Entwicklungs-Thread Modul 36_Shelly.pm
Begonnen von Starkstrombastler, 24 Februar 2024, 12:15:05
stobor
#195
wie bringe ich denn am besten einen Shelly Pro 2 zum Laufen?
Ich habe schon versucht, das Template des Shelly Pro 4pm zu verwenden, doch wenn ich den Shelly über dessen Web-Interface schalte kommt bei FHEM nichts an.
Angebunden ist der Shelly über MQTT and erzeugt über AUTOCREATE:
define shellypro2_TerrasseSued MQTT2_DEVICE shellypro2_TerrasseSued
setuuid shellypro2_TerrasseSued 6a66f6cd-f33f-2cfb-292f-2e4ed82ccbf83416
attr shellypro2_TerrasseSued devStateIcon {my $onl = ReadingsVal($name,'online','false') eq 'false'?'10px-kreis-rot':'10px-kreis-gruen';; $onl = FW_makeImage($onl);; my $light = FW_makeImage(ReadingsVal($name,'state','off'));; my $temp = ReadingsVal($name,'temperature','-100');; my $ip = ReadingsVal($name,'ip','none');; my $reb = ReadingsVal($name,'sys_restart_required','false') eq 'true'?'<a href="/fhem?cmd.dummy=set '.$name.' x_reboot&XHR=1"> ... Notwendigen Reboot durchführen</a>':'';; qq(<a href="http://$ip" target="_blank">${onl}</a><a href="/fhem?cmd.dummy=set $name toggle&XHR=1">${light}</a>$reb<div>Temp: $temp °C</div>)}
attr shellypro2_TerrasseSued devicetopic shellypro2_TerrasseSued
attr shellypro2_TerrasseSued getList in_mode:noArg in_mode $DEVICETOPIC/rpc {"id": 1,"src":"$DEVICETOPIC", "method": "Switch.GetConfig", "params": {"id": 0}}
attr shellypro2_TerrasseSued icon message_socket
attr shellypro2_TerrasseSued jsonMap switch_state:state switch_temperature_tC:temperature switch_temperature_tF:0 params_wifi_sta_ip:ip params_switch_0_temperature_tC:temperature params_switch_0_temperature_tF:0 req_result_in_mode:in_mode
attr shellypro2_TerrasseSued model shellyPlus_1
attr shellypro2_TerrasseSued readingList $DEVICETOPIC/online:.* online\
  $DEVICETOPIC/events/rpc:.* { json2nameValue($EVENT,'',$JSONMAP) }\
  $DEVICETOPIC/status/mqtt:.* { json2nameValue($EVENT, 'mqtt_', $JSONMAP) }\
  $DEVICETOPIC/status/sys:.* { json2nameValue($EVENT, 'sys_', $JSONMAP) }\
  $DEVICETOPIC/status/switch_0:.* { $EVENT =~ s/"output":true/"state":"on"/g;; $EVENT =~ s/"output":false/"state":"off"/g;; json2nameValue($EVENT, 'switch_', $JSONMAP) }\
  $DEVICETOPIC/status/cloud:.* {}\
  $DEVICETOPIC/rpc:.* { json2nameValue($EVENT, 'req_', $JSONMAP, 'in_mode')}\
  $DEVICETOPIC/status/input_0:.* { json2nameValue($EVENT, 'input_', $JSONMAP) }\
  fhem2shelly/rpc:.* {}\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/events/rpc:.* { json2nameValue($EVENT, 'rpc_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/switch_1:.* { json2nameValue($EVENT, 'switch_1_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/switch_0:.* { json2nameValue($EVENT, 'switch_0_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/online:.* online\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/ble:.* ble\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/cloud:.* { json2nameValue($EVENT, 'cloud_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/eth:.* { json2nameValue($EVENT, 'eth_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/input_0:.* { json2nameValue($EVENT, 'input_0_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/input_1:.* { json2nameValue($EVENT, 'input_1_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/mqtt:.* { json2nameValue($EVENT, 'mqtt_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/sys:.* { json2nameValue($EVENT, 'sys_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/wifi:.* { json2nameValue($EVENT, 'wifi_', $JSONMAP) }\
