Can't connect to 127.0.0.1:43199: IO::Socket::INET:
Begonnen von Burny4600, 02 April 2022, 10:29:20
eisman
hi,
kann sein das ich auch die Probleme habe (bei 3 gleiche installationen ist es nur eine)
fhem.pl                25922 2022-04-05 08:55:13Z rudolfkoenig
2022.04.11 22:19:14 3: CUL0: Unknown code 21  775, help me!
2022.04.11 22:23:20 1: xxx.xxx.xxx.xxx:1883 disconnected, waiting to reappear (mqttClient)
2022.04.11 22:23:25 1: xxx.xxx.xxx.xxx:1883 reappeared (mqttClient)
2022.04.11 22:26:59 3: FB7590S: read from http://xxx.xxx.xxx.xxx:80 timed out
2022.04.11 22:29:11 1: xxx.xxx.xxx.xxx:1883 disconnected, waiting to reappear (mqttClient)
2022.04.11 22:29:13 1: xxx.xxx.xxx.xxx:1883 reappeared (mqttClient)
2022.04.11 22:34:38 1: xxx.xxx.xxx.xxx:1883 disconnected, waiting to reappear (mqttClient)
2022.04.11 22:34:50 1: xxx.xxx.xxx.xxx:1883 reappeared (mqttClient)
2022.04.11 22:35:51 1: xxx.xxx.xxx.xxx:1883 disconnected, waiting to reappear (mqttClient)
2022.04.11 22:35:52 1: xxx.xxx.xxx.xxx:1883 reappeared (mqttClient)
2022.04.11 22:37:23 3: FB7590S: read from http://xxx.xxx.xxx.xxx:80 timed out
2022.04.11 22:39:06 2: mqttClient: No PINGRESP for last PINGREQ (at 2022-04-11 22:38:27), disconnecting
2022.04.11 22:39:06 1: xxx.xxx.xxx.xxx:1883 disconnected, waiting to reappear (mqttClient)
2022.04.11 22:39:17 1: xxx.xxx.xxx.xxx:1883 reappeared (mqttClient)
2022.04.11 22:41:39 1: xxx.xxx.xxx.xxx:1883 disconnected, waiting to reappear (mqttClient)
2022.04.11 22:41:40 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 3340
2022.04.11 22:41:40 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 3341
2022.04.11 22:41:42 1: xxx.xxx.xxx.xxx:1883 reappeared (mqttClient)
2022.04.11 22:43:08 1: Timeout for FRITZBOX_Readout_Run_Web reached, terminated process 3351
2022.04.11 22:43:08 1: FRITZBOX FR3000: Readout_Aborted.1931 Error: Timeout when reading Fritz!Box data.
2022.04.11 22:43:08 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 3350
2022.04.11 22:43:28 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 3353
2022.04.11 22:43:28 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 3354
2022.04.11 22:43:28 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 3356
2022.04.11 22:43:35 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 3357
2022.04.11 22:43:38 1: xxx.xxx.xxx.xxx:1883 disconnected, waiting to reappear (mqttClient)
2022.04.11 22:43:39 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 3358
2022.04.11 22:43:39 1: xxx.xxx.xxx.xxx:1883 reappeared (mqttClient)
2022.04.11 22:44:30 1: xxx.xxx.xxx.xxx:1883 disconnected, waiting to reappear (mqttClient)
2022.04.11 22:44:57 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 3371
2022.04.11 22:44:57 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 3372
2022.04.11 22:44:57 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 3373
2022.04.11 22:44:57 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 3374
2022.04.11 22:44:57 1: Timeout for PRESENCE_DoLocalFunctionScan reached, terminated process 3375
2022.04.11 22:45:09 1: xxx.xxx.xxx.xxx:1883 reappeared (mqttClient)
2022.04.12 00:02:12 1: BlockingInformParent (BlockingRegisterTelnet): Can't connect to 127.0.0.1:7072: IO::Socket::INET: connect: Connection timed out
2022.04.12 00:02:14 1: BlockingInformParent (BlockingRegisterTelnet): Can't connect to 127.0.0.1:7072: IO::Socket::INET: connect: Connection timed out
2022.04.12 00:02:43 1: Timeout for FRITZBOX_Readout_Run_Web reached, terminated process 4007
2022.04.12 00:02:44 1: FRITZBOX FB7490: Readout_Aborted.1931 Error: Timeout when reading Fritz!Box data.
