Hallo Jens,
DEF /dev/serial/by-id/usb-Arduino__www.arduino.cc__Arduino_Uno_6493534313335141C261-if00@57600
DeviceName /dev/serial/by-id/usb-Arduino__www.arduino.cc__Arduino_Uno_6493534313335141C261-if00@57600
FD 62
FUUID 5c77ca64-f33f-dec7-5fed-b2c85630156b6931
LAST_RECEIVED 2020-11-24 21:43:30
NAME firmata
NOTIFYDEV global
NR 380
NTFY_ORDER 50-firmata
PARTIAL
STATE Initialized
TYPE FRM
analog_pins 14,15,16,17,18,19
analog_resolutions 14:10,15:10,16:10,17:10,18:10,19:10
encoder_pins 2,3
encoder_resolutions 2:28,3:28
firmware ConfigurableFirmata.ino
firmware_version V_2_06
i2c_pins 18,19
input_pins 2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19
onewire_pins 2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19
output_pins 2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19
protocol_version V_2_06
pwm_pins 3,5,6,9,10,11
pwm_resolutions 3:8,5:8,6:8,9:8,10:8,11:8
servo_pins 2,3,4,5,6,7,8,9,10,11,12,13
servo_resolutions 2:14,3:14,4:14,5:14,6:14,7:14,8:14,9:14,10:14,11:14,12:14,13:14
stepper_pins 2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19
stepper_resolutions 2:21,3:21,4:21,5:21,6:21,7:21,8:21,9:21,10:21,11:21,12:21,13:21,14:21,15:21,16:21,17:21,18:21,19:21
2020-11-24 21:42:04 state Initialized
SERIAL:
i2c-config 1
room Geräte
verbose 3
DEF 3
FUUID 5c77c9fd-f33f-dec7-31b7-8ed9c67e00a09d54
IODev firmata
IODev_ERROR 1
NAME in_gaszaehler
NR 158
STATE on
TYPE FRM_IN
2020-11-06 11:41:45 reading on
2020-11-24 21:42:04 state error: Perl module Device::Firmata not properly installed
IODev firmata
activeLow yes
comment Bei einer großen Leitungslänge eines Arduino eingangs ist der Interne Pullup zu hoch. ein Externe 1KOhm Wiederstand ist hier besser.
group Gas
internal-pullup off
room Heizung,Keller
stateFormat reading
10_FRM.pm 23052 2020-10-30 17:48:53Z jensb
20_FRM_IN.pm 23054 2020-10-30 18:16:24Z jensb
OneWire und I2C funktionieren mit dem Firmata Device