shellypro2_TerrasseSued:shellypro2-TerrasseSued/status/ws:.* { json2nameValue($EVENT, 'ws_', $JSONMAP) }
attr shellypro2_TerrasseSued room MQTT,Terrasse
attr shellypro2_TerrasseSued setList toggle:noArg $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Switch.Toggle","params": {"id":0}}\
  off:noArg $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Switch.Set","params": {"id":0,"on":false}}\
  on:noArg $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Switch.Set","params": {"id":0,"on":true}}\
  on-for-timer $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Switch.Set","params": {"id":0,"on":true,"toggle_after":$EVTPART1}}\
  off-for-timer $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Switch.Set","params": {"id":0,"on":false,"toggle_after":$EVTPART1}}\
  in_mode:toggle,flip,detached {fhem("sleep 0.2;; get $NAME in_mode");; my $val = $EVTPART1 ne 'toggle' ? $EVTPART1 : ReadingsVal($NAME,'in_mode','flip') eq 'flip' ? 'detached':'flip';; qq($DEVICETOPIC/rpc {"id":1,"src":"fhem2shelly","method":"Switch.SetConfig","params": {"id":0, "config": {"in_mode": "$val"}}})}\
  x_update:noArg $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Shelly.Update","params": {"stage":"stable"}}\
  x_reboot:noArg $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Shelly.Reboot"}\
  x_eco:true,false $DEVICETOPIC/rpc {"id":0,"src":"fhem2shelly","method":"Sys.SetConfig","params": {"config": {"device": {"eco_mode": $EVTPART1}}}}
attr shellypro2_TerrasseSued setStateList on off toggle on-for-timer off-for-timer
attr shellypro2_TerrasseSued webCmd :
Internals
CID    shellypro2_TerrasseSued
DEF    shellypro2_TerrasseSued
FUUID    6a66f6cd-f33f-2cfb-292f-2e4ed82ccbf83416
IODev    MQTT2
LASTInputDev    MQTT2
MQTT2_CONN    MQTT2_192.168.179.24_59748
MQTT2_MSGCNT    14
MQTT2_TIME    27.07.2026 15:13
MSGCNT    14
NAME    shellypro2_TerrasseSued
NR    1899
STATE    set_on
TYPE    MQTT2_DEVICE
eventCount    26
Readings
IODev
MQTT2
2026-07-27 15:04:43
associatedWith
shellypro2_TerrasseSued_CH2,shellypro2_TerrasseSued_CH3,shellypro2_TerrasseSued_CH4
2026-07-27 15:02:51
attrTemplateVersion
20240627
2026-07-27 15:02:53
ble
2026-07-27 15:05:07
cloud_connected
false
2026-07-27 15:05:07
input_0_id
0
2026-07-27 15:05:07
input_0_state
false
2026-07-27 15:05:07
input_1_id
1
2026-07-27 15:05:07
input_1_state
false
2026-07-27 15:05:07
mqtt_connected
true
2026-07-27 15:05:07
online
true
2026-07-27 15:05:07
rpc_dst
2026-07-27 15:13:34
rpc_method
NotifyStatus
2026-07-27 15:13:34
rpc_params_cloud_connected
false
2026-07-27 15:05:07
rpc_params_input_0_id
0
2026-07-27 15:05:07
rpc_params_input_0_state
false
2026-07-27 15:05:07
rpc_params_input_1_id
1
2026-07-27 15:05:07
rpc_params_input_1_state
false
2026-07-27 15:05:07
rpc_params_mqtt_connected
true
2026-07-27 15:05:07
rpc_params_switch_0_id
0
2026-07-27 15:05:52
rpc_params_switch_0_output
false
2026-07-27 15:05:52
rpc_params_switch_0_source
WS_in
2026-07-27 15:05:52
rpc_params_switch_0_temperature_tC
34.5
2026-07-27 15:05:07
rpc_params_switch_0_temperature_tF
94.1
2026-07-27 15:05:07
rpc_params_switch_1_id
1
