Umstellung auf VCCU => wirre Readings aller Homematic Komponenten
Begonnen von DonCornuto, 01 Januar 2024, 15:03:49
DonCornuto
...wenn ich alles in eine Antwort schreibe bekomme ich "Datenbankfehler..." als Rückmeldung.
Syslog Teil 1/2
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd-modules-load[141]: Inserted module 'i2c_dev'
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem fake-hwclock[146]: Sun  7 Jan 17:45:30 UTC 2024
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd-fsck[154]: e2fsck 1.46.2 (28-Feb-2021)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished Set the console keyboard layout.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished Coldplug All udev Devices.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Helper to synchronize boot up for ifupdown...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished Helper to synchronize boot up for ifupdown.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd-fsck[154]: rootfs: clean, 74361/30878144 files, 15715827/124960342 blocks
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished File System Check on Root Device.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Remount Root and Kernel File Systems...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished Remount Root and Kernel File Systems.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Flush Journal to Persistent Storage...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Load/Save Random Seed...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Create System Users...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished Load/Save Random Seed.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Condition check resulted in First Boot Complete being skipped.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished Create System Users.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Create Static Device Nodes in /dev...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished Create Static Device Nodes in /dev.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Reached target Local File Systems (Pre).
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Rule-based Manager for Device Events and Files...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished Flush Journal to Persistent Storage.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Started Rule-based Manager for Device Events and Files.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd-udevd[181]: Using default interface naming scheme 'v247'.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd-udevd[181]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem mtp-probe: checking bus 1, device 3: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4"
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Condition check resulted in Huge Pages File System being skipped.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem mtp-probe: bus: 1, device: 3 was not an MTP device
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem mtp-probe: checking bus 2, device 2: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb2/2-2"
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem mtp-probe: bus: 2, device: 2 was not an MTP device
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Found device Intenso_SSD_SATAIII boot.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting File System Check on /dev/disk/by-partuuid/ea796b08-01...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd-udevd[190]: event0: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd-udevd[192]: event1: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd-fsck[311]: fsck.fat 4.2 (2021-01-31)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd-fsck[311]: /dev/sda1: 335 files, 101472/516190 clusters
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished File System Check on /dev/disk/by-partuuid/ea796b08-01.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Mounting /boot...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Mounted /boot.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Reached target Local File Systems.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Set console font and keymap...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Raise network interfaces...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Preprocess NFS configuration...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Create Volatile Files and Directories...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished Set console font and keymap.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: nfs-config.service: Succeeded.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished Preprocess NFS configuration.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Reached target NFS client services.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Reached target Remote File Systems (Pre).
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Reached target Remote File Systems.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished Create Volatile Files and Directories.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Network Time Synchronization...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished Update UTMP about System Boot/Shutdown.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished Raise network interfaces.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Started Network Time Synchronization.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Reached target System Initialization.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Started Daily Cleanup of Temporary Directories.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Reached target System Time Set.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Reached target System Time Synchronized.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Started Daily apt download activities.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Started Daily apt upgrade and clean activities.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Started Periodic ext4 Online Metadata Check for All Filesystems.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Started Discard unused blocks once a week.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Started Daily rotation of log files.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Started Daily man-db regeneration.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Reached target Timers.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Listening on D-Bus System Message Bus Socket.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Listening on triggerhappy.socket.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Reached target Sockets.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Reached target Basic System.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Condition check resulted in Manage Sound Card State (restore and store) being skipped.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Save/Restore Sound Card State...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Started Regular background program processing daemon.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Started D-Bus System Message Bus.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem cron[376]: (CRON) INFO (pidfile fd = 3)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Started deCONZ: ZigBee gateway -- Update Service.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem cron[376]: (CRON) INFO (Running @reboot jobs)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Found user 'avahi' (UID 108) and group 'avahi' (GID 113).
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Successfully dropped root privileges.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem avahi-daemon[375]: avahi-daemon 0.8 starting up.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Remove Stale Online ext4 Metadata Check Snapshots...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Condition check resulted in Configure Bluetooth Modems connected by UART being skipped.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Condition check resulted in Copy user wpa_supplicant.conf being skipped.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting DHCP Client Daemon...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting LSB: rng-tools (Debian variant)...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Successfully called chroot().
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Successfully dropped remaining capabilities.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem dhcpcd[394]: dev: loaded udev
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem avahi-daemon[375]: No service file found in /etc/avahi/services.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Joining mDNS multicast group on interface lo.IPv6 with address ::1.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem avahi-daemon[375]: New relevant interface lo.IPv6 for mDNS.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem avahi-daemon[375]: New relevant interface lo.IPv4 for mDNS.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Network interface enumeration completed.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Registering new address record for ::1 on lo.*.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Registering new address record for 127.0.0.1 on lo.IPv4.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Check for Raspberry Pi EEPROM updates...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem deCONZ-init.sh[406]: cat: /sys/block/mmcblk0/device/cid: No such file or directory
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting System Logging Service...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting User Login Management...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting triggerhappy global hotkey daemon...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem thd[426]: Found socket passed from systemd
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting Disk Manager...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Starting WPA supplicant...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.2102.0]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] random: crng init done
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.5
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] efi: UEFI not found.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x000000000ec00000, size 512 MiB
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Zone ranges:
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ffffffff]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Movable zone start for each node
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Early memory node ranges
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003befffff]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] On node 0, zone DMA32: 16640 pages in unavailable ranges
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Detected PIPT I-cache on CPU0
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] CPU features: detected: Spectre-v2
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] CPU features: detected: Spectre-v3a
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] CPU features: detected: Spectre-v4
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] CPU features: detected: Spectre-BHB
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] CPU features: kernel page table isolation forced ON by KASLR
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] CPU features: detected: ARM erratum 1742098
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] alternatives: applying boot alternatives
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2031620
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:83:DB:71 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=ea796b08-02 rootfstype=ext4 fsck.repair=yes rootwait
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] software IO TLB: area num 4.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] software IO TLB: mapped [mem 0x0000000037f00000-0x000000003bf00000] (64MB)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Memory: 7482604K/8256512K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 249620K reserved, 524288K cma-reserved)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] ftrace: allocating 39744 entries in 156 pages
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] ftrace: allocated 156 pages with 4 groups
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] trace event string verifier disabled
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] rcu: Preemptible hierarchical RCU implementation.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] rcu: RCU event tracing is enabled.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Trampoline variant of Tasks RCU enabled.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Rude variant of Tasks RCU enabled.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Tracing variant of Tasks RCU enabled.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] Root IRQ handler: gic_handle_irq
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000301] Console: colour dummy device 80x25
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000902] printk: console [tty1] enabled
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.000981] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.001021] pid_max: default: 32768 minimum: 301
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.001161] LSM: Security Framework initializing
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.001408] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.001519] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.002764] cgroup: Disabling memory control group subsystem
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.004931] cblist_init_generic: Setting adjustable number of callback queues.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.004966] cblist_init_generic: Setting shift to 2 and lim to 1.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.005154] cblist_init_generic: Setting shift to 2 and lim to 1.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.005340] cblist_init_generic: Setting shift to 2 and lim to 1.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.005784] rcu: Hierarchical SRCU implementation.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.005809] rcu: Max phase no-delay instances is 1000.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.007127] EFI services will not be available.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.007649] smp: Bringing up secondary CPUs ...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.008773] Detected PIPT I-cache on CPU1
