(Gelöst) Alexa mit Zigbee2Mqtt Dimmen
Begonnen von SamNitro, 01 Dezember 2022, 15:36:23
TomLee
#15
Zitat... aber zum einen ist das irritierend, dass man zwar nur 254 reinkloppen darf, aber (fast) 255 zurückkommt?!?
Das war ein Kopierfehler, hatte das gestern nur so nebenbei bei einer kurzen Pause am Tablet nachvollzogen.
Heute kränkle ich sowieso und es hat mich nicht losgelassen bis ich den korrekten Umrechnungsfaktor rausgefunden habe  ::), der ist:
0.39370078740157425
15:25:12.449
SENT
zigbee2mqtt/0x00158d0003278378/set
{"state":"on","brightness":"100"}
15:25:12.532
mqttjs_91f275c4
zigbee2mqtt/bridge/logging
{"level":"debug","message":"Received MQTT message on 'zigbee2mqtt/0x00158d0003278378/set' with data '{\"state\":\"on\",\"brightness\":\"100\"}'"}
15:25:12.550
mqttjs_91f275c4
{"level":"debug","message":"Publishing 'set' 'brightness' to '0x00158d0003278378'"}
15:25:12.561
mqttjs_91f275c4
{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/0x00158d0003278378', payload '{\"brightness\":100,\"color_mode\":\"color_temp\",\"color_temp\":320,\"linkquality\":143,\"state\":\"ON\"}'"}
15:25:12.572
mqttjs_91f275c4
{"brightness":100,"color_mode":"color_temp","color_temp":320,"linkquality":143,"state":"ON"}
15:25:17.885
SENT
{"state":"on","brightness":"75"}
15:25:17.967
mqttjs_91f275c4
{"level":"debug","message":"Received MQTT message on 'zigbee2mqtt/0x00158d0003278378/set' with data '{\"state\":\"on\",\"brightness\":\"75\"}'"}
15:25:17.977
mqttjs_91f275c4
15:25:18.000
mqttjs_91f275c4
{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/0x00158d0003278378', payload '{\"brightness\":75,\"color_mode\":\"color_temp\",\"color_temp\":320,\"linkquality\":143,\"state\":\"ON\"}'"}
15:25:18.010
mqttjs_91f275c4
{"brightness":75,"color_mode":"color_temp","color_temp":320,"linkquality":143,"state":"ON"}
15:25:23.440
SENT
{"state":"on","brightness":"49"}
15:25:23.522
mqttjs_91f275c4
{"level":"debug","message":"Received MQTT message on 'zigbee2mqtt/0x00158d0003278378/set' with data '{\"state\":\"on\",\"brightness\":\"49\"}'"}
15:25:23.532
mqttjs_91f275c4
15:25:23.552
mqttjs_91f275c4
{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/0x00158d0003278378', payload '{\"brightness\":49,\"color_mode\":\"color_temp\",\"color_temp\":320,\"linkquality\":143,\"state\":\"ON\"}'"}
15:25:23.562
mqttjs_91f275c4
{"brightness":49,"color_mode":"color_temp","color_temp":320,"linkquality":143,"state":"ON"}
Zitat von: TomLee am 02 Dezember 2022, 15:26:25der ist:
0.39370078740157425
...auf sowas ähnliches war ich auch gekommen, daher die Kurzform ohne den Kleinschmodder hinter den zwei Nullen...
Bedeutet: "Bitte übernehmen" (weil die damit ermittelten Zahlenwerte super-integer sind) oder "ich melde mich nochmal, wenn ich das im fitten Zustand getestet habe"?
(Ich kann das nicht aus eigener Anschauung beurteilen und werde aus dem Log auch nicht so schlau wie es vermutlich gedacht ist).
TomLee
Bedeutet, bitte genauso jetzt übernehmen, das gestern mit einer Stelle mehr, war einfach nur ein Schnellschuss, weil ich eh am schreiben war, du aber schneller warst und das mit factor schon angesprochen hattest.
Der Auszug aus dem letzten Beitrag ist der MQTT-Verkehr am MQTT2-Server, bei dem drei Sprachbefehle abgesetzt wurden.