20
und das geht, bis nichts mehr geht
nach dem neustart geht es wieder für
ein paar Stunden.....
mfg
1x FHEM Debian, Homematic,ZigBee,FS20 / 1X Raspberry, ConBee / 7x ESP
1x FHEM Debian, Homematic,Z2M             / 1X Raspberry, ConBee / 6x ESP
1x FHEM Debian,MQTT2                             / 1X Raspberry, i2c,onewire,gpio
1x auf Windows 2012 Hyper-V-S
DS_Starter
gleiches Symptom wie bei mir.
hanswerner1
mfg
Ja, genau auch bei mir so.
eisman
hi,
ich habe heute vormittag: https://wiki.fhem.de/wiki/Raspberry_Pi
die Tabelle unten nach installiert( nicht alles ), seit dem habe ich den Fehler nicht mehr (hoffe ich)
aber ich warte noch bis morgen.
ob es wieder zum Absturz kommt.....
Hier geht es mW nicht um einen Absturz, sondern um eine vmtl. von FHEM verschuldete Fehlermeldung.
Ich kann mir zwar Faelle vorstellen, wo das Problem durch Installation eines externen Paketes behoben wird, die sind aber alle sehr stark konstruiert, und nicht realistisch.
eisman
hi,
ja ist korrekt, nur sind seit dem Zeitpunkt keine Meldungen mehr gekommen,
ob es der Grund war kann ich nicht sagen.
jedenfalls keine ausfälle mehr seit über 12std
mfg
DS_Starter
Zwischenstand: die 25889 läuft einwandfrei, jetzt ist die 25891 eingespielt und in der Beobachtung.
Aktueller Status: 25889 ist OK, 25896 verursacht Probleme.
Dazwischen gab es zwei Aenderungen:
- 25891: ermoeglicht, dass der Puffer fuer nicht blockierendes Schreiben ueber 1MB wachsen kann,  falls mit dem Schreiben noch nicht begonnen wurde, auch wenn man den Puffer in mehreren Aufrufen fuellt. Ueber 1MB im ersten Aufruf war auch vorher moeglich. Ich sehe damit nach 15 Minuten Code-Anstarren immer noch kein Problem. Da aber dieses Feature nicht wirklich relevant ist, werde ich es ausbauen, falls diese Version als problematisch gemeldet wird.
- 25896: korrigiert einen Syntaxfehler (@_[0] => $_[0]) bei der Regexp-Pruefung, was z.Bsp. bei der MQTT2_DEVICE Attributsetzung aufgerufen wird. Wenn das sich als Problem rausstellt (ich hoffe nicht), dann liegt das an einem internen Perl-Fehler.
DS_Starter
ich kann definitiv Probleme mit der 25891 vermelden.
Nach ein paar Stunden Laufzeit ergibt sich das bekannte Bild.
Das Frontend ist nicht mehr erreichbar, die CPU ist zu 100% ausgelastet.
2022.04.13 16:27:36.827 2: deCONZ: http request failed: read from http://192.168.2.10:32785 timed out
2022.04.13 16:27:38.764 2: HUEBridge: http request failed: read from http://192.168.2.7:80 timed out
2022.04.13 16:27:38.765 2: HUEBridge: http request failed: read from http://192.168.2.7:80 timed out
2022.04.13 16:27:39.047 2: SDS1_SVS - error while requesting http://192.168.2.10:5000/webapi/entry.cgi?api="SYNO.SurveillanceStation.HomeMode"&version="1"&method=GetInfo&_sid="LgGJMTnsCalKueXJhTjeFuG1NDEaN1ifAMW9WvQqBPIzCK1mjSoP1YTfkagQcgyUNIU4ODH5r1l3oVyqy-GbTA" - http://192.168.2.10:5000/webapi/entry.cgi?api="SYNO.SurveillanceStation.HomeMode"&version="1"&method=GetInfo&_sid="LgGJMTnsCalKueXJhTjeFuG1NDEaN1ifAMW9WvQqBPIzCK1mjSoP1YTfkagQcgyUNIU4ODH5r1l3oVyqy-GbTA": empty answer received
2022.04.13 16:27:39.109 1: BlockingInformParent (BlockingRegisterTelnet): Can't connect to 127.0.0.1:7072: IO::Socket::INET: connect: Connection timed out