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.008924] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.010048] Detected PIPT I-cache on CPU2
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.010172] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.011256] Detected PIPT I-cache on CPU3
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.011379] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.011526] smp: Brought up 1 node, 4 CPUs
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.011616] SMP: Total of 4 processors activated.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.011636] CPU features: detected: 32-bit EL0 Support
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.011655] CPU features: detected: 32-bit EL1 Support
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.011676] CPU features: detected: CRC32 instructions
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.011818] CPU: All CPU(s) started at EL2
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.011851] alternatives: applying system-wide alternatives
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.013788] devtmpfs: initialized
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.025486] Enabled cp15_barrier support
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.025549] Enabled setend support
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.025771] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.025822] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.038625] pinctrl core: initialized pinctrl subsystem
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.039503] DMI not present or invalid.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.040231] NET: Registered PF_NETLINK/PF_ROUTE protocol family
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.043627] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.043942] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.044925] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.045034] audit: initializing netlink subsys (disabled)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.045313] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.045900] thermal_sys: Registered thermal governor 'step_wise'
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.045989] cpuidle: using governor menu
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.046326] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.046537] ASID allocator initialised with 32768 entries
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.046708] Serial: AMBA PL011 UART driver
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.060403] bcm2835-mbox fe00b880.mailbox: mailbox enabled
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.080331] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.084345] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.100135] KASLR enabled
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.134145] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.139891] SCSI subsystem initialized
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.140157] usbcore: registered new interface driver usbfs
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.140229] usbcore: registered new interface driver hub
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.140307] usbcore: registered new device driver usb
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.140705] usb_phy_generic phy: supply vcc not found, using dummy regulator
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.140939] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.141310] pps_core: LinuxPPS API ver. 1 registered
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.141334] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.141374] PTP clock support registered
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.142486] vgaarb: loaded
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.143130] clocksource: Switched to clocksource arch_sys_counter
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.144105] VFS: Disk quotas dquot_6.6.0
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.144201] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.144394] FS-Cache: Loaded
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.144593] CacheFiles: Loaded
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.155057] NET: Registered PF_INET protocol family
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.155942] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.164862] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.164980] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.165027] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.165442] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.168057] TCP: Hash tables configured (established 65536 bind 65536)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.168315] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.168438] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.168790] NET: Registered PF_UNIX/PF_LOCAL protocol family
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.169567] RPC: Registered named UNIX socket transport module.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.169598] RPC: Registered udp transport module.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.169617] RPC: Registered tcp transport module.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.169636] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.169670] PCI: CLS 0 bytes, default 64
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.172601] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.172998] kvm [1]: IPA Size Limit: 44 bits
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.174306] kvm [1]: vgic interrupt IRQ9
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    0.174547] kvm [1]: Hyp mode initialized successfully
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.305033] Initialise system trusted keyrings
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.305518] workingset: timestamp_bits=46 max_order=21 bucket_order=0
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.313057] zbud: loaded
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.316024] NFS: Registering the id_resolver key type
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.316076] Key type id_resolver registered
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.316097] Key type id_legacy registered
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.316218] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.316247] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.317669] Key type asymmetric registered
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.317700] Asymmetric key parser 'x509' registered
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.317791] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.318076] io scheduler mq-deadline registered
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.318106] io scheduler kyber registered
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.320207] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.328411] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.328473] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.328577] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.328675] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x01ffffffff -> 0x0400000000
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.329696] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.329730] pci_bus 0000:00: root bus resource [bus 00-ff]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.329767] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.329853] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.330116] pci 0000:00:00.0: PME# supported from D0 D3hot
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.334072] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.334363] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.334550] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.334664] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.397224] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.397328] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.397410] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.397690] pci 0000:01:00.0: PME# supported from D0 D3hot
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.398218] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.398274] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.398310] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.398366] pci 0000:00:00.0: PCI bridge to [bus 01]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.398397] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.406480] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.409698] iproc-rng200 fe104000.rng: hwrng registered
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.410296] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.411900] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.424800] brd: module loaded
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.433498] loop: module loaded
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.434352] Loading iSCSI transport class v2.0-870.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.439725] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.499288] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.500442] usbcore: registered new interface driver r8152
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.500528] usbcore: registered new interface driver lan78xx
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.500602] usbcore: registered new interface driver smsc95xx
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.545506] pci 0000:00:00.0: enabling device (0000 -> 0002)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.545692] xhci_hcd 0000:01:00.0: xHCI Host Controller
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.545734] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.546457] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.547613] xhci_hcd 0000:01:00.0: xHCI Host Controller
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.547662] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.547697] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.548073] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.548108] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.548136] usb usb1: Product: xHCI Host Controller
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.548159] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.548181] usb usb1: SerialNumber: 0000:01:00.0
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.548913] hub 1-0:1.0: USB hub found
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.548994] hub 1-0:1.0: 1 port detected
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.549947] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.549983] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.550010] usb usb2: Product: xHCI Host Controller
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.550032] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.550054] usb usb2: SerialNumber: 0000:01:00.0
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.550761] hub 2-0:1.0: USB hub found
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.550869] hub 2-0:1.0: 4 ports detected
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.552706] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.553059] dwc_otg: FIQ enabled
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.553070] dwc_otg: NAK holdoff enabled
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.553080] dwc_otg: FIQ split-transaction FSM enabled
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.553099] Module dwc_common_port init
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.553666] usbcore: registered new interface driver uas
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.553797] usbcore: registered new interface driver usb-storage
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.554023] mousedev: PS/2 mouse device common for all mice
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.560995] sdhci: Secure Digital Host Controller Interface driver
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.561034] sdhci: Copyright(c) Pierre Ossman
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.561704] sdhci-pltfm: SDHCI platform and OF driver helper
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.565206] ledtrig-cpu: registered to indicate activity on CPUs
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.565639] hid: raw HID events driver (C) Jiri Kosina
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.565839] usbcore: registered new interface driver usbhid
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.565864] usbhid: USB HID core driver
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.574156] NET: Registered PF_PACKET protocol family
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.574301] Key type dns_resolver registered
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.575686] registered taskstats version 1
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.575776] Loading compiled-in X.509 certificates
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.576685] Key type .fscrypt registered
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.576713] Key type fscrypt-provisioning registered
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.591963] uart-pl011 fe201000.serial: there is not valid maps for state default
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.592660] uart-pl011 fe201000.serial: cts_event_workaround enabled
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.592817] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.600939] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.601892] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, base_baud = 93750000) is a 16550
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.603615] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.604081] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.607722] of_cfs_init
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.607864] of_cfs_init: OK
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.643207] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.643536] Waiting for root device PARTUUID=ea796b08-02...