Es kommt also genau das zurüxk was auch gesendet wurde.
Wenn jetzt noch fragen sind hab ich erstmal keine Zeit, weil eh heut schon alles liegengeblieben ist wegen der Kacke und ich trotz kränkeln noch was arbeiten will.
SamNitro
Hallo, ich habe wieder einen Fehler im system, jetzt bekomme ich einen brightness wert von:
set 254.00000000000034
obwohl der factor=0.39370078740157425 ist..
(Intel-Nuc Proxmox) (Homematic) (EnOcean) (CUL868) (CUL433) (Zigbee2MQTT) (ESP8266) (Echo) (DUOFERN)
Bitte mal mit den ersten 4 stellen testen.
SamNitro
mit folgendem Faktor geht es:
0.39370078740159
damit bekomme ich
brightness = 253.9999999999902
TomLee
Interessant wär den MQTT Verkehr zu sehen mit factor=0.39370078740157425.
Ich vermute von Alexa kommt 100 zurück und in z2m wird bei dem dimmer wieder anders gerechnet wie mit den Leuchten mit denen ich getestet hatte.
SamNitro
Alexa log erst 50% dann 100%
[8.12.2022, 19:00:51] >>>> [ssh] {"directive":{"header":{"messageId":"78201bf7-a64e-4a46-971d-c8c5e8e795c1","namespace":"Alexa.BrightnessController","name":"SetBrightness","payloadVersion":"3","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"39F6EFCC-F7ADEA4A9C957841"},"endpointId":"638a23df-f33f-19ae-5f8a-24d32dfafe6ee68b","cookie":{"device":"MQTT2_zigbee_Stehlampe","fuuid":"638a23df-f33f-19ae-5f8a-24d32dfafe6ee68b"}},"payload":{"brightness":50}}}
[8.12.2022, 19:00:51] [FHEM]     caching: Brightness: NaN (as number; from 'set 254.00000000000034')
[8.12.2022, 19:00:51] [FHEM] MQTT2_zigbee_Stehlampe: executing set cmd for Brightness with value 50
[8.12.2022, 19:00:51] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=set%20MQTT2_zigbee_Stehlampe%20brightness%20127.00000000000017&XHR=1
[8.12.2022, 19:00:51] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.BrightnessController","name":"brightness","value":50,"timeOfSample":"2022-12-08T18:00:51.254Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"9379a7ca-605b-4f91-ba3e-0a76bb810ebf","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"39F6EFCC-F7ADEA4A9C957841"},"endpointId":"638a23df-f33f-19ae-5f8a-24d32dfafe6ee68b"},"payload":{}}}
  2022-12-08 19:00:51 caching: MQTT2_zigbee_Stehlampe-brightness: set 127.00000000000017
[8.12.2022, 19:00:51] [FHEM]     caching: Brightness: NaN (as number; from 'set 127.00000000000017')
  2022-12-08 19:00:51 caching: MQTT2_zigbee_Stehlampe-brightness: 127.00000000000017
[8.12.2022, 19:00:51] [FHEM]     caching: Brightness: 50 (as number; from '127.00000000000017')
[8.12.2022, 19:00:55] >>>> [ssh] {"directive":{"header":{"messageId":"91ba84fd-1b17-4207-91e2-20bcb527a51d","namespace":"Alexa.BrightnessController","name":"SetBrightness","payloadVersion":"3","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"39F6EFCC-F7ADEA4A9C957841"},"endpointId":"638a23df-f33f-19ae-5f8a-24d32dfafe6ee68b","cookie":{"device":"MQTT2_zigbee_Stehlampe","fuuid":"638a23df-f33f-19ae-5f8a-24d32dfafe6ee68b"}},"payload":{"brightness":100}}}
[8.12.2022, 19:00:55] [FHEM]     caching: Brightness: 50 (as number; from '127.00000000000017')
