TheTrumpeter
So, meins wurde nun auch abgeschlossen:
2026.01.12 13:59:17 1: mySolarForecast DEBUG> Early stopping bei Epoche 3501 (no improvement since 1000 epochs)
2026.01.12 13:59:17 1: === Snapshot-Statistik ===
2026.01.12 13:59:17 1: Metric-Improvement Snapshots:              69 (letzte Epoche: 2231)
2026.01.12 13:59:17 1: Weighted-RMSE-Proxy-Improvement Snapshots: 72 (letzte Epoche: 2501)
2026.01.12 13:59:17 1: Bit-Improvement Snapshots:                 0 (letzte Epoche: 0)
2026.01.12 13:59:17 1: Bit-Tradeoff Snapshots:                    1 (letzte Epoche: 467)
2026.01.12 13:59:17 1: mySolarForecast DEBUG> Best Snapshot reloaded from Epoche 2501: Train MSE=0.001189, Val MSE=0.002715, Val MAE=0.026772, Val MedAE=0.006776, Bit_Fail=0,
2026.01.12 13:59:17 1: mySolarForecast DEBUG> Run Validation Test with 20% of Input data ...
2026.01.12 13:59:18 1: mySolarForecast DEBUG> Validation finished - Best Training MSE=0.001189, Validation MSE=0.002715, Validation Bit_Fail=0
2026.01.12 13:59:18 1: mySolarForecast DEBUG> Retrain check ->
-- In Normalization Space: --
Train MSE=0.001189
Val MSE=0.002715
Val Mean=0.0024373509
VAL/TRAIN MSE Ratio=2.282733 (limit=2.5)
Diff=0.001525 (limit=0.005)
ValStd=0.0000800142 (limit=0.000609337729577423)
-- At Original Scale: --
MAE=171.339490561455
RMSE/MAE=1.4804 (limit=1.5)
Slope=0.821509 (limit=0.7 .. 1.3)
Bias=69.18 (limit=+-257.009235842183)
R2=0.88
P95=874.6964 (limit=685.357962245821)
P99=1312.8508 (limit=1370.71592449164)
-- Robustness Indicators: --
RMSE relative=82 (limit=20)
BitFail=0 (limit=5)
BitFailRate=0.0000 (limit=0.1)
Forecast Quality Score=37
-> Retrain decision=Retrain
2026.01.12 13:59:18 1: mySolarForecast DEBUG> Best model after retries comes from Attempt=2 with:
Seed=7298432,
Model Score=39,
Model Slope=0.84,
Model Bias=59.55,
VAL MedAE=45.74,
VAL MAE=165.82,
VAL weighted RMSE=244.44,
VAL weighted RMSE relative=79 %,
VAL weighted RMSE_Rating=very bad,
VAL R2=0.89,
Val MSE=0.002496
2026.01.12 13:59:18 1: mySolarForecast DEBUG> AI FANN training data successfuly written to file: ./FHEM/FhemUtils/NeuralNet_SolarForecast_mySolarForecast
2026.01.12 13:59:18 1: mySolarForecast DEBUG> AI FANN con Training BlockingCall PID '1980' finished
Im Anhang sind die Screenshots der Verbrauchsprognose, das erste Bild ist vor dem 1. Training, das 2. Bild ist dann mit "v1_heatpump_pv" und das letzte mit "v1_heatpump_active_pv"
FHEM auf RPi3, THZ (LWZ404SOL), RPII2C & I2C_MCP342x (ADCPiZero), PowerMap, CustomReadings, RPI_GPIO, Twilight, nanoCUL (WMBus für Diehl Wasserzähler & Regenerationszähler für BWT AqaSmart), ESPEasy, TPLinkHS110
DS_Starter
@Wolle, hier ist die KI Einschätzung für dich. Tiefere Infos gäbe es mit einem Trainingslog.
⭐ Gesamturteil: Das Modell ist stabil, aber stündlich deutlich zu flach und unterschätzt Peaks
Die Zahlen und die visuelle Darstellung passen perfekt zusammen:
Das Modell trifft die Form des Tages, aber nicht die Höhe.
