Autor Thema: fhempy: googlecast  (Gelesen 27603 mal)
Offline benm
  • New Member
Antw:fhempy: googlecast
« Antwort #225 am: 14 Februar 2021, 13:42:15 »
Kannst du mal im Container ein
sudo -u fhem pip3 install cryptographymachen und mir die Ausgabe posten.
Hi Dominik,
habe ich ausgeführt und bekomme folgendes zurück (hoffe es ist nicht zu viel...):
     │                        • MobaXterm 20.6 •                          │
     │            (SSH client, X-server and networking tools)             │
     │ ➤ SSH session to pi@192.168.86.152                                 │
     │   • SSH compression : ✔                                            │
     │   • SSH-browser     : ✔                                            │
     │   • X11-forwarding  : ✔  (remote display is forwarded through SSH) │
     │   • DISPLAY         : ✔  (automatically set on remote server)      │
     │ ➤ For more info, ctrl+click on help or visit our website           │
Linux raspberrypi 5.10.14-v7+ #1401 SMP Mon Feb 8 14:23:24 GMT 2021 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun Feb 14 13:01:57 2021 from 192.168.86.40
SSH is enabled and the default password for the 'pi' user has not been changed.
This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
Wi-Fi is currently blocked by rfkill.
Use raspi-config to set the country before use.
pi@raspberrypi:~ $ docker exec -it fhem bash
root@6f2a32ab32b7:/opt/fhem# sudo -u fhem pip3 install cryptography
Collecting cryptography
  Using cached https://files.pythonhosted.org/packages/60/6d/b32368327f600a12e59fb51a904fc6200dd7e65e953fd6fc6ae6468e3423/cryptography-3.4.5.tar.gz
  Installing build dependencies ... done
Requirement already satisfied: cffi>=1.12 in ./.local/lib/python3.7/site-packages (from cryptography) (1.14.5)
Requirement already satisfied: pycparser in ./.local/lib/python3.7/site-packages (from cffi>=1.12->cryptography) (2.20)
Building wheels for collected packages: cryptography
  Running setup.py bdist_wheel for cryptography ... error
  Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-4gzaxddm/cryptography/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-716o1ldc --python-tag cp37:
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-armv7l-3.7
  creating build/lib.linux-armv7l-3.7/cryptography
  copying src/cryptography/utils.py -> build/lib.linux-armv7l-3.7/cryptography
  copying src/cryptography/fernet.py -> build/lib.linux-armv7l-3.7/cryptography
  copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-3.7/cryptography
  copying src/cryptography/__about__.py -> build/lib.linux-armv7l-3.7/cryptography
  copying src/cryptography/__init__.py -> build/lib.linux-armv7l-3.7/cryptography
  creating build/lib.linux-armv7l-3.7/cryptography/x509
  copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-3.7/cryptography/x509
  copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-3.7/cryptography/x509
  copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-3.7/cryptography/x509
  copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-3.7/cryptography/x509
  copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-3.7/cryptography/x509
  copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-3.7/cryptography/x509
  copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-3.7/cryptography/x509
  copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-3.7/cryptography/x509
  creating build/lib.linux-armv7l-3.7/cryptography/hazmat
  copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat
  copying src/cryptography/hazmat/_types.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat
  copying src/cryptography/hazmat/_der.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat
  copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat
  creating build/lib.linux-armv7l-3.7/cryptography/hazmat/bindings
  copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/bindings
  creating build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives
  creating build/lib.linux-armv7l-3.7/cryptography/hazmat/backends
  copying src/cryptography/hazmat/backends/interfaces.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends
  copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends
  creating build/lib.linux-armv7l-3.7/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/bindings/openssl
  creating build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/ciphers
  creating build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/kdf
  creating build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/utils.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/twofactor
  creating build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/asymmetric
  creating build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/primitives/serialization
