Panasonic Klima mit ESP32 steuern
Begonnen von Guybrush, 01 Juni 2025, 13:27:13
Moli
Sorry, dachte FHEM Panasonic heißt es ja anders.
logger:
  level: VERY_VERBOSE
Sonst weiß ich jetzt nicht was du meinst.
[09:06:22.145][V][mqtt.idf:161]: MQTT_EVENT_DATA esp_klima_wozi/climate/panasonic_ac/preset/command
[09:06:22.155][D][climate:049]: 'Panasonic AC' - Setting
[09:06:22.239][D][climate:066]:  Custom Preset: Quiet
Moli
Ähm ja sorry, da hat sich ein Fehlerteufel eingeschlichen, in der Konfig, deshalb ist das log ein bisschen low, hier nun besser:
[18:24:21.810][D][climate:049]: 'Panasonic AC' - Setting
[18:24:21.810][D][climate:066]:  Custom Preset: Quiet
[18:24:21.810][V][panasonic_ac.cz_tacg1:211]: Copying data to cmd
[18:24:21.810][V][panasonic_ac.cz_tacg1:297]: Requested preset change
[18:24:21.818][V][panasonic_ac.cz_tacg1:422]: Sending Command
[18:24:21.818][V][panasonic_ac:282]: TX: F0.0A.30.2F.80.30.56.44.00.40.00.00.1D (13)
[18:24:21.818][V][panasonic_ac:284]: RX: 70.20.30.2F.80.30.56.40.00.40.00.00.00.2F.00.00.00.00.12.09.2B.12.09.FF.80.80.FF.80.08.00.00.C0.00.00.B5 (35)
[18:24:21.825][V][panasonic_ac:094]: Received target temperature 23.50
[18:24:21.832][V][panasonic_ac:105]: Target temperature incl. offset: 23.50
[18:24:21.832][V][panasonic_ac:080]: Received current temperature 18
[18:24:21.868][V][panasonic_ac:089]: Current temperature incl. offset: 18
[18:24:21.868][V][panasonic_ac:064]: Received outside temperature 9
[18:24:21.868][D][climate:438]: 'Panasonic AC' >>
[18:24:21.870][D][climate:441]:   Mode: OFF
[18:24:21.870][D][climate:443]:   Action: OFF
[18:24:21.870][D][climate:449]:   Custom Fan Mode: 1
[18:24:21.870][D][climate:455]:   Custom Preset: Normal
[18:24:21.870][D][climate:458]:   Swing Mode: OFF
[18:24:21.870][D][climate:461]:   Current Temperature: 18.00°C
[18:24:21.870][D][climate:468]:   Target Temperature: 23.50°C
[18:24:21.870][V][mqtt:532]: Publish(topic='esp_klima_gaeste/climate/panasonic_ac/mode/state' retain=1 qos=0)
[18:24:21.870][V][mqtt:532]: Publish(topic='esp_klima_gaeste/climate/panasonic_ac/current_temperature/state' retain=1 qos=0)
[18:24:21.870][V][mqtt:532]: Publish(topic='esp_klima_gaeste/climate/panasonic_ac/target_temperature/state' retain=1 qos=0)
[18:24:21.870][V][mqtt:532]: Publish(topic='esp_klima_gaeste/climate/panasonic_ac/preset/state' retain=1 qos=0)
[18:24:21.870][V][mqtt:532]: Publish(topic='esp_klima_gaeste/climate/panasonic_ac/action/state' retain=1 qos=0)
[18:24:21.878][V][mqtt:532]: Publish(topic='esp_klima_gaeste/climate/panasonic_ac/fan_mode/state' retain=1 qos=0)
[18:24:21.878][V][mqtt:532]: Publish(topic='esp_klima_gaeste/climate/panasonic_ac/swing_mode/state' retain=1 qos=0)
[18:24:26.724][V][panasonic_ac.cz_tacg1:415]: Polling AC
[18:24:26.787][V][panasonic_ac:282]: TX: 70.0A.00.00.00.00.00.00.00.00.00.00.86 (13)
[18:24:26.925][V][panasonic_ac:284]: RX: 70.20.30.2F.80.30.56.40.00.40.00.00.00.2F.00.00.00.00.12.09.2B.12.09.FF.80.80.FF.80.08.00.00.C1.41.17.5C (35)
[18:24:26.926][V][panasonic_ac:094]: Received target temperature 23.50
[18:24:26.935][V][panasonic_ac:105]: Target temperature incl. offset: 23.50
[18:24:26.940][V][panasonic_ac:080]: Received current temperature 18
[18:24:26.940][V][panasonic_ac:089]: Current temperature incl. offset: 18
[18:24:26.952][V][panasonic_ac:064]: Received outside temperature 9
[18:24:26.952][D][climate:438]: 'Panasonic AC' >>
[18:24:26.952][D][climate:441]:   Mode: OFF
[18:24:26.958][D][climate:443]:   Action: OFF
[18:24:26.970][D][climate:449]:   Custom Fan Mode: 1
[18:24:26.970][D][climate:455]:   Custom Preset: Normal
[18:24:26.989][D][climate:458]:   Swing Mode: OFF
[18:24:26.990][D][climate:461]:   Current Temperature: 18.00°C
[18:24:26.990][D][climate:468]:   Target Temperature: 23.50°C
[18:24:26.998][V][mqtt:532]: Publish(topic='esp_klima_gaeste/climate/panasonic_ac/mode/state' retain=1 qos=0)
[18:24:26.998][V][mqtt:532]: Publish(topic='esp_klima_gaeste/climate/panasonic_ac/current_temperature/state' retain=1 qos=0)
[18:24:26.998][V][mqtt:532]: Publish(topic='esp_klima_gaeste/climate/panasonic_ac/target_temperature/state' retain=1 qos=0)
[18:24:27.022][V][mqtt:532]: Publish(topic='esp_klima_gaeste/climate/panasonic_ac/preset/state' retain=1 qos=0)
[18:24:27.022][V][mqtt:532]: Publish(topic='esp_klima_gaeste/climate/panasonic_ac/action/state' retain=1 qos=0)
Guybrush
poste mal deine device settings. das sieht nach was anderem aus, als ein mqtt device?
