[gelöst] Migration des Netzwerks von Aeotec Gen5 zu 10 Pro
Begonnen von fireball, 23 August 2025, 12:48:47
fireball
#15
kleines AddOn, weiß nicht obs von Bedeutung ist, so hat FHEM einmal den Stick neu angelegt, hatte das Device aber dann wieder gelöscht.
2025.08.30 19:55:23 3: Opening ZWDongle_1 device /dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_00C3805E-if01-port0
2025.08.30 19:55:23 3: Setting ZWDongle_1 serial parameters to 115200,8,N,1
2025.08.30 19:55:26 3: ZWDongle_1 device opened
2025.08.30 19:55:28 1: /dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_00C3805E-if01-port0 disconnected, waiting to reappear (ZWDongle_1)
2025.08.30 19:55:28 3: Setting ZWDongle_1 serial parameters to 115200,8,N,1
2025.08.30 19:55:28 1: ZWDongle_ReadAnswer: no data read
2025.08.30 19:55:28 1: /dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_00C3805E-if01-port0 reappeared (ZWDongle_1)
So zeigt ZWaveUI JS die Konfig an des 10pro an:
  "id": 1,
  "name": "",
  "loc": "",
  "values": [],
  "groups": [],
  "neighbors": [],
  "ready": true,
  "available": true,
  "hassDevices": {},
  "failed": false,
  "inited": true,
  "eventsQueue": [
      "time": "2025-08-30T19:21:50.510Z",
      "event": "alive",
      "args": [
        0
      "time": "2025-08-30T19:21:50.560Z",
      "event": "ready",
      "args": []
      "event": "ready",
      "args": []
  "status": "Alive",
  "interviewStage": "Complete",
  "priorityReturnRoute": {},
  "customReturnRoute": {},
  "customSUCReturnRoutes": [],
  "applicationRoute": false,
  "hexId": "0x0371 0x0004-0x003c",
  "dbLink": "https://devices.zwave-js.io/?jumpTo=0x0371:0x0004:0x003c:7.23.2",
  "manufacturerId": 881,
  "productId": 60,
  "productType": 4,
  "deviceConfig": {
    "filename": "/usr/src/app/store/.config-db/devices/0x0371/zwa060.json",
    "isEmbedded": true,
    "manufacturer": "Aeotec Ltd.",
    "label": "ZWA060",
    "description": "Z-Stick 10 Pro",
    "devices": [
        "productType": 4,
        "productId": 60
    "firmwareVersion": {
      "min": "0.0",
      "max": "255.255"
    "preferred": false
  "productLabel": "ZWA060",
  "productDescription": "Z-Stick 10 Pro",
  "firmwareVersion": "7.23.2",
  "sdkVersion": "7.23.2",
  "protocolVersion": 3,
  "endpointsCount": 0,
  "endpoints": [
      "index": 0,
      "label": "Root Endpoint",
      "deviceClass": {
        "basic": 2,
        "generic": 2,
        "specific": 1
  "supportsSecurity": false,
  "supportsBeaming": true,
  "isControllerNode": true,
  "isListening": true,
  "isFrequentListening": false,
  "isRouting": true,
  "keepAwake": false,
  "maxDataRate": 100000,
  "deviceClass": {
    "basic": 2,
    "generic": 2,
    "specific": 1
  "lastActive": 1756581722034,
  "firmwareCapabilities": {
    "firmwareUpgradable": false
  "protocol": 0,
  "deviceId": "881-60-4",
  "hasDeviceConfigChanged": false,
  "rfRegions": [
      "value": 2,
      "title": "Australia/New Zealand",
      "disabled": false
      "value": 8,
      "title": "China",
      "disabled": false
      "value": 11,
      "title": "Europe (Long Range)",
      "disabled": false
      "value": 3,
      "title": "Hong Kong",
      "disabled": false
      "value": 5,
      "title": "India",
      "disabled": false
      "value": 6,
      "title": "Israel",
      "disabled": false
      "value": 32,
      "title": "Japan",
      "disabled": false
      "value": 33,
      "title": "Korea",
      "disabled": false
      "value": 7,
      "title": "Russia",
      "disabled": false
      "value": 9,
      "title": "USA (Long Range)",
      "disabled": false
  "supportsLongRange": true,
  "supportsTime": false,
  "_name": "NodeID_1",
  "statistics": {
    "messagesTX": 45,
    "messagesRX": 90,
    "messagesDroppedRX": 7,
    "NAK": 0,
    "CAN": 0,
    "timeoutACK": 0,
    "timeoutResponse": 0,
    "timeoutCallback": 0,
    "messagesDroppedTX": 0
  "prioritySUCReturnRoute": false,
  "lastReceive": 1756581722034,
  "lastTransmit": 1756581722034,
  "errorReceive": false,
  "errorTransmit": false,
  "powerlevel": -11.6,
  "measured0dBm": -0.1,
  "RFRegion": 11,
  "maxLongRangePowerlevel": 14
letztes Update für heute:
Kann es sein, dass die FHEM die ZWAVE API nicht richtig implementiert?!
Wenn ich mir diese Zeile im Log anschaue:
2025.08.30 20:13:36 4: ZWDongle_ReadAnswer for homeId: 0120ec4154d20001
dann sehe ich nach der 0120 die HomeID:ec4154d und dann kommt die NodeID: 0001
Wie die 0001 jetzt interpretiert wird ist mir nicht klar, aber mit nem Hex-Umrechner komme ich auf ne 1.
VG
René
Zitat2025.08.30 20:13:36 4: ZWDongle_ReadAnswer for homeId: 0120ec4154d20001
Dieses Format ist fuer mich (und das Modul) neu: nodeIdHex ist hier 4-stellig, bekannt war 2-stellig.
Ich habe das Modul angepasst, FHEM-Update ist morgen ab 8 verfuegbar, bis dahin bitte direkt aus SVN holen.
Ich muss noch ueberlegen was ich mache, falls die ID auch in anderen Nachrichten 4-stellig ist.
Ist jemandem eine aktuelle Dokumentation der Controller Schnittstelle bekannt?
fireball
#17
Hi Rudolf,
da haben wir ja den Ursache gefunden. Super. Ich teste das morgen Vormittag dann.
Bzgl Dokumentation... ich hatte dir die API verlinkt, oder was meinst du genau?!
Ansonsten ist hier der Chip
Hier die API
Hier noch ein Datenblatt zur Architektur
Hier ein Link zur Doku zur 800ter Serie bei Silicon Labs, schau mal unter "Developer's Guides (4)" da gibts eine Connect Stack API und mehr.
Wenn du noch was anderes brauchst, ich habe noch mein Ticket bei Aeotec offen, der Typ ist echt hilfsbereit... ich könnte den auch direkt fragen.