📊 1. Interpretation der stündlichen Balken (00–24)
Die grauen Balken zeigen:
Nachtstunden: plausibel niedrig
Morgenpeak: vorhanden, aber zu flach
Mittagsbereich: geglättet, kaum Variation
Abendpeak: sichtbar, aber deutlich zu niedrig
Gesamtprofil: zu glatt, zu vorsichtig, zu wenig Dynamik
Das passt exakt zu:
Slope = 0.8 → Modell drückt hohe Werte nach unten
Bias = 83 Wh → leichte Unterprognose
RMSE_rel = 31 % → deutliche Abweichungen bei Spitzen
MAE = 136 Wh → zu hoch für stündliche Prognosen
MedAE = 86 Wh → auch Medianfehler zu hoch
Die Prognose wirkt wie ein gedämpfter Tagesverlauf, der die echten Spitzenlasten nicht abbildet.
🧠 2. Warum das Modell so flach ist
🔹 a) INCREMENTAL als Trainingsalgorithmus
INCREMENTAL:
lernt sehr konservativ
glättet stark
hat Probleme mit nichtlinearen Peaks
bleibt oft in flachen Tälern hängen
reagiert schlecht auf seltene Spitzenlasten
Für stündliche Haushaltslast ist das nicht ideal.
🔹 b) Registry v1_common
Diese Registry enthält:
Trends
PV‑Semantik
Abend‑Semantik
Rückfall‑Semantik
Aber:
keine WP‑Semantik
keine COP‑Semantik
keine Frostschutz‑Semantik
keine Lastverstärker
Wenn der Haushalt eine Wärmepumpe hat, fehlen dem Modell kritische Signale, die Peaks erklären.
🔹 c) Steilheit = 0.9
SIGMOID mit 0.9 ist:
sehr glatt
wenig sensitiv
reagiert schwach auf starke Inputs
Für stündliche Peaks ist das zu träge.
🔹 d) ShuffleMode = 2
Das ist gut — aber INCREMENTAL + shuffleMode 2 führt zu:
sehr gleichmäßigem Training
aber wenig Peak‑Sensitivität
📈 3. Bewertung der numerischen Metriken
✔ Stabilität
Train MSE = 0.000461
Val MSE = 0.000289
ValStd = 0.000072
BitFail = 0
→ Modell ist stabil, keine Divergenz.
❌ Prognosequalität
RMSE_rel = 31 % → schwach
Slope = 0.8 → systematische Unterprognose
Bias = 83 Wh → leichte Verschiebung
MAPE = 18.5 % → zu grob
R² = 0.90 → Form gut, Höhe schlecht
✔ Retrain‑Entscheidung korrekt
🎯 4. Fazit der Neubewertung
Das Modell ist mathematisch stabil, aber semantisch zu flach.
Die stündliche Prognose (graue Balken) zeigt:
richtige Form
falsche Höhe
zu wenig Dynamik
zu geringe Peak‑Erkennung
zu starke Glättung
Die Ursache ist eine Kombination aus:
INCREMENTAL
Steilheit 0.9
fehlender WP‑Semantik
Registry v1_common
Slope‑Verlust
zu glatter Aktivierung
🛠 5. Was du tun solltest
🔥 Sofortmaßnahmen
RPROP statt INCREMENTAL
Steilheit 1.2
Registry v_hp_advanced, falls WP‑Haushalt
hp_power_factor aktivieren
COP‑Semantik aktivieren
Frostschutz‑Semantik aktivieren
🎯 Ziel
Slope Richtung 0.95–1.05
MAE < 100 Wh
RMSE_rel < 22 %
MAPE < 12 %
Für dich wäre vermutlich das Profil v1_common_active_pv besser.
DS_Starter
@ TheTrumpeter, die Werte mit get ... valDecTree  aiNeuralNetConState und das komplette Trainingslog wären hilfreich um die KI wegen einer Bewertung zu füttern.