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.803197] usb 1-1: new high-speed USB device number 2 using xhci_hcd
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.953887] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.953926] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.953953] usb 1-1: Product: USB2.0 Hub
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.955834] hub 1-1:1.0: USB hub found
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    1.956138] hub 1-1:1.0: 4 ports detected
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.079534] usb 2-2: new SuperSpeed USB device number 2 using xhci_hcd
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.100795] usb 2-2: New USB device found, idVendor=174c, idProduct=1156, bcdDevice= 1.00
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.100831] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.100857] usb 2-2: Product: Forty
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.100878] usb 2-2: Manufacturer: Argon
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.100899] usb 2-2: SerialNumber: 0000000000E4
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.113200] scsi host0: uas
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.114493] scsi 0:0:0:0: Direct-Access     Argon    Forty            0    PQ: 0 ANSI: 6
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.117719] sd 0:0:0:0: [sda] 1000215216 512-byte logical blocks: (512 GB/477 GiB)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.117923] sd 0:0:0:0: [sda] Write Protect is off
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.117953] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.118275] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.118751] sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.118781] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.122024]  sda: sda1 sda2
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.122603] sd 0:0:0:0: [sda] Attached SCSI disk
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.151386] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.151523] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.154319] devtmpfs: mounted
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.162231] Freeing unused kernel memory: 4160K
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.162440] Run /sbin/init as init process
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.162461]   with arguments:
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.162470]     /sbin/init
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.162480]   with environment:
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.162488]     HOME=/
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.162498]     TERM=linux
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.251188] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.360376] usb 1-1.4: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.360433] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.360463] usb 1-1.4: Product: ConBee II
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.360486] usb 1-1.4: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.360511] usb 1-1.4: SerialNumber: DE2423879
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.477657] NET: Registered PF_INET6 protocol family
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.479591] Segment Routing with IPv6
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    2.479650] In-situ OAM (IOAM) with IPv6
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    3.368198] i2c_dev: i2c /dev entries driver
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    3.371391] fuse: init (API version 7.37)
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    4.135521] EXT4-fs (sda2): re-mounted. Quota mode: none.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    4.931865] mc: Linux media interface: v0.10
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    4.983621] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    4.985636] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    4.985673] [vc_sm_connected_init]: start
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.006991] [vc_sm_connected_init]: installed successfully
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.124321] videodev: Linux video capture interface: v2.00
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.131755] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.139438] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.231202] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.288848] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.301700] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.315392] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.324217] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.327704] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.375289] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.382268] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.382327] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.402367] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.402439] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.405320] rpivid feb10000.codec: Device registered as /dev/video19
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.406945] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.406989] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.407975] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.408368] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.408874] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.409335] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.409369] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.409391] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.409408] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.409425] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.433853] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.433916] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.440407] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.441257] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.445139] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.445199] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.446691] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.451826] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.453770] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.456438] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.456484] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.456507] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.456525] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.456542] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.457477] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.468248] usbcore: registered new interface driver cdc_acm
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.468281] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.785267] sd 0:0:0:0: Attached scsi generic sg0 type 0
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.961517] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.964260] Registered IR keymap rc-cec
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.964456] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.964664] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.968008] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.991786] Registered IR keymap rc-cec
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.992009] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    5.992229] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    6.004675] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    6.005300] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    6.005776] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    6.006220] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    6.006663] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
DonCornuto
Syslog Teil 2/2
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    6.007000] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    6.029084] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    6.051018] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    6.051757] vc4-drm gpu: [drm] Cannot find any crtc or sizes
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem kernel: [    7.120817] 8021q: 802.1Q VLAN Support v1.8
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem rsyslogd: [origin software="rsyslogd" swVersion="8.2102.0" x-pid="415" x-info="https://www.rsyslog.com"] start
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Started triggerhappy global hotkey daemon.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Started System Logging Service.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished Save/Restore Sound Card State.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem wpa_supplicant[438]: Successfully initialized wpa_supplicant
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem udisksd[435]: udisks daemon version 2.9.2 starting
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem dphys-swapfile[382]: want /var/swap=100MByte, checking existing: keeping it
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: e2scrub_reap.service: Succeeded.
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem systemd[1]: Finished Remove Stale Online ext4 Metadata Check Snapshots.
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem deCONZ-init.sh[378]:  stopping deconz-wifi.service
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Started WPA supplicant.
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Reached target Network.
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Reached target Sound Card.
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem kernel: [    7.420272] Adding 102396k swap on /var/swap.  Priority:-2 extents:2 across:110588k SSFS
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem kernel: [    7.435070] cfg80211: Loading compiled-in X.509 certificates for regulatory database
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Starting The Apache HTTP Server...
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Starting FHEM Home Automation...
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem rngd[496]: rngd 2.2 starting up...
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Starting MariaDB 10.5.21 database server...
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Starting Mosquitto MQTT Broker...
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem udisksd[435]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Starting /etc/rc.local Compatibility...
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem udisksd[435]: Failed to load the 'mdraid' libblockdev plugin
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem rngd[496]: entropy feed to the kernel ready
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem dbus-daemon[377]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.4' (uid=0 pid=435 comm="/usr/libexec/udisks2/udisksd ")
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Starting OpenBSD Secure Shell server...
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem kernel: [    7.574350] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem kernel: [    7.578657] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Starting Permit User Sessions...
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Started LSB: rng-tools (Debian variant).
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Finished dphys-swapfile - set up, mount/unmount, and delete a swap file.
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Started /etc/rc.local Compatibility.
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Finished Permit User Sessions.
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem kernel: [    7.728905] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem kernel: [    7.730385] bcmgenet fd580000.ethernet eth0: Link is Down
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem dhcpcd[394]: eth0: waiting for carrier
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem deCONZ[380]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-Smarthome'
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Started User Login Management.
