Cannot load module allergy
Begonnen von en-trust, 20 April 2020, 11:53:16
en-trust
#15
.profile
# if running bash
if [ -n "$BASH_VERSION" ]; then
    # include .bashrc if it exists
    if [ -f "$HOME/.bashrc" ]; then
        . "$HOME/.bashrc"
    fi
fi
# set PATH so it includes user's private bin if it exists
if [ -d "$HOME/bin" ] ; then
    PATH="$HOME/bin:$PATH"
fi
und in bashrc seh ich nichts Auffälliges.
Hat das gggf. noch was damit zu tun ?
ZitatDann noch /etc/init.d/fhem anpassen. Änderungen sind fett.
#!/bin/bash
# description: Start or stop the fhem server
# Added by Alex Peuchert
### BEGIN INIT INFO
# Provides:             fhem.pl
# Required-Start:       $local_fs $remote_fs
# Required-Stop:        $local_fs $remote_fs
# Default-Start:        2 3 4 5
# Default-Stop:         0 1 6
# Short-Description:    FHEM server
### END INIT INFO
export PERLBREW_ROOT=/opt/perlbrew
source /opt/perlbrew/etc/bashrc
perlbrew use perl-5.20.3
Inhalt dieser /opt/perlbrew/etc/bashrc...
export PERLBREW_SHELLRC_VERSION=0.85
__perlbrew_reinit() {
    if [[ ! -d "$PERLBREW_HOME" ]]; then
        mkdir -p "$PERLBREW_HOME"
    fi
    [ -f "$PERLBREW_HOME/init" ] && rm "$PERLBREW_HOME/init"
    echo '# DO NOT EDIT THIS FILE' > "$PERLBREW_HOME/init"
    command perlbrew env $1 | \grep PERLBREW_ >> "$PERLBREW_HOME/init"
    . "$PERLBREW_HOME/init"
    __perlbrew_set_path
__perlbrew_purify () {
    local path patharray outsep
    IFS=: read -r${BASH_VERSION+a}${ZSH_VERSION+A} patharray <<< "$1"
    for path in "${patharray[@]}" ; do
        case "$path" in
            (*"$PERLBREW_HOME"*) ;;
            (*"$PERLBREW_ROOT"*) ;;
            (*) printf '%s' "$outsep$path" ; outsep=: ;;
        esac
    done
__perlbrew_set_path () {
    export MANPATH=$PERLBREW_MANPATH${PERLBREW_MANPATH:+:}$(__perlbrew_purify "$(manpath 2>/dev/null)")
    export PATH=${PERLBREW_PATH:-$PERLBREW_ROOT/bin}:$(__perlbrew_purify "$PATH")
    hash -r
__perlbrew_set_env() {
    local code
    code="$($perlbrew_command env $@)" || return $?
    eval "$code"
__perlbrew_activate() {
    [[ -n $(alias perl 2>/dev/null) ]] && unalias perl 2>/dev/null
    if [[ -n "$PERLBREW_PERL" ]]; then
        __perlbrew_set_env "$PERLBREW_PERL${PERLBREW_LIB:+@}$PERLBREW_LIB"
    fi
    __perlbrew_set_path
__perlbrew_deactivate() {
    __perlbrew_set_env
    unset PERLBREW_PERL
    unset PERLBREW_LIB
    __perlbrew_set_path
perlbrew () {
    local exit_status
    local short_option
    export SHELL
    if [[ $1 == -* ]]; then
        short_option=$1
        shift
    else
        short_option=""
    fi
    case $1 in
        (use)
            if [[ -z "$2" ]] ; then
                echo -n "Currently using ${PERLBREW_PERL:-system perl}"
                [ -n "$PERLBREW_LIB" ] && echo -n "@$PERLBREW_LIB"
                echo
            else
                __perlbrew_set_env "$2" && { __perlbrew_set_path ; true ; }
                exit_status="$?"
            fi
        (switch)
                  command perlbrew switch
              else
                  perlbrew use $2 && { __perlbrew_reinit $2 ; true ; }
                  exit_status=$?
              fi
        (off)
            echo "perlbrew is turned off."
        (switch-off)
            __perlbrew_reinit
            echo "perlbrew is switched off."
            command perlbrew $short_option "$@"
            exit_status=$?
    esac
    hash -r
    return ${exit_status:-0}
[[ -z "$PERLBREW_ROOT" ]] && export PERLBREW_ROOT="$HOME/perl5/perlbrew"
[[ -z "$PERLBREW_HOME" ]] && export PERLBREW_HOME="$HOME/.perlbrew"
if [[ ! -n "$PERLBREW_SKIP_INIT" ]]; then
    if [[ -f "$PERLBREW_HOME/init" ]]; then
    fi
fi
perlbrew_bin_path="${PERLBREW_ROOT}/bin"
if [[ -f $perlbrew_bin_path/perlbrew ]]; then
    perlbrew_command="$perlbrew_bin_path/perlbrew"
else
    perlbrew_command="perlbrew"
fi
unset perlbrew_bin_path
__perlbrew_activate
en-trust
Habe die /etc/init.d/fhem jetzt auch mal geändert...
#!/bin/bash
### BEGIN INIT INFO
# Provides:             fhem.pl
### END INIT INFO
#export PERLBREW_ROOT=/opt/perlbrew
export PERLBREW_ROOT=/home/pi/perl5/perlbrew
#source /opt/perlbrew/etc/bashrc
source /home/pi/perl5/perlbrew/etc/bashrc
perlbrew switch perl-5.20.3
fhem zeigt beim reload aber immernoch...
Can't locate XML/Simple.pm in @INC (you may need to install the XML::Simple module) (@INC contains: ./FHEM/lib ./lib ./FHEM . /opt/perlbrew/perls/perl-5.20.3/lib/site_perl/5.20.3/armv7l-linux /opt/perlbrew/perls/perl-5.20.3/lib/site_perl/5.20.3 /opt/perlbrew/perls/perl-5.20.3/lib/5.20.3/armv7l-linux /opt/perlbrew/perls/perl-5.20.3/lib/5.20.3) at ./FHEM/60_allergy.pm line 26.
BEGIN failed--compilation aborted at ./FHEM/60_allergy.pm line 26.
en-trust
#17
Nach langem suchen bin ich fündig geworden. Manchmal dauert es eben etwas länger. Ich musste einfach nur...
/opt/perlbrew/perls/perl-5.20.3/bin/cpan
...und dort dann sämtlich fehlende Module installieren. Dann klappte auch der reload...