VG
René
PS: ok ich hatte keine Ruhe, ich habs direkt ausprobiert:
1. Der Stick wird jetzt richtig erkannt, get version, nodeList, homeID funzen und es gibt die korrekte Ausgaben:
   CallbackNr 0
   Clients    :ZWave:
   DEF        /dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_00C3805E-if01-port0@115200
   DeviceName /dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_00C3805E-if01-port0@115200
   FD         32
   FUUID      68b33db3-f33f-0804-05cd-b051d618f8ab19b1
   MaxSendRetries 3
   NAME       ZWDongle_0
   NR         724
   PARTIAL
   RAWMSG     00a8000001002b0631050422000400a7007f7f
   ReadTime   1756634162.06488
   STATE      Initialized
   SendRetries 0
   SendTime   1756634089.59257
   TYPE       ZWDongle
   WaitForAck 0
   ZWDongle_0_MSGCNT 85
   ZWDongle_0_TIME 2025-08-31 11:56:02
   devioNoSTATE 1
   eventCount 1
   homeId     ec4154d2
   nodeIdHex  01
   nrNAck     0
   MatchList:
     1:ZWave    .*
     2025-08-31 11:48:47   caps            Vers:7 Rev:23 ManufID:0371 ProductType:0004 ProductID:003c SERIAL_API_GET_INIT_DATA SERIAL_API_APPL_NODE_INFORMATION ZW_GET_CONTROLLER_CAPABILITIES SERIAL_API_SET_TIMEOUTS SERIAL_API_GET_CAPABILITIES SERIAL_API_SOFT_RESET UNKNOWN_09 UNKNOWN_0a SERIAL_API_SETUP ZW_SET_R_F_RECEIVE_MODE ZW_SEND_NODE_INFORMATION ZW_SEND_DATA ZW_SEND_DATA_MULTI ZW_GET_VERSION ZW_SEND_DATA_ABORT ZW_GET_RANDOM MEMORY_GET_ID MEMORY_GET_BYTE MEMORY_PUT_BYTE MEMORY_GET_BUFFER MEMORY_PUT_BUFFER FLASH_AUTO_PROG_SET ZW_NVR_GET_VALUE NVM_GET_ID NVM_EXT_READ_LONG_BUFFER NVM_EXT_READ_LONG_BYTE UNKNOWN_2e ZW_CLEAR_TX_TIMERS ZW_GET_TX_TIMERS CLEAR_NETWORK_STATS GET_NETWORK_STATS GET_BACKGROUND_RSSI UNKNOWN_3c UNKNOWN_3d REMOVE_NODEID_FROM_NETWORK ZW_GET_NODE_PROTOCOL_INFO ZW_SET_DEFAULT ZW_ASSIGN_RETURN_ROUTE ZW_DELETE_RETURN_ROUTE ZW_REQUEST_NODE_NEIGHBOR_UPDATE ZW_APPLICATION_UPDATE ZW_ADD_NODE_TO_NETWORK ZW_REMOVE_NODE_FROM_NETWORK ZW_CONTROLLER_CHANGE ZW_ASSIGN_PRIORITY_RETURN_ROUTE ZW_SET_LEARN_MODE ZW_ASSIGN_SUC_RETURN_ROUTE ZW_REQUEST_NETWORK_UPDATE ZW_SET_SUC_NODE_ID ZW_DELETE_SUC_RETURN_ROUTE ZW_GET_SUC_NODE_ID ZW_SEND_SUC_ID ZW_ASSIGN_PRIORITY_SUC_RETURN_ROUTE ZW_EXPLORE_REQUEST_INCLUSION ZW_EXPLORE_REQUEST_EXCLUSION ZW_REQUEST_NODE_INFO ZW_REMOVE_FAILED_NODE_ID ZW_IS_FAILED_NODE ZW_REPLACE_FAILED_NODE UNKNOWN_65 UNKNOWN_68 UNKNOWN_69 UNKNOWN_6a UNKNOWN_6b UNKNOWN_6c GET_ROUTING_TABLE_LINE LOCK_ROUTE_RESPONSE ZW_GET_PRIORITY_ROUTE ZW_SET_PRIORITY_ROUTE UNKNOWN_98 SERIAL_API_SLAVE_NODE_INFO ZW_SEND_SLAVE_NODE_INFO ZW_SET_SLAVE_LEARN_MODE ZW_GET_VIRTUAL_NODES ZW_IS_VIRTUAL_NODE ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ZW_SEND_DATA_BRIDGE ZW_SEND_DATA_MULTI_BRIDGE UNKNOWN_ac ZW_TYPE_LIBRARY ZW_SEND_TEST_FRAME ZW_GET_PROTOCOL_STATUS WATCHDOG_START WATCHDOG_STOP ZW_SET_ROUTING_MAX UNKNOWN_d6 UNKNOWN_d7 UNKNOWN_d8 UNKNOWN_d9 UNKNOWN_da UNKNOWN_db UNKNOWN_dc UNKNOWN_dd UNKNOWN_de UNKNOWN_df UNKNOWN_e7 UNKNOWN_e8
     2025-08-31 11:48:47   ctrlCaps        PRIMARY
     2025-08-31 11:54:05   homeId          HomeId:ec4154d2 CtrlNodeIdHex:01
     2025-08-31 11:53:52   nodeList        ZWDongle_0 FIBARO_RGB_1 WallPlug_Kuehlschrank Aussenlicht_Modul_1 Innenlicht_Modul_1 FSensor_EG_BAD_N FSensor_OG_BAD_N FSensor_EG_WZ_T_S FSensor_OG_GZ_S FSensor_OG_KZ_N TSensor_GARAGE_HWR FSensor_EG_WZ_2_W Alarm_Sirene Aussenlicht_vorn_Garage UNKNOWN_26 FSensor_OG_SZ_1_S FSensor_EG_WZ_1_W FSensor_EG_WZ_K_S FSensor_EG_BUERO_S TSensor_GARAGE FSensor_OG_SZ_2_S TSensor_GARAGENTOR Alarm_Wassersensor BM_EG_Flur BM_OG_Flur Gartenhaus_Master_Switch AEON_MultiSensor Gartenhaus_Garagentor SmokeSensor_WZ WallPlug_Waschmaschiene WallPlug_Gefrierschrank WallPlug_Weichwasseranlage WallPlug_Geschirrspueler SmokeSensor_HWR SmokeSensor_Garage FIBARO_RGB_2 UNKNOWN_51 LAD7_PV_MODE Deckenlicht_Wohnzimmer Wohnzimmer_Taster Aussenlicht_Modul_2 Wohnzimmer_Taster_2 TV_Wand_Modul
     2025-08-31 11:48:47   random          f0d6e4ade4259c109f73f1185d347b36e9f485413a99f17d3282e1ca33575e58
     2025-08-31 11:52:52   state           Initialized
     2025-08-31 11:48:47   sucNodeId       no
     2025-08-31 11:54:13   version         Z-Wave 7.23 BRIDGE_CONTROLLER
   SendStack:
   homeId     ec4154d2
   room       ZWave
   verbose    0
2. ABER es lassen sich keine Geräte schalten...
habe mal ein paar Geräte an und ausgeschalter mit verbose 5 :
025.08.31 11:58:39 2: ZWave: No ACK from Innenlicht_Modul_1 after 5s for sentset:130a07600d00022501FF2507
2025.08.31 11:58:39 5: ZWDongle_Write 00130a07600d00022501002508 (ec4154d2)
2025.08.31 11:58:39 5: DevIo_SimpleWrite ZWDongle_0: 010e00130a07600d0002250100250889
2025.08.31 11:58:39 5: ACK received, WaitForAck=>2 for 010e00130a07600d0002250100250889
2025.08.31 11:58:39 4: ZWDongle_Read ZWDongle_0: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2025.08.31 11:58:39 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.08.31 11:58:39 5: ZWDongle_0: dispatch 011301
2025.08.31 11:58:40 4: ZWDongle_Read ZWDongle_0: rcvd 00a8000001002b0631050422000600a7007f7f (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.08.31 11:58:40 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.08.31 11:58:40 5: ZWDongle_0: dispatch 00a8000001002b0631050422000600a7007f7f
2025.08.31 11:58:40 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:00 ARG:01002b0631050422000600a7007f7f CB:00
2025.08.31 11:58:40 4: ZWave: unknown message 00a8000001002b0631050422000600a7007f7f for ID 01
2025.08.31 11:58:42 4: no response from device, removing 010e00130a07600d0002250100250889 from dongle sendstack
2025.08.31 11:58:44 3: ZWave set BM_EG_Flur01 on
2025.08.31 11:58:44 5: ZWDongle_Write 00132307600d00012501FF250b (ec4154d2)
2025.08.31 11:58:44 5: DevIo_SimpleWrite ZWDongle_0: 010e00132307600d00012501FF250b5f
2025.08.31 11:58:44 5: ACK received, WaitForAck=>2 for 010e00132307600d00012501FF250b5f
2025.08.31 11:58:44 4: ZWDongle_Read ZWDongle_0: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2025.08.31 11:58:44 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.08.31 11:58:44 5: ZWDongle_0: dispatch 011301
2025.08.31 11:58:44 2: ZWave: No ACK from Innenlicht_Modul_1 after 5s for sentset:130a07600d00022501002508
2025.08.31 11:58:44 5: ZWDongle_Write 00130a07600d00012501FF2509 (ec4154d2)
2025.08.31 11:58:45 3: ZWave set BM_EG_Flur01 off
2025.08.31 11:58:46 4: no response from device, removing 010e00132307600d00012501FF250b5f from dongle sendstack
2025.08.31 11:58:46 5: DevIo_SimpleWrite ZWDongle_0: 010e00130a07600d00012501FF250974
2025.08.31 11:58:46 5: ACK received, WaitForAck=>2 for 010e00130a07600d00012501FF250974
2025.08.31 11:58:46 4: ZWDongle_Read ZWDongle_0: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2025.08.31 11:58:46 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.08.31 11:58:46 5: ZWDongle_0: dispatch 011301
2025.08.31 11:58:48 4: ZWDongle_Read ZWDongle_0: rcvd 00a800000100280631050422000000a6007f7f (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.08.31 11:58:48 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.08.31 11:58:48 5: ZWDongle_0: dispatch 00a800000100280631050422000000a6007f7f
2025.08.31 11:58:48 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:00 ARG:0100280631050422000000a6007f7f CB:00
2025.08.31 11:58:48 4: ZWave: unknown message 00a800000100280631050422000000a6007f7f for ID 01
2025.08.31 11:58:49 4: ZWDongle_Read ZWDongle_0: rcvd 00a814000100280631050422000000b3000000 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.08.31 11:58:49 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.08.31 11:58:49 5: ZWDongle_0: dispatch 00a814000100280631050422000000b3000000
2025.08.31 11:58:49 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:00 ARG:0100280631050422000000b3000000 CB:14
2025.08.31 11:58:49 4: ZWave: unknown message 00a814000100280631050422000000b3000000 for ID 01
2025.08.31 11:58:49 4: no response from device, removing 010e00130a07600d00012501FF250974 from dongle sendstack
2025.08.31 11:58:49 2: ZWave: No ACK from BM_EG_Flur after 5s for sentset:132307600d00012501FF250b
2025.08.31 11:58:49 5: ZWDongle_Write 00132307600d0001250100250c (ec4154d2)
2025.08.31 11:58:49 5: DevIo_SimpleWrite ZWDongle_0: 010e00132307600d0001250100250ca7
2025.08.31 11:58:49 5: ACK received, WaitForAck=>2 for 010e00132307600d0001250100250ca7
2025.08.31 11:58:49 4: ZWDongle_Read ZWDongle_0: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2025.08.31 11:58:49 5: ZWDongle_0: dispatch 011301
Wenn ich mich recht erinnere, hatten wir die Kommunikationsschnittstelle durch "beobachten" von anderen Programmen "gelernt".