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem rpi-eeprom-update[404]: Skipping automatic bootloader upgrade. current 1643121041 >= min 1599135103
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Server startup complete. Host name is RaspberryPi4-8GB-Fhem.local. Local service cookie is 88974288.
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem apachectl[519]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Started OpenBSD Secure Shell server.
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem mosquitto[534]: 1704649534: Loading config file /etc/mosquitto/conf.d/local.conf
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem systemd[1]: Reloading.
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem deCONZ[380]: libpng warning: iCCP: known incorrect sRGB profile
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem rpi-eeprom-update[404]: BOOTLOADER: up to date
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem rpi-eeprom-update[404]:    CURRENT: Tue 25 Jan 14:30:41 UTC 2022 (1643121041)
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem rpi-eeprom-update[404]:     LATEST: Wed 11 Jan 17:40:52 UTC 2023 (1673458852)
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem rpi-eeprom-update[404]:    RELEASE: default (/lib/firmware/raspberrypi/bootloader/default)
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem rpi-eeprom-update[404]:             Use raspi-config to change the release.
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem rpi-eeprom-update[404]:   VL805_FW: Using bootloader EEPROM
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem rpi-eeprom-update[404]:      VL805: up to date
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem rpi-eeprom-update[404]:    CURRENT: 000138a1
Jan  7 18:45:34 RaspberryPi4-8GB-Fhem rpi-eeprom-update[404]:     LATEST: 000138a1
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem raspi-config[395]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem systemd[1]: Started Mosquitto MQTT Broker.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem systemd[1]: Finished Check for Raspberry Pi EEPROM updates.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem systemd[1]: deconz-init.service: Succeeded.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem systemd[1]: Finished deCONZ: ZigBee gateway -- Initialisation.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem systemd[1]: Started The Apache HTTP Server.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem systemd[1]: Started Getty on tty1.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem systemd[1]: Reached target Login Prompts.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem systemd[1]: Starting Authorization Manager...
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem systemd[1]: Started FHEM Home Automation.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem polkitd[667]: started daemon version 0.105 using authority implementation `local' version `0.105'
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem dbus-daemon[377]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem systemd[1]: Started Authorization Manager.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] Starting MariaDB 10.5.21-MariaDB-0+deb11u1 source revision bed70468ea08c2820647f5e3ac006a9ff88144ac as process 668
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Warning] WSREP: Failed to guess base node address. Set it explicitly via wsrep_node_address.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Warning] WSREP: Guessing address for incoming client connections failed. Try setting wsrep_node_incoming_address explicitly.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] WSREP: Node addr:
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem systemd[1]: Started Disk Manager.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem udisksd[435]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] InnoDB: Uses event mutexes
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] InnoDB: Number of pools: 1
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] InnoDB: Using ARMv8 crc32 instructions
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] InnoDB: Using Linux native AIO
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] InnoDB: Initializing buffer pool, total size = 134217728, chunk size = 134217728
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] InnoDB: Completed initialization of buffer pool
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] InnoDB: 128 rollback segments are active.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] InnoDB: Creating shared tablespace for temporary tables
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] InnoDB: 10.5.21 started; log sequence number 266696994625; transaction id 32690702
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] Plugin 'FEEDBACK' is disabled.
Jan  7 18:45:35 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:35 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
Jan  7 18:45:36 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:36 0 [Note] Server socket created on IP: '::'.
Jan  7 18:45:36 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:36 0 [Note] Reading of all Master_info entries succeeded
Jan  7 18:45:36 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:36 0 [Note] Added new Master_info '' to hash table
Jan  7 18:45:36 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:36 0 [Note] /usr/sbin/mariadbd: ready for connections.
Jan  7 18:45:36 RaspberryPi4-8GB-Fhem mariadbd[668]: Version: '10.5.21-MariaDB-0+deb11u1'  socket: '/run/mysqld/mysqld.sock'  port: 3306  Debian 11
Jan  7 18:45:36 RaspberryPi4-8GB-Fhem systemd[1]: Started MariaDB 10.5.21 database server.
Jan  7 18:45:36 RaspberryPi4-8GB-Fhem /etc/mysql/debian-start[698]: Upgrading MySQL tables if necessary.
Jan  7 18:45:36 RaspberryPi4-8GB-Fhem /etc/mysql/debian-start[701]: Looking for 'mariadb' as: /usr/bin/mariadb
Jan  7 18:45:36 RaspberryPi4-8GB-Fhem /etc/mysql/debian-start[701]: Looking for 'mariadb-check' as: /usr/bin/mariadb-check
Jan  7 18:45:36 RaspberryPi4-8GB-Fhem /etc/mysql/debian-start[701]: This installation of MariaDB is already upgraded to 10.5.12-MariaDB.
Jan  7 18:45:36 RaspberryPi4-8GB-Fhem /etc/mysql/debian-start[701]: There is no need to run mysql_upgrade again for 10.5.21-MariaDB.
Jan  7 18:45:36 RaspberryPi4-8GB-Fhem /etc/mysql/debian-start[701]: You can use --force if you still want to run mysql_upgrade
Jan  7 18:45:36 RaspberryPi4-8GB-Fhem /etc/mysql/debian-start[709]: Checking for insecure root accounts.
Jan  7 18:45:36 RaspberryPi4-8GB-Fhem /etc/mysql/debian-start[713]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tables
Jan  7 18:45:36 RaspberryPi4-8GB-Fhem mariadbd[668]: 2024-01-07 18:45:36 0 [Note] InnoDB: Buffer pool(s) load completed at 240107 18:45:36
Jan  7 18:45:37 RaspberryPi4-8GB-Fhem dbus-daemon[377]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.8' (uid=1000 pid=746 comm="/usr/bin/timedatectl status ")
Jan  7 18:45:37 RaspberryPi4-8GB-Fhem systemd[1]: Starting Time & Date Service...
Jan  7 18:45:37 RaspberryPi4-8GB-Fhem dbus-daemon[377]: [system] Successfully activated service 'org.freedesktop.timedate1'
Jan  7 18:45:37 RaspberryPi4-8GB-Fhem systemd[1]: Started Time & Date Service.
Jan  7 18:45:37 RaspberryPi4-8GB-Fhem deCONZ[380]: This plugin does not support propagateSizeHints()
Jan  7 18:45:38 RaspberryPi4-8GB-Fhem dhcpcd[394]: eth0: carrier acquired
Jan  7 18:45:38 RaspberryPi4-8GB-Fhem kernel: [   11.807322] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Jan  7 18:45:38 RaspberryPi4-8GB-Fhem kernel: [   11.807360] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Jan  7 18:45:38 RaspberryPi4-8GB-Fhem dhcpcd[394]: DUID 00:01:00:01:29:86:1c:45:e4:5f:01:83:db:71
Jan  7 18:45:38 RaspberryPi4-8GB-Fhem dhcpcd[394]: eth0: IAID 01:83:db:71
Jan  7 18:45:38 RaspberryPi4-8GB-Fhem dhcpcd[394]: eth0: adding address fe80::2688:6a0c:7058:adcd
Jan  7 18:45:38 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::2688:6a0c:7058:adcd.