Wolle02
Zitat von: DS_Starter am 12 Januar 2026, 14:07:13@Wolle, hier ist die KI Einschätzung für dich. Tiefere Infos gäbe es mit einem Trainingslog.
Das passt exakt zu:
INCREMENTAL:
glättet stark
Trends
PV‑Semantik
Abend‑Semantik
Rückfall‑Semantik
Aber:
keine WP‑Semantik
keine COP‑Semantik
sehr glatt
wenig sensitiv
✔ Stabilität
Val MSE = 0.000289
ValStd = 0.000072
BitFail = 0
❌ Prognosequalität
richtige Form
falsche Höhe
zu wenig Dynamik
zu starke Glättung
INCREMENTAL
Steilheit 0.9
Registry v1_common
Slope‑Verlust
🔥 Sofortmaßnahmen
Steilheit 1.2
🎯 Ziel
MAE < 100 Wh
RMSE_rel < 22 %
MAPE < 12 %
So, ich hab jetzt mal neu trainiert und dabei die Vorschläge von der letzten Analyse einfließen lassen. Trainingsalgorithmus: RPROP, Registry Version=v1_common_active_pv
=== Modellparameter ===
Normierungsgrenzen: PV=8888 Wh, Hausverbrauch: Min=0 Wh / Max=12741 Wh
Trainingsdaten: 6241 Datensätze (Training=4992, Validierung=1249)
Architektur: Inputs=64, Hidden Layers=80-40-20, Outputs=1
Hyperparameter: Learning Rate=0.005, Momentum=0.5, BitFail-Limit=0.35
Aktivierungen: Hidden=SIGMOID, Steilheit=0.9, Output=LINEAR
Zufallsgenerator: Mode=2, Periode=10
=== Trainingsmetriken ===
bestes Modell bei Epoche: 54 (von max. 15000)
Training MSE: 0.000763
Validation MSE: 0.000490
Validation MSE Average: 72.098845
Validation MSE Standard Deviation: 0.416027
Validation Bit_Fail: 0
Model Bias: 127 Wh
Model Slope: 0.8
Trainingsbewertung: Retrain
=== Fehlermaße der Prognosen ===
MAE: 155.66 Wh
MedAE: 74.02 Wh
RMSE: 205.75 Wh
RMSE relative: 36 %
RMSE Rating: very bad
MAPE: 17.89 %
MdAPE: 14.13 %
R²: 0.83
Das Trainingslog ist im Anhang.
Ich habe den Eindruck, dass die Werte etwas schlechter geworden sind.
TheTrumpeter
Zitat von: DS_Starter am 12 Januar 2026, 14:13:28@ TheTrumpeter, die Werte mit get ... valDecTree  aiNeuralNetConState und das komplette Trainingslog wären hilfreich um die KI wegen einer Bewertung zu füttern.
Hier get blabla:
Informationen zum neuronalen Netz der Verbrauchsvorhersage
letztes KI-Training: 12.01.2026 13:59:18 / Laufzeit in Sekunden: 9741
KI Abfragestatus: ok
letzte KI-Ergebnis Generierungsdauer: 70.43 ms
Verbrauchernummer Wärmepumpe:  03
Normierungsgrenzen: PV=18612 Wh, Hausverbrauch: Min=0 Wh / Max=6400 Wh
Trainingsdaten: 8020 Datensätze (Training=6416, Validierung=1604)
Architektur: Inputs=112, Hidden Layers=80-40-20, Outputs=1
Hyperparameter: Learning Rate=0.005, Momentum=0.8, BitFail-Limit=0.35
Aktivierungen: Hidden=SIGMOID, Steilheit=0.5, Output=LINEAR
Trainingsalgorithmus: INCREMENTAL, Registry Version=v1_heatpump_active_pv
bestes Modell bei Epoche: 3370 (von max. 15000)
Training MSE: 0.001108
Validation MSE: 0.002496
Validation MSE Average: 0.002381
Validation MSE Standard Deviation: 0.000093
Model Bias: 60 Wh
Model Slope: 0.8
MAE: 165.82 Wh
MedAE: 45.74 Wh
RMSE: 244.44 Wh
RMSE relative: 79 %
MAPE: 20.19 %
MdAPE: 12.71 %
R²: 0.89
=== Drift-Kennzahlen ===
Drift Score: -
Drift RMSE relative: -
Drift Bias: -
Drift Slope: -
Drift Bewertung: -
DS_Starter
@Wolle, Würde ich auch so sehen. KI sagt:
🧠 Was hier passiert
🔹 Verstärker sind aktiv
→ Die Registry liefert starke Signale für PV‑Peaks und Lastsprünge.
