[Signalduino] Deckenventilator Forrovenco QX-01-DE1 - Funkprotokoll-Findung
Begonnen von drhirn, 13 November 2025, 17:17:08
drhirn
Light on/off:
2025.11.15 13:58:30 4: Signalduino: Read, msg: MS;P2=-269;P3=230;P4=-781;P5=751;P6=-7890;D=363452343434343452343452343452523434525252345234343434345252343452;CP=3;SP=6;R=221;O;m2;
2025.11.15 13:58:30 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:58:30 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267419 length 32 RSSI = -91.5
2025.11.15 13:58:30 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010000011001, hlen 8
2025.11.15 13:58:30 4: Signalduino: Read, msg: MS;P2=-300;P3=228;P4=-785;P5=724;P6=-7907;D=363452343434343452343452343452523434525252345234343434345252343452;CP=3;SP=6;R=221;O;m1;
2025.11.15 13:58:30 4: Signalduino: Dispatch, P20#41267419, Dropped due to short time or equal msg
2025.11.15 13:58:30 4: Signalduino: Read, msg: MS;P2=-308;P3=210;P4=-814;P5=713;P6=-7895;D=363452343434343452343452343452523434525252345234343434345252343452;CP=3;SP=6;R=221;m0;
2025.11.15 13:58:31 4: Signalduino: Read, msg: MS;P2=-279;P3=234;P4=-784;P5=738;P6=-7911;D=363452343434343452343452343452523434525252345234343434523452345234;CP=3;SP=6;R=220;O;m2;
2025.11.15 13:58:31 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:58:31 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#4126742A length 32 RSSI = -92
2025.11.15 13:58:31 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010000101010, hlen 8
2025.11.15 13:58:31 4: Signalduino: Read, msg: MS;P2=-296;P3=235;P4=-783;P5=725;P6=-7896;D=363452343434343452343452343452523434525252345234343434523452345234;CP=3;SP=6;R=220;O;m1;
2025.11.15 13:58:31 4: Signalduino: Dispatch, P20#4126742A, Dropped due to short time or equal msg
2025.11.15 13:58:31 4: Signalduino: Read, msg: MS;P2=-288;P3=218;P4=-804;P5=714;P6=-7906;D=363452343434343452343452343452523434525252345234343434523452345234;CP=3;SP=6;R=220;O;m0;
2025.11.15 13:58:31 4: Signalduino: Read, msg: MS;P2=-297;P3=195;P4=-828;P5=720;P6=-7911;D=363452343434343452343452343452523434525252345234343434523452345234;CP=3;SP=6;R=220;
2025.11.15 13:58:32 4: Signalduino: Read, msg: MS;P2=-283;P3=233;P4=-777;P5=736;P6=-7899;D=363452343434343452343452343452523434525252345234343434525252345252;CP=3;SP=6;R=219;O;m2;
2025.11.15 13:58:32 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:58:32 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#4126743B length 32 RSSI = -92.5
2025.11.15 13:58:32 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010000111011, hlen 8
2025.11.15 13:58:32 4: Signalduino: Read, msg: MS;P2=-287;P3=223;P4=-789;P5=726;P6=-7901;D=363452343434343452343452343452523434525252345234343434525252345252;CP=3;SP=6;R=219;O;m1;
2025.11.15 13:58:32 4: Signalduino: Dispatch, P20#4126743B, Dropped due to short time or equal msg
2025.11.15 13:58:32 4: Signalduino: Read, msg: MS;P2=-290;P3=216;P4=-801;P5=716;P6=-7912;D=363452343434343452343452343452523434525252345234343434525252345252;CP=3;SP=6;R=219;O;m0;
2025.11.15 13:58:32 4: Signalduino: Read, msg: MS;P2=-293;P3=213;P4=-797;P5=726;P6=-7926;D=363452343434343452343452343452523434525252345234343434525252345252;CP=3;SP=6;R=219;O;
2025.11.15 13:58:33 4: Signalduino: Read, msg: MS;P2=-285;P3=226;P4=-784;P5=728;P6=-7901;D=363452343434343452343452343452523434525252345234343452343452523434;CP=3;SP=6;R=219;O;m2;