Jan  7 18:45:38 RaspberryPi4-8GB-Fhem avahi-daemon[375]: New relevant interface eth0.IPv6 for mDNS.
Jan  7 18:45:38 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Registering new address record for fe80::2688:6a0c:7058:adcd on eth0.*.
Jan  7 18:45:38 RaspberryPi4-8GB-Fhem dhcpcd[394]: eth0: soliciting an IPv6 router
Jan  7 18:45:38 RaspberryPi4-8GB-Fhem dhcpcd[394]: eth0: rebinding lease of 192.168.111.222
Jan  7 18:45:38 RaspberryPi4-8GB-Fhem dhcpcd[394]: eth0: probing address 192.168.111.222/24
Jan  7 18:45:39 RaspberryPi4-8GB-Fhem kernel: [   13.186210] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
Jan  7 18:45:39 RaspberryPi4-8GB-Fhem dhcpcd[394]: eth0: Router Advertisement from fe80::e72:74ff:feba:26c8
Jan  7 18:45:39 RaspberryPi4-8GB-Fhem dhcpcd[394]: eth0: adding address 2a00:e180:177a:1a00:1121:dabd:15ba:7b12/64
Jan  7 18:45:39 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::2688:6a0c:7058:adcd.
Jan  7 18:45:39 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Joining mDNS multicast group on interface eth0.IPv6 with address 2a00:e180:177a:1a00:1121:dabd:15ba:7b12.
Jan  7 18:45:39 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Registering new address record for 2a00:e180:177a:1a00:1121:dabd:15ba:7b12 on eth0.*.
Jan  7 18:45:39 RaspberryPi4-8GB-Fhem dhcpcd[394]: eth0: adding route to 2a00:e180:177a:1a00::/64
Jan  7 18:45:39 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Withdrawing address record for fe80::2688:6a0c:7058:adcd on eth0.
Jan  7 18:45:39 RaspberryPi4-8GB-Fhem dhcpcd[394]: eth0: requesting DHCPv6 information
Jan  7 18:45:39 RaspberryPi4-8GB-Fhem dhcpcd[394]: eth0: adding default route via fe80::e72:74ff:feba:26c8
Jan  7 18:45:40 RaspberryPi4-8GB-Fhem deCONZ[380]: This plugin does not support propagateSizeHints()
Jan  7 18:45:40 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Got SIGHUP, reloading.
Jan  7 18:45:40 RaspberryPi4-8GB-Fhem avahi-daemon[375]: No service file found in /etc/avahi/services.
Jan  7 18:45:43 RaspberryPi4-8GB-Fhem deCONZ-update2.sh[379]: found deCONZ port 8880
Jan  7 18:45:43 RaspberryPi4-8GB-Fhem deCONZ-update2.sh[379]: use database file /home/Smarthome/.local/share/dresden-elektronik/deCONZ/zll.db
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem dhcpcd[394]: eth0: leased 192.168.111.222 for 2592000 seconds
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.111.222.
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem avahi-daemon[375]: New relevant interface eth0.IPv4 for mDNS.
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Registering new address record for 192.168.111.222 on eth0.IPv4.
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem dhcpcd[394]: eth0: adding route to 192.168.111.0/24
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem dhcpcd[394]: eth0: adding default route via 192.168.111.1
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem deCONZ-update2.sh[379]: process update state noupdates
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem avahi-daemon[375]: Got SIGHUP, reloading.
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem avahi-daemon[375]: No service file found in /etc/avahi/services.
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem dhcpcd[394]: forked to background, child pid 935
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem systemd[1]: Started DHCP Client Daemon.
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem systemd[1]: Reached target Multi-User System.
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem systemd[1]: Reached target Graphical Interface.
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem systemd[1]: Started Argon One Fan and Button Service.
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem systemd[1]: Starting Update UTMP about System Runlevel Changes...
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem systemd[1]: Finished Update UTMP about System Runlevel Changes.
Jan  7 18:45:44 RaspberryPi4-8GB-Fhem systemd[1]: Startup finished in 2.315s (kernel) + 15.178s (userspace) = 17.494s.
Jan  7 18:46:02 RaspberryPi4-8GB-Fhem systemd[1]: systemd-fsckd.service: Succeeded.
Jan  7 18:46:19 RaspberryPi4-8GB-Fhem systemd-timesyncd[342]: Initial synchronization to time server [2a01:4f8:1c1c:8183::]:123 (2.debian.pool.ntp.org).
Jan  7 18:46:22 RaspberryPi4-8GB-Fhem systemd[1]: systemd-timedated.service: Succeeded.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1]: Created slice User Slice of UID 1000.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1]: Starting User Runtime Directory /run/user/1000...
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1]: Finished User Runtime Directory /run/user/1000.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1]: Starting User Manager for UID 1000...
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1087]: Queued start job for default target Main User Target.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1087]: Created slice User Application Slice.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1087]: Reached target Paths.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1087]: Reached target Timers.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1087]: Starting D-Bus User Message Bus Socket.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1087]: Listening on GnuPG network certificate management daemon.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1087]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1087]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1087]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1087]: Listening on GnuPG cryptographic agent and passphrase cache.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1087]: Listening on D-Bus User Message Bus Socket.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1087]: Reached target Sockets.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1087]: Reached target Basic System.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1]: Started User Manager for UID 1000.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1087]: Reached target Main User Target.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1087]: Startup finished in 265ms.
Jan  7 18:46:28 RaspberryPi4-8GB-Fhem systemd[1]: Started Session 1 of user Smarthome.
Jan  7 18:46:47 RaspberryPi4-8GB-Fhem systemd[1]: Started Session 3 of user Smarthome.
Jan  7 19:00:57 RaspberryPi4-8GB-Fhem systemd[1]: Starting Cleanup of Temporary Directories...
Jan  7 19:00:57 RaspberryPi4-8GB-Fhem systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
Jan  7 19:00:57 RaspberryPi4-8GB-Fhem systemd[1]: Finished Cleanup of Temporary Directories.
Jan  7 19:01:49 RaspberryPi4-8GB-Fhem kernel: [  966.898218] uart-pl011 fe201000.serial: no DMA platform data
Jan  7 19:14:23 RaspberryPi4-8GB-Fhem systemd[1]: Started Session 4 of user Smarthome.