Eine Doku (Z-Wave 400 Series Appl. Prg. Guide v6.01.01) habe ich viel spaeter entdeckt, diese aber nicht mehr durchgearbeitet.
In diesem Dokument schaut getHomeId in etwa so aus:
void MemoryGetID(BYTE *pHomeID, BYTE *pNodeID )
Macro: ZW_MEMORY_GET_ID(homeID, nodeID)
The MemoryGetID function copy the Home-ID and Node-ID from the non-volatile memory to the
specified RAM addresses.
NOTE: A NULL pointer can be given as the pHomeID parameter if the application is only interested in
reading the Node ID.
Defined in: ZW_mem_api.h
Parameters:
pHomeID OUT Home-ID pointer
pNodeID OUT Node-ID pointer
Serial API:
HOST->ZW: REQ | 0x20
ZW->HOST: RES | 0x20 | HomeId(4 bytes) | NodeId
Fuer mich ist nur der Abschnitt Serial API relevant.
Nachtraeglich zu lesen ist es interessant, dass bei NodeId keine Laenge angegeben wurde.
Da das Dokument aus 2011 ist, bin ich nicht sicher, ob es sich lohnt, nochmal durchzuarbeiten.
Die verlinkten Dokus beschreiben eine Bibliothek, was in FHEM nicht verwendet wird, und ich habe keine Hinweise auf Beschreibungen auf Byte-Ebene (s.o.) gefunden.
krikan
Nach https://www.silabs.com/documents/public/user-guides/INS12350-Serial-API-Host-Appl.-Prg.-Guide.pdf unter "7.14 Set Node ID Base Type" kann man die Länge der genutzten NodeId-Länge wieder auf 8 Bits setzen. Das müsste wohl getestet werden.
krikan
Nach https://zwave.cc/assets/doc/2024A%20Specification%20Package/Z-Wave%20Stack%20Specifications/Z-Wave%20Host%20API%20Specification.pdf könnte/sollte folgender Befehl die verwendete NodeId-Länge auf 8 Bits setzen:
get <controllerName> raw 0B8001Der Befehl ändert das nicht dauerhaft. Nach Stromlosmachen des Controllers sollte der vorherige Zustand kommen.
Leider kann ich das nicht eigenständig testen. Also garantiere ich für nichts. Kann zwar aus den Docs keine problematischen Seiteneffekte erlesen, aber....
@Rene:
Wenn Du den Mut hast das zu probieren, dann bitte verbose 5 am Controller setzen, obigen raw-Befehl absetzen, Aktoren mal schalten und berichten sowie das Log gerne posten.
fireball
#21
Moinsen,
sry für die späte Antwort, ich hatte leider nicht eher Zeit zum Testen.
Ich habe gestern noch mit kuriosen Zuständen verbracht (No FD (dummy device?)), dass der Controller auf einmal nicht mehr von FHEM gefunden wurde, obwohl der unter /dev/serial/by-id/ eingetragen war... ein zwei Reboots später, an/abziehen, dann gings wieder...
Ich habe parallel auf der gleichen PI jetzt in nem Docker noch das ZWaveUI-JS laufen, da ich das hin und herwechseln zu meiner Proxmox-Instanz wo ich HA+ZWaveUI-JS testhalber laufen habe leid war.
Aber das zwei Programme gleichzeitig auf einen USB Stick zugreifen, sollte doch kein Problem darstellen oder meint ihr das könnte die Ursache sein!?
Zurück zum eigentlichen Thema... ich habe den Befehl mutig abgesetzt :P
get <controllerName> raw 0B8001In FHEM kam zwar ein Popup mit nem TimeOut, aber in den Logs sieht man, dass sich was geändert hat und SIEHE DA... es funzt!
Ich kann mit dem 10pro jetzt die Geräte schalten. Hab 3-4 Schalter ausprobiert und einen Rollladen. Alles reagiert. Auch batteriebetriebene Gräte (Fenstersensoren) haben Zustände gemeldet.
Anbei das Log:
2025.09.01 14:13:34 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:13:34 5: ZWDongle_0: dispatch 00a8000001003513600d020032022144000002510e100000025100009e007f7f
2025.09.01 14:13:34 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:00 ARG:01003513600d020032022144000002510e100000025100009e007f7f CB:00
2025.09.01 14:13:34 4: ZWave: unknown message 00a8000001003513600d020032022144000002510e100000025100009e007f7f for ID 01
2025.09.01 14:13:36 4: ZWDongle *** get ZWDongle_0 raw 0B8001
2025.09.01 14:13:36 5: ZWDongle_Write 000B8001 ()
2025.09.01 14:13:36 5: DevIo_SimpleWrite ZWDongle_0: 0105000B800170
2025.09.01 14:13:36 4: ZWDongle_ReadAnswer arg:raw regexp:^010B
2025.09.01 14:13:36 5: ACK received, removing 0105000B800170 from dongle sendstack
2025.09.01 14:13:36 4: ZWDongle_Read ZWDongle_0: rcvd 010b8001 (answer SERIAL_API_SETUP), sending ACK
2025.09.01 14:13:36 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:13:36 5: ZWDongle_0: dispatch 010b8001
2025.09.01 14:13:36 4: ZWDongle_0 unhandled ANSWER: SERIAL_API_SETUP 8001
2025.09.01 14:13:37 5: ZWDongle_ReadAnswer: select timeout
2025.09.01 14:13:42 4: ZWDongle_Read ZWDongle_0: rcvd 00a800013613600d02003202213400000000001f000000000000a5 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:13:42 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:13:42 5: ZWDongle_0: dispatch 00a800013613600d02003202213400000000001f000000000000a5
2025.09.01 14:13:42 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:3613600d02003202213400000000001f000000000000a5 CB:00
2025.09.01 14:13:48 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000000a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:13:48 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:13:48 5: ZWDongle_0: dispatch 00a800012b0631050422000000a9
2025.09.01 14:13:48 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000000a9 CB:00
2025.09.01 14:13:49 3: ZWave got config for fibaro/fgwpe.xml from ./FHEM/lib/openzwave_deviceconfig.xml.gz, found 19 commands
2025.09.01 14:13:49 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000300aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:13:49 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:13:49 5: ZWDongle_0: dispatch 00a800012b0631050422000300aa
2025.09.01 14:13:49 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000300aa CB:00
2025.09.01 14:13:52 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000000aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:13:52 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:13:52 5: ZWDongle_0: dispatch 00a800012b0631050422000000aa
2025.09.01 14:13:52 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000000aa CB:00
2025.09.01 14:13:53 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000300aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:13:53 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:13:53 5: ZWDongle_0: dispatch 00a800012b0631050422000300aa
2025.09.01 14:13:53 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000300aa CB:00
2025.09.01 14:13:54 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000400aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:13:54 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:13:54 5: ZWDongle_0: dispatch 00a800012b0631050422000400aa
2025.09.01 14:13:54 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000400aa CB:00
2025.09.01 14:13:55 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000300aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:13:55 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:13:55 5: ZWDongle_0: dispatch 00a800012b0631050422000300aa
2025.09.01 14:13:55 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000300aa CB:00
2025.09.01 14:13:57 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000500a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:13:57 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:13:57 5: ZWDongle_0: dispatch 00a800012b0631050422000500a9
2025.09.01 14:13:57 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000500a9 CB:00
2025.09.01 14:13:58 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000000aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:13:58 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:13:58 5: ZWDongle_0: dispatch 00a800012b0631050422000000aa
2025.09.01 14:13:58 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000000aa CB:00
2025.09.01 14:14:00 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000400aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:00 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:00 5: ZWDongle_0: dispatch 00a800012b0631050422000400aa
2025.09.01 14:14:00 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000400aa CB:00
2025.09.01 14:14:06 4: ZWDongle_Read ZWDongle_0: rcvd 00a8000127063105012200ce00aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:06 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:06 5: ZWDongle_0: dispatch 00a8000127063105012200ce00aa
2025.09.01 14:14:06 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:27063105012200ce00aa CB:00
2025.09.01 14:14:08 4: ZWDongle_Read ZWDongle_0: rcvd 00a8000127063105012200ce00aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:08 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:08 5: ZWDongle_0: dispatch 00a8000127063105012200ce00aa
2025.09.01 14:14:08 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:27063105012200ce00aa CB:00
2025.09.01 14:14:08 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012705310505015200aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:08 5: ZWDongle_0: dispatch 00a800012705310505015200aa
2025.09.01 14:14:08 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2705310505015200aa CB:00
2025.09.01 14:14:09 4: ZWDongle_Read ZWDongle_0: rcvd 00a80001270380036400aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:09 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:09 5: ZWDongle_0: dispatch 00a80001270380036400aa
2025.09.01 14:14:09 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:270380036400aa CB:00
2025.09.01 14:14:09 4: ZWDongle_Read ZWDongle_0: rcvd 00a8000127063105030a084f00aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:09 5: ZWDongle_0: dispatch 00a8000127063105030a084f00aa
2025.09.01 14:14:09 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:27063105030a084f00aa CB:00
2025.09.01 14:14:09 4: ZWDongle_Read ZWDongle_0: rcvd 00a80001270531051b010000aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:09 5: ZWDongle_0: dispatch 00a80001270531051b010000aa