  creating build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ocsp.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/encode_asn1.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/poly1305.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-armv7l-3.7/cryptography/hazmat/backends/openssl
  running egg_info
  writing src/cryptography.egg-info/PKG-INFO
  writing dependency_links to src/cryptography.egg-info/dependency_links.txt
  writing requirements to src/cryptography.egg-info/requires.txt
  writing top-level names to src/cryptography.egg-info/top_level.txt
  reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
  reading manifest template 'MANIFEST.in'
  no previously-included directories found matching 'docs/_build'
  warning: no previously-included files found matching 'vectors'
  warning: no previously-included files matching '*' found under directory 'vectors'
  warning: no previously-included files matching '*' found under directory '.github'
  warning: no previously-included files found matching 'release.py'
  warning: no previously-included files found matching '.coveragerc'
  warning: no previously-included files found matching 'codecov.yml'
  warning: no previously-included files found matching '.readthedocs.yml'
  warning: no previously-included files found matching 'dev-requirements.txt'
  warning: no previously-included files found matching 'tox.ini'
  warning: no previously-included files found matching 'mypy.ini'
  warning: no previously-included files matching '*' found under directory '.zuul.d'
  warning: no previously-included files matching '*' found under directory '.zuul.playbooks'
  writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
  copying src/cryptography/py.typed -> build/lib.linux-armv7l-3.7/cryptography
  running build_ext
  generating cffi module 'build/temp.linux-armv7l-3.7/_padding.c'
  creating build/temp.linux-armv7l-3.7
  generating cffi module 'build/temp.linux-armv7l-3.7/_openssl.c'
  running build_rust
      =============================DEBUG ASSISTANCE=============================
      If you are seeing a compilation error please try the following steps to
      successfully install cryptography:
      1) Upgrade to the latest pip and try again. This will fix errors for most
         users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
      2) Read https://cryptography.io/en/latest/installation.html for specific
         instructions for your platform.
      3) Check our frequently asked questions for more information:
         https://cryptography.io/en/latest/faq.html
      4) Ensure you have a recent Rust toolchain installed:
         https://cryptography.io/en/latest/installation.html#rust
      5) If you are experiencing issues with Rust for *this release only* you may
         set the environment variable `CRYPTOGRAPHY_DONT_BUILD_RUST=1`.
  error: Can not find Rust compiler
  Failed building wheel for cryptography
  Running setup.py clean for cryptography
Failed to build cryptography
Installing collected packages: cryptography
  Running setup.py install for cryptography ... error
    Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-4gzaxddm/cryptography/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-wyoldcwf/install-record.txt --single-version-externally-managed --compile --user --prefix=:
    running install
    running build
    running build_py
    creating build
    running egg_info
    running build_ext
    running build_rust
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-4gzaxddm/cryptography/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-wyoldcwf/install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in /tmp/pip-install-4gzaxddm/cryptography/
Wegen der Zeile:
error: Can not find Rust compilerhabe ich Rust installiert:
curl https://sh.rustup.rs -sSf | shHat leider keine Besserung gebracht
Obwohl das vermutlich nichts bringt, wegen der obrigen Fehlermeldung habe ich deinen zweiten Vorschlag auch ausgeführt:
Bitte dann folgendes testen:
sudo -u fhem pip3 install --upgrade cryptography
sudo -u fhem pip3 install --upgrade fhempy
Als Ergebnis kam das raus:
running build_rust
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-ngq5wpyw/cryptography/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-ho0_lwtc/install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in /tmp/pip-install-ngq5wpyw/cryptography/
Ich vermute, dass es mit dem fehlenden Rust Compiler zu tun hat...stehe aber auf dem Schlauch.
Offline dominik
« Antwort #226 am: 14 Februar 2021, 14:55:36 »
Ok, der Fehler liegt an der neuen Cryptography Rust Abhängigkeit, hat wohl mehrere erwischt:
https://github.com/pyca/cryptography/issues/5771
Ich schau mal was ich tun kann, eventuell entferne ich die Abhängigkeit auch und suche eine andere Library.
fhempy -  https://github.com/dominikkarall/fhempy: GoogleCast, UPnP, Ring, EQ3BT, Nespresso, Xiaomi, Spotify, Object Detection, ...
