Rereadcfg benutze ich schon lange nicht mehr. Seit halt der Fehler auftrat. Stattdessen eben restart.
Wird sich schon jemand was bei gedacht haben.
rereadcfg war jetzt nur ein Experiment.
list VCCU wenns funktioniert.
CFGFN ./FHEM/MyLanInterface.cfg
DEF 2576CB
FUUID 5c44eb3c-f33f-9dc6-955e-3b26dd5c810a4994
IODev XX_LANInterface
LASTInputDev XX_HMUART
MSGCNT 58
NAME XX_VCCU
NOTIFYDEV global
NR 445
NTFY_ORDER 50-XX_VCCU
STATE XX_LANInterface:ok,XX_HMUART:ok
TYPE CUL_HM
XX_HMUART_MSGCNT 15
XX_HMUART_RAWMSG 050001369981122576CB000000
XX_HMUART_RSSI -54
XX_HMUART_TIME 2021-09-12 18:41:39
XX_LANInterface_MSGCNT 43
XX_LANInterface_RAWMSG E2576CB,0000,000FF7E2,FF,FFC6,C780022576CB6041B30101C800
XX_LANInterface_RSSI -58
XX_LANInterface_TIME 2021-09-12 18:35:22
assignedIOs XX_HMUART,XX_LANInterface
lastMsg No:99 - t:12 s:2576CB d:000000
protLastRcv 2021-09-12 18:41:39
protRcv 58 last_at:2021-09-12 18:41:39
protRcvB 1 last_at:2021-09-12 18:14:58
rssi_at_XX_HMUART cnt:15 min:-54 max:-52 avg:-53.06 lst:-54
rssi_at_XX_LANInterface cnt:43 min:-58 max:-56 avg:-57.11 lst:-58
2021-09-12 18:35:21 CommandAccepted yes
2021-09-12 18:09:43 IODev XX_LANInterface
2021-09-12 18:41:39 IOopen 2
2021-09-12 18:35:21 aesKeyNbr 02
2021-09-12 13:31:01 aesReqTo JA_WZT_Jal
2021-09-11 23:07:23 cfgState ok
2020-07-17 11:27:30 commState CMDs_done
2021-09-12 18:41:39 state XX_LANInterface:ok,XX_HMUART:ok
2021-09-10 08:21:18 unknown_2437B9 received
helper:
HM_CMDNR 153
mId FFF0
peerFriend -
peerOpt -:virtual
regLst
rxType 1
supp_Pair_Rep 0
ack:
cmds:
TmplKey :no:1631462984.8173
TmplTs 1631462984.8173
cmdKey 0:1:1::XX_VCCU:FFF0:00:
cmdLst:
assignIO -IO- [({set}|unset)]
clear [(readings|rssi|msgEvents|attack|{msgErrors}|unknownDev)]
defIgnUnknown noArg
hmPairForSec [-sec-]
hmPairSerial -serial-
update noArg
virtual [(1..50;1|{1})]
lst:
condition slider,0,1,255
peer
peerOpt
tplChan
tplDel
tplPeer
rtrvLst:
cmdList [({short}|long)]
deviceInfo [({short}|long)]
list [({normal}|full)]
listDevice noArg
param -param-
expert:
def 1
det 0
raw 0
tpl 0
io:
nextSend 1631464899.53466
prefIO
vccu XX_VCCU
ioList:
XX_LANInterface
XX_HMUART
mRssi:
mNo 99
io:
XX_HMUART:
-54
-54
XX_LANInterface:
-52
peerIDsH:
prt:
bErr 0
sProc 0
rspWait:
q:
qReqConf
qReqStat
role:
dev 1
vrt 1
rssi:
at_XX_HMUART:
avg -53.0666666666667
cnt 15
lst -54
max -52
min -54
at_XX_LANInterface:
avg -57.1162790697674
cnt 43
lst -58
max -56
min -58
tmpl:
IOList XX_LANInterface,XX_HMUART
IOgrp XX_VCCU
alias VCCU
group Homematic
model CCU-FHEM
room Server
subType virtual
webCmd virtual:update
Nach rereadcfg wenn AES nicht funktioniert, mir fällt
aesKeyNbr 00
auf
DEF 2576CB
LASTInputDev XX_LANInterface
MSGCNT 47
NAME XX_VCCU
NOTIFYDEV global
NR 445
TYPE CUL_HM
XX_HMUART_MSGCNT 10
XX_HMUART_RAWMSG 050000361180022576CB6119DA0091EA1CC2
XX_HMUART_RSSI -54
XX_HMUART_TIME 2021-09-12 18:48:19
XX_LANInterface_MSGCNT 37