2022.04.13 16:28:00.101 1: BlockingInformParent (BlockingRegisterTelnet): Can't connect to 127.0.0.1:7072: IO::Socket::INET: connect: Connection timed out
2022.04.13 16:28:00.613 1: BlockingInformParent (BlockingRegisterTelnet): Can't connect to 127.0.0.1:7072: IO::Socket::INET: connect: Connection timed out
2022.04.13 16:28:00.869 1: BlockingInformParent (SysStatHM_BlockingDone): Can't connect to 127.0.0.1:7072: IO::Socket::INET: connect: Connection timed out
2022.04.13 16:28:01.893 1: BlockingInformParent (DbRep_maxvalDone): Can't connect to 127.0.0.1:7072: IO::Socket::INET: connect: Connection timed out
2022.04.13 16:28:03.328 2: CamKE1 - error while requesting http://192.168.2.10:5000/webapi/entry.cgi?api=SYNO.SurveillanceStation.Camera&version=8&method="GetCapabilityByCamId"&cameraId=8&_sid="P1-tB1Hw2zyaoeIm3LOqNcgQHxO8vHOE_0OVU0MhQOczyhMrE5sYw03lnzI4cONWMNG2uBD6-2V8r3XVJLoeZ8" - http://192.168.2.10:5000/webapi/entry.cgi?api=SYNO.SurveillanceStation.Camera&version=8&method="GetCapabilityByCamId"&cameraId=8&_sid="P1-tB1Hw2zyaoeIm3LOqNcgQHxO8vHOE_0OVU0MhQOczyhMrE5sYw03lnzI4cONWMNG2uBD6-2V8r3XVJLoeZ8": empty answer received
2022.04.13 16:28:03.329 2: SynControl - ERROR message: http://192.168.2.10:5000/webapi/entry.cgi?api=SYNO.Cal.Event&version=3&method=list&cal_id_list=["/Heiko/cepikza/"]&start=1649714400&end=1650492000&list_repeat=true&_sid=0zqSRUjwpTXq1-Q0YOMh14GKcZFYRUZg0S2H0tvqfmMJb_JkgBVXa_O_iSInEwUCKPS8U50SS8m0UTSrW0_BvU: empty answer received
2022.04.13 16:28:03.601 2: SynControl - ERROR - "eventlist" SendQueue index "67" not executed. Restart SendQueue in 3600 s (retryCount 7).
2022.04.13 16:28:03.913 1: ZWDongle_1: SOF missing (got 12 instead of 01)
2022.04.13 16:28:10.597 1: BlockingInformParent (DbRep_delHashValFromBlocking): Can't connect to 127.0.0.1:7072: IO::Socket::INET: connect: Connection timed out
2022.04.13 16:28:11.109 1: BlockingInformParent (BlockingStart): Can't connect to 127.0.0.1:7072: IO::Socket::INET: connect: Connection timed out
Danke fuers Testen, ich habe die Aenderungen ausgebaut.
Ich habe nochmal darueber gegruebelt, wie diese Aenderung das Problem ausloesen koennte, leider ohne Erfolg.
Und wenn die CPU erst nach Stunden auf 100% geht, und damit FHEM nicht mehr reagiert, ist debuggen auch schwierig.
Burny4600
#25
Ich bin noch meine Modulversionen schuldig.
Rasp01
Latest Revision: 25948
File                 Rev   Last Change
95_Alarm.pm          17344 2018-09-14 14:05:23Z phenning
96_allowed.pm        25797 2022-03-08 08:54:57Z rudolfkoenig
95_Astro.pm          25198 2021-11-07 15:42:54Z phenning
90_at.pm             25248 2021-11-21 10:29:01Z rudolfkoenig
98_autocreate.pm     23727 2021-02-12 20:31:37Z rudolfkoenig
70_BRAVIA.pm         24219 2021-04-11 14:29:19Z vuffiraa
98_cloneDummy.pm     13015 2017-01-08 20:26:33Z betateilchen
00_CUL.pm            24815 2021-08-01 16:14:02Z rudolfkoenig
15_CUL_EM.pm         16293 2018-02-28 21:33:57Z rudolfkoenig
09_CUL_FHTTK.pm      18391 2019-01-23 19:05:58Z Matscher
10_CUL_HM.pm         25298 2021-12-05 08:23:08Z martinp876