Kaffeespende: https://paypal.me/todominik
Offline benm
  • New Member
« Antwort #227 am: 14 Februar 2021, 15:43:29 »
Danke dir...eine Möglichkeit die alte Version zu installieren gibt es nicht?!?
Offline benm
  • New Member
« Antwort #228 am: 14 Februar 2021, 17:16:29 »
Scheinbar hat es jetzt geklappt.
Hab mir einige Posts hier durchgelesen:
Dort steht, dass als Lösungsvorschlag:
apt install -y rustc python3-pip
Danach noch mal:
Und es läuft durch.
Danke dir noch mal für deine Hilfe!
Edit 17:54 Uhr:
Leider noch mal eine Korrektur, ich glaube es geht doch nicht. Meine Google Cast Geräte bleiben alle offline.
Kann das damit was zu tun haben?:
2021-02-14 17:32:39,013 - INFO     - fhempy.lib.fhem_pythonbinding: Starting fhempy...
2021-02-14 17:32:39,039 - INFO     - fhempy.lib.fhem_pythonbinding: Waiting for FHEM connection
2021-02-14 17:32:39,050 - INFO     - asyncio: <Server sockets=[<socket.socket fd=6, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('0.0.0.0', 15733)>]> is serving
2021-02-14 17:32:46,639 - INFO     - asyncio: poll took 7587.267 ms: 1 events
2021-02-14 17:32:46,663 - INFO     - fhempy.lib.fhem_pythonbinding: Incoming FHEM connection: 127.0.0.1
2021-02-14 17:32:47,020 - WARNING  - asyncio: Executing <Task pending coro=<PyBinding.onMessage() running at /opt/fhem/.local/lib/python3.7/site-packages/fhempy/lib/fhem_pythonbinding.py:126> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/lib/python3.7/asyncio/futures.py:348, <TaskWakeupMethWrapper object at 0x73fcf530>()] created at /usr/lib/python3.7/asyncio/base_events.py:396> created at /usr/lib/python3.7/asyncio/tasks.py:325> took 0.205 seconds
2021-02-14 17:32:47,953 - WARNING  - asyncio: Executing <Handle <TaskWakeupMethWrapper object at 0x71c41930>(<Future finis...events.py:396>) created at /usr/lib/python3.7/asyncio/tasks.py:368> took 0.311 seconds
2021-02-14 17:32:56,228 - INFO     - asyncio: poll took 6990.183 ms: 1 events
2021-02-14 17:32:59,775 - INFO     - asyncio: poll took 2730.697 ms: 1 events
Die beiden Befehle hatte ich auch ausgeführt:
« Letzte Änderung: 14 Februar 2021, 17:59:45 von benm »
Offline dominik
« Antwort #229 am: 14 Februar 2021, 20:59:08 »
Das Log sieht eigentlich gut aus.
Auch nach einem Neustart von fhempy tut es nicht? Stell mal bei einem Googlecast Device verbose auf 5 und schau dann nochmals im fhempy Log.
Offline benm
  • New Member
« Antwort #230 am: 14 Februar 2021, 21:12:01 »
Hab bei dem "cast" welches den Namen "Wohnzimmer" (Nest Wifi) hat auf Verbose 5 gestellt. Hab zusätzlich noch zwei andere GoogleCast Geräte (Chromecast Audio und Nest Mini) hinzugefügt (ohne Verbose hoch zu setzen), beide sind auch "offline".
Das ist das LOG File von fhempy seit dem Container-Restart:
2021-02-14 19:00:14,993 - WARNING  - asyncio: Executing <Handle _SelectorSocketTransport._read_ready() created at /usr/lib/python3.7/asyncio/selector_events.py:249> took 0.107 seconds
2021-02-14 21:04:13,088 - INFO     - asyncio: poll took 7437795.551 ms: 1 events
2021-02-14 21:04:30,119 - INFO     - asyncio: poll took 16837.416 ms: 1 events
2021-02-14 21:06:18,150 - INFO     - fhempy.lib.fhem_pythonbinding: Starting fhempy...