2025.11.15 13:58:33 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:58:33 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#4126744C length 32 RSSI = -92.5
2025.11.15 13:58:33 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010001001100, hlen 8
2025.11.15 13:58:33 4: Signalduino: Read, msg: MS;P2=-300;P3=226;P4=-791;P5=710;P6=-7910;D=363452343434343452343452343452523434525252345234343452343452523434;CP=3;SP=6;R=219;O;m1;
2025.11.15 13:58:33 4: Signalduino: Dispatch, P20#4126744C, Dropped due to short time or equal msg
2025.11.15 13:58:34 4: Signalduino: Read, msg: MS;P2=-300;P3=206;P4=-804;P5=717;P6=-7925;D=363452343434343452343452343452523434525252345234343452343452523434;CP=3;SP=6;R=219;O;m0;
2025.11.15 13:58:34 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:58:34 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#4126744C length 32 RSSI = -92.5
2025.11.15 13:58:34 4: Signalduino: Dispatch, P20#4126744C, Dropped due to short time or equal msg
2025.11.15 13:58:34 4: Signalduino: Read, msg: MS;P2=-309;P3=187;P4=-834;P5=719;P6=-7918;D=363452343434343452343452343452523434525252345234343452343452523434;CP=3;SP=6;R=219;
2025.11.15 13:58:35 4: Signalduino: Read, msg: MS;P2=-295;P3=233;P4=-776;P5=729;P6=-7902;D=363452343434343452343452343452523434525252345234343452345252523452;CP=3;SP=6;R=219;O;m2;
2025.11.15 13:58:35 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:58:35 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#4126745D length 32 RSSI = -92.5
2025.11.15 13:58:35 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010001011101, hlen 8
2025.11.15 13:58:35 4: Signalduino: Read, msg: MS;P2=-282;P3=231;P4=-782;P5=730;P6=-7901;D=363452343434343452343452343452523434525252345234343452345252523452;CP=3;SP=6;R=219;O;m1;
2025.11.15 13:58:35 4: Signalduino: Dispatch, P20#4126745D, Dropped due to short time or equal msg
2025.11.15 13:58:35 4: Signalduino: Read, msg: MS;P2=-302;P3=217;P4=-798;P5=709;P6=-7904;D=363452343434343452343452343452523434525252345234343452345252523452;CP=3;SP=6;R=219;O;m0;
2025.11.15 13:58:35 4: Signalduino: Read, msg: MS;P2=-327;P3=203;P4=-814;P5=706;P6=-7910;D=363452343434343452343452343452523434525252345234343452345252523452;CP=3;SP=6;R=219;
fan_1:
2025.11.15 13:59:33 4: Signalduino: Read, msg: MS;P0=244;P1=-275;P2=743;P4=-776;P6=-7908;D=060421040404040421040421040421210404212121210404040421210404042104;CP=0;SP=6;R=219;O;m2;
2025.11.15 13:59:33 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:59:33 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267862 length 32 RSSI = -92.5
2025.11.15 13:59:33 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100001100010, hlen 8
2025.11.15 13:59:33 4: Signalduino: Read, msg: MS;P0=231;P1=-299;P2=723;P4=-783;P6=-7908;D=060421040404040421040421040421210404212121210404040421210404042104;CP=0;SP=6;R=219;O;m1;
2025.11.15 13:59:33 4: Signalduino: Dispatch, P20#41267862, Dropped due to short time or equal msg
2025.11.15 13:59:33 4: Signalduino: Read, msg: MS;P0=223;P1=-299;P2=715;P4=-789;P6=-7918;D=060421040404040421040421040421210404212121210404040421210404042104;CP=0;SP=6;R=219;O;m0;
2025.11.15 13:59:33 4: Signalduino: Read, msg: MS;P0=209;P1=-313;P2=702;P4=-804;P6=-7927;D=060421040404040421040421040421210404212121210404040421210404042104;CP=0;SP=6;R=219;O;
2025.11.15 13:59:33 4: Signalduino: Read, msg: MS;P0=204;P1=-811;P2=701;P3=-306;P4=-8018;D=040123010101010123010123010123230101232323230101010123230101012301;CP=0;SP=4;R=219;m2;