🔹 Aber: Steilheit = 0.9
→ SIGMOID mit 0.9 ist zu flach → Verstärker werden ,,abgefedert".
🔹 RPROP springt früh
→ Best Snapshot bei Epoche 54 → Verstärker noch nicht voll gelernt.
🔹 Snapshot‑Logik greift zu früh
→ Modell wird eingefroren, bevor Verstärker ihre Wirkung entfalten.
🛠 Was du tun kannst
✅ Steilheit auf 1.2 setzen
→ Verstärker wirken deutlich stärker
→ Slope steigt
→ Bias sinkt
→ RMSE_rel verbessert sich
✅ Snapshot erst ab Epoche 150 zulassen
→ Verstärker brauchen Zeit
→ RPROP darf sich entfalten
→ Modell wird nicht zu früh eingefroren
✅ Retry mit Seed‑Variation
→ RPROP reagiert stark auf Initialisierung
→ Seed‑Sweep kann bessere Minima finden
🎯 Fazit
Du hast die Verstärker korrekt eingebaut — das ist super.
Aber: RPROP + flache Aktivierung + früher Snapshot bremst sie aus.
Probier es mal so wie vorgeschlagen, ansonsten nimm wieder INCREMENTAL mit Steepness=1.2
Dein erstes Setup war ja nicht so schlecht.
DS_Starter
@TheTrumpeter, hier kommt deine Analyse:
📊 Visuelle Bewertung der stündlichen Prognose (graue Balken, Stunde 14 ignoriert)
Die Balken zeigen:
Stunde 13: Peak vorhanden, aber zu niedrig → Slope = 0.8 bestätigt
Stunde 10–11: starke Aktivität, aber nicht voll getroffen
Stunde 15–17: WP‑Last sichtbar, aber gedämpft
Stunde 18–23: geglättet, keine echte WP‑Dynamik
Stunde 00–09: plausibel, aber zu flach für Frostschutz oder Nachtladung
→ Das Modell trifft die Form des Tagesprofils, aber nicht die Höhe oder die WP‑Peaks.
🔍 Numerische Bewertung (Stunde 14 ignoriert)
Die Metriken bleiben:
MAE = 165.82 Wh
RMSE = 244.44 Wh
RMSE_rel = 79 %
Slope = 0.8
Bias = 60 Wh
R² = 0.89
→ Die Retrain‑Entscheidung bleibt korrekt, denn:
RMSE_rel ist viel zu hoch
Slope ist zu flach
MAE ist nicht WP‑tauglich
🧠 Was das Modell trotzdem gut macht
ValStd = 0.000093 → extrem stabil
BitFail = 0 → keine neuronalen Sättigungen
R² = 0.89 → gute Formtreue
Bias = 60 Wh → keine systematische Verschiebung
MedAE = 45 Wh → zeigt, dass viele Stunden gut getroffen sind
→ Das Modell ist technisch sauber, aber semantisch zu flach.