2026-07-27 15:13:34
rpc_params_switch_1_output
true
2026-07-27 15:05:40
rpc_params_switch_1_source
WS_in
2026-07-27 15:05:40
rpc_params_switch_1_temperature_tC
44.06
2026-07-27 15:13:34
rpc_params_switch_1_temperature_tF
111.30
2026-07-27 15:13:34
rpc_params_sys_available_updates_beta_version
2.0.0-beta3
2026-07-27 15:05:07
rpc_params_sys_available_updates_stable_version
1.7.5
2026-07-27 15:05:07
rpc_params_sys_cfg_rev
8
2026-07-27 15:05:07
rpc_params_sys_fs_free
208896
2026-07-27 15:05:07
rpc_params_sys_fs_size
524288
2026-07-27 15:05:07
rpc_params_sys_kvs_rev
0
2026-07-27 15:05:07
rpc_params_sys_mac
80F3DAC8B8A0
2026-07-27 15:05:07
rpc_params_sys_ram_free
111420
2026-07-27 15:05:07
rpc_params_sys_ram_size
260204
2026-07-27 15:05:07
rpc_params_sys_reset_reason
3
2026-07-27 15:05:07
rpc_params_sys_restart_required
false
2026-07-27 15:05:07
rpc_params_sys_schedule_rev
0
2026-07-27 15:05:07
rpc_params_sys_time
15:05
2026-07-27 15:05:07
rpc_params_sys_unixtime
1785157506
2026-07-27 15:05:07
rpc_params_sys_uptime
23287
2026-07-27 15:05:07
rpc_params_sys_webhook_rev
0
2026-07-27 15:05:07
rpc_params_ts
1785158014.19
2026-07-27 15:13:34
rpc_params_wifi_rssi
-72
2026-07-27 15:05:07
rpc_params_wifi_ssid
Quadratogramm
2026-07-27 15:05:07
rpc_params_wifi_sta_ip
192.168.179.24
2026-07-27 15:05:07
rpc_params_wifi_status
got ip
2026-07-27 15:05:07
rpc_params_ws_connected
false
2026-07-27 15:05:07
rpc_src
shellypro2-80f3dac8b8a0
2026-07-27 15:13:34
switch_0_id
0
2026-07-27 15:05:52
switch_0_output
false
2026-07-27 15:05:52
switch_0_source
WS_in
2026-07-27 15:05:52
34.6
2026-07-27 15:05:52
94.3
2026-07-27 15:05:52
switch_1_id
1
2026-07-27 15:13:34
switch_1_output
true
2026-07-27 15:13:34
switch_1_source
WS_in
2026-07-27 15:13:34
44.1
2026-07-27 15:13:34
111.3
2026-07-27 15:13:34
2.0.0-beta3
2026-07-27 15:05:07
1.7.5
2026-07-27 15:05:07
sys_cfg_rev
8
2026-07-27 15:05:07
sys_fs_free
208896
2026-07-27 15:05:07
sys_fs_size
524288
2026-07-27 15:05:07
sys_kvs_rev
0
2026-07-27 15:05:07
sys_mac
80F3DAC8B8A0
2026-07-27 15:05:07
sys_ram_free
110016
2026-07-27 15:05:07
sys_ram_size
260100
2026-07-27 15:05:07
sys_reset_reason
3
2026-07-27 15:05:07
false
2026-07-27 15:05:07
sys_schedule_rev
0
2026-07-27 15:05:07
sys_time
15:05
2026-07-27 15:05:07
sys_unixtime
1785157506
2026-07-27 15:05:07
sys_uptime
23287
2026-07-27 15:05:07
sys_webhook_rev
0
2026-07-27 15:05:07
wifi_rssi
-73
2026-07-27 15:05:07
wifi_ssid
Quadratogramm
2026-07-27 15:05:07
wifi_sta_ip
192.168.179.24
2026-07-27 15:05:07
wifi_status
got ip
2026-07-27 15:05:07
ws_connected
false
2026-07-27 15:05:07
x_reboot
set
Attributes
comment
Shelly Pro 2
deleteattr
devStateIcon
{my $onl = ReadingsVal($name,'online','false') eq 'false'?'10px-kreis-rot':'10px-kreis-gruen'; $onl = FW_makeImage($onl); my $light = FW_makeImage(ReadingsVal($name,'state','off')); my $temp = ReadingsVal($name,'temperature','-100'); my $ip = ReadingsVal($name,'ip','none'); my $reb = ReadingsVal($name,'sys_restart_required','false') eq 'true'?'<a href="/fhem?cmd.dummy=set '.$name.' x_reboot&XHR=1"> ... Notwendigen Reboot durchführen</a>':''; qq(<a href="http://$ip" target="_blank">${onl}</a><a href="/fhem?cmd.dummy=set $name toggle&XHR=1">${light}</a>$reb<div>Temp: $temp °C</div>)}
deleteattr
devicetopic
deleteattr
getList
deleteattr
icon
message_socket