2025.11.15 13:59:33 4: Signalduino: Read, msg: MU;P0=204;P1=-811;P2=701;P3=-306;P4=-8018;P5=-32001;D=04012301010101012301012301012323010123232323010101012323010101230105;CP=0;R=219;
2025.11.15 13:59:34 4: Signalduino: Read, msg: MS;P2=-279;P3=222;P4=-785;P5=736;P6=-7913;D=363452343434343452343452343452523434525252523434343452525234345252;CP=3;SP=6;R=219;O;m2;
2025.11.15 13:59:34 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:59:34 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267873 length 32 RSSI = -92.5
2025.11.15 13:59:34 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100001110011, hlen 8
2025.11.15 13:59:34 4: Signalduino: Read, msg: MS;P2=-281;P3=229;P4=-787;P5=724;P6=-7909;D=363452343434343452343452343452523434525252523434343452525234345252;CP=3;SP=6;R=219;O;m1;
2025.11.15 13:59:34 4: Signalduino: Dispatch, P20#41267873, Dropped due to short time or equal msg
2025.11.15 13:59:34 4: Signalduino: Read, msg: MS;P2=-280;P3=234;P4=-774;P5=739;P6=-7910;D=363452343434343452343452343452523434525252523434343452525234345252;CP=3;SP=6;R=219;O;m0;
2025.11.15 13:59:34 4: Signalduino: Read, msg: MS;P2=-287;P3=226;P4=-794;P5=729;P6=-7921;D=363452343434343452343452343452523434525252523434343452525234345252;CP=3;SP=6;R=219;O;
2025.11.15 13:59:34 4: Signalduino: Read, msg: MU;P0=668;P1=-345;P2=166;P3=-849;P4=-7926;P5=248;D=01232301012423012323232323012323012323010123230101010123232323010101232301012423012323232323012323012323010123235;CP=2;R=219;
2025.11.15 13:59:36 4: Signalduino: Read, msg: MS;P0=-7981;P2=-288;P3=230;P4=-783;P5=738;D=303452343434343452343452343452523434525252523434343434343434523434;CP=3;SP=0;R=219;O;m2;
2025.11.15 13:59:36 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:59:36 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267804 length 32 RSSI = -92.5
2025.11.15 13:59:36 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100000000100, hlen 8
2025.11.15 13:59:36 4: Signalduino: Read, msg: MS;P0=-7918;P2=-287;P3=236;P4=-780;P5=725;D=303452343434343452343452343452523434525252523434343434343434523434;CP=3;SP=0;R=219;O;m1;
2025.11.15 13:59:36 4: Signalduino: Dispatch, P20#41267804, Dropped due to short time or equal msg
2025.11.15 13:59:36 4: Signalduino: Read, msg: MS;P0=-7905;P2=-283;P3=243;P4=-779;P5=731;D=303452343434343452343452343452523434525252523434343434343434523434;CP=3;SP=0;R=219;O;m0;
2025.11.15 13:59:36 4: Signalduino: Read, msg: MS;P0=-7900;P2=-282;P3=218;P4=-797;P5=736;D=303452343434343452343452343452523434525252523434343434343434523434;CP=3;SP=0;R=219;O;
2025.11.15 13:59:36 4: Signalduino: Read, msg: MU;P0=161;P1=-939;P2=646;P3=-362;P4=-7943;D=010123010104012301010101012301012301012323010123232323010101010101010123010104012301010101012301012301012323010123232323010101010101010123010104012301010101012301;CP=0;R=220;
2025.11.15 13:59:37 4: Signalduino: Read, msg: MS;P2=-277;P3=235;P4=-780;P5=741;P6=-7894;D=363452343434343452343452343452523434525252523434343434345234523452;CP=3;SP=6;R=220;O;m2;
2025.11.15 13:59:37 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:59:37 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267815 length 32 RSSI = -92
2025.11.15 13:59:37 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100000010101, hlen 8
2025.11.15 13:59:37 4: Signalduino: Read, msg: MS;P2=-269;P3=240;P4=-777;P5=748;P6=-7909;D=363452343434343452343452343452523434525252523434343434345234523452;CP=3;SP=6;R=220;O;m1;
2025.11.15 13:59:37 4: Signalduino: Dispatch, P20#41267815, Dropped due to short time or equal msg