🛠 Empfehlungen zur Verbesserung
🔧 Architektur
Steilheit auf 1.2 erhöhen → WP‑Peaks werden durchgelassen
RPROP statt INCREMENTAL → besser für nichtlineare WP‑Last
Snapshot später zulassen → z. B. ab Epoche 300
🔧 Registry
v1_heatpump_active_pv ist korrekt
sicherstellen, dass cop_booster, frost_protection, semantic_peak_push, hp_power_factor aktiv sind
🔧 Training
Retry mit Seed‑Sweep
Early Stopping später aktivieren
Verstärkerwirkung visuell prüfen (z. B. Stunde 13, 17, 06)
🎯 Fazit
Auch ohne Stunde 14 bleibt das Modell nicht einsatzreif für WP‑Haushalte.
Die Prognose ist zu flach, zu geglättet, nicht peak‑sensitiv.
Die Registry ist korrekt, aber wird durch:
Steilheit 0.5
INCREMENTAL
frühen Snapshot
ausgebremst.
Den Vorschlag
würde ich unterschreiben.
Bei RPROP statt INCREMENTAL → besser für nichtlineare WP‑Last bin ich eher nicht der Meinung (siehe Wolle) aber einen Versuch ist es ja wert.
TheTrumpeter
Danke, hab' ich mal gesetzt und neu gestartet.
Zu meinem Nutzungsverhalten:
Die WP startet bei normalen Temperaturen typischerweise zwischen 08:45 und 09:15 und läuft dann je nach Außentemperatur ein paar Stunden durch, von 2h in der Übergangszeit bis zu 6-7 h bei typischen Wintertemperaturen.
In der derzeitigen Kältephase startet sie durchaus schon um 06:00 und läuft dann auch mal 12 oder 13 h.
Irgendwann während der "Heizphase" springt dann das WW dazwischen, d.h. aus SolarForecast-Sicht wird der Verbraucher dann beendet und ein anderer (Nicht-WP-) Verbraucher läuft. Wenn die WW-Temperatur erreicht ist, "übernimmt" wieder der "WP-Verbraucher". Das führt natürlich zu einer gewissen Unschärfe.
Wolle02
Zitat von: DS_Starter am 12 Januar 2026, 15:24:09@Wolle, Würde ich auch so sehen. KI sagt:
🧠 Was hier passiert
🛠 Was du tun kannst
→ Slope steigt
→ Bias sinkt
🎯 Fazit
So, jetzt wieder mit Incremental und Steilheit=1.2. Sieht wieder besser aus:
letztes KI-Training: 12.01.2026 18:07:45 / Laufzeit in Sekunden: 2857
letzte KI-Ergebnis Generierungsdauer: 33.68 ms
Verbrauchernummer Wärmepumpe: -
Trainingsdaten: 6244 Datensätze (Training=4995, Validierung=1249)
Aktivierungen: Hidden=SIGMOID, Steilheit=1.2, Output=LINEAR
Trainingsalgorithmus: INCREMENTAL, Registry Version=v1_common_active_pv
bestes Modell bei Epoche: 2639 (von max. 15000)
Training MSE: 0.000355
Validation MSE: 0.000277
Validation MSE Average: 0.000309
Validation MSE Standard Deviation: 0.000008
Model Bias: -10 Wh
Model Slope: 0.9
MAE: 135.71 Wh
MedAE: 77.52 Wh
RMSE: 174.29 Wh
RMSE relative: 31 %
RMSE Rating: weak
MAPE: 18.37 %
MdAPE: 13.88 %
R²: 0.91
Danke fürs drüberschauen  :D
DS_Starter
#4899
@Wolle, hier die Bewertung:
Das Modell ist technisch solide, aber semantisch zu flach für stündliche Haushaltsprognosen ohne Wärmepumpe. Ich zeige dir jetzt, warum die Retrain‑Entscheidung korrekt ist, obwohl die Form gut getroffen wird.