2025.09.01 14:14:09 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:270531051b010000aa CB:00
2025.09.01 14:14:10 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000000aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:10 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:10 5: ZWDongle_0: dispatch 00a800012b0631050422000000aa
2025.09.01 14:14:10 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000000aa CB:00
2025.09.01 14:14:11 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000400aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:11 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:11 5: ZWDongle_0: dispatch 00a800012b0631050422000400aa
2025.09.01 14:14:11 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000400aa CB:00
2025.09.01 14:14:13 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012e0631050422011500a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:13 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:13 5: ZWDongle_0: dispatch 00a800012e0631050422011500a9
2025.09.01 14:14:13 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2e0631050422011500a9 CB:00
2025.09.01 14:14:13 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000000aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:13 5: ZWDongle_0: dispatch 00a800012b0631050422000000aa
2025.09.01 14:14:13 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000000aa CB:00
2025.09.01 14:14:13 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012e0631050422030800aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:13 5: ZWDongle_0: dispatch 00a800012e0631050422030800aa
2025.09.01 14:14:13 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2e0631050422030800aa CB:00
2025.09.01 14:14:13 4: ZWDongle_Read ZWDongle_0: rcvd 00a800013613600d02003202213400000000001f000000000000a5 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:13 5: ZWDongle_0: dispatch 00a800013613600d02003202213400000000001f000000000000a5
2025.09.01 14:14:13 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:3613600d02003202213400000000001f000000000000a5 CB:00
2025.09.01 14:14:13 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012e063105042201cb00a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:13 5: ZWDongle_0: dispatch 00a800012e063105042201cb00a9
2025.09.01 14:14:13 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2e063105042201cb00a9 CB:00
2025.09.01 14:14:14 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012e0631050422013a00aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:14 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:14 5: ZWDongle_0: dispatch 00a800012e0631050422013a00aa
2025.09.01 14:14:14 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2e0631050422013a00aa CB:00
2025.09.01 14:14:15 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012e0631050422018f00a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:15 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:15 5: ZWDongle_0: dispatch 00a800012e0631050422018f00a9
2025.09.01 14:14:15 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2e0631050422018f00a9 CB:00
2025.09.01 14:14:16 1: BYDHVS -> BMS: 1/1
2025.09.01 14:14:18 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000300aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:18 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:18 5: ZWDongle_0: dispatch 00a800012b0631050422000300aa
2025.09.01 14:14:18 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000300aa CB:00
2025.09.01 14:14:18 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012e063105042202e900a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:18 5: ZWDongle_0: dispatch 00a800012e063105042202e900a9
2025.09.01 14:14:18 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2e063105042202e900a9 CB:00
2025.09.01 14:14:19 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000000aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:19 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:19 5: ZWDongle_0: dispatch 00a800012b0631050422000000aa
2025.09.01 14:14:19 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000000aa CB:00
2025.09.01 14:14:21 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000600aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:21 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:21 5: ZWDongle_0: dispatch 00a800012b0631050422000600aa
2025.09.01 14:14:21 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000600aa CB:00
2025.09.01 14:14:23 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000400aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:23 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:23 5: ZWDongle_0: dispatch 00a800012b0631050422000400aa
2025.09.01 14:14:23 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000400aa CB:00
2025.09.01 14:14:24 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000300aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:24 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:24 5: ZWDongle_0: dispatch 00a800012b0631050422000300aa
2025.09.01 14:14:24 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000300aa CB:00
2025.09.01 14:14:25 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000500aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:25 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:25 5: ZWDongle_0: dispatch 00a800012b0631050422000500aa
2025.09.01 14:14:25 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000500aa CB:00
2025.09.01 14:14:27 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000400aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:27 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:27 5: ZWDongle_0: dispatch 00a800012b0631050422000400aa
2025.09.01 14:14:27 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000400aa CB:00
2025.09.01 14:14:27 5: ZWDongle_Write 00130a07600d00022501FF251d (ec4154d2)
2025.09.01 14:14:27 5: DevIo_SimpleWrite ZWDongle_0: 010e00130a07600d00022501FF251d63
2025.09.01 14:14:27 5: ACK received, WaitForAck=>2 for 010e00130a07600d00022501FF251d63
2025.09.01 14:14:27 4: ZWDongle_Read ZWDongle_0: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2025.09.01 14:14:27 5: ZWDongle_0: dispatch 011301
2025.09.01 14:14:28 4: ZWDongle_Read ZWDongle_0: rcvd 00131d000009009d7f7f7f7f01010300000000020300007f7f7f7f7f (request ZW_SEND_DATA), sending ACK
2025.09.01 14:14:28 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:28 5: device ack received, removing 010e00130a07600d00022501FF251d63 from dongle sendstack
2025.09.01 14:14:28 5: ZWDongle_0: dispatch 00131d000009009d7f7f7f7f01010300000000020300007f7f7f7f7f
2025.09.01 14:14:28 4: CMD:ZW_SEND_DATA ID:00 ARG:0009009d7f7f7f7f01010300000000020300007f7f7f7f7f CB:1d
2025.09.01 14:14:28 4: ZWDongle_0 transmit OK for CB 1d, target Innenlicht_Modul_1
2025.09.01 14:14:28 4: ZWDongle_Read ZWDongle_0: rcvd 00a800010a07600d02002503ff009e (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:28 5: ZWDongle_0: dispatch 00a800010a07600d02002503ff009e
2025.09.01 14:14:28 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:0a07600d02002503ff009e CB:00
2025.09.01 14:14:28 4: ZWDongle_Read ZWDongle_0: rcvd 00a800010a07600d02002503ff009d (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:28 5: ZWDongle_0: dispatch 00a800010a07600d02002503ff009d
2025.09.01 14:14:28 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:0a07600d02002503ff009d CB:00
2025.09.01 14:14:28 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000300aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:28 5: ZWDongle_0: dispatch 00a800012b0631050422000300aa
2025.09.01 14:14:28 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000300aa CB:00
2025.09.01 14:14:28 4: ZWDongle_Read ZWDongle_0: rcvd 00a800010a07600d02002503ff00a5 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:28 5: ZWDongle_0: dispatch 00a800010a07600d02002503ff00a5
2025.09.01 14:14:28 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:0a07600d02002503ff00a5 CB:00
2025.09.01 14:14:30 4: ZWDongle_Read ZWDongle_0: rcvd 00a800010a0c600d020032022132006e000000a4 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:30 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:30 5: ZWDongle_0: dispatch 00a800010a0c600d020032022132006e000000a4
2025.09.01 14:14:30 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:0a0c600d020032022132006e000000a4 CB:00
2025.09.01 14:14:31 5: ZWDongle_Write 00130a07600d0002250100251e (ec4154d2)
2025.09.01 14:14:31 5: DevIo_SimpleWrite ZWDongle_0: 010e00130a07600d0002250100251e9f
2025.09.01 14:14:31 5: ACK received, WaitForAck=>2 for 010e00130a07600d0002250100251e9f
2025.09.01 14:14:31 4: ZWDongle_Read ZWDongle_0: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2025.09.01 14:14:31 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:31 5: ZWDongle_0: dispatch 011301
2025.09.01 14:14:31 4: ZWDongle_Read ZWDongle_0: rcvd 00131e00000d01a47f7f7f7f02010305000000010100007f7f7f7f7f (request ZW_SEND_DATA), sending ACK
2025.09.01 14:14:31 5: device ack received, removing 010e00130a07600d0002250100251e9f from dongle sendstack
2025.09.01 14:14:31 5: ZWDongle_0: dispatch 00131e00000d01a47f7f7f7f02010305000000010100007f7f7f7f7f
2025.09.01 14:14:31 4: CMD:ZW_SEND_DATA ID:00 ARG:000d01a47f7f7f7f02010305000000010100007f7f7f7f7f CB:1e
2025.09.01 14:14:31 4: ZWDongle_0 transmit OK for CB 1e, target Innenlicht_Modul_1
2025.09.01 14:14:32 4: ZWDongle_Read ZWDongle_0: rcvd 00a800010a07600d020025030000a5 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:32 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:32 5: ZWDongle_0: dispatch 00a800010a07600d020025030000a5
2025.09.01 14:14:32 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:0a07600d020025030000a5 CB:00