2025.11.15 13:59:37 4: Signalduino: Read, msg: MS;P2=-276;P3=236;P4=-775;P5=739;P6=-7898;D=363452343434343452343452343452523434525252523434343434345234523452;CP=3;SP=6;R=220;O;m0;
2025.11.15 13:59:37 4: Signalduino: Read, msg: MS;P2=-289;P3=225;P4=-791;P5=737;P6=-7901;D=363452343434343452343452343452523434525252523434343434345234523452;CP=3;SP=6;R=220;O;
2025.11.15 13:59:37 4: Signalduino: Read, msg: MS;P0=684;P1=-334;P2=187;P3=-826;P4=-7915;D=242301232323232301232301232301012323010101012323232323230123012301;CP=2;SP=4;R=221;O;m2;
2025.11.15 13:59:37 4: Signalduino: Read, msg: MS;P0=684;P1=-334;P2=183;P3=-863;P4=-7915;D=242301232323232301232301232301012323010101012323232323230123012301;CP=2;SP=4;R=221;m1;
2025.11.15 13:59:38 4: Signalduino: Read, msg: MS;P0=-770;P2=-285;P3=243;P4=738;P5=-7904;D=353042303030303042303042303042423030424242423030303030423030424230;CP=3;SP=5;R=220;O;m2;
2025.11.15 13:59:38 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:59:38 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267826 length 32 RSSI = -92
2025.11.15 13:59:38 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100000100110, hlen 8
2025.11.15 13:59:38 4: Signalduino: Read, msg: MS;P0=-793;P2=-284;P3=227;P4=728;P5=-7893;D=353042303030303042303042303042423030424242423030303030423030424230;CP=3;SP=5;R=220;O;m1;
2025.11.15 13:59:38 4: Signalduino: Dispatch, P20#41267826, Dropped due to short time or equal msg
2025.11.15 13:59:38 4: Signalduino: Read, msg: MS;P0=-783;P2=-290;P3=228;P4=723;P5=-7898;D=353042303030303042303042303042423030424242423030303030423030424230;CP=3;SP=5;R=220;O;m0;
2025.11.15 13:59:38 4: Signalduino: Read, msg: MS;P0=-783;P2=-282;P3=227;P4=731;P5=-7901;D=353042303030303042303042303042423030424242423030303030423030424230;CP=3;SP=5;R=220;O;
2025.11.15 13:59:38 4: Signalduino: Read, msg: MS;P0=208;P1=-866;P2=681;P3=-348;P4=-7940;D=040123010101010123010123010123230101232323230101010101230101232301;CP=0;SP=4;R=220;
fan_reverse:
2025.11.15 14:00:08 4: Signalduino: Read, msg: MS;P2=-253;P3=248;P4=-760;P5=760;P6=-7816;D=363452343434343452343452343452523434525252523434345234525252525252;CP=3;SP=6;R=225;O;m2;
2025.11.15 14:00:08 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:08 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412678BF length 32 RSSI = -89.5
2025.11.15 14:00:08 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100010111111, hlen 8
2025.11.15 14:00:08 4: Signalduino: Read, msg: MS;P2=-261;P3=252;P4=-759;P5=756;P6=-7824;D=363452343434343452343452343452523434525252523434345234525252525252;CP=3;SP=6;R=225;O;m1;
2025.11.15 14:00:08 4: Signalduino: Dispatch, P20#412678BF, Dropped due to short time or equal msg
2025.11.15 14:00:08 4: Signalduino: Read, msg: MS;P2=-259;P3=256;P4=-761;P5=760;P6=-7830;D=363452343434343452343452343452523434525252523434345234525252525252;CP=3;SP=6;R=225;O;m0;
2025.11.15 14:00:08 4: Signalduino: Read, msg: MS;P2=-259;P3=249;P4=-776;P5=748;P6=-7823;D=363452343434343452343452343452523434525252523434345234525252525252;CP=3;SP=6;R=225;O;
2025.11.15 14:00:08 4: Signalduino: Read, msg: MS;P0=698;P1=-318;P2=200;P3=-7870;P4=-833;D=232401242424242401242401242401012424010101012424240124010101010101;CP=2;SP=3;R=220;
2025.11.15 14:00:09 4: Signalduino: Read, msg: MS;P2=-271;P3=249;P4=-768;P5=743;P6=-7830;D=363452343434343452343452343452523434525252523434345252343452343434;CP=3;SP=6;R=222;O;m2;
