01:53:19] [MAIN   ] Monitoring remote device: KH_28_FF8E8C811603
[11.5.2020, 01:53:19] [MAIN   ] Monitoring remote device: KH_28_FF976C811605
[11.5.2020, 01:53:19] [MAIN   ] Monitoring remote device: KH_28_FFA45D811604
[11.5.2020, 01:53:19] [MAIN   ] Monitoring remote device: LI_28_A3D984001605
[11.5.2020, 01:53:19] [MAIN   ] Monitoring remote device: Luefter
[11.5.2020, 01:53:20] [MAIN   ] Monitoring remote device: NAFT.002
[11.5.2020, 01:53:20] [MAIN   ] Monitoring remote device: NAVOC.002
[11.5.2020, 01:53:20] [MAIN   ] Monitoring remote device: TA_28_736020050000
[11.5.2020, 01:53:20] [MAIN   ] Monitoring remote device: TA_28_FF313C4E0400
[11.5.2020, 01:53:20] [MAIN   ] Monitoring remote device: UKW_12V
[11.5.2020, 01:53:20] [MAIN   ] Monitoring remote device: UKW_ON
(node:2892) UnhandledPromiseRejectionWarning: RangeError: Maximum call stack size exceeded
    at Caseless.set (/usr/lib/node_modules/fhemsync/node_modules/caseless/index.js:11:20)
    at Request.resp.setHeader (/usr/lib/node_modules/fhemsync/node_modules/caseless/index.js:54:14)
    at Request.init (/usr/lib/node_modules/fhemsync/node_modules/request/request.js:387:10)
    at Request.RP$initInterceptor [as init] (/usr/lib/node_modules/fhemsync/node_modules/request-promise-core/configure/request2.js:45:29)
    at new Request (/usr/lib/node_modules/fhemsync/node_modules/request/request.js:127:8)
    at request (/usr/lib/node_modules/fhemsync/node_modules/request/index.js:53:10)
    at /usr/lib/node_modules/fhemsync/node_modules/request/index.js:100:12
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 3)
(node:2892) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    at Request.init (/usr/lib/node_modules/fhemsync/node_modules/request/request.js:290:10)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 4)
[11.5.2020, 01:53:42] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:53:43] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:54:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:54:13] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:54:27] [MAIN   ] Monitoring remote device: BMP180
[11.5.2020, 01:54:43] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:55:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:55:13] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:55:42] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:55:43] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:56:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:56:13] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:56:42] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:56:43] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:57:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:57:14] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:57:42] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:57:44] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:58:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:58:14] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:58:21] [MAIN   ] Monitoring remote device: FA_26_A2D984000007
[11.5.2020, 01:58:21] [MAIN   ] Monitoring remote device: FIRMATA
[11.5.2020, 01:58:21] [MAIN   ] Monitoring remote device: FI_26_A3D984001605
[11.5.2020, 01:58:21] [MAIN   ] Monitoring remote device: HI_28_A2D984001677
[11.5.2020, 01:58:21] [MAIN   ] Monitoring remote device: KH_28_FF5A50811605
[11.5.2020, 01:58:21] [MAIN   ] Monitoring remote device: KH_28_FF715C811603
[11.5.2020, 01:58:22] [MAIN   ] Monitoring remote device: KH_28_FF8E8C811603
[11.5.2020, 01:58:22] [MAIN   ] Monitoring remote device: KH_28_FF976C811605
[11.5.2020, 01:58:22] [MAIN   ] Monitoring remote device: KH_28_FFA45D811604
[11.5.2020, 01:58:22] [MAIN   ] Monitoring remote device: LI_28_A3D984001605
[11.5.2020, 01:58:22] [MAIN   ] Monitoring remote device: Luefter
[11.5.2020, 01:58:22] [MAIN   ] Monitoring remote device: NAFT.002
[11.5.2020, 01:58:22] [MAIN   ] Monitoring remote device: NAVOC.002
[11.5.2020, 01:58:22] [MAIN   ] Monitoring remote device: TA_28_736020050000
[11.5.2020, 01:58:22] [MAIN   ] Monitoring remote device: TA_28_FF313C4E0400
[11.5.2020, 01:58:23] [MAIN   ] Monitoring remote device: UKW_12V
[11.5.2020, 01:58:23] [MAIN   ] Monitoring remote device: UKW_ON
[11.5.2020, 01:58:42] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:58:44] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:59:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:59:14] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 01:59:27] [MAIN   ] Monitoring remote device: BMP180