2025.09.01 14:14:32 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000000a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:32 5: ZWDongle_0: dispatch 00a800012b0631050422000000a9
2025.09.01 14:14:32 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000000a9 CB:00
2025.09.01 14:14:32 4: ZWDongle_Read ZWDongle_0: rcvd 00a800010a0c600d0200320221320000000000a5 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:32 5: ZWDongle_0: dispatch 00a800010a0c600d0200320221320000000000a5
2025.09.01 14:14:32 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:0a0c600d0200320221320000000000a5 CB:00
2025.09.01 14:14:33 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000300a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:33 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:33 5: ZWDongle_0: dispatch 00a800012b0631050422000300a9
2025.09.01 14:14:33 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000300a9 CB:00
2025.09.01 14:14:34 3: ZWave set Innenlicht_FenstrStDo on
2025.09.01 14:14:34 5: ZWDongle_Write 00130a07600d00012501FF251f (ec4154d2)
2025.09.01 14:14:34 5: DevIo_SimpleWrite ZWDongle_0: 010e00130a07600d00012501FF251f62
2025.09.01 14:14:34 5: ACK received, WaitForAck=>2 for 010e00130a07600d00012501FF251f62
2025.09.01 14:14:34 4: ZWDongle_Read ZWDongle_0: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2025.09.01 14:14:34 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:34 5: ZWDongle_0: dispatch 011301
2025.09.01 14:14:34 4: ZWDongle_Read ZWDongle_0: rcvd 00131f00003401a47f7f7f7f02010305000000010100007f7f7f7f7f (request ZW_SEND_DATA), sending ACK
2025.09.01 14:14:34 5: device ack received, removing 010e00130a07600d00012501FF251f62 from dongle sendstack
2025.09.01 14:14:34 5: ZWDongle_0: dispatch 00131f00003401a47f7f7f7f02010305000000010100007f7f7f7f7f
2025.09.01 14:14:34 4: CMD:ZW_SEND_DATA ID:00 ARG:003401a47f7f7f7f02010305000000010100007f7f7f7f7f CB:1f
2025.09.01 14:14:34 4: ZWDongle_0 transmit OK for CB 1f, target Innenlicht_Modul_1
2025.09.01 14:14:35 4: ZWDongle_Read ZWDongle_0: rcvd 00a800010a07600d01002503ff00a4 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:35 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:35 5: ZWDongle_0: dispatch 00a800010a07600d01002503ff00a4
2025.09.01 14:14:35 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:0a07600d01002503ff00a4 CB:00
2025.09.01 14:14:36 3: ZWave set Innenlicht_FenstrStDo off
2025.09.01 14:14:36 5: ZWDongle_Write 00130a07600d00012501002520 (ec4154d2)
2025.09.01 14:14:36 5: DevIo_SimpleWrite ZWDongle_0: 010e00130a07600d00012501002520a2
2025.09.01 14:14:36 5: ACK received, WaitForAck=>2 for 010e00130a07600d00012501002520a2
2025.09.01 14:14:36 4: ZWDongle_Read ZWDongle_0: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2025.09.01 14:14:36 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:36 5: ZWDongle_0: dispatch 011301
2025.09.01 14:14:36 4: ZWDongle_Read ZWDongle_0: rcvd 00132000000d01a47f7f7f7f02010305000000010100007f7f7f7f7f (request ZW_SEND_DATA), sending ACK
2025.09.01 14:14:36 5: device ack received, removing 010e00130a07600d00012501002520a2 from dongle sendstack
2025.09.01 14:14:36 5: ZWDongle_0: dispatch 00132000000d01a47f7f7f7f02010305000000010100007f7f7f7f7f
2025.09.01 14:14:36 4: CMD:ZW_SEND_DATA ID:00 ARG:000d01a47f7f7f7f02010305000000010100007f7f7f7f7f CB:20
2025.09.01 14:14:36 4: ZWDongle_0 transmit OK for CB 20, target Innenlicht_Modul_1
2025.09.01 14:14:37 4: ZWDongle_Read ZWDongle_0: rcvd 00a800010a07600d010025030000a5 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:37 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:37 5: ZWDongle_0: dispatch 00a800010a07600d010025030000a5
2025.09.01 14:14:37 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:0a07600d010025030000a5 CB:00
2025.09.01 14:14:37 4: ZWDongle_Read ZWDongle_0: rcvd 00a800010a0c600d0100320221320000000000a5 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:37 5: ZWDongle_0: dispatch 00a800010a0c600d0100320221320000000000a5
2025.09.01 14:14:37 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:0a0c600d0100320221320000000000a5 CB:00
2025.09.01 14:14:37 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000700a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:37 5: ZWDongle_0: dispatch 00a800012b0631050422000700a9
2025.09.01 14:14:37 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000700a9 CB:00
2025.09.01 14:14:38 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000000a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:38 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:38 5: ZWDongle_0: dispatch 00a800012b0631050422000000a9
2025.09.01 14:14:38 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000000a9 CB:00
2025.09.01 14:14:39 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000300a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:39 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:39 5: ZWDongle_0: dispatch 00a800012b0631050422000300a9
2025.09.01 14:14:39 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000300a9 CB:00
2025.09.01 14:14:40 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000000a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:40 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:40 5: ZWDongle_0: dispatch 00a800012b0631050422000000a9
2025.09.01 14:14:40 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000000a9 CB:00
2025.09.01 14:14:41 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000400a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:41 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:41 5: ZWDongle_0: dispatch 00a800012b0631050422000400a9
2025.09.01 14:14:41 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000400a9 CB:00
2025.09.01 14:14:44 4: ZWDongle_Read ZWDongle_0: rcvd 00a800013613600d02003202213400000000001f000000000000a5 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:44 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:44 5: ZWDongle_0: dispatch 00a800013613600d02003202213400000000001f000000000000a5
2025.09.01 14:14:44 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:3613600d02003202213400000000001f000000000000a5 CB:00
2025.09.01 14:14:45 3: ZWave set BM_EG_Flur01 on
2025.09.01 14:14:45 5: ZWDongle_Write 00132307600d00012501FF2521 (ec4154d2)
2025.09.01 14:14:45 5: DevIo_SimpleWrite ZWDongle_0: 010e00132307600d00012501FF252175
2025.09.01 14:14:45 5: ACK received, WaitForAck=>2 for 010e00132307600d00012501FF252175
2025.09.01 14:14:45 4: ZWDongle_Read ZWDongle_0: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2025.09.01 14:14:45 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:45 5: ZWDongle_0: dispatch 011301
2025.09.01 14:14:45 4: ZWDongle_Read ZWDongle_0: rcvd 001321000036019d7f7f7f7f01010436000000020800007f7f7f7f7f (request ZW_SEND_DATA), sending ACK
2025.09.01 14:14:45 5: device ack received, removing 010e00132307600d00012501FF252175 from dongle sendstack
2025.09.01 14:14:45 5: ZWDongle_0: dispatch 001321000036019d7f7f7f7f01010436000000020800007f7f7f7f7f
2025.09.01 14:14:45 4: CMD:ZW_SEND_DATA ID:00 ARG:0036019d7f7f7f7f01010436000000020800007f7f7f7f7f CB:21
2025.09.01 14:14:45 4: ZWDongle_0 transmit OK for CB 21, target BM_EG_Flur
2025.09.01 14:14:46 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000000aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:46 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:46 5: ZWDongle_0: dispatch 00a800012b0631050422000000aa
2025.09.01 14:14:46 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000000aa CB:00
2025.09.01 14:14:46 4: ZWDongle_Read ZWDongle_0: rcvd 00a8000123032003ff009d (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:46 5: ZWDongle_0: dispatch 00a8000123032003ff009d
2025.09.01 14:14:46 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:23032003ff009d CB:00
2025.09.01 14:14:47 4: ZWDongle_Read ZWDongle_0: rcvd 00a8000123032003ff009d (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:47 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:47 5: ZWDongle_0: dispatch 00a8000123032003ff009d
2025.09.01 14:14:47 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:23032003ff009d CB:00
2025.09.01 14:14:47 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000400a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:47 5: ZWDongle_0: dispatch 00a800012b0631050422000400a9
2025.09.01 14:14:47 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000400a9 CB:00
2025.09.01 14:14:47 4: ZWDongle_Read ZWDongle_0: rcvd 00a8000123032003ff00a6 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:47 5: ZWDongle_0: dispatch 00a8000123032003ff00a6
2025.09.01 14:14:47 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:23032003ff00a6 CB:00
2025.09.01 14:14:47 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012307600d01012503ff009f (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:47 5: ZWDongle_0: dispatch 00a800012307600d01012503ff009f
2025.09.01 14:14:47 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2307600d01012503ff009f CB:00
2025.09.01 14:14:47 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012307600d01012503ff00a0 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:47 5: ZWDongle_0: dispatch 00a800012307600d01012503ff00a0
2025.09.01 14:14:47 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2307600d01012503ff00a0 CB:00
2025.09.01 14:14:47 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012307600d01012503ff009d (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:47 5: ZWDongle_0: dispatch 00a800012307600d01012503ff009d
2025.09.01 14:14:47 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2307600d01012503ff009d CB:00