18_CUL_HOERMANN.pm   15510 2017-11-27 16:52:44Z rudolfkoenig
14_CUL_REDIRECT.pm   18358 2019-01-20 20:21:05Z bjoernh
14_CUL_TCM97001.pm   20839 2019-12-28 09:41:47Z bjoernh
14_CUL_TX.pm         17102 2018-08-08 05:34:42Z rudolfkoenig
14_CUL_WS.pm         20918 2020-01-08 19:20:38Z rudolfkoenig
98_dewpoint.pm       18846 2019-03-10 11:45:58Z hotbso
98_DOIF.pm           25946 2022-04-11 08:24:02Z Damian
98_DOIFtools.pm      22610 2020-08-15 17:21:34Z Ellert
98_Dooya.pm          15400 2017-11-05 18:11:51Z Sidey
98_dummy.pm          25606 2022-02-01 10:43:57Z rudolfkoenig
No Id found for 99_Easymeter.pm
70_ENIGMA2.pm        18995 2019-03-22 20:09:53Z loredo
91_eventTypes.pm     23471 2021-01-04 19:24:21Z rudolfkoenig
93_FHEM2FHEM.pm      25703 2022-02-18 18:25:03Z rudolfkoenig
01_FHEMWEB.pm        25943 2022-04-10 11:34:15Z rudolfkoenig
11_FHT.pm            25689 2022-02-15 20:50:26Z rudolfkoenig
92_FileLog.pm        25748 2022-02-27 10:29:56Z rudolfkoenig
14_FLAMINGO.pm       22619 2020-08-17 17:29:09Z HomeAuto_User
95_FLOORPLAN.pm      13735 2017-03-19 12:43:53Z UliM
98_freezemon.pm      25141 2021-10-28 19:13:56Z Adimarantis
10_FS10.pm           25488 2022-01-17 20:59:06Z Sidey
10_FS20.pm           14888 2017-08-13 12:07:12Z rudolfkoenig
No Id found for 58_GPIO4.pm
98_help.pm           25013 2021-09-23 21:07:00Z betateilchen
14_Hideki.pm         25560 2022-01-25 21:43:09Z Sidey
98_HMinfo.pm         25293 2021-12-04 17:37:15Z martinp876
00_HMUARTLGW.pm      25203 2021-11-08 09:18:29Z mgernoth
95_holiday.pm        25187 2021-11-06 09:54:35Z rudolfkoenig
98_HourCounter.pm    11307 2016-04-25 08:02:06Z rudolfkoenig
98_HTTPMOD.pm        24708 2021-07-06 17:15:46Z StefanStrobel
52_I2C_MCP23017.pm   19551 2019-06-04 20:10:50Z klausw
No Id found for 52_I2C_SUSV.pm
10_IT.pm             20839 2019-12-28 09:41:47Z bjoernh
70_JSONMETER.pm      20819 2019-12-23 23:07:57Z tupol
13_KS300.pm          20008 2019-08-17 10:24:14Z rudolfkoenig
98_logProxy.pm       25793 2022-03-07 18:47:32Z justme1968
59_LuftdatenInfo.pm  25647 2022-02-07 09:14:08Z rudolfkoenig
No Id found for 70_MppSolarPip.pm
10_MQTT2_DEVICE.pm   25889 2022-03-27 10:39:22Z rudolfkoenig
00_MQTT2_SERVER.pm   25943 2022-04-10 11:34:15Z rudolfkoenig
# $Id: 99_myUtils.pm  2016-09-25  V1.0  Christian Schmidt $
99_myUtils_Astro.pm     11 2017-07-15 00:00:00Z Fhemmike
91_notify.pm         25888 2022-03-27 10:22:58Z rudolfkoenig
34_NUT.pm             9023 2015-08-05 09:00:12Z narsskrarc
41_OREGON.pm         18660 2019-02-19 22:44:37Z Sidey
59_PROPLANTA.pm      23449 2021-01-01 09:56:49Z tupol
33_readingsGroup.pm  23844 2021-02-27 19:43:24Z justme1968
33_readingsProxy.pm  16299 2018-03-01 08:06:55Z justme1968
19_Revolt.pm         24864 2021-08-22 05:57:16Z yoda_gh
44_ROLLO.pm          18436 2019-01-27 20:46:04Z KernSani
00_RPII2C.pm         23664 2021-02-02 23:48:59Z klausw
51_RPI_GPIO.pm       19785 2019-07-05 21:39:13Z klausw
14_SD_BELL.pm        24840 2021-08-09 19:57:53Z HomeAuto_User
10_SD_GT.pm          22380 2020-07-10 19:58:00Z Sidey
# $Id: 14_SD_Keeloq.pm 0 2021-08-12 11:49:29Z $
14_SD_UT.pm          24839 2021-08-09 19:55:13Z HomeAuto_User