[11.5.2020, 01:59:44] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:00:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:00:14] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:00:42] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:00:44] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:01:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:01:14] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:01:42] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:01:44] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:02:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:02:15] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:02:42] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:02:45] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:03:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:03:15] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:03:24] [MAIN   ] Monitoring remote device: FA_26_A2D984000007
[11.5.2020, 02:03:24] [MAIN   ] Monitoring remote device: FIRMATA
[11.5.2020, 02:03:24] [MAIN   ] Monitoring remote device: FI_26_A3D984001605
[11.5.2020, 02:03:24] [MAIN   ] Monitoring remote device: HI_28_A2D984001677
[11.5.2020, 02:03:24] [MAIN   ] Monitoring remote device: KH_28_FF5A50811605
[11.5.2020, 02:03:24] [MAIN   ] Monitoring remote device: KH_28_FF715C811603
[11.5.2020, 02:03:24] [MAIN   ] Monitoring remote device: KH_28_FF8E8C811603
[11.5.2020, 02:03:24] [MAIN   ] Monitoring remote device: KH_28_FF976C811605
[11.5.2020, 02:03:25] [MAIN   ] Monitoring remote device: KH_28_FFA45D811604
[11.5.2020, 02:03:25] [MAIN   ] Monitoring remote device: LI_28_A3D984001605
[11.5.2020, 02:03:25] [MAIN   ] Monitoring remote device: Luefter
[11.5.2020, 02:03:25] [MAIN   ] Monitoring remote device: NAFT.002
[11.5.2020, 02:03:25] [MAIN   ] Monitoring remote device: NAVOC.002
[11.5.2020, 02:03:25] [MAIN   ] Monitoring remote device: TA_28_736020050000
[11.5.2020, 02:03:25] [MAIN   ] Monitoring remote device: TA_28_FF313C4E0400
[11.5.2020, 02:03:25] [MAIN   ] Monitoring remote device: UKW_12V
[11.5.2020, 02:03:25] [MAIN   ] Monitoring remote device: UKW_ON
[11.5.2020, 02:03:42] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:03:45] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:04:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:04:15] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:04:28] [MAIN   ] Monitoring remote device: BMP180
[11.5.2020, 02:04:45] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:05:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:05:15] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:05:42] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:05:45] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:06:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:06:15] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:06:42] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:06:45] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:07:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:07:16] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:07:42] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:07:46] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:08:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:08:16] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:08:26] [MAIN   ] Monitoring remote device: FA_26_A2D984000007
[11.5.2020, 02:08:26] [MAIN   ] Monitoring remote device: FIRMATA
[11.5.2020, 02:08:26] [MAIN   ] Monitoring remote device: FI_26_A3D984001605
[11.5.2020, 02:08:26] [MAIN   ] Monitoring remote device: HI_28_A2D984001677
[11.5.2020, 02:08:27] [MAIN   ] Monitoring remote device: KH_28_FF5A50811605
[11.5.2020, 02:08:27] [MAIN   ] Monitoring remote device: KH_28_FF715C811603
[11.5.2020, 02:08:27] [MAIN   ] Monitoring remote device: KH_28_FF8E8C811603
[11.5.2020, 02:08:27] [MAIN   ] Monitoring remote device: KH_28_FF976C811605
[11.5.2020, 02:08:27] [MAIN   ] Monitoring remote device: KH_28_FFA45D811604
[11.5.2020, 02:08:27] [MAIN   ] Monitoring remote device: LI_28_A3D984001605
[11.5.2020, 02:08:27] [MAIN   ] Monitoring remote device: Luefter
[11.5.2020, 02:08:27] [MAIN   ] Monitoring remote device: NAFT.002
[11.5.2020, 02:08:27] [MAIN   ] Monitoring remote device: NAVOC.002
[11.5.2020, 02:08:28] [MAIN   ] Monitoring remote device: TA_28_736020050000
[11.5.2020, 02:08:28] [MAIN   ] Monitoring remote device: TA_28_FF313C4E0400
[11.5.2020, 02:08:28] [MAIN   ] Monitoring remote device: UKW_12V
[11.5.2020, 02:08:28] [MAIN   ] Monitoring remote device: UKW_ON