XX_LANInterface_RAWMSG E2576CB,0000,00099547,FF,FFC7,70A0022576CB5C83510457320000320C00
XX_LANInterface_RSSI -57
XX_LANInterface_TIME 2021-09-12 18:51:08
lastMsg No:70 - t:02 s:2576CB d:5C8351 0457320000320C00
protLastRcv 2021-09-12 18:51:08
protRcv 47 last_at:2021-09-12 18:51:08
rssi_at_XX_HMUART cnt:10 min:-54 max:-54 avg:-54 lst:-54
rssi_at_XX_LANInterface cnt:37 min:-58 max:-57 avg:-57.43 lst:-57
2021-09-12 18:48:18 CommandAccepted yes
2021-09-12 18:47:43 IODev XX_LANInterface
2021-09-12 18:48:04 IOopen 2
2021-09-12 18:51:08 aesKeyNbr 00
2021-09-12 18:48:04 state XX_LANInterface:ok,XX_HMUART:ok
helper:
HM_CMDNR 112
mId FFF0
peerFriend -
peerOpt -:virtual
regLst
rxType 1
supp_Pair_Rep 0
ack:
cmds:
TmplKey :no:1631465275.25671
TmplTs 1631465275.25671
cmdKey 0:1:1::XX_VCCU:FFF0:01:
cmdLst:
defIgnUnknown noArg
tplSet_0 -tplChan-
update noArg
lst:
peer
peerOpt
tplChan
tplDel
tplPeer
rtrvLst:
listDevice noArg
param -param-
expert:
def 1
det 0
raw 0
tpl 0
io:
nextSend 1631465468.26954
prefIO
vccu XX_VCCU
ioList:
XX_LANInterface
XX_HMUART
mRssi:
mNo 70
io:
XX_HMUART:
XX_LANInterface:
-51
-51
peerIDsH:
prt:
bErr 0
sProc 0
rspWait:
q:
qReqConf
qReqStat
role:
dev 1
vrt 1
rssi:
at_XX_HMUART:
avg -54
cnt 10
lst -54
max -54
min -54
at_XX_LANInterface:
avg -57.4324324324324
cnt 37
lst -57
max -57
min -58
tmpl:
IOgrp XX_VCCU
alias VCCU
group Homematic
model CCU-FHEM
room Server
subType virtual
Jetzt die beiden IOs in der IOList vertauscht, in meiner Version geht das ja noch.
Fehler weiterhin vorhanden.
DEF 2576CB
MSGCNT 48
NAME XX_VCCU
NOTIFYDEV global
NR 445
STATE XX_HMUART:ok,XX_LANInterface:ok
TYPE CUL_HM
XX_HMUART_MSGCNT 10
XX_HMUART_RSSI -54
XX_LANInterface_MSGCNT 38
XX_LANInterface_RAWMSG E2576CB,0000,000B5606,FF,FFC6,82943F2576CB000000020428D0ECEE
XX_LANInterface_TIME 2021-09-12 18:53:03
lastMsg No:82 - t:3F s:2576CB d:000000 020428D0ECEE
protLastRcv 2021-09-12 18:53:03
protRcv 48 last_at:2021-09-12 18:53:03
protRcvB 1 last_at:2021-09-12 18:53:03
rssi_at_XX_LANInterface cnt:38 min:-58 max:-57 avg:-57.44 lst:-58
2021-09-12 18:56:04 IOopen 2
2021-09-12 18:56:04 state XX_HMUART:ok,XX_LANInterface:ok
helper:
HM_CMDNR 130
mId FFF0
peerFriend -
peerOpt -:virtual
regLst
rxType 1
supp_Pair_Rep 0
ack:
cmds:
cmdLst:
defIgnUnknown noArg
update noArg
lst:
peer
peerOpt
tplChan
tplDel
tplPeer
rtrvLst:
listDevice noArg
param -param-
expert:
def 1
det 0
raw 0
tpl 0
io:
nextSend 1631465583.13224
prefIO
vccu XX_VCCU
ioList:
XX_HMUART
XX_LANInterface
mRssi:
mNo 82
io:
XX_HMUART:
XX_LANInterface:
-52
-52
peerIDsH:
prt:
bErr 0
sProc 0
rspWait:
q:
qReqConf
qReqStat
role:
dev 1
vrt 1
rssi:
at_XX_HMUART:
avg -54
cnt 10
lst -54
max -54
min -54
at_XX_LANInterface:
avg -57.4473684210526
cnt 38
lst -58
max -57
min -58
tmpl:
IOList XX_HMUART,XX_LANInterface
IOgrp XX_VCCU
alias VCCU
group Homematic
model CCU-FHEM
room Server
subType virtual
ioList scheint mir jedesmal passend.
