[gelöst] 76_SolarForecast.pm - Consumer Switching
Begonnen von Christian83, 13 Mai 2024, 08:41:17
Christian83
nachdem es gestern dann funktioniert ha, ging es heute mal wieder nicht...
2024.05.14 07:18:36 1: Forecast3 DEBUG> ############### consumerSwitching consumer "01" ###############
2024.05.14 07:18:36 1: Forecast3 DEBUG> consumer "01" - general switching parameters => auto mode: 1, current Consumption: 458 W, nompower: 2000, surplus: 2367 W, planstate: interrupted:, starttime: 14.05.2024 05:38:58
2024.05.14 07:18:36 1: Forecast3 DEBUG> consumer "01" - isInLocktime: 0
2024.05.14 07:18:36 1: Forecast3 DEBUG> consumer "01" - current Context is >switch on< => swoncond: 1, on-command: heater on
2024.05.14 07:18:36 1: Forecast3 DEBUG> consumer "01" - device >WhirlpoolESP< is used as switching device
2024.05.14 07:18:36 3: MQTT2_DEVICE set WhirlpoolESP heater on
2024.05.14 07:18:36 2: Forecast3 - switching Consumer 'WhirlpoolESP' to 'heater on', cause: existing surplus
2024.05.14 07:18:36 1: Forecast3 DEBUG> consumer "01" - current Context is >switch off< => swoffcond: 0, off-command: heater off
2024.05.14 07:18:36 1: Forecast3 DEBUG> consumer "01" - current planning state: continuing
2024.05.14 07:19:41 1: Forecast3 DEBUG> ############### consumerSwitching consumer "01" ###############
2024.05.14 07:19:41 1: Forecast3 DEBUG> consumer "01" - general switching parameters => auto mode: 1, current Consumption: 387 W, nompower: 2000, surplus: 2485 W, planstate: continuing:, starttime: 14.05.2024 05:38:58
2024.05.14 07:19:41 1: Forecast3 DEBUG> consumer "01" - isInLocktime: 0
2024.05.14 07:19:41 1: Forecast3 DEBUG> consumer "01" - current Context is >switch on< => swoncond: 1, on-command: heater on
2024.05.14 07:19:41 1: Forecast3 DEBUG> consumer "01" - device >WhirlpoolESP< is used as switching device
2024.05.14 07:19:41 1: Forecast3 DEBUG> consumer "01" - current Context is >switch off< => swoffcond: 0, off-command: heater off
2024.05.14 07:19:41 1: Forecast3 DEBUG> consumer "01" - current planning state: continuing
2024.05.14 07:20:46 1: Forecast3 DEBUG> ############### consumerSwitching consumer "01" ###############
2024.05.14 07:20:46 1: Forecast3 DEBUG> consumer "01" - general switching parameters => auto mode: 1, current Consumption: 452 W, nompower: 2000, surplus: 2442 W, planstate: continuing:, starttime: 14.05.2024 05:38:58
2024.05.14 07:20:46 1: Forecast3 DEBUG> consumer "01" - isInLocktime: 0
2024.05.14 07:20:46 1: Forecast3 DEBUG> consumer "01" - current Context is >switch on< => swoncond: 1, on-command: heater on
2024.05.14 07:20:46 1: Forecast3 DEBUG> consumer "01" - device >WhirlpoolESP< is used as switching device
2024.05.14 07:20:46 1: Forecast3 DEBUG> consumer "01" - current Context is >switch off< => swoffcond: 0, off-command: heater off
2024.05.14 07:20:46 1: Forecast3 DEBUG> consumer "01" - current planning state: continuing
Scheinbar verschluckt das MQTT Device den on Befehl. Machst du hier nach einer Zeitlang nochmal set on? Ich habe bis jetzt immer den planning state continuing
DS_Starter
ZitatScheinbar verschluckt das MQTT Device den on Befehl. Machst du hier nach einer Zeitlang nochmal set on? Ich habe bis jetzt immer den planning state continuing
Wenn du dir die V1.20.0 von heute früh updatest, wird beim auch planning state continuing der Einschaltbefehl bei jedem Zykuls wiederholt solange bis "on" bzw. "continued" erkannt wird.
Christian83
Zitat von: DS_Starter am 14 Mai 2024, 09:47:41Wenn du dir die V1.20.0 von heute früh updatest, wird beim auch planning state continuing der Einschaltbefehl bei jedem Zykuls wiederholt solange bis "on" bzw. "continued" erkannt wird.
Ja. jetzt ging es. Nach 3 mal set ... on ging es an. Das ist irgendwie nicht zufriedenstellend (also  vom MQTT Device).
Vielen Dank für deine schnelle Hilfe.
Dann kann ich jetzt mal wieder den Modus can versuchen.