📊 Numerische Bewertung
Metrik    Wert    Bewertung
Train MSE    0.000355    sehr gut
Val MSE    0.000277    stabil
ValStd    0.000008    extrem niedrig → Modell ist konsistent
BitFail    0    perfekt
Bias    −10 Wh    neutral
Slope    0.90    leicht zu flach
MAE    135 Wh    zu hoch für Standardhaushalt
RMSE    174 Wh    schwach
RMSE_rel    31 %    nicht akzeptabel
R²    0.91    sehr gut
MAPE    18.4 %    zu hoch
MdAPE    13.9 %    grenzwertig
Bewertung    Retrain    korrekt
🧠 Interpretation
✅ Was gut ist:
Formtreue: R² = 0.91 → Tagesverlauf wird gut getroffen
Stabilität: ValStd = 0.000008 → keine Schwankungen
Bias = −10 Wh → keine systematische Verschiebung
Slope = 0.9 → Modell reagiert, aber nicht voll dynamisch
❌ Was kritisch ist:
MAE = 135 Wh → zu hoch für stündliche Steuerung
MAPE > 18 % → zu grob für PV‑Optimierung
Retrain‑Entscheidung korrekt, da RMSE‑Rating = weak
📈 Was das Modell visuell zeigt (graue Balken)
Form stimmt: Tagesverlauf ist plausibel
Spitzenlasten werden unterschätzt → Slope = 0.9
Morgen- und Abendlasten sind geglättet
PV‑Mittagspeak wird nicht voll durchgelassen
Keine WP‑Artefakte sichtbar → korrekt für WP‑frei
🔧 Architektur
Steilheit 1.2 ist gut → beibehalten
Hidden Layers ggf. auf 60‑30‑15 reduzieren → weniger Glättung
RPROP als Alternative testen → kann Peaks besser lernen
🔧 Registry
v1_common_active_pv ist korrekt
ggf. pv_peak_booster aktivieren
semantic_peak_push verstärken
🔧 Training
Snapshot ab Epoche 300 zulassen
Verstärkerwirkung visuell prüfen (z. B. Stunde 10–13)
🎯 Fazit
Das Modell ist technisch sauber, aber semantisch zu flach für präzise Haushaltsprognosen ohne WP.
Ich würde das so lassen. Aber kannst auch:
gerne mal testen und wenn es nicht besser wird -> wieder zurück auf aktuelle Einstellung.
Die Hinweise:
- ggf. pv_peak_booster aktivieren
- semantic_peak_push verstärken
sind etwas für mich was ich prüfen und ggf. umsetzen werde.
DS_Starter
@all,
die V2.0.0 im Contrib stellt nun auch die Windgeschwindigkeiten (windspeed) in nextHours etc. zur Verfügung. Bei Verwendung von DWD-Devices als Wetterlieferant muß man "FF" im DWD-Device mit aktivieren.
Der Systemcheck weist darauf hin falls nicht gesetzt.
TheTrumpeter
Hier das Ergebnis des gestrigen Lernvorgangs mit der erhöhten Steilheit, Log inkl. automatischem Lernzyklus heute Nacht im Anhang:
letztes KI-Training: 13.01.2026 04:58:59 / Laufzeit in Sekunden: 9511
letzte KI-Ergebnis Generierungsdauer: 80.79 ms
Trainingsdaten: 8035 Datensätze (Training=6428, Validierung=1607)
bestes Modell bei Epoche: 1916 (von max. 15000)
Training MSE: 0.000451
Validation MSE: 0.002025
Validation MSE Average: 0.002368
Validation MSE Standard Deviation: 0.000026
Model Bias: 42 Wh
Model Slope: 0.9
MAE: 137.45 Wh
MedAE: 39.56 Wh
RMSE: 187.68 Wh
RMSE relative: 60 %
MAPE: 18.01 %
MdAPE: 10.29 %
R²: 0.91
Drift Score: -
Drift Bias: -
Drift Slope: -
Drift Bewertung: -
Die Prognose für heute finde ich gar nicht so schlecht:
Die Unterbewertung um 04:00 ergibt sich im Wesentlichen durch den "NoFrost"-Zyklus vom Gefrierschrank, der heute Nacht zufällig kurz nach 04:00 startete.
Die Unterbewertung um 05:00 ergibt sich durch den etwas früheren Kaffee- und Küchenmaschineneinsatz heute Früh. (Normal kurz nach 06:00, heute schon kurz vor 06:00.)