    at Request.init (/usr/lib/node_modules/fhemsync/node_modules/request/request.js:168:12)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 14)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 15)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 16)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 17)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 18)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 19)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 20)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 21)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 22)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 28)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 29)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 30)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 31)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 32)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 36)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 37)
(node:2892) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 38)
[11.5.2020, 02:08:42] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:08:46] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:09:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:09:16] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 02:09:28] [MASTER ] Failed to fetch devices: RangeError: Maximum call stack size exceeded
[11.5.2020, 02:09:28] [SLAVE2 ] Failed to fetch devices: RangeError: Maximum call stack size exceeded
[11.5.2020, 02:09:46] [SLAVE2 ] longpoll end: retry in: 30000msec
Nach restart im FHEMWEB:
[11.5.2020, 23:11:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[11.5.2020, 23:11:22] [SLAVE2 ] longpoll end: retry in: 30000msec
[11.5.2020, 23:11:35] [MAIN   ] Starting FHEMSync version 2.8.1...
[11.5.2020, 23:11:35] [MAIN   ] Options: {"version":"2.8.1","fhem":true,"port":true,"webname":true,"auth":true,"device":true,"selfSignedCert":true}
[11.5.2020, 23:11:36] [SLAVE1 ] longpoll end: retry in: 200msec
[11.5.2020, 23:11:36] [SLAVE2 ] longpoll end: retry in: 200msec
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: BMP180
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: FA_26_A2D984000007
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: FIRMATA
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: FI_26_A3D984001605
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: HI_28_A2D984001677
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: KH_28_FF5A50811605
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: KH_28_FF715C811603
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: KH_28_FF8E8C811603
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: KH_28_FF976C811605
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: KH_28_FFA45D811604
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: LI_28_A3D984001605
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: Luefter
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: NAFT.002
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: NAVOC.002
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: TA_28_736020050000
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: TA_28_FF313C4E0400
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: UKW_12V
[11.5.2020, 23:11:36] [MAIN   ] Monitoring remote device: UKW_ON
[code][12.5.2020, 13:21:12] [SLAVE1 ] longpoll end: retry in: 30000msec
[12.5.2020, 13:21:17] [SLAVE2 ] longpoll end: retry in: 30000msec
[12.5.2020, 13:21:23] [MAIN   ] Monitoring remote device: FA_26_A2D984000007
[12.5.2020, 13:21:23] [MAIN   ] Monitoring remote device: FIRMATA
[12.5.2020, 13:21:23] [MAIN   ] Monitoring remote device: FI_26_A3D984001605
[12.5.2020, 13:21:24] [MAIN   ] Monitoring remote device: HI_28_A2D984001677
[12.5.2020, 13:21:24] [MAIN   ] Monitoring remote device: KH_28_FF5A50811605
[12.5.2020, 13:21:24] [MAIN   ] Monitoring remote device: KH_28_FF715C811603
[12.5.2020, 13:21:24] [MAIN   ] Monitoring remote device: KH_28_FF8E8C811603
[12.5.2020, 13:21:24] [MAIN   ] Monitoring remote device: KH_28_FF976C811605
[12.5.2020, 13:21:24] [MAIN   ] Monitoring remote device: KH_28_FFA45D811604
[12.5.2020, 13:21:24] [MAIN   ] Monitoring remote device: LI_28_A3D984001605
[12.5.2020, 13:21:24] [MAIN   ] Monitoring remote device: Luefter
[12.5.2020, 13:21:24] [MAIN   ] Monitoring remote device: NAFT.002
[12.5.2020, 13:21:25] [MAIN   ] Monitoring remote device: NAVOC.002
[12.5.2020, 13:21:25] [MAIN   ] Monitoring remote device: TA_28_736020050000
[12.5.2020, 13:21:25] [MAIN   ] Monitoring remote device: TA_28_FF313C4E0400
[12.5.2020, 13:21:25] [MAIN   ] Monitoring remote device: UKW_12V
[12.5.2020, 13:21:25] [MAIN   ] Monitoring remote device: UKW_ON
(node:30527) UnhandledPromiseRejectionWarning: RangeError: Maximum call stack size exceeded
    at request (/usr/lib/node_modules/fhemsync/node_modules/request/index.js:47:16)
Maista
Aber das Forum hat scheinbar Probleme alles korrekt darzustellen.
