Autor Thema: fhempy: googlecast  (Gelesen 27640 mal)
Offline kriegerkl
  • Jr. Member
Antw:fhempy: googlecast
« Antwort #180 am: 29 Januar 2021, 22:47:25 »
Hier ist die Ausgabe:
pi@raspberrypi:/opt/fhem/log $ sudo -u fhem pip3 install spotify_token
Defaulting to user installation because normal site-packages is not writeable
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting spotify_token
  Downloading spotify_token-1.0.0-py2.py3-none-any.whl (3.5 kB)
Requirement already satisfied: requests>=2.0 in /usr/local/lib/python3.8/site-packages (from spotify_token) (2.25.0)
Collecting beautifulsoup4>=4.8.1
  Downloading beautifulsoup4-4.9.3-py3-none-any.whl (115 kB)
     |████████████████████████████████| 115 kB 2.2 MB/s
Collecting lxml>=4.4.1
  Downloading lxml-4.6.2.tar.gz (3.2 MB)
     |████████████████████████████████| 3.2 MB 2.9 MB/s
    ERROR: Command errored out with exit status 1:
     command: /usr/bin/python3 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-ysawmp8w/lxml/setup.py'"'"'; __file__='"'"'/tmp/pip-install-ysawmp8w/lxml/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-2v7nuv37
         cwd: /tmp/pip-install-ysawmp8w/lxml/
    Complete output (3 lines):
    Building lxml version 4.6.2.
    Building without Cython.
    Error: Please make sure the libxml2 and libxslt development packages are installed.
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
WARNING: You are using pip version 20.2.4; however, version 21.0 is available.
You should consider upgrading via the '/usr/bin/python3 -m pip install --upgrade pip' command.
Kann sein, dass ich  fhempy schon lokal gestartet hatte.
Ich starte den pi noch mal neu.
Offline dominik
« Antwort #181 am: 29 Januar 2021, 23:48:15 »
Mach mal
sudo apt install libxml2-dev libxslt-dev
fhempy -  https://github.com/dominikkarall/fhempy: GoogleCast, UPnP, Ring, EQ3BT, Nespresso, Xiaomi, Spotify, Object Detection, ...
Kaffeespende: https://paypal.me/todominik
Offline kriegerkl
  • Jr. Member
« Antwort #182 am: 30 Januar 2021, 18:25:45 »
Danke Dominik,
Mach mal
Das habe ich gemacht.
Im PhytonBindingLog gibt es weiter den Fehler:
2021-01-30 18:15:15,348 - INFO     - fhempy.lib.fhem_pythonbinding: Starting fhempy...
2021-01-30 18:15:15,434 - INFO     - fhempy.lib.fhem_pythonbinding: Waiting for FHEM connection
  File "FHEM/bindings/python/bin/fhempy", line 121, in <module>
    fpb.run()
  File "/opt/fhem/.local/lib/python3.8/site-packages/fhempy/lib/fhem_pythonbinding.py", line 463, in run
    asyncio.get_event_loop().run_until_complete(
  File "/usr/local/lib/python3.8/asyncio/base_events.py", line 616, in run_until_complete
    return future.result()
  File "/usr/local/lib/python3.8/asyncio/tasks.py", line 684, in _wrap_awaitable
    return (yield from awaitable.__await__())
  File "/opt/fhem/.local/lib/python3.8/site-packages/websockets/server.py", line 965, in __await_impl__
    server = await self._create_server()
  File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1463, in create_server
    raise OSError(err.errno, 'error while attempting '
OSError: [Errno 98] error while attempting to bind on address ('0.0.0.0', 15733): address already in use
Ich habe einmal sudo fuser 15733/tcp ausgeführt.
Ergebnis: 15733/tcp:            2271
pi@raspberrypi:~ $ ps -p 2271
  PID TTY          TIME CMD
 2271 ?        00:00:22 fhempy
Wenn ich den Prozess kille, entsteht relativ schnell wieder ein neuer fhempy-Prozess.
Was kann das Problem sein?
Ich hatte die Installation befolgt und folgendes ausgeführt:
Systemd configuration for autostart
    curl -sL https://raw.githubusercontent.com/dominikkarall/fhempy/master/install_systemd_fhempy.sh | sudo -E bash -
Wird über den /etc/systemd/system/fhempy.service fhempy immer wieder gestartet oder liegt es an dem User pi unter dem er dort gestartet wird?