2021-02-14 21:06:18,190 - INFO     - fhempy.lib.fhem_pythonbinding: Waiting for FHEM connection
2021-02-14 21:06:18,215 - INFO     - asyncio: <Server sockets=[<socket.socket fd=6, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('0.0.0.0', 15733)>]> is serving
2021-02-14 21:06:25,492 - INFO     - asyncio: poll took 7275.678 ms: 1 events
2021-02-14 21:06:25,537 - INFO     - fhempy.lib.fhem_pythonbinding: Incoming FHEM connection: 127.0.0.1
2021-02-14 21:06:25,702 - WARNING  - asyncio: Executing <Task pending coro=<PyBinding.onMessage() running at /opt/fhem/.local/lib/python3.7/site-packages/fhempy/lib/fhem_pythonbinding.py:126> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/lib/python3.7/asyncio/futures.py:348, <TaskWakeupMethWrapper object at 0x75375350>()] created at /usr/lib/python3.7/asyncio/base_events.py:396> created at /usr/lib/python3.7/asyncio/tasks.py:325> took 0.101 seconds
2021-02-14 21:06:25,818 - WARNING  - asyncio: Executing <Task pending coro=<PyBinding.onMessage() running at /opt/fhem/.local/lib/python3.7/site-packages/fhempy/lib/fhem_pythonbinding.py:126> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/lib/python3.7/asyncio/futures.py:348, <TaskWakeupMethWrapper object at 0x749d4630>()] created at /usr/lib/python3.7/asyncio/base_events.py:396> created at /usr/lib/python3.7/asyncio/tasks.py:325> took 0.109 seconds
2021-02-14 21:06:25,948 - WARNING  - asyncio: Executing <Task pending coro=<PyBinding.onMessage() running at /opt/fhem/.local/lib/python3.7/site-packages/fhempy/lib/fhem_pythonbinding.py:126> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/lib/python3.7/asyncio/futures.py:348, <TaskWakeupMethWrapper object at 0x749fcc10>()] created at /usr/lib/python3.7/asyncio/base_events.py:396> created at /usr/lib/python3.7/asyncio/tasks.py:325> took 0.113 seconds
2021-02-14 21:06:27,251 - WARNING  - asyncio: Executing <Handle <TaskWakeupMethWrapper object at 0x71787690>(<Future finis...events.py:396>) created at /usr/lib/python3.7/asyncio/tasks.py:368> took 0.509 seconds
2021-02-14 21:06:29,071 - INFO     - asyncio: poll took 1790.579 ms: 1 events
2021-02-14 21:06:29,613 - DEBUG    - cast: Start discovery
2021-02-14 21:06:32,912 - INFO     - asyncio: poll took 3291.207 ms: 1 events
2021-02-14 21:06:34,067 - INFO     - asyncio: poll took 1092.769 ms: 1 events
2021-02-14 21:06:39,925 - INFO     - asyncio: poll took 5823.931 ms: 1 events
2021-02-14 21:07:57,532 - INFO     - asyncio: poll took 76782.353 ms: 1 events
2021-02-14 21:08:00,971 - INFO     - asyncio: poll took 3381.136 ms: 1 events
2021-02-14 21:08:11,609 - INFO     - asyncio: poll took 10571.946 ms: 1 events
Offline dominik
« Antwort #231 am: 14 Februar 2021, 21:18:41 »
Kann es sein, dass das Device aus dem Container nicht gefunden werden kann? Eventuell Netzwerk Thema?
Offline JF Mennedy
  • Full Member
« Antwort #232 am: 26 März 2021, 15:29:11 »
Hallo funktioniert bei Euch noch spotify mit googlecast?