Ich hänge die Logs als Dateien an.
Hab das gestern mehrfach versucht zu markieren und einzufügen aber da stand dann immer etwas anderes im kopierten drin.
FHEMSync hat es sich dann heute wieder erhängt.
Speicher sieht auch nicht schlecht aus. Siehe Bild.
Gruss Gerd
Edit: Logs entfernt und als Datei angehängt.
dominik
Das ist eigenartig. Nutzt du auth? Zumindest laut dem Source Code von request könnte der Fehler dort liegen.
dominik
Ich habe gerade eine Aenderung gemacht -> Version 2.8.2
Kannst du bitte kurzfristig pruefen ob die bei dir laeuft? Danke fuer deine ausgiebigen Tests!
Maista
 auth? Hm...
Meinst du basicauth?
Also nicht das ich wüsste.
Ich habe nur ein Passwort beim login.
Aber geht ja bisher.
Maista
Ja Laptop ist neben Couch an ;D
Danke ebenso
Maista
[12.5.2020, 20:41:27] [MAIN   ] Options: {"version":"2.8.2","fhem":true,"port":true,"webname":true,"auth":true,"device":true,"selfSignedCert":true}
[12.5.2020, 20:41:27] [SLAVE1 ] Failed to get CSRF-Token: StatusCodeError: 401 - undefined
[12.5.2020, 20:41:27] [SLAVE2 ] Failed to get CSRF-Token: StatusCodeError: 401 - undefined
[12.5.2020, 20:41:28] [SLAVE1 ] longpoll end: retry in: 200msec
[12.5.2020, 20:41:28] [SLAVE2 ] longpoll end: retry in: 200msec
[12.5.2020, 20:41:28] [SLAVE1 ] Failed to fetch devices: StatusCodeError: 401 - undefined
[12.5.2020, 20:41:28] [SLAVE2 ] Failed to fetch devices: StatusCodeError: 401 - undefined
dominik
dominik
Maista
[12.5.2020, 20:43:49] [SLAVE2 ] longpoll end: retry in: 30000msec
[12.5.2020, 20:57:47] [MAIN   ] Starting FHEMSync version 2.8.3...
[12.5.2020, 20:57:47] [MAIN   ] Options: {"version":"2.8.3","fhem":true,"port":true,"webname":true,"auth":true,"device":true,"selfSignedCert":true}
(node:15176) UnhandledPromiseRejectionWarning: TypeError: this.request is not a function
    at FHEM.execute (/usr/lib/node_modules/fhemsync/fhemsync.js:337:24)
    at FHEM.getFHEMSyncDevice (/usr/lib/node_modules/fhemsync/fhemsync.js:348:24)
    at main (/usr/lib/node_modules/fhemsync/fhemsync.js:489:41)
(node:15176) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
(node:15176) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
[12.5.2020, 20:58:08] [MAIN   ] Starting FHEMSync version 2.8.3...
[12.5.2020, 20:58:08] [MAIN   ] Options: {"version":"2.8.3","fhem":true,"port":true,"webname":true,"auth":true,"device":true,"selfSignedCert":true}
(node:15199) UnhandledPromiseRejectionWarning: TypeError: this.request is not a function
(node:15199) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
(node:15199) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