Moli
Ich habe es gefunden, danke!
Fast peinlich, ich habe alles gemacht, während die Anlagen aus war, alle Werte, lesen schreiben, ohne Probleme.
Ich wollte das jetzt genauer prüfen und habe eine angemacht und zack geht es.
Heißt alle Werte kann man lesen und schreiben während die Anlagen aus sind, nur die Voreinstellung nicht (Quiet/Powerfull/Normal)
Super... Danke für die Ansätze.
Mumpitz
#34
Zitat von: Guybrush am 07 August 2025, 11:10:19das sollte dann so sein. ich weiss aber auch nicht welche esphome version du nutzt und ob es da änderungen gibt. wie dem auch sei - es dürfte so auch funktionieren
So, heute wurden nun die beiden Innengeräte mit dem Aussengerät verbunden und angeschlossen. Die Geräte laufen einwandfrei. Ich freue mich somit auf die heissen Tage. Was allerdings noch nicht so recht klappt ist die Einbindung in fhem. Das Device wird nicht aktualisert, ich bekomme jedoch Einträge im EventMontior, im Fhemlog (Verbose 5) und FileLog des Geräts:
Mein Device:
defmod paceltern MQTT2_DEVICE paceltern
attr paceltern DbLogExclude .*
attr paceltern alias Klimaanlage Eltern
attr paceltern cmdIcon Ein:general_an@white Aus:general_aus@white
attr paceltern devStateIcon cool:frost@green heat:sani_heating@green fan_only:ventilator_fett@green dry:humidity@green heat_cool:time_automatic@green Aus:control_standby@grey
attr paceltern event-on-change-reading state,mode,temperature,temperatureTarget,preset,fanMode,swingMode,verticalSwingMode,temperatureOutside,mildDrySwitch,powerConsumption,status
attr paceltern event-on-update-reading mode
attr paceltern eventMap on:Ein off:Aus
attr paceltern icon secur_frost_protection
attr paceltern readingList paceltern:esphome/discover/paceltern-3834a0:.* { json2nameValue($EVENT) }\
paceltern:paceltern-3834a0/sensor/mac_adress/state:.* state\
paceltern:paceltern-3834a0/climate/paceltern/mode/state:.* state\
paceltern:paceltern-3834a0/climate/paceltern/target_temperature/state:.* state\
paceltern:paceltern-3834a0/climate/paceltern/preset/state:.* state\
paceltern:paceltern-3834a0/climate/paceltern/fan_mode/state:.* state\
paceltern:paceltern-3834a0/climate/paceltern/swing_mode/state:.* state\
paceltern:paceltern-3834a0/switch/paceltern_mild_dry_switch/state:.* state\
paceltern:paceltern-3834a0/sensor/ip_adress/state:.* state\
paceltern:paceltern-3834a0/sensor/paceltern_power_consumption/state:.* state\
paceltern:paceltern-3834a0/select/paceltern_vertical_swing_mode/state:.* state\
paceltern:paceltern-3834a0/climate/paceltern/current_temperature/state:.* state\
paceltern:paceltern-3834a0/sensor/paceltern_outside_temperature/state:.* state
attr paceltern room Klima,OG->Eltern
attr paceltern setList mode:off,cool,heat,fan_only,dry,heat_cool paceltern-3834a0/climate/pac/mode/command\
fanMode:1,2,3,4,5,Automatic paceltern-3834a0/climate/pac/fan_mode/command\
status:noArg paceltern-3834a0/climate/pac/mode/state\
temperatureTarget:slider,16,0.5,30 paceltern-3834a0/climate/pac/target_temperature/command\
swingMode:off,both,vertical,horizontal paceltern-3834a0/climate/pac/swing_mode/command\
preset:Normal,Powerful,Quiet paceltern-3834a0/climate/pac/preset/command\
on:noArg paceltern-3834a0/climate/pac/mode/command cool\
off:noArg paceltern-3834a0/climate/pac/mode/command off\
clear_all:noArg {fhem("deletereading -q $NAME (?!associatedWith|IODev).*");;;;return undef}
attr paceltern stateFormat {ReadingsVal($name,'mode','')."\n"."<br/>".ReadingsVal($name,'temperature','')." °C"}
attr paceltern verbose 5
attr paceltern webCmd Ein:Aus
setstate paceltern \
<br/> °C
setstate paceltern 2026-04-03 20:17:57 IODev myBroker
setstate paceltern 2026-04-29 11:12:36 board esp32-c3-devkitm-1
setstate paceltern 2026-04-29 11:12:36 ip 192.168.17.35
setstate paceltern 2026-04-29 11:12:36 mac b8f8623834a0
setstate paceltern 2026-04-29 11:12:36 name paceltern-3834a0
setstate paceltern 2026-04-29 11:12:36 network wifi
setstate paceltern 2026-04-29 11:12:36 platform ESP32
setstate paceltern 2026-04-29 13:25:05 state off