2025.09.01 14:14:48 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012307600d01012503ff00a6 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:48 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:48 5: ZWDongle_0: dispatch 00a800012307600d01012503ff00a6
2025.09.01 14:14:48 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2307600d01012503ff00a6 CB:00
2025.09.01 14:14:48 3: ZWave set BM_EG_Flur01 off
2025.09.01 14:14:48 5: ZWDongle_Write 00132307600d00012501002522 (ec4154d2)
2025.09.01 14:14:48 5: DevIo_SimpleWrite ZWDongle_0: 010e00132307600d0001250100252289
2025.09.01 14:14:48 5: ACK received, WaitForAck=>2 for 010e00132307600d0001250100252289
2025.09.01 14:14:48 4: ZWDongle_Read ZWDongle_0: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2025.09.01 14:14:48 5: ZWDongle_0: dispatch 011301
2025.09.01 14:14:49 4: ZWDongle_Read ZWDongle_0: rcvd 001322000042019e7f7f7f7f0101050a000000020a00007f7f7f7f7f (request ZW_SEND_DATA), sending ACK
2025.09.01 14:14:49 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:49 5: device ack received, removing 010e00132307600d0001250100252289 from dongle sendstack
2025.09.01 14:14:49 5: ZWDongle_0: dispatch 001322000042019e7f7f7f7f0101050a000000020a00007f7f7f7f7f
2025.09.01 14:14:49 4: CMD:ZW_SEND_DATA ID:00 ARG:0042019e7f7f7f7f0101050a000000020a00007f7f7f7f7f CB:22
2025.09.01 14:14:49 4: ZWDongle_0 transmit OK for CB 22, target BM_EG_Flur
2025.09.01 14:14:50 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012303200300009e (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:50 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:50 5: ZWDongle_0: dispatch 00a800012303200300009e
2025.09.01 14:14:50 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2303200300009e CB:00
2025.09.01 14:14:50 4: ZWDongle_Read ZWDongle_0: rcvd 00a80001230320030000a6 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:50 5: ZWDongle_0: dispatch 00a80001230320030000a6
2025.09.01 14:14:50 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:230320030000a6 CB:00
2025.09.01 14:14:50 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012307600d0101250300009a (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:50 5: ZWDongle_0: dispatch 00a800012307600d0101250300009a
2025.09.01 14:14:50 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2307600d0101250300009a CB:00
2025.09.01 14:14:50 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012307600d0101250300009e (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:50 5: ZWDongle_0: dispatch 00a800012307600d0101250300009e
2025.09.01 14:14:50 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2307600d0101250300009e CB:00
2025.09.01 14:14:50 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012307600d0101250300009d (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:50 5: ZWDongle_0: dispatch 00a800012307600d0101250300009d
2025.09.01 14:14:50 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2307600d0101250300009d CB:00
2025.09.01 14:14:50 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012307600d010125030000a6 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:50 5: ZWDongle_0: dispatch 00a800012307600d010125030000a6
2025.09.01 14:14:50 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2307600d010125030000a6 CB:00
2025.09.01 14:14:54 3: ZWave got config for fibaro/fgrgbwm441.xml from ./FHEM/lib/openzwave_deviceconfig.xml.gz, found 21 commands
2025.09.01 14:14:54 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000300ab (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:54 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:54 5: ZWDongle_0: dispatch 00a800012b0631050422000300ab
2025.09.01 14:14:54 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000300ab CB:00
2025.09.01 14:14:54 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000400ab (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:54 5: ZWDongle_0: dispatch 00a800012b0631050422000400ab
2025.09.01 14:14:54 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000400ab CB:00
2025.09.01 14:14:55 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000500ab (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:55 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:55 5: ZWDongle_0: dispatch 00a800012b0631050422000500ab
2025.09.01 14:14:55 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000500ab CB:00
2025.09.01 14:14:57 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000400aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:57 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:57 5: ZWDongle_0: dispatch 00a800012b0631050422000400aa
2025.09.01 14:14:57 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000400aa CB:00
2025.09.01 14:14:59 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000500aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:14:59 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:14:59 5: ZWDongle_0: dispatch 00a800012b0631050422000500aa
2025.09.01 14:14:59 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000500aa CB:00
2025.09.01 14:14:59 3: ZWave set Gartenhaus_Garagentor on
2025.09.01 14:14:59 5: ZWDongle_Write 001328032601FF2523 (ec4154d2)
2025.09.01 14:14:59 5: DevIo_SimpleWrite ZWDongle_0: 010a001328032601FF252313
2025.09.01 14:14:59 5: ACK received, WaitForAck=>2 for 010a001328032601FF252313
2025.09.01 14:14:59 4: ZWDongle_Read ZWDongle_0: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2025.09.01 14:14:59 5: ZWDongle_0: dispatch 011301
2025.09.01 14:14:59 4: ZWDongle_Read ZWDongle_0: rcvd 00132300000602aa7f7f7f7f01010308250000020100007f7f7f7f7f (request ZW_SEND_DATA), sending ACK
2025.09.01 14:14:59 5: device ack received, removing 010a001328032601FF252313 from dongle sendstack
2025.09.01 14:14:59 5: ZWDongle_0: dispatch 00132300000602aa7f7f7f7f01010308250000020100007f7f7f7f7f
2025.09.01 14:14:59 4: CMD:ZW_SEND_DATA ID:00 ARG:000602aa7f7f7f7f01010308250000020100007f7f7f7f7f CB:23
2025.09.01 14:14:59 4: ZWDongle_0 transmit OK for CB 23, target Gartenhaus_Garagentor
2025.09.01 14:15:01 4: ZWDongle_Read ZWDongle_0: rcvd 00a80001280631050422062800aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:01 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:01 5: ZWDongle_0: dispatch 00a80001280631050422062800aa
2025.09.01 14:15:01 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:280631050422062800aa CB:00
2025.09.01 14:15:04 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000000a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:04 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:04 5: ZWDongle_0: dispatch 00a800012b0631050422000000a9
2025.09.01 14:15:04 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000000a9 CB:00
2025.09.01 14:15:05 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000400a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:05 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:05 5: ZWDongle_0: dispatch 00a800012b0631050422000400a9
2025.09.01 14:15:05 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000400a9 CB:00
2025.09.01 14:15:06 4: ZWDongle_Read ZWDongle_0: rcvd 00a8000127063105012200ce00aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:06 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:06 5: ZWDongle_0: dispatch 00a8000127063105012200ce00aa
2025.09.01 14:15:06 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:27063105012200ce00aa CB:00
2025.09.01 14:15:08 4: ZWDongle_Read ZWDongle_0: rcvd 00a8000127063105012200ce00aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:08 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:08 5: ZWDongle_0: dispatch 00a8000127063105012200ce00aa
2025.09.01 14:15:08 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:27063105012200ce00aa CB:00
2025.09.01 14:15:08 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012705310505015200aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:08 5: ZWDongle_0: dispatch 00a800012705310505015200aa
2025.09.01 14:15:08 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2705310505015200aa CB:00
2025.09.01 14:15:09 4: ZWDongle_Read ZWDongle_0: rcvd 00a80001270380036400aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:09 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:09 5: ZWDongle_0: dispatch 00a80001270380036400aa
2025.09.01 14:15:09 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:270380036400aa CB:00
2025.09.01 14:15:09 4: ZWDongle_Read ZWDongle_0: rcvd 00a8000127063105030a08fa00aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:09 5: ZWDongle_0: dispatch 00a8000127063105030a08fa00aa
2025.09.01 14:15:09 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:27063105030a08fa00aa CB:00
2025.09.01 14:15:09 4: ZWDongle_Read ZWDongle_0: rcvd 00a80001270531051b010000aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:09 5: ZWDongle_0: dispatch 00a80001270531051b010000aa
2025.09.01 14:15:09 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:270531051b010000aa CB:00
2025.09.01 14:15:12 4: ZWDongle_Read ZWDongle_0: rcvd 00a80001280631050422000000aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:12 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:12 5: ZWDongle_0: dispatch 00a80001280631050422000000aa
2025.09.01 14:15:12 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:280631050422000000aa CB:00
2025.09.01 14:15:13 3: ZWave set Gartenhaus_Garagentor off
2025.09.01 14:15:13 5: ZWDongle_Write 001328032601002524 (ec4154d2)
2025.09.01 14:15:13 5: DevIo_SimpleWrite ZWDongle_0: 010a001328032601002524eb
2025.09.01 14:15:13 5: ACK received, WaitForAck=>2 for 010a001328032601002524eb
2025.09.01 14:15:13 4: ZWDongle_Read ZWDongle_0: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2025.09.01 14:15:13 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:13 5: ZWDongle_0: dispatch 011301