14_SD_WS.pm          25484 2022-01-17 20:50:12Z Sidey
14_SD_WS07.pm        25485 2022-01-17 20:52:47Z Sidey
14_SD_WS_Maverick.pm 21666 2020-04-13 21:14:53Z Sidey
# $Id: 99_serial.pm $ 06/16/2013
No Id found for 99_sethmkey.pm
00_SIGNALduino.pm    25549 2022-01-23 10:59:59Z Sidey
90_SIGNALduino_un.pm 20749 2019-12-14 22:35:00Z Sidey
98_Siro.pm           20772 2019-12-17 16:52:51Z Byte09
10_SOMFY.pm          22865 2020-09-27 15:55:14Z viegener
98_structure.pm      24999 2021-09-21 07:54:25Z rudolfkoenig
99_SUNRISE_EL.pm     24249 2021-04-14 05:45:49Z rudolfkoenig
98_SVG.pm            25876 2022-03-23 11:28:24Z rudolfkoenig
42_SYSMON.pm         24758 2021-07-16 13:54:47Z hexenmeister
98_telnet.pm         25754 2022-02-27 16:49:52Z rudolfkoenig
46_TRX_ELSE.pm       16542 2018-04-02 22:10:20Z KernSani
46_TRX_LIGHT.pm      21770 2020-04-24 20:20:40Z KernSani
46_TRX_SECURITY.pm   20805 2019-12-22 15:31:48Z KernSani
59_Twilight.pm       25067 2021-10-13 04:26:30Z Beta-User
10_UNIRoll.pm        20792 2019-12-20 17:32:00Z rudolfkoenig
98_update.pm         25724 2022-02-21 17:12:17Z rudolfkoenig
99_Utils.pm          24128 2021-04-02 16:29:11Z rudolfkoenig
98_version.pm        15140 2017-09-26 09:20:09Z markusbloch
98_weblink.pm        23597 2021-01-23 17:57:05Z rudolfkoenig
AttrTemplate.pm      25155 2021-10-30 12:48:21Z rudolfkoenig
Blocking.pm          23268 2020-12-01 11:48:48Z rudolfkoenig
Color.pm             20813 2019-12-22 18:42:10Z justme1968
DevIo.pm             25716 2022-02-20 17:39:00Z rudolfkoenig
GPUtils.pm           19666 2019-06-20 11:17:29Z CoolTux
HMConfig.pm          25160 2021-10-30 17:38:52Z martinp876
HttpUtils.pm         25784 2022-03-06 09:20:24Z rudolfkoenig
Meta.pm              21008 2020-01-18 10:22:10Z loredo
RTypes.pm            10476 2016-01-12 21:03:33Z borisneubert
SD_Protocols.pm      25549 2022-01-23 10:59:59Z Sidey
SetExtensions.pm     25286 2021-12-03 10:16:56Z rudolfkoenig
TcpServerUtils.pm    25866 2022-03-21 09:01:16Z rudolfkoenig
UConv.pm             21159 2020-02-09 14:04:27Z loredo
doif.js                    24438 2021-05-14 18:08:18Z Ellert
fhemweb.js                 25924 2022-04-05 14:38:39Z rudolfkoenig
fhemweb_readingsGroup.js   15189 2017-10-03 17:53:27Z justme1968
svg.js                     23428 2020-12-27 22:07:20Z rudolfkoenig
Ich habe aber in der Zwischenzeit einen Austausch der Hauptinstanz von einem Rp3+ V1.2 auf einen Rp4 mit 4GB Ram durchgeführt.
Dabei das Ganze System mit Buster Lite neu installiert. Buster Lite ist auch auf den anderen Systemen installiert.
Jetzt ist das Problem nach einem Neustart nur bei den TelNet und FHEM2FHEM Verbindungen der Fall, was sich nach einiger Zeit beruhigt.
Was mir aber bei der Systemauslastung aufgefallen ist, ist nur bei der Hauptinstanz die ständig wiederkehrend Netzwerklast, wobei das beim Rp4 nicht stört, aber auffällig ist.
Ich habe die restlichen 9 Rp überprüft, ob das bei diesen auch der Fall ist. Da ist aber nichts auffälliges, obwohl alle Systeme aktuell sind.
Was die Ursache des stündlichen Anstiegs des Netzwerkempfangs am Ras01 ist, habe ich noch nicht herausgefunden.
Hier die Versionen der 9 Rp.