« Letzte Änderung: 30 Januar 2021, 18:42:56 von kriegerkl »
Offline dominik
« Antwort #183 am: 30 Januar 2021, 19:48:58 »
Geht es hier um einen fhempy peer oder eine lokale fhempy Installation? Lokale fhempy Installation bedeutet, dass es am gleichen Node wie FHEM läuft.
Offline kriegerkl
  • Jr. Member
« Antwort #184 am: 30 Januar 2021, 20:56:49 »
Ich habe die nach Deiner Anleitung installiert: https://github.com/dominikkarall/fhempy
Ich weiß nicht genau, was peer bedeutet.
« Letzte Änderung: 30 Januar 2021, 20:59:10 von kriegerkl »
Offline dominik
« Antwort #185 am: 30 Januar 2021, 21:14:20 »
Das Command ist NUR für fhempy peers notwendig, was das ist steht hier beschrieben:
https://github.com/dominikkarall/fhempy#fhempy-peers-eg-extend-bluetooth-range
Falls du die Commands nun auf deinem FHEM System ausgeführt hast, musst du nun folgendes machen
sudo systemctl stop fhempy
sudo systemctl disable fhempy
pip3 uninstall fhempy
Danach bitte nochmals im Log prüfen was drin steht.
Offline JF Mennedy
  • Full Member
« Antwort #186 am: 30 Januar 2021, 21:16:59 »
peer bedeutet dass fhempy nicht auf dem selben raspi wie deine fhem Instanz läuft... Wenn fhempy auf dem selben  raspi läuft wie dein fhem Instanz ist es lokal... Wenn es lokal läuft brauchst du gar nicht den Dienst einzurichten. Dann erfolgt alles automatisch mit dem define des BindingsIO
define local_pybinding BindingsIo Python
Gruss Jan
Offline kriegerkl
  • Jr. Member
« Antwort #187 am: 31 Januar 2021, 00:23:30 »
Gruss Jan
Danke für die Erklärung.
Dann hab ich das jetzt verstanden.
Im Log steht jetzt:
2021-01-30 21:34:31,530 - INFO     - fhempy.lib.fhem_pythonbinding: Starting fhempy...
2021-01-30 21:34:31,619 - INFO     - fhempy.lib.fhem_pythonbinding: Waiting for FHEM connection
    fpb.run()
2021-01-30 21:34:54,624 - INFO     - fhempy.lib.fhem_pythonbinding: Starting fhempy...
2021-01-30 21:34:54,732 - INFO     - fhempy.lib.fhem_pythonbinding: Waiting for FHEM connection
2021-01-30 21:34:54,777 - INFO     - asyncio: <Server sockets=(<asyncio.TransportSocket fd=6, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('0.0.0.0', 15733)>,)> is serving
2021-01-30 21:35:04,492 - INFO     - fhempy.lib.fhem_pythonbinding: Incoming FHEM connection: 127.0.0.1
2021-01-30 21:35:04,591 - WARNING  - asyncio: Executing <Task pending name='Task-5' coro=<WebSocketServerProtocol.handler() running at /opt/fhem/.local/lib/python3.8/site-packages/websockets/server.py:191> wait_for=<Future pending cb=[<TaskWakeupMethWrapper object at 0x75cf2ec8>()] created at /usr/local/lib/python3.8/asyncio/base_events.py:422> created at /opt/fhem/.local/lib/python3.8/site-packages/websockets/server.py:116> took 0.115 seconds
Sieht also besser aus.
Mein Device:
define castWohnzimmer PythonModule googlecast Wohnzimmer
attr castWohnzimmer userattr favorite_1 favorite_2 favorite_3 favorite_4 favorite_5
attr castWohnzimmer IODev local_pybinding
attr castWohnzimmer icon gassistant
sagt allerdings immer noch:
castWohnzimmer PythonBinding offline
Nach stop und start von fhem jetzt immerhin das:
castWohnzimmer Installing updates...
« Letzte Änderung: 31 Januar 2021, 00:40:15 von kriegerkl »
Offline dominik
« Antwort #188 am: 31 Januar 2021, 08:19:16 »
Ok, jetzt bitte nochmals
sudo -u fhem pip3 install spotify-token
Online Sommerfeld
  • Jr. Member
« Antwort #189 am: 31 Januar 2021, 09:14:03 »
Hallo Domonik,
nach mehreren update Versuchen habe ich immer noch die
Version 1.26.