Jan  7 19:17:01 RaspberryPi4-8GB-Fhem CRON[7916]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jan  7 19:31:53 RaspberryPi4-8GB-Fhem systemd[1]: Started Session 6 of user Smarthome.
Jan  7 19:34:47 RaspberryPi4-8GB-Fhem systemd[1]: Started Session 7 of user Smarthome.
Jan  7 19:43:05 RaspberryPi4-8GB-Fhem systemd[1]: session-1.scope: Succeeded.
Jan  7 19:43:05 RaspberryPi4-8GB-Fhem systemd[1]: session-1.scope: Consumed 7.963s CPU time.
Jan  7 19:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: bits received from HRNG source: 80064
Jan  7 19:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: bits sent to kernel pool: 30240
Jan  7 19:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: entropy added to kernel pool: 30240
Jan  7 19:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS 140-2 successes: 4
Jan  7 19:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS 140-2 failures: 0
Jan  7 19:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Jan  7 19:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS 140-2(2001-10-10) Poker: 0
Jan  7 19:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS 140-2(2001-10-10) Runs: 0
Jan  7 19:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS 140-2(2001-10-10) Long run: 0
Jan  7 19:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Jan  7 19:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: HRNG source speed: (min=246.380; avg=360.876; max=771.590)Kibits/s
Jan  7 19:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS tests speed: (min=7.691; avg=18.024; max=89.128)Mibits/s
Jan  7 19:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: Lowest ready-buffers level: 2
Jan  7 19:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: Entropy starvations: 0
Jan  7 19:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Jan  7 19:47:16 RaspberryPi4-8GB-Fhem systemd[1]: Started Session 8 of user Smarthome.
Jan  7 20:17:01 RaspberryPi4-8GB-Fhem CRON[21286]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jan  7 20:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: bits received from HRNG source: 100064
Jan  7 20:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: bits sent to kernel pool: 60000
Jan  7 20:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: entropy added to kernel pool: 60000
Jan  7 20:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS 140-2 successes: 5
Jan  7 20:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS 140-2 failures: 0
Jan  7 20:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Jan  7 20:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS 140-2(2001-10-10) Poker: 0
Jan  7 20:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS 140-2(2001-10-10) Runs: 0
Jan  7 20:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS 140-2(2001-10-10) Long run: 0
Jan  7 20:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Jan  7 20:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: HRNG source speed: (min=246.380; avg=403.805; max=771.590)Kibits/s
Jan  7 20:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: FIPS tests speed: (min=7.691; avg=21.460; max=90.396)Mibits/s
Jan  7 20:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: Lowest ready-buffers level: 2
Jan  7 20:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: Entropy starvations: 0
Jan  7 20:45:49 RaspberryPi4-8GB-Fhem rngd[496]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
[/code]
Ich weiß nicht was da genau bei Dir passiert, aber die 3 markanten Zeilen mit uart-pl011 fe201000.serial kommen bei mir in der gleichen Sekunde, bei Dir hat die letzte Zeile einen Abstand von 16 minuten.
In beiden Logs ist zwischen 18:45 und 20:01 eine Lücke ohne Einträge ... während des Systemstartes - keine Ahnung was da wirklich klemmt.
frank
Zitat von: Otto123 am 07 Januar 2024, 21:59:00In beiden Logs ist zwischen 18:45 und 20:01 eine Lücke ohne Einträge ... während des Systemstartes - keine Ahnung was da wirklich klemmt.
hm..., meinst du vielleicht 19:01?
im fhem.log gibt es allerdings noch einträge zwischendurch.
was ist eigentlich die "wahre" zeit?
die zeit fängt etwa mit fake-hwclock an:
Jan  7 18:45:33 RaspberryPi4-8GB-Fhem fake-hwclock[146]: Sun  7 Jan 17:45:30 UTC 2024früher gab es dann irgend wann vom ntpd die wahre zeit übers internet.
ich sehe hier aber keinen hinweis, dennoch könnte ja irgend ein "zeitsprung" durch ein setzen der zeit ausgelöst sein.
ich vermute ein netzwerkproblem:
denn der hmuart (myHmUART auf dem pi) wird sofort initialisiert, aber das LanGateWay braucht über eine stunde!!!
2024.01.07 19:01:46 1: Including ./log/fhem.save
2024.01.07 19:01:49 3: Opening LanGateWay device 192.168.111.223:2000
2024.01.07 19:01:49 3: Opening myHmUART device /dev/ttyAMA0
2024.01.07 19:01:49 3: Setting myHmUART serial parameters to 115200,8,N,1
2024.01.07 19:01:49 3: myHmUART device opened
2024.01.07 20:15:19 3: Opening LanGateWay:keepAlive device 192.168.111.223:2001
2024.01.07 20:15:19 3: LanGateWay device opened
2024.01.07 20:15:19 3: HMUARTLGW LanGateWay BidCoS-port opened
2024.01.07 20:15:19 3: LanGateWay:keepAlive device opened
2024.01.07 20:15:19 3: HMUARTLGW LanGateWay:keepAlive KeepAlive-port opened
ausserdem:
ich habe keine erfahrung mit datenbank, deconz und mqtt.
ich würde aber den fhemstart so weit verzögern, dass alles bereits verfügbar ist.
FHEM: 6.0(SVN) => Pi3(buster)
Zitat von: frank am 08 Januar 2024, 13:39:04hm..., meinst du vielleicht 19:01?
ja sorry - also 16 min kein Eintrag. Ich habe diesen Start und die Logeinträge versucht bei meinem PI nachzuvollziehen. Da gibt es kein erkennbaren Lücken.
Es gibt doch beim neustart diesen Zeitsprung nicht, den gibt es doch nur wenn der Pi aus war?
Die Lücke im Log kann DonCarnuto ja auch nachvollziehen, es dauert ja wirklich so lange, an einen fake-hwclock Sprung glaube ich nicht.
Wernieman
Also ein Netzproblem liegt definitiv vor:
Laut kern.log:
Warum sollte eth0 down und nach 4 Sec. wieder up gehen? und das ganze 10 sec. nach start?
(Stichwort Netwerkkabel?)
Kann aber frank nur zustimmen. fürs debugging würde ich erstmal alle autostarts abschalten.
-> pi starten und gucken ob alles gut ist.
-> MariaDB starten (Ist es ein Pi mit SdCard?) und prüfen
-> Moskito starten und prüfen (Warum nicht den FHEM eigenen?)
-> deCONZ starten und prüfen
-> dann erst fhem ...