2025.09.01 14:15:13 4: ZWDongle_Read ZWDongle_0: rcvd 00a80001280326036300aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:13 5: ZWDongle_0: dispatch 00a80001280326036300aa
2025.09.01 14:15:13 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:280326036300aa CB:00
2025.09.01 14:15:13 4: ZWDongle_Read ZWDongle_0: rcvd 00132401004a007f7f7f7f7f01010700000000020700000000000000 (request ZW_SEND_DATA), sending ACK
2025.09.01 14:15:13 5: device ack received, removing 010a001328032601002524eb from dongle sendstack
2025.09.01 14:15:13 5: ZWDongle_0: dispatch 00132401004a007f7f7f7f7f01010700000000020700000000000000
2025.09.01 14:15:13 4: CMD:ZW_SEND_DATA ID:01 ARG:004a007f7f7f7f7f01010700000000020700000000000000 CB:24
2025.09.01 14:15:13 2: ZWDongle_0 transmit NO_ACK for CB 24, target Gartenhaus_Garagentor
2025.09.01 14:15:15 4: ZWDongle_Read ZWDongle_0: rcvd 00a80001280631050422000000aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:15 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:15 5: ZWDongle_0: dispatch 00a80001280631050422000000aa
2025.09.01 14:15:15 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:280631050422000000aa CB:00
2025.09.01 14:15:16 4: ZWDongle_Read ZWDongle_0: rcvd 00a80001280631050422000000aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:16 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:16 5: ZWDongle_0: dispatch 00a80001280631050422000000aa
2025.09.01 14:15:16 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:280631050422000000aa CB:00
2025.09.01 14:15:16 4: ZWDongle_Read ZWDongle_0: rcvd 00a800013613600d02003202213400000000001f000000000000a4 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:16 5: ZWDongle_0: dispatch 00a800013613600d02003202213400000000001f000000000000a4
2025.09.01 14:15:16 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:3613600d02003202213400000000001f000000000000a4 CB:00
2025.09.01 14:15:17 4: ZWDongle_Read ZWDongle_0: rcvd 00a80001280631050422000000aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:17 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:17 5: ZWDongle_0: dispatch 00a80001280631050422000000aa
2025.09.01 14:15:17 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:280631050422000000aa CB:00
2025.09.01 14:15:17 4: ZWDongle_Read ZWDongle_0: rcvd 00a800013613600d02003202213400000000001f0000000000009f (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:17 5: ZWDongle_0: dispatch 00a800013613600d02003202213400000000001f0000000000009f
2025.09.01 14:15:17 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:3613600d02003202213400000000001f0000000000009f CB:00
2025.09.01 14:15:17 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000500a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:17 5: ZWDongle_0: dispatch 00a800012b0631050422000500a9
2025.09.01 14:15:17 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000500a9 CB:00
2025.09.01 14:15:17 4: ZWDongle_Read ZWDongle_0: rcvd 00a800013613600d02003202213400000000001f0000000000009e (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:17 5: ZWDongle_0: dispatch 00a800013613600d02003202213400000000001f0000000000009e
2025.09.01 14:15:17 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:3613600d02003202213400000000001f0000000000009e CB:00
2025.09.01 14:15:20 4: ZWDongle_Read ZWDongle_0: rcvd 00a81401280631050422000000b8 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:20 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:20 5: ZWDongle_0: dispatch 00a81401280631050422000000b8
2025.09.01 14:15:20 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:280631050422000000b8 CB:14
2025.09.01 14:15:20 4: ZWDongle_Read ZWDongle_0: rcvd 00a81401280631050422000000a6 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:20 5: ZWDongle_0: dispatch 00a81401280631050422000000a6
2025.09.01 14:15:20 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:280631050422000000a6 CB:14
2025.09.01 14:15:20 4: ZWDongle_Read ZWDongle_0: rcvd 00a81401280631050422000000a7 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:20 5: ZWDongle_0: dispatch 00a81401280631050422000000a7
2025.09.01 14:15:20 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:280631050422000000a7 CB:14
2025.09.01 14:15:20 4: ZWDongle_Read ZWDongle_0: rcvd 00a80001280631050422063700aa (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:20 5: ZWDongle_0: dispatch 00a80001280631050422063700aa
2025.09.01 14:15:20 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:280631050422063700aa CB:00
2025.09.01 14:15:21 4: ZWDongle_Read ZWDongle_0: rcvd 00a814012806310504220000009f (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:21 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:21 5: ZWDongle_0: dispatch 00a814012806310504220000009f
2025.09.01 14:15:21 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2806310504220000009f CB:14
2025.09.01 14:15:21 1: BYDHVS -> BMS: 1/1
2025.09.01 14:15:21 4: ZWDongle_Read ZWDongle_0: rcvd 00a81401280631050422000000b1 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:21 5: ZWDongle_0: dispatch 00a81401280631050422000000b1
2025.09.01 14:15:21 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:280631050422000000b1 CB:14
2025.09.01 14:15:21 4: ZWDongle_Read ZWDongle_0: rcvd 00a81401280631050422000000b8 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:21 5: ZWDongle_0: dispatch 00a81401280631050422000000b8
2025.09.01 14:15:21 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:280631050422000000b8 CB:14
2025.09.01 14:15:21 4: ZWDongle_Read ZWDongle_0: rcvd 00a81401280631050422000000a7 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:21 5: ZWDongle_0: dispatch 00a81401280631050422000000a7
2025.09.01 14:15:21 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:280631050422000000a7 CB:14
2025.09.01 14:15:21 4: ZWDongle_Read ZWDongle_0: rcvd 00a81401280631050422000000a8 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:21 5: ZWDongle_0: dispatch 00a81401280631050422000000a8
2025.09.01 14:15:21 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:280631050422000000a8 CB:14
2025.09.01 14:15:21 4: ZWDongle_Read ZWDongle_0: rcvd 00a814012806310504220000009b (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:21 5: ZWDongle_0: dispatch 00a814012806310504220000009b
2025.09.01 14:15:21 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2806310504220000009b CB:14
2025.09.01 14:15:21 4: ZWDongle_Read ZWDongle_0: rcvd 00a814012806310504220000009e (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:21 5: ZWDongle_0: dispatch 00a814012806310504220000009e
2025.09.01 14:15:21 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2806310504220000009e CB:14
2025.09.01 14:15:22 4: ZWDongle_Read ZWDongle_0: rcvd 00a80001050631050422001b00a5 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:22 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:22 5: ZWDongle_0: dispatch 00a80001050631050422001b00a5
2025.09.01 14:15:22 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:050631050422001b00a5 CB:00
2025.09.01 14:15:23 3: ZWave got config for fibaro/fgwpfzw5.xml from ./FHEM/lib/openzwave_deviceconfig.xml.gz, found 22 commands
2025.09.01 14:15:23 4: ZWDongle_Read ZWDongle_0: rcvd 00a80001050631050422001000a5 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:23 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:23 5: ZWDongle_0: dispatch 00a80001050631050422001000a5
2025.09.01 14:15:23 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:050631050422001000a5 CB:00
2025.09.01 14:15:24 4: ZWDongle_Read ZWDongle_0: rcvd 00a80001050631050422000b00a5 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:24 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:15:24 5: ZWDongle_0: dispatch 00a80001050631050422000b00a5
2025.09.01 14:15:24 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:050631050422000b00a5 CB:00
2025.09.01 14:15:24 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000400a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:15:24 5: ZWDongle_0: dispatch 00a800012b0631050422000400a9
2025.09.01 14:15:24 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000400a9 CB:00
Vor dem Absetzen des Befehls wurde folgendes DebugLog immer ausgegeben (letzte Zeile mit "unknown message ... for ID 01")
jetzt kommt immer:
2025.09.01 14:26:32 4: ZWDongle_Read ZWDongle_0: rcvd 00a800012b0631050422000300a9 (request ZW_APPLICATION_COMMAND_HANLDER_BRIDGE), sending ACK
2025.09.01 14:26:32 5: DevIo_SimpleWrite ZWDongle_0: 06
2025.09.01 14:26:32 5: ZWDongle_0: dispatch 00a800012b0631050422000300a9
2025.09.01 14:26:32 4: CMD:ZW_APPLICATION_COMMAND_HANLDER_BRIDGE ID:01 ARG:2b0631050422000300a9 CB:00
Das sieht doch jetzt viel besser aus!
Was wären die nächsten Schritte?!
Wäre es nicht nachhaltiger aber sicherlich aufwändiger, das Modul auf diese ZWAVE API umzustellen, anstatt der aktuelle Weg? Kann man bei den ZwaveUI JS Kollegen nicht abkucken?!
Die können ja auch dieses Backup/Restore... ich würde sonst parallel gern nur das ZwaveUI JS parallel als Verwaltungsoberfläche im Docker weiter laufen lassen... Ansonsten seid ihr tiefer in der Technik drin, ich versteh noch nicht so genau, was ihr da für Magie macht :)
Der Support von Aeotec konnte leider nichts weiter beitragen, viell. hab ich es auch falsch erklärt, aber sie sagen auch immer sie kennen FHEM nicht und verweisen auf die Jungs von ZWaveJS UI und dass die dort viel Zeit investiert haben.
VG
René
ZitatAber das zwei Programme gleichzeitig auf einen USB Stick zugreifen, sollte doch kein Problem darstellen oder meint ihr das könnte die Ursache sein!?
Wenn zwei Programme von der gleichen Schnittstelle lesen, dann werden beide jeweils nur Teile der Daten bekommen => damit funktioniert vmtl. keiner der beiden richtig.