Was muss ich machen, um die aktuelle Version 1.27 zu
bekommen?
   .FhemMetaInternals 1
   BindingType Python
   DEF        Python
   DeviceName ws:127.0.0.1:15733
   FD         231
   FUUID      5f513675-f33f-3b5c-6a47-c3e970bbbfac9d07
   FVERSION   10_BindingsIo.pm:0.182830/2019-01-16
   IP         127.0.0.1
   NAME       local_pybinding
   NR         1075
   NTFY_ORDER 50-local_pybinding
   PARTIAL
   PORT       15733
   STATE      opened
   TYPE       BindingsIo
   WEBSOCKET  1
   localBinding 1
   nextOpenDelay 10
   .attraggr:
   .attrminint:
     2021-01-31 08:45:25   info            ready
     2021-01-31 08:45:24   state           opened
     2021-01-27 08:05:42   version         0.1.26
   args:
     local_pybinding
     BindingsIo
     Python
   argsh:
     room       06_1_Sprachausgabe,hidden
   verbose    3
Offline dominik
« Antwort #190 am: 31 Januar 2021, 09:25:50 »
sudo -u fhem pip3 install --upgrade fhempy
Da ist mir leider ein Fehler im Update Prozess unterlaufen, daher muss nun einmalig manuell aktualisiert werden.
Offline dominik
« Antwort #191 am: 31 Januar 2021, 09:37:34 »
Warte noch ein bisschen, ich werde die Abhängigkeit rausnehmen. In dem Package sind zu viele requirements drin die gar nicht gebraucht werden.
Offline dominik
« Antwort #192 am: 31 Januar 2021, 09:43:10 »
So, Version 1.0.45. Installier bitte diese, damit sollte es mit spotify_token keine Probleme mehr geben, habe die Dependency entfernt.
Offline kriegerkl
  • Jr. Member
« Antwort #193 am: 31 Januar 2021, 18:57:45 »
Vielen Dank Dominik für Deine Hilfe
Es hat jetzt funktioniert.
Meine googlecast Devices waren jetzt verbunden (ready).
Dann habe ich allerdings den RPI rebootet, um zu überprüfen, ob es dann auch noch funktioniert.
Im local_pybinding-Device steht dann: "info Please wait till connection is established, might take a few minutes"
Und das steht auch noch nach Stunden da und die googlecast Devices sind offline.
Im PythonBinding.log steht folgendes:
2021-01-31 12:55:01,662 - INFO     - fhempy.lib.fhem_pythonbinding: Starting fhempy...
2021-01-31 12:55:01,813 - INFO     - fhempy.lib.fhem_pythonbinding: Waiting for FHEM connection
2021-01-31 12:55:01,888 - INFO     - asyncio: <Server sockets=(<asyncio.TransportSocket fd=6, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('0.0.0.0', 15733)>,)> is serving
2021-01-31 12:55:09,521 - INFO     - fhempy.lib.fhem_pythonbinding: Incoming FHEM connection: 127.0.0.1
2021-01-31 12:55:09,644 - WARNING  - asyncio: Executing <Task pending name='Task-5' coro=<WebSocketServerProtocol.handler() running at /opt/fhem/.local/lib/python3.8/site-packages/websockets/server.py:191> wait_for=<Future pending cb=[<TaskWakeupMethWrapper object at 0x75cd8f88>()] created at /usr/local/lib/python3.8/asyncio/base_events.py:422> created at /opt/fhem/.local/lib/python3.8/site-packages/websockets/server.py:116> took 0.141 seconds
2021-01-31 12:55:09,980 - WARNING  - asyncio: Executing <Task pending name='Task-9' coro=<PyBinding.onMessage() running at /opt/fhem/.local/lib/python3.8/site-packages/fhempy/lib/fhem_pythonbinding.py:126> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.8/asyncio/futures.py:360, <TaskWakeupMethWrapper object at 0x74ae9f88>()] created at /usr/local/lib/python3.8/asyncio/base_events.py:422> created at /usr/local/lib/python3.8/asyncio/tasks.py:382> took 0.311 seconds
Offline dominik
« Antwort #194 am: 31 Januar 2021, 19:03:50 »
Kannst du bitte mal schauen ob im FHEM Log was steht?
decade-submarginal