Wenn irgendeiner dieser Schritte länger (und mehr Recourcen) als "üblich" braucht, hast Du ein Problem ...
- Bitte um Input für Output
DonCornuto
Hallo Zusammen,
danke erst einmal für eure zahlreichen Lösungsansätze.
Da ich erst am Sonntag wieder ausgiebig Zeit habe, mich genauer mit dem PI auseinander zu setzen, kann ich zunächst nur auf folgendes eingehen.
Zitatfrüher gab es dann irgend wann vom ntpd die wahre zeit übers internet.
Die Uhrzeit stimmt nahezu identisch mit der "richtigen" überein. Habe mir die Zeiten vom Neustart an etc. notiert um alles nachvollziehen zu können. Was auch immer diese "fake Zeit" ist, die Zeit passte auf jeden Fall. Hab während des Neustart auch ab und an die Logs aktualisiert, die Einträge kamen wirklich zu den entsprechenden Zeitstempeln.
Die Kombination habe ich seit 2017 laufen, zuerst auf einem PI3, dann kam der Umstieg auf den PI4, da Ram von dem 3er und die ganzen Dienste irgendwann am Ende waren.
Die Verzögerungen werde ich ausprobieren. Es hängt aber eigentlich nur FHEM. Decoz z.B. ist bereits nach ein paar Sekunden verfügbar, über Web erreichbar und die Geräte bedienbar. Alles ohne Probleme und irgendwelche Netzwerkstörungen. Via Heidi SQL kann ich auch die Datenbanken erreichen.
ZitatWarum sollte eth0 down und nach 4 Sec. wieder up gehen? und das ganze 10 sec. nach start?
Teste sicherheitshalber ein anderes Kabel. Halte ich aktuell aber für unwahrscheinlich, da es während des Betriebes bisher nie Netzwerkprobleme gab. Was da passiert weiß ich jedoch auch nicht.
ZitatMariaDB starten (Ist es ein Pi mit SdCard?) und prüfen
Nein, der Pi ist in einem Argone ONE m.2 mit 256GB Sandisk SSD
ZitatMoskito starten und prüfen (Warum nicht den FHEM eigenen?)
Ehrlich gesagt weiß ich das nicht mehr. Ich glaube die Einrichtung so wie es jetzt ist mit dem MQTT2_Client ist mit einfacher gefallen.
ZitatWenn irgendeiner dieser Schritte länger (und mehr Recourcen) als "üblich" braucht, hast Du ein Problem ...
Prüfe ich im Detail, aber ich denke nicht, dass es an den Diensten liegen wird. FHEM ist der einzige Task, der mit 100% CPU Last läuft. Alles andere nicht und alles Andere ist verfügbar / bedienbar. Natürlich könnte es Einflüsse geben, werde ich prüfen.
Zitatdenn der hmuart (myHmUART auf dem pi) wird sofort initialisiert, aber das LanGateWay braucht über eine stunde!!!
Hatte schon einmal das Gateway vom Strom, in Fhem gelöscht, gleiches Verhalten (Neustart weit über eine Stunde, hatte ich damals noch nicht konkret notiert).
Was ich immer noch komisch finde, ist, dass bei dem Screenshot zu dem FHEM dienst unten zwei Tasks laufen? Das habe ich noch nie gesehen und auch nirgends etwas zu gefunden. Finde ich sehr komisch, oder hat das jemand von euch schon einmal gehabt / gesehen?
Zitat von: DonCornuto am 09 Januar 2024, 20:41:57Was auch immer diese "fake Zeit" ist
Zur Erklärung: Ein "normaler Computer" hat eine Hardware Uhr, die läuft weiter wenn der Rechner ausgeschaltet ist. Beim Systemstart wird diese Zeit als Start gesetzt, später wird normalerweise per NTP die "echte" Zeit geholt und gesetzt.
Ein Pi hat keine Hardware Uhr, die fake-hwclock ist ein Dienst der beim shutdown eine Datei mir der letzten Zeit schreibt. Beim Start des Pi wird diese Zeit gelesen und gesetzt. Im laufenden Betrieb wird ab und zu die Datei mit der aktuellen Zeit geschrieben. Stürzt der Pi ab und der letzte Schreibvorgang ist eine Stunde zurück oder ist der Pi ein Stunde aus, ist beim Systemstart die Zeit eine Stunde zurück, erst mit ntp wird die Zeit wieder aktuell gesetzt, es kommt zu einem Zeitsprung. Das erklärt manchmal solche komischen Zeitlücken wie sie bei Dir auftauchen. Beim einem ordentlichen Neustart sind dies aber nur Sekunden...
FHEM startet durchaus mehrere Prozesse, das ist nicht ungewöhnlich.
Ist die SSD kaputt/am sterben? Hast Du mal mit smartctl  den Zustand ermittelt?
frank
wie sieht es aus, wenn das system mal "geschmeidig" läuft, du dann nur ein fhem restart machst?
DonCornuto
Zitatwie sieht es aus, wenn das system mal "geschmeidig" läuft, du dann nur ein fhem restart machst?
Hatte ich schon einmal gemacht, waren etwa 40 Minuten bis FHEM wieder Reaktionen zeigte. Hatte dazu aber keine Logs gespeichert.
ZitatHast Du mal mit smartctl  den Zustand ermittelt?
Self Test
Smarthome@RaspberryPi4-8GB-Fhem:~ $ sudo smartctl -l selftest /dev/sda
smartctl 7.2 2020-12-30 r5155 [aarch64-linux-6.1.21-v8+] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF READ SMART DATA SECTION ===
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%     15074         -
# 2  Short offline       Completed without error       00%     15074         -
SMART
=== START OF INFORMATION SECTION ===
Device Model:     Intenso SSD SATAIII
Serial Number:    AAAA0000000000000558
Firmware Version: T1125A0
User Capacity:    512,110,190,592 bytes [512 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
TRIM Command:     Available
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-3 T13/2161-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Jan 14 10:55:36 2024 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x03) Offline data collection activity
                                        is in progress.
                                        Auto Offline Data Collection: Disabled.
Self-test execution status:      ( 243) Self-test routine in progress...
                                        30% of test remaining.
Total time to complete Offline
data collection:                (  120) seconds.
capabilities:                    (0x11) SMART execute Offline immediate.
                                        No Auto Offline data collection support.
                                        Suspend Offline collection upon new
                                        command.
                                        No Offline surface scan supported.
                                        Self-test supported.
                                        No Conveyance Self-test supported.
                                        No Selective Self-test supported.