deleteattr
jsonMap
deleteattr
model
shellyPlus_1
deleteattr
readingList
  $DEVICETOPIC/status/switch_0:.* { $EVENT =~ s/"output":true/"state":"on"/g; $EVENT =~ s/"output":false/"state":"off"/g; json2nameValue($EVENT, 'switch_', $JSONMAP) }
deleteattr
room
MQTT,Terrasse
deleteattr
setList
  in_mode:toggle,flip,detached {fhem("sleep 0.2; get $NAME in_mode"); my $val = $EVTPART1 ne 'toggle' ? $EVTPART1 : ReadingsVal($NAME,'in_mode','flip') eq 'flip' ? 'detached':'flip'; qq($DEVICETOPIC/rpc {"id":1,"src":"fhem2shelly","method":"Switch.SetConfig","params": {"id":0, "config": {"in_mode": "$val"}}})}
deleteattr
setStateList
deleteattr
webCmd
Intel NUC (Ubuntu 24.04.4 LTS)  mit CUL V3.2 (FW 1.57 CUL868) für FS20 und CCU3 für HM(IP) + Arduino Mega (Firmata) - FHEM Revision: 31515 - FS20, HM(IP), MQTT, Philips HUE, ModBus
JoWiemann
hier gar nicht. Das Thema musst Du schon im Bereich Shelly MQTT adressieren. Hier geht es nur um das Shelly Modul. Ganz anderer Ansatz.
Grüße Jörg
Jörg Wiemann
piet_pit
#197
Hallo Starkstrombastler,
vielen Dank für deine tolle Arbeit am Modul Shelly, ich nutze das bei meinen Shellys auschließlich und sehr gerne!
Ich nutze einen Shelly Pro Dual Cover PM (SPSH-002PE16EU) mit aktueller Firmware 2.0.0, den ich einfach nicht richtig ansprechen kann! Ich möchte den gerne wie auch alle anderen Shellys über Homekit bedienen.
Da das Homebridge-fhem PlugIn die beiden Kanäle eines Dual Covers nicht getrennt ansteuern kann, habe ich für beide Kanäle jeweils einen readingsProxy aufgebaut.
Mittlerweile funktionieren darüber sowohl Homebridge / Apple Home als auch AutoShuttersControl (ASC) grundsätzlich. Die getrennte Abbildung der beiden Kanäle über den readingsProxy scheint also zu funktionieren. Eine saubere Steuerung der beiden Kanäle ist aber leider nicht möglich. Es gibt bei der Positionsfahrt weiterhin ein nicht nachvollziehbares Verhalten.
Deshalb habe ich mit Hilfe von ChatGPT versucht, den Ablauf Schritt für Schritt einzugrenzen.
Dabei konnten wir folgendes ausschließen:
- Homebridge-fhem sendet den gewünschten Positionswert korrekt an FHEM.
- Der readingsProxy ruft die setFn korrekt auf.
- Das Shelly-Device erhält den entsprechenden Befehl (z. B. set DachgeschossRollo pct 65 1).
Bei der Analyse von 36_Shelly.pm ist anschließend folgende Stelle aufgefallen:
my $pos = ReadingsVal($name,"position","");
my $pct = ReadingsVal($name,"pct",0);
Zu diesem Zeitpunkt wurde der Kanal bereits bestimmt:
$subs = "_$channel";
Mein Shelly-Device besitzt jedoch ausschließlich folgende Readings:
position_0
position_1
pct_0
pct_1
Ein Reading position bzw. pct existiert nicht.
Meine Frage ist deshalb:
Ist das bewusst so implementiert, weil intern an anderer Stelle position bzw. pct gespiegelt werden, oder müsste bei einem Multi-Channel-Gerät an dieser Stelle position$subs bzw. pct$subs verwendet werden?
Es kann gut sein, dass ich den internen Ablauf des Moduls nicht vollständig verstanden habe. Bevor ich an dieser Stelle einen Patch ausprobiere, möchte ich deshalb lieber nachfragen.
Meine Umgebung:
FHEM Revision 31518
36_Shelly.pm Revision 31383
33_readingsProxy.pm Revision 31192
Shelly Firmware 2.0.0
Vielen Dank für jede Rückmeldung!
piet_pit
FHEM Latest Revision: 29615
Raspberry Pi 3, Rasbian-Stretch
FRITZ!Box 7690
HM-Mod-RPI-PCB, JeeLink
CUNO 1.47