ZitatKann man bei den ZwaveUI JS Kollegen nicht abkucken?!
Klar, es sind "nur" 32MB, was man verstehen muss.
Wenn sie wenigstens etwas weniger strukturiert waeren, dann muesste man nicht so viele Dateien durchlesen.
Laut zwave.js Code (zwave-js/src/lib/driver/Driver.ts) und auch der vom krikan verlinkten Doku ist der Initialzustand des Controllers 8-bit nodeId, zwave.js aendert es auf 16 Bit, wenn der Controller das ZWave LongRange Feature unterstuetzt.
Das FHEM Modul auf 16-Bit nodeid umzubauen waere aufwendig, jedenfalls faellt mir nichts Einfaches dazu ein.
fireball
Hi Rudolf,
heißt das dann im Umkehrschluss, durch die Migration von Gen5+ auf 10pro über ZwaveUI JS, habe ich mir quasi erst die 16bit eingehandelt, weil der Stick ja LongRange unterstützt?
Und wenn ich jetzt auf 8bit zurückstelle, dann geht aber mein Netzwerk wieder, aber ich habe das LongRange Feature nicht mehr?!
Ich wollte ja nicht nur mal eben Hardware wechseln, sondern auch ein paar Vorteile haben und LongRange fand ich neben aktuellerer HW sehr gut um einfach auch mehr Stabilität ins ZWAVE-Netzwerk zu bekommen. Wobei reicht es aus, wenn der Stick das hat oder müssen es auch die "clients" haben!?
Nebenbei hat der Stick aber auch noch die Zigbee-Chip inkludiert und alles ist in einem "Bauteil"... Klar Ausfallsicherheit habe ich damit minimiert... Wenn sind beide Netzwerke kaputt...
Was heißt das jetzt für FHEM? Könnt ihr den Stick unterstützen oder muss ich immer den von kirkan erwähnten Befehl manuell ausführen, falls er mal stromlos werden sollte?!
Bin grad am zweifeln ob der Stick auf Dauer die richtige Entscheidung ist, meine Hausautomatisierung basiert hauptsächlich auf ZWAVE.
VG+Danke
René
Laut Doku ist 8-bit default, d.h. die Version, mit der FHEM umgehen kann.
Kannst Du das durch ab-/anstecken testen?
Wg. LongRange:
https://www.silabs.com/wireless/z-wave/z-wave-long-range-overview:
ZitatZ-Wave LR is an extra 100kbps DSSS OQPSK modulation addition to the Z-Wave protocol. The modulation is treated as a fourth channel - allowing gateways to add LR nodes to the existing Z-Wave channel scanning. Currently, Z-Wave LR is only available for the US market however, the technical workgroup within the Z-Wave Alliance is evaluating and testing to ensure compliance and to be able to support Europe and APAC regions in the future.
Das heisst:
- vermutlich funktioniert Longrange auch mit 8-bit (und damit ohne FHEM Anpassung). Dann natuerlich mit hoechstens ca 200 Clients.
- nur Geraete mit passenden Chipsatz koennen bei LongRange mitmachen.
fireball
Also ich habe den Stick jetzt mal für 10Sek vom Raspberry abgezogen, da der 10ner keine eingebaute Batterie wie der Gen5* mehr hat, sollte also alles was flüchtig gesetzt wird, auch weg sein... nach dem Anstecken ging alles wie gewohnt weiter.
Kann mich aber auch erinnern, dass man beim Gen5 mit einem ähnlichen Kommando permanent das Blinken des Sticks ausschalten konnte.
Also wenn jetzt nichts mehr dageben spricht, würde ich wohl auf der neueren HW bleiben.
Wahrscheinlich darf ich Ihn jetzt aber nicht nochmal mit ZwaveUI-JS betreiben oder? Nicht das die Software wieder alles auf 16bit umstellt...
VG
René
krikan
Mich wundert, dass Ein- und Ausstecken nicht zum Verlust der Einstellung führt: Wegen default=8 bit?
https://www.silabs.com/documents/public/user-guides/INS12350-Serial-API-Host-Appl.-Prg.-Guide.pdf sagt:
ZitatNotice: The command is not persistent. Must be re-issued after a reset or power-cycle of the Serial API
Controller. I.e. the Host should subscribe to the Serial API started Command [7.16] to be notified of any
Controller restart and re-issue the command accordingly.
Aber Hauptsache es funktioniert.
Zitat von: fireball am 01 September 2025, 18:22:00Wahrscheinlich darf ich Ihn jetzt aber nicht nochmal mit ZwaveUI-JS betreiben oder? Nicht das die Software wieder alles auf 16bit umstellt...
Ist zu befürchten, aber Du kennst jetzt den Weg zurück.
Aktueller Blog-Beitrag der zwave-js-Entwickler zu Long Rang: https://blog.zwave-js.io/2025/08/01/zwave-not-so-long-range/
Wer braucht das jetzt und warum sollte man den Stick nicht im 8bit-Modus für die NodeId unter Fhem betreiben!?
ZitatIst zu befürchten, aber Du kennst jetzt den Weg zurück.
Wir koennten das auch in die Initialisierung des Controlles aufnehmen.
Ich muesste nur wissen, woran ich erkenne, dass der Controller das kann.
ZitatAktueller Blog-Beitrag der zwave-js-Entwickler zu Long Rang: https://blog.zwave-js.io/2025/08/01/zwave-not-so-long-range/
Danke, nett :)
Damu
Laut z-wave.me kann der RaZberry 7 Pro auch Long Range Mode:
ZitatSwitching between Normal and Long Range mode
(supported on the 7th generation or newer)
    Normal mode (compatibility with 5th gen and 7th gen non-Long-Range firmwares):
    Echo command:
        echo -ne "\x01\x05\x00\x0B\x80\x01\x70" > /dev/ttyAMA0
    uSAPI:
        uSAPI -b "0B 80 01" -p /dev/ttyACM0 -r 1
    Long Range mode:
    Echo command:
        echo -ne "\x01\x05\x00\x0B\x80\x02\x73" > /dev/ein
    uSAPI:
        uSAPI -b "0B 80 02" -p /dev/ttyACM0 -r 1
Da gibt geht es auch ein Befehl für wieder den Normal Mode.
Es gibt aber auch ein Static Mode und ein Bridge Mode.
Switching between Static and Bridge mode.
Zitat(supported on the 7th generation or newer)
    Static mode (compatibility with 5th gen firmwares):
    Z-Way API:
        http://localhost:8083/JS/Run/zway.ZMESerialAPIOptionsStaticAPISet(true)
    Echo command:
        echo -ne "\x01\x06\x00\xF8\x04\x01\x01\x05" > /dev/ttyAMA0
    uSAPI:
        uSAPI -b "F8 04 01 01" -p /dev/ttyACM0 -r 1
    Bridge mode (compatibility with 7th gen SiLabs firmware):
    Z-Way API:
        http://localhost:8083/JS/Run/zway.ZMESerialAPIOptionsStaticAPISet(false)
    Echo command:
        echo -ne "\x01\x06\x00\xF8\x04\x01\x00\x04" > /dev/ttyAMA0
    uSAPI:
        uSAPI -b "F8 04 01 00" -p /dev/ttyACM0 -r 1
Was ist den da der Unterschied.
Hat der Controller da eventuell mehrere Node IDs?
fireball
#29
also ich habe sicherheitshalber den Stick jetzt nochmal 1h vom Raspberry getrennt und FHEM restartet.
Danach wieder dran und der Stick konnte die Geräte immernoch schalten.
Kann man den Stick nicht an diesen Readings erkennen:
Vers:7 Rev:23 ManufID:0371 ProductType:0004 ProductID:003c Also die ersten beiden Werte ähneln aber verdamt der Firmwareversion: Z-Wave 7.23 BRIDGE_CONTROLLER aber der Rest sollte doch statisch sein...
https://devices.zwave-js.io/?jumpTo=0x0371:0x0004:0x003c:0.0
Zum Thema STATIC vs BRIDGE... keine Ahnung was das ist, aber das hatte ich in den vergangen Posts schonmal erwähnt:
Zitatalter Gen5 Aeotec - Stick:
- HomeId:ec4154d2 CtrlNodeIdHex:01
- version Z-Wave 3.95 STATIC_CONTROLLER
Migration von Gen5 via Aeotec BackupTool auf
"neuen" Gen5+ Aeotec - Stick:
- version Z-Wave 6.07 STATIC_CONTROLLER
Migration von Gen5+ via ZWaveUI JS Backup/Restore auf
"nagelneuen" 10 Pro Aeotec - Stick
- version Z-Wave 7.23 BRIDGE_CONTROLLER
Der 10pro wird als BRIDGE Controller ausgelesen, wenn man get version macht.
VG
René
PS: Bestätigt!!! Ein kurzer Sprung zu ZWaveUI JS und schwups ist die Einstellung wieder hin, dann muss man wieder get <controllerName> raw 0B8001
Dann geht der Fehler wieder weg:
2025.09.01 20:43:03 4: ZWave: unknown message 00a8000001003513600d02003202213400000051001f000000530000a2007f7f for ID 01