[8.12.2022, 19:00:55] [FHEM] MQTT2_zigbee_Stehlampe: executing set cmd for Brightness with value 100
[8.12.2022, 19:00:55] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=set%20MQTT2_zigbee_Stehlampe%20brightness%20254.00000000000034&XHR=1
[8.12.2022, 19:00:55] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.BrightnessController","name":"brightness","value":100,"timeOfSample":"2022-12-08T18:00:55.722Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"b41ec524-c066-4078-9b79-0f88c109e4be","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"39F6EFCC-F7ADEA4A9C957841"},"endpointId":"638a23df-f33f-19ae-5f8a-24d32dfafe6ee68b"},"payload":{}}}
  2022-12-08 19:00:55 caching: MQTT2_zigbee_Stehlampe-brightness: set 254.00000000000034
[8.12.2022, 19:00:55] [FHEM]     caching: Brightness: NaN (as number; from 'set 254.00000000000034')
MQTT 50% und 100%
19:03:46.961
SENT
zigbee2mqtt/0x842e14fffe413dbb/set
{"state":"on","brightness":"127.00000000000017"}
19:03:47.083
zigbee2mqtt
{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/0x842e14fffe413dbb', payload '{\"brightness\":127.00000000000017,\"linkquality\":160,\"power_on_behavior\":\"on\",\"state\":\"ON\",\"update\":{\"state\":\"idle\"},\"update_available\":false}'"}
19:03:47.087
zigbee2mqtt
{"brightness":127.00000000000017,"linkquality":160,"power_on_behavior":"on","state":"ON","update":{"state":"idle"},"update_available":false}
19:03:51.713
SENT
{"state":"on","brightness":"254.00000000000034"}
19:03:51.719
zigbee2mqtt
{"level":"error","message":"Publish 'set' 'brightness' to '0x842e14fffe413dbb' failed: 'Error: Brightness value of message: '{\"state\":\"on\",\"brightness\":\"254.00000000000034\"}' invalid, must be a number >= 0 and =< 254'"}
19:03:51.723
zigbee2mqtt
{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{\"message\":\"Publish 'set' 'brightness' to '0x842e14fffe413dbb' failed: 'Error: Brightness value of message: '{\\\"state\\\":\\\"on\\\",\\\"brightness\\\":\\\"254.00000000000034\\\"}' invalid, must be a number >= 0 and =< 254'\",\"meta\":{\"friendly_name\":\"0x842e14fffe413dbb\"},\"type\":\"zigbee_publish_error\"}'"}
19:03:51.727
zigbee2mqtt
{"message":"Publish 'set' 'brightness' to '0x842e14fffe413dbb' failed: 'Error: Brightness value of message: '{\"state\":\"on\",\"brightness\":\"254.00000000000034\"}' invalid, must be a number >= 0 and =< 254'","meta":{"friendly_name":"0x842e14fffe413dbb"},"type":"zigbee_publish_error"}
TomLee
#23
Hmm, keine Ahnung, bei mir siehts im Alexa_log gut aus.
Meine alexa-fhem Version ist die 0.5.61.
[8.12.2022, 19:32:49] >>>> [srv] {"directive":{"header":{"messageId":"0e69814c-fdbe-465c-bd6f-c365216d759a","namespace":"Alexa.BrightnessController","name":"SetBrightness","payloadVersion":"3","correlationToken":"bla"},"endpoint":{"scope":{"type":"BearerToken","token":"bla"},"endpointId":"5fcd1b4c-f33f-78f5-517f-83893558e44c8d56","cookie":{"device":"MQTT2_zigbee_gu10_6","fuuid":"5fcd1b4c-f33f-78f5-517f-83893558e44c8d56"}},"payload":{"brightness":50}}}
[8.12.2022, 19:32:49] accepted new token
[8.12.2022, 19:32:49] [FHEM] MQTT2_zigbee_gu10_6: executing set cmd for Brightness with value 50