setstate paceltern 2025-08-19 18:55:40 subscriptions esphome/discover esphome/ping/paceltern-3834a0
setstate paceltern 2026-04-29 11:12:36 version 2025.7.4
Eventmonitor:
2026-04-29 12:00:33 MQTT2_DEVICE paceltern 22.0
2026-04-29 12:00:33 MQTT2_DEVICE paceltern Normal
2026-04-29 12:00:33 MQTT2_DEVICE paceltern Aus
FhemLog (verbose 5):
2026.04.29 11:59:58 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/swing_mode/state => state
2026.04.29 11:59:58 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/fan_mode/state => state
2026.04.29 11:59:58 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/preset/state => state
2026.04.29 11:59:58 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/target_temperature/state => state
2026.04.29 11:59:58 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/current_temperature/state => state
2026.04.29 11:59:58 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/mode/state => state
2026.04.29 11:59:53 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/swing_mode/state => state
2026.04.29 11:59:53 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/fan_mode/state => state
2026.04.29 11:59:53 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/preset/state => state
2026.04.29 11:59:53 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/target_temperature/state => state
2026.04.29 11:59:53 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/current_temperature/state => state
2026.04.29 11:59:53 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/mode/state => state
2026.04.29 11:59:48 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/swing_mode/state => state
2026.04.29 11:59:48 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/fan_mode/state => state
2026.04.29 11:59:48 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/preset/state => state
2026.04.29 11:59:48 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/target_temperature/state => state
2026.04.29 11:59:48 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/current_temperature/state => state
2026.04.29 11:59:48 4: MQTT2_DEVICE_Parse: paceltern paceltern-3834a0/climate/paceltern/mode/state => state
FileLog des Device:
2026-04-29_12:00:03 paceltern Aus
2026-04-29_12:00:03 paceltern 2
2026-04-29_12:00:03 paceltern Normal
2026-04-29_12:00:03 paceltern 22.0
2026-04-29_12:00:03 paceltern cool
Speziell im Device ist, dass der state fast sekündlich zwischen off und cool hin und herr springt egal ob das Gerät läuft oder nicht
Das Gerät welche nicht läuft zeigt im Log diese Einträge alle 5 Sekunden:
2026-04-29_12:10:09 pacxxxx Aus
2026-04-29_12:10:09 pacxxxx Automatic
2026-04-29_12:10:09 pacxxxx Normal
2026-04-29_12:10:09 pacxxxx 22.0
2026-04-29_12:10:09 pacxxxx 18.0
2026-04-29_12:10:09 pacxxxx 55
Aber auch bei diesem ausgeschalteten Gerät springt der state kaum sichtbar im Device hin und her...
Wo soll ich ansetzen?
Guybrush
in deiner readingslist wird alles dem reading state zugewiesen. das macht wenig sinn. du willst di werte ja jeweils als eigenes reading haben und nicht nur das jeweils zuletzt gesetzte?
Mumpitz
Zitat von: Guybrush am 29 April 2026, 16:38:54in deiner readingslist wird alles dem reading state zugewiesen. das macht wenig sinn. du willst di werte ja jeweils als eigenes reading haben und nicht nur das jeweils zuletzt gesetzte?
Danke für den Tip. Damit habe ich den Fehler gefunden und ich erhalte nun alle Readings wie gewünscht. Beim Schalten, sprich bei SetList hatte ich ebenfalls noch einen Fehler drinn:
pac muss da ebenfalls auf den richtigen Namen, in meinem Fall "paceltern", angepasst werden.
Cool, ich freu mich auf den Sommer und bin gespannt was für Automatismen ich einbauen werde...
Mumpitz
Darf ich an dieser Stelle mal nachfragen was für Automatismen ihr am laufen habt um die Klimaanlage von fhem steuern zu lassen?
Mach mir jede Menge Gedanken dazu, habe aber noch zu wenig praktische Erfahrungen mit den Teilern :-)
Guybrush
im wesentlichen nur die Raumtemperatursteuerung. analog zur Heizung, nur mit separaten Temperaturwerten