SMART capabilities:            (0x0002) Does not save SMART data before
                                        entering power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        (  10) minutes.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x0032   100   100   050    Old_age   Always       -       0
  5 Reallocated_Sector_Ct   0x0032   100   100   050    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   050    Old_age   Always       -       15155
 12 Power_Cycle_Count       0x0032   100   100   050    Old_age   Always       -       75
160 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       0
161 Unknown_Attribute       0x0033   100   100   050    Pre-fail  Always       -       100
163 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       14
164 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       5979
165 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       48
166 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       3
167 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       31
168 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       2000
169 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       99
175 Program_Fail_Count_Chip 0x0032   100   100   050    Old_age   Always       -       0
176 Erase_Fail_Count_Chip   0x0032   100   100   050    Old_age   Always       -       0
177 Wear_Leveling_Count     0x0032   100   100   050    Old_age   Always       -       0
178 Used_Rsvd_Blk_Cnt_Chip  0x0032   100   100   050    Old_age   Always       -       0
181 Program_Fail_Cnt_Total  0x0032   100   100   050    Old_age   Always       -       0
182 Erase_Fail_Count_Total  0x0032   100   100   050    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   050    Old_age   Always       -       72
194 Temperature_Celsius     0x0022   100   100   050    Old_age   Always       -       40
195 Hardware_ECC_Recovered  0x0032   100   100   050    Old_age   Always       -       0
196 Reallocated_Event_Count 0x0032   100   100   050    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   100   100   050    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0032   100   100   050    Old_age   Always       -       0
199 UDMA_CRC_Error_Count    0x0032   100   100   050    Old_age   Always       -       12
232 Available_Reservd_Space 0x0032   100   100   050    Old_age   Always       -       100
241 Total_LBAs_Written      0x0030   100   100   050    Old_age   Offline      -       83298
242 Total_LBAs_Read         0x0030   100   100   050    Old_age   Offline      -       73873
245 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       102607
SMART Error Log Version: 1
ATA Error Count: 12 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        SC = Sector Count Register [HEX]
        SN = Sector Number Register [HEX]
        CL = Cylinder Low Register [HEX]
        CH = Cylinder High Register [HEX]
        DH = Device/Head Register [HEX]
        DC = Device Command Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 8 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  When the command that caused the error occurred, the device was doing SMART Offline or Self-test.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  00 00 00 00 00 00 00   at LBA = 0x00000000 = 0
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  61 08 60 58 fc 7c 00 00      00:00:00.000  WRITE FPDMA QUEUED
Selective Self-tests/Logging not supported
Zu der ID 161 habe ich bisher nichts ergoogeln können.
Am Freitag bei der wöchentlichen Datenbanksicherung hat sich der PI komplett weggehängt. Es half nur noch den Strom abzuschalten.
In den Logs ist leider absolut kein Eintrag vorhanden. Erst nach dem Neustart gibt es wieder Einträge.
Ich habe nun erstmal eine neue SSD bestellt, um diese als Fehlerquelle auszuschließen. Dann werde ich die aktuelle 1 zu 1 spiegeln und ausprobieren, was passiert.
Sollte alles gleich sein, werde ich alle Autostarts deaktivieren und nach und nach testen, ob hier etwas für die Verzögerungen verantwortlich ist.
Wernieman
Zitathat sich der PI komplett weggehängt.
Wenn der Pi per Netzwerk (Kabel) angeschlossen ist und nicht mal auf "ping" reagiert, dann hat es Ihn ziemlich tief "erwischt". Konntest Du einen Bildschirm anschließen?
DonCornuto
kurzes Update.
Ich habe den ganzen Tag versucht die SSD von dem Pi zu klonen. Bisher leider ohne Erfolg.
Weder unter Windows, noch Linux (debian) habe ich es geschafft, daten von der SSD zu kopieren. Hatte zunächst den USB Dongle in Verdacht, aber die neue SSD ist problemslos erreichbar.
Habe nahezu alle tools durch, leider hat nichts funktioniert. Werde dann wohl den PI mit der neuen SSD neu aufsetzen müssen.
Werde mich dann vorab aber mal an die Autostart Thematik machen. Das empfinde ich aktuell als weniger aufwändig.
ZitatWenn der Pi per Netzwerk (Kabel) angeschlossen ist und nicht mal auf "ping" reagiert, dann hat es Ihn ziemlich tief "erwischt". Konntest Du einen Bildschirm anschließen?
Kein Ping, kein SSH, nichts. An einen Bildschirm habe ich nicht gedacht, da ich dort keine GUI laufen habe. Da hätte ich doch dann sowieso nichts sehen können?
Don
Wernieman
Ohne GUI siehst Du die Konsole .. also ja, Du hättest eventuell was sehen können.
Die SSD ist überhaupt nicht erreichbar? Was sagt das kern.log (und syslog), wenn Du sie in einem laufenden Linux-System per USB-Adapter anschließt?
Ich habe da mal ne Anleitung bei Crash des Datenträgers geschrieben SD Card oder SSD ist von der Sache her egal.
https://heinz-otto.blogspot.com/2020/08/crash-recovery.html
DonCornuto
ich bin noch nicht viel weiter, da es zeitlich gerade sehr eng ist.
ZitatIch habe da mal ne Anleitung bei Crash des Datenträgers geschrieben SD Card oder SSD ist von der Sache her egal.
Mein Problem ist, dass ich die M.2 SSD nicht auslesen kann. Habe einen USB Adapter, welcher die SSD zwar erkennt, aber ich weder unter Linux oder Windows diese mounten kann, so dass ich Zugriff darauf bekomme. Wenn ich die neue SSD einbaue kann ich sie in Windows sofort einrichten und benutzen. Hat der Pi so ein spezielles Dateisystem?
Da ich hier nicht weiter gekommen bin habe ich auf der neuen SSD nun das aktuellste PI OS installiert, alle Updates etc gemacht und Fhem mit allen Paketen istalliert. Dann das frisch erstellte Backup eingespielt. Somit waren auf der SSD nur das OS und Fhem, nichts anderes.
Fhem konnte ich nach etwas über 60 minuten erreichen. Habe leider vergessen die Logs zu kopieren. Auf den ersten Blick habe ich jedoch keine Unterschiede gesehen, außer, dass natürlich einiges gefehlt hat, da nicht installiert.
Für mich heißt das nun, neune SSD, "sauberer" PI, dennoch diese ewige Wartezeit, wo nicht herauszufinden ist, was der Pi da macht.
Daher bleibt eigentlich nur Fhem komlpett neu aufzubauen? Also abtippen und von vorne anfangen. Mehr fällt mir da nicht ein.
In über 7 Jahen ist da natürlich einiges zusammengekommen. Das wird auf jeden Fall keine Wochenendaufgabe...