[8.12.2022, 19:32:49] [FHEM]   executing: http://192.168.188.26:8083/fhem?cmd=set%20MQTT2_zigbee_gu10_6%20brightness%2050&fwcsrf=bla&XHR=1
[8.12.2022, 19:32:49] <<<< [srv] {"context":{"properties":[{"namespace":"Alexa.BrightnessController","name":"brightness","value":50,"timeOfSample":"2022-12-08T18:32:49.580Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"e7031e31-4203-450c-ac0e-2f6cf4562f34","correlationToken":"bla"},"endpoint":{"scope":{"type":"BearerToken","token":"bla"},"endpointId":"5fcd1b4c-f33f-78f5-517f-83893558e44c8d56"},"payload":{}}}
[8.12.2022, 19:32:56] >>>> [srv] {"directive":{"header":{"messageId":"d3e81897-c3e4-421c-8343-81b34931f1d4","namespace":"Alexa.BrightnessController","name":"SetBrightness","payloadVersion":"3","correlationToken":"bla"},"endpoint":{"scope":{"type":"BearerToken","token":"bla"},"endpointId":"5fcd1b4c-f33f-78f5-517f-83893558e44c8d56","cookie":{"device":"MQTT2_zigbee_gu10_6","fuuid":"5fcd1b4c-f33f-78f5-517f-83893558e44c8d56"}},"payload":{"brightness":100}}}
[8.12.2022, 19:32:56] accepted new token
[8.12.2022, 19:32:56] [FHEM] MQTT2_zigbee_gu10_6: executing set cmd for Brightness with value 100
[8.12.2022, 19:32:56] [FHEM]   executing: http://192.168.188.26:8083/fhem?cmd=set%20MQTT2_zigbee_gu10_6%20brightness%20100&fwcsrf=bla&XHR=1
[8.12.2022, 19:32:56] <<<< [srv] {"context":{"properties":[{"namespace":"Alexa.BrightnessController","name":"brightness","value":100,"timeOfSample":"2022-12-08T18:32:56.503Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"ac8ddf5c-f16d-4c23-b115-9ff271154173","correlationToken":"bla"},"endpoint":{"scope":{"type":"BearerToken","token":"bla"},"endpointId":"5fcd1b4c-f33f-78f5-517f-83893558e44c8d56"},"payload":{}}}
19:32:49.628
SENT
{"state":"on","brightness":"50"}
19:32:49.783
mqttjs_91f275c4
{"level":"debug","message":"Received MQTT message on 'zigbee2mqtt/0x00158d0003278378/set' with data '{\"state\":\"on\",\"brightness\":\"50\"}'"}
19:32:49.793
mqttjs_91f275c4
19:32:49.813
mqttjs_91f275c4
{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/0x00158d0003278378', payload '{\"brightness\":50,\"color_mode\":\"color_temp\",\"color_temp\":320,\"linkquality\":143,\"state\":\"ON\"}'"}
19:32:49.823
mqttjs_91f275c4
{"brightness":50,"color_mode":"color_temp","color_temp":320,"linkquality":143,"state":"ON"}
19:32:56.544
SENT
19:32:56.696
mqttjs_91f275c4
19:32:56.706
mqttjs_91f275c4
19:32:56.718
mqttjs_91f275c4
19:32:56.729
mqttjs_91f275c4
define MQTT2_zigbee_gu10_6 MQTT2_DEVICE zigbee_0x00158d0003278378
attr MQTT2_zigbee_gu10_6 userattr lightSceneParamsToSave lightSceneRestoreOnlyIfChanged:1,0 structexclude wzdl wzdl_map
attr MQTT2_zigbee_gu10_6 IODev MQTT2_Server
attr MQTT2_zigbee_gu10_6 alexaName decke6
attr MQTT2_zigbee_gu10_6 devStateIcon {zigbee2mqtt_devStateIcon255($name)}
attr MQTT2_zigbee_gu10_6 devicetopic zigbee2mqtt/0x00158d0003278378
attr MQTT2_zigbee_gu10_6 genericDeviceType light
attr MQTT2_zigbee_gu10_6 group Wohnzimmer
attr MQTT2_zigbee_gu10_6 homebridgeMapping Brightness=brightness::brightness,maxValue=100,0.393700787401574250 ,delay=true