Bis vor ein paar Tagen alles gut, doch jetzt gehts nicht merhr und im log steht folgendes:
2021-03-26 15:22:42,941 - ERROR    - Google_Home_Mini: No device with id "a5d21dadee4casasdafgasg1a4ebc821a0c" known by Spotify
2021-03-26 15:22:42,941 - ERROR    - Google_Home_Mini: Known devices: []
Das erste Mal war das am 22.03. im Log..
Habe noch mal die sp_dc und sp_key erneuert, Spotify_USer wird auch in den Readings richtig angezeigt...
Hat hier eventuell Spotify etwas geändert?
Gruss Jan
Offline JF Mennedy
  • Full Member
« Antwort #233 am: 27 März 2021, 15:02:56 »
Anscheinend ist das Problem bereits bei spotipy bekannt...
https://github.com/plamere/spotipy/issues/659
Offline Atara
  • New Member
« Antwort #234 am: 31 März 2021, 09:29:05 »
ich hoffe, ich frage nichts, was hier schon behandelt wurde.
Ich habe mit dem "Fünfzeiler" das Binding  auf meinem RPi installiert und anschließend ein googlecast device angelegt.
defmod FG_CAST PythonModule googlecast "Flur Erdgeschoss"
Das wurde aber nicht installiert.
Bei der Fehlersuche habe ich bemerkt, dass das Binding fhempy nicht automatisch gestartet wurde.
Nach einem manuellen Start wurde alles installiert und meine Sprachausgabe funktioniert.
Nur bleibt das Problem, dass fhempy (0.1.57) nicht automatisch startet.
Kann mir hier jemand einen Tipp geben?
Besten Dank im Voraus!
Offline dominik
« Antwort #235 am: 04 April 2021, 20:07:43 »
das mit Spotify dürfte wohl ein generelles Problem sein.
Kannst du mal folgendes probieren:
 - define spotify_player PythonModule spotify
 - Einloggen über den Link in den Readings
 - set home_mini startSpotify
 - set spotify_player update_devices
 - DeviceID kopieren (nur die ID, nicht den Name)
 - set spotify_player play https://SPOTIFYURL DEVICEID
Sollte das gehen, dann muss ich wohl im Chromecast Modul den Spotify Login + sp_dc integrieren.
Offline dominik
« Antwort #236 am: 04 April 2021, 20:09:09 »
define local_pybinding BindingsIo Python
hast du gemacht? Existiert ein Device Pythonbinding_15733? Das macht den Autostart.
Offline JF Mennedy
  • Full Member
« Antwort #237 am: 04 April 2021, 20:58:11 »
Hi Dominik,
  -> Pling auf Ghome ertönt
  -> Ich bekomme eine Device ID
 - set spotify_player play https://SPOTIFYURL DEVICEID := set Google_Home_Mini_Bureau play https://open.spotify.com/playlist/37i9asdasdad0zmsulfyDdq 12esdfsdfsdfsdfsd741c97f56b9d38d73fa1c222cc
  -> Antwort von Fhem "Usage: set Google_Home_Mini_Bureau play url"
Gruss Jan
Offline dominik
« Antwort #238 am: 04 April 2021, 22:15:03 »
Hi Jan,
ich habe es bei mir gerade mit folgendem play probiert:
set spotify_player play https://open.spotify.com/artist/3fgrINtlzNkMEhUEq0CZS8 DEVICEID
Da hat es funktioniert über FHEM Web. Eventuell hat sich da noch irgendwo ein Leerzeichen eingeschlichen bei dir?
Kannst du es mal mit einer öffentlichen Playlist oder Artist Link testen? Wobei eine private Playlist eigentlich auch klappen sollte.
« Letzte Änderung: 04 April 2021, 22:16:52 von dominik »
Offline JF Mennedy
  • Full Member
« Antwort #239 am: 04 April 2021, 22:50:10 »
Ok, ich Hornochse.. hab set play auf dem CastDevice ausgeführt.. Im Spoti-Player gehts...
