Fritzbox 7490 doesn´t call from fhem anymore (solved)
Begonnen von HarryT, 19 Juni 2025, 12:19:18
HarryT
Hi
I used to make calls to **9 from my fritzbox 7490 in some events.
Unfortunately after a fresh install this call doesn´t work anymore.
To be clear, the command is "set FritzBox ring 9"
During the start of FHEM I get:
  PERL WARNING: Use of uninitialized value $val[0] in string eq at ./FHEM/72_FRITZBOX.pm line 1825.
but that doesn´t seem a big deal to me.
The logging doesn´t give me any information even with verbose = 5
I can see the debug info, but that is to complex for me.
In fhem.cfg I have
attr FritzBox INTERVAL 300
attr FritzBox boxUser fritz8145
What can be wrong?
Thanks
 I changed this post because it works again. I updated again and did a reboot. Something has fixed the issue.
FHEM 6.3 auf Raspberry Pi3  (1,2 Ghz)
RFXTRX433XL, ZWave, KFL200 and ConBeeIII
Raspberry Pi1 (0,7 Ghz) and Raspberry Pi4 for testing
German reading skills are good.