attr MQTT2_zigbee_gu10_6 icon light_control
attr MQTT2_zigbee_gu10_6 imageLink /fhem/deviceimages/mqtt2/404006-404008-404004.jpg
attr MQTT2_zigbee_gu10_6 jsonMap color_temp:ct color_temp_startup:ct_startup
attr MQTT2_zigbee_gu10_6 model zigbee2mqtt_light_cct
attr MQTT2_zigbee_gu10_6 readingList $DEVICETOPIC:.* { json2nameValue($EVENT,'',$JSONMAP) }
attr MQTT2_zigbee_gu10_6 room MQTT2_DEVICE,Privat->OG->Wohnzimmer
attr MQTT2_zigbee_gu10_6 setList on:noArg $DEVICETOPIC/set {"brightness": 120 , "state":"ON", "color_temp": 320}\
  off:noArg $DEVICETOPIC/set {"state":"OFF"}\
  brightness:colorpicker,BRI,0,5,255 $DEVICETOPIC/set {"state":"on","$EVTPART0":"$EVTPART1"}\
  ct:colorpicker,CT,154,2,500 $DEVICETOPIC/set {"color_temp":"$EVTPART1"}\
  ct_startup:coolest,cool,neutral,warmest,previous $DEVICETOPIC/set {"color_temp_startup":"$EVTPART1"}
attr MQTT2_zigbee_gu10_6 setStateList on off
attr MQTT2_zigbee_gu10_6 verbose 2
attr MQTT2_zigbee_gu10_6 webCmd toggle:on:off:brightness:ct
attr MQTT2_zigbee_gu10_6 webCmdLabel Helligkeit\
#   CID        zigbee_0x00158d0003278378
#   DEF        zigbee_0x00158d0003278378
#   FUUID      5fcd1b4c-f33f-78f5-517f-83893558e44c8d56
#   IODev      MQTT2_Server
#   LASTInputDev MQTT2_Server
#   MQTT2_Server_CONN MQTT2_Server_127.0.0.1_44538
#   MQTT2_Server_MSGCNT 170
#   MQTT2_Server_TIME 2022-12-08 19:32:56
#   MSGCNT     170
#   NAME       MQTT2_zigbee_gu10_6
#   NR         280
#   STATE      ON
#   TYPE       MQTT2_DEVICE
#   eventCount 340
#   .DT:
#     DEVICETOPIC zigbee2mqtt/0x00158d0003278378
#   .attraggr:
#   .attrminint:
#   JSONMAP:
#     color_temp ct
#     color_temp_startup ct_startup
#   READINGS:
#     2022-12-02 15:19:30   IODev           MQTT2_Server
#     2022-12-08 19:32:56   brightness      100
#     2022-12-08 19:32:56   color_mode      color_temp
#     2022-12-08 19:32:56   ct              320
#     2022-12-08 19:32:56   linkquality     143
#     2022-12-08 19:32:56   state           ON
setstate MQTT2_zigbee_gu10_6 ON
setstate MQTT2_zigbee_gu10_6 2022-12-02 15:19:30 IODev MQTT2_Server
setstate MQTT2_zigbee_gu10_6 2022-12-08 19:32:56 brightness 100
setstate MQTT2_zigbee_gu10_6 2022-12-08 19:32:56 color_mode color_temp
setstate MQTT2_zigbee_gu10_6 2022-12-08 19:32:56 ct 320
setstate MQTT2_zigbee_gu10_6 2022-12-08 19:32:56 linkquality 143
setstate MQTT2_zigbee_gu10_6 2022-12-08 19:32:56 state ON
SamNitro
TomLee
Ich mach später oder morgen mal ein update, um auszuschliessen das es an der Version liegt.
SamNitro
bei dir rechnet der ja nix um.. mqtt sendet bei dir brightness 50 und 100
SamNitro
Habe noch was gefunden:
homebridgeMapping Brightness=brightness::brightness,maxValue=100,max=100,factor=0.39371,delay=true
damit bekomme ich nur glatte werte
100% = brightness 254
50%   = brightness 127
TomLee
Tatsache, ich hab tatsächlich das homebridgemapping falsch, da fehlt das factor und die ganze Zeit einen Denkfehler, sry an beide, schäm.
TomLee
Zitatdamit bekomme ich nur glatte werte
Ich halt zwar besser den Mund, aber ja ich auch.