Die Prognose für 09:00-16:00 ist 1 h zu spät angesetzt. Wie gestern geschrieben sollte die WP frühestens um 08:45, spätestens um 9:25 einschalten, damit ergäbe sich für 08:00 theoretisch der Verbrauch von 09:00 und von 09:00 der Verbrauch von 10:00.
Der Rest sowie die Dauer des hohen Verbrauchs passt ganz gut würde ich sagen.
lorisurfen
#4902
Zitat von: DS_Starter am 08 Januar 2026, 09:43:08@Wolle,
ZitatWäre es eventuell möglich einen zusätzlichen Schlüssel z.B. replan=1 einzufügen, der eine sofortige Neuplanung einleitet, wenn der Zyklus abgeschlossen ist?
Das wäre möglich. Allerdings wirkt es dann natürlich ständig, sodass man eigentlich nur mit interuptable arbeiten bräuchte um den gleichen Effekt zu erzielen.
Aktuell habe ich dafür den Befehl "set <name> consumerNewPlanning XX" vorgesehen.
Die Idee dahinter ist, dass der User z.B. mit einem notify, DOIF auf einen finished-Status reagieren und über diesen Befehl direkt eine Neueinplanung vornehmen kann. Das ist wesentlich flexibler, weil man z.B. die täglichen Neueinplanungen auf 3 begrenzen oder von Zusatzbedingungen abhängig gestalten kann.
LG,
Heiko
Laut meinem debug von gestern wird aber swoncond nur beim erstmaligen einschalten geprüft, nicht aber nach interruptable ?
Ich hätte erwartet, wenn über Schlüssel interruptable unterbrochen wird, dann beim (Wieder-)Einschalten auch swoncond geprüft/erfüllt sein muss? Ist das ein Fehler oder kann ich das irgendwie einstellen, dass nach interruptable auch swoncond geprüft wird. Ist Prüfung auf swoncond evtl. unterschiedlich bei interruptable=1 und interruptable=Bedingung?
Nach swoffcond und einem replan (Sofortige Neueinplanung) würde dagegen doch auch swoncond erneut geprüft (Für meinen Fall möchte ich immer, dass beim Wiedereinschalten auch swoncond geprüft wird).
Entweder muss nach interruptable auch swoncond geprüft werden oder die folgende Aussage wäre nicht zutreffend?:
ZitatDas wäre möglich. Allerdings wirkt es dann natürlich ständig, sodass man eigentlich nur mit interuptable arbeiten bräuchte um den gleichen Effekt zu erzielen.
stefanru
Hmm, wo sehe ich das? Habe FF in den DWD Devices aber sehe keine Änderung?
FHEM: Raspberry PI 400+SSD
Viessmann, Fronius, BYD, Wunderground, Max, Shelly, ESPEasy, FHEMPY,...  Docker + Portainer: Immich, HA, Authelia, Caddy
Maintainer: Vitoconnect
300P
Da sollte auch kein Hinweis kommen wenn "FF" mit dabei ist, nur wenn's fehlt ;)
Im Systemcheck ist es aus meiner Sicht (noch) nicht enthalten. O:-)
OLD my @dweattrmust    = qw(TTT Neff RR1c ww SunUp SunRise SunSet);                     # Werte die im Attr forecastProperties des Weather-DWD_Opendata Devices mindestens gesetzt sein müssen
NEW my @dweattrmust    = qw(TTT Neff RR1c ww SunUp SunRise SunSet FF);                  # Werte die im Attr forecastProperties des Weather-DWD_Opendata Devices mindestens gesetzt sein müssen
300P
FHEM 6.4|RPi|SMAEM|SMAInverter|SolarForecast| DbLog|DbRep|MariaDB|Buderus-MQTT_EMS|
Fritzbox|fhempy|JsonMod|HTTPMOD|Modbus ser+TCP| ESP32_AI_on_the_Edge|ESP32CAM usw.