Rasp02
98_Modbus.pm        24146 2021-04-04 10:30:25Z StefanStrobel
# $Id: 98_ModbusEPEVER.pm $
No Id found for 98_ModbusSDM630M.pm
98_PID20.pm         10722 2016-02-04 17:12:18Z john99sr
98_statistics.pm    20819 2019-12-23 23:07:57Z tupol
# $Id: 39_STELLMOTOR.pm 3002 2014-10-03 11:51:00Z Florian Duesterwald $
Rasp03
52_I2C_MCP342x.pm   19551 2019-06-04 20:10:50Z klausw
51_I2C_TSL2561.pm   15723 2017-12-29 21:08:17Z jensb
Rasp04
51_I2C_BMP180.pm    18271 2019-01-15 19:39:40Z klausw
Rasp05
Rasp06
Rasp07
Rasp08
73_PRESENCE.pm      20782 2019-12-19 10:51:06Z markusbloch
44_TEK603.pm        22613 2020-08-16 09:12:36Z eisler
Rasp09
Rasp10
Vielleicht sieht man beim Vergleich etwas heraus, welches Modul es nicht sein kann.
MfG Chris
Raspberry Pi 2-5, Bullseye Lite, Bookworm Lite
Devices: APC, Eastron, FS20, IT, Homematic, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, S.USV, TEK603, WMR200, YouLess
DS_Starter
Danke Rudi, ich habe die Version bei mir auch gleich implementiert.
Es müssen m.M. nach ein paar Nebenbedingungen zutreffen, damit sich dieser Fehler zeigt.
Bei mir ist auch nur die produktive Instanz betroffen und bei anderen Usern die sich gemeldet haben, sieht es ja ähnlich aus.
Vielleicht kommen wir noch dahinter ...
Schöne Ostern !
Heiko
hanswerner1
Die 25957 läuft bei mir jetzt über 24h stabil.
Schöne Ostern
HW1
rossi007
Auch bei mir sind nach Update massive Probleme aufgetreten - leider gab es bei uns wegen Schneefall einen 2,5 Stunden Stromausfall, weswegen ich die Probleme zunächst darauf zurückgeführt habe. Es ist dadurch auch so, daß das Mesh der Fritzbox überlastet ist und abstürzt, weil zahlreiche Sensoren, die über MQTT2 angekoppelt sind, keine Verbindung mehr haben und dauernde Versuche absetzen.
Generell sind alle Verbindungen betroffen, die über TCP von FHEM aufgebaut werden. Nach viertägiger Suche bin ich zu folgenden Indizien gekommen:
- es kommt fortlaufend (nach kurzer Zeit nach dem Reboot) zu Freezes, die Perfmon mit ca. 10s angibt
- in Linux sieht man mit "netstat -an", daß jede Menge Verbindungen im Bereich TCP auflaufen, die hängenbleiben und im Status "Close_Wait" verharren, da die Verbindung nicht abgebaut wird. Damit säuft das System dann geschmeidig ab
- Auch Abfragen von Webpages über HTTPMOD bleiben so hängen und blockieren
Ich habe nun nach Fehlersuche im Netzwerk (die Nichterreichbarkeit der Teilnehmer liegt an der Blockade, nicht am Netzwerk selbst - man kann z.B. nicht mehr per HTTP auf das Webinterface eines Sensors zugreifen) alle devices auskommentiert, die TCP benutzen. Damit läuft FHEM wieder flüssig und alle Verbindungen zu der Sensorik sowie die Fritzbox funktionieren sofort wieder (schade - ich habe mir vor Panik bereits einen neue 7590AX bestellt, aber das schadet ja nichts  ;))
Beim schrittweisen Aktivieren wird FHEM dezent langsamer, Freezes von 1,5 bis 4s treten gelegentlich auf.
Als letztes habe ich alexa-fhem, bzw. den zugehörigen FHEMWEB-Port wieder freigegeben und damit ist das Chaos reproduzierbar wieder in vollem Umfang da. Es liegt wohl daran, daß der Kontakt zu Alexa einen ständigen intensiven Datenverkehr hervorruft. Ohne Alexa-Kopplung läuft das System mit leichten Freezes
Ich hoffe, diese Beobachtungen tragen dazu bei, das Problem einzugrenzen - ich werde nun versuchen, das fhem.pl downzugraden.
Uwe
ZitatIch hoffe, diese Beobachtungen tragen dazu bei, das Problem einzugrenzen - ich werde nun versuchen, das fhem.pl downzugraden.
Sind diese Probleme mit fhem.pl Version >= 25957 vorhanden?