2025.11.15 14:00:09 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:09 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412678C8 length 32 RSSI = -91
2025.11.15 14:00:09 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100011001000, hlen 8
2025.11.15 14:00:09 4: Signalduino: Read, msg: MS;P2=-271;P3=245;P4=-770;P5=745;P6=-7825;D=363452343434343452343452343452523434525252523434345252343452343434;CP=3;SP=6;R=222;O;m1;
2025.11.15 14:00:09 4: Signalduino: Dispatch, P20#412678C8, Dropped due to short time or equal msg
2025.11.15 14:00:09 4: Signalduino: Read, msg: MS;P2=-275;P3=231;P4=-791;P5=738;P6=-7830;D=363452343434343452343452343452523434525252523434345252343452343434;CP=3;SP=6;R=222;O;m0;
2025.11.15 14:00:09 4: Signalduino: Read, msg: MS;P2=-322;P3=199;P4=-845;P5=692;P6=-7833;D=363452343434343452343452343452523434525252523434345252343452343434;CP=3;SP=6;R=222;
2025.11.15 14:00:10 4: Signalduino: Read, msg: MS;P2=-279;P3=240;P4=-770;P5=739;P6=-7828;D=363452343434343452343452343452523434525252523434345252345252343452;CP=3;SP=6;R=221;O;m2;
2025.11.15 14:00:10 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:10 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412678D9 length 32 RSSI = -91.5
2025.11.15 14:00:10 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100011011001, hlen 8
2025.11.15 14:00:10 4: Signalduino: Read, msg: MS;P2=-272;P3=242;P4=-780;P5=746;P6=-7827;D=363452343434343452343452343452523434525252523434345252345252343452;CP=3;SP=6;R=221;O;m1;
2025.11.15 14:00:10 4: Signalduino: Dispatch, P20#412678D9, Dropped due to short time or equal msg
2025.11.15 14:00:10 4: Signalduino: Read, msg: MS;P2=-280;P3=232;P4=-776;P5=737;P6=-7831;D=363452343434343452343452343452523434525252523434345252345252343452;CP=3;SP=6;R=221;O;m0;
2025.11.15 14:00:10 4: Signalduino: Read, msg: MS;P2=-329;P3=210;P4=-848;P5=683;P6=-7835;D=363452343434343452343452343452523434525252523434345252345252343452;CP=3;SP=6;R=221;
2025.11.15 14:00:11 4: Signalduino: Read, msg: MS;P2=-255;P3=252;P4=-770;P5=753;P6=-7815;D=363452343434343452343452343452523434525252523434345252523452345234;CP=3;SP=6;R=223;O;m2;
2025.11.15 14:00:11 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:11 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412678EA length 32 RSSI = -90.5
2025.11.15 14:00:11 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100011101010, hlen 8
2025.11.15 14:00:11 4: Signalduino: Read, msg: MS;P2=-303;P3=208;P4=-805;P5=717;P6=-7831;D=363452343434343452343452343452523434525252523434345252523452345234;CP=3;SP=6;R=223;m1;
2025.11.15 14:00:11 4: Signalduino: Dispatch, P20#412678EA, Dropped due to short time or equal msg
2025.11.15 14:00:12 4: Signalduino: Read, msg: MS;P2=-257;P3=254;P4=-759;P5=756;P6=-7822;D=363452343434343452343452343452523434525252523434345252525252345252;CP=3;SP=6;R=223;O;m2;
2025.11.15 14:00:12 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:12 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412678FB length 32 RSSI = -90.5
2025.11.15 14:00:12 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100011111011, hlen 8
2025.11.15 14:00:12 4: Signalduino: Read, msg: MS;P2=-250;P3=259;P4=-766;P5=767;P6=-7825;D=363452343434343452343452343452523434525252523434345252525252345252;CP=3;SP=6;R=223;O;m1;
2025.11.15 14:00:12 4: Signalduino: Dispatch, P20#412678FB, Dropped due to short time or equal msg
2025.11.15 14:00:12 4: Signalduino: Read, msg: MS;P2=-260;P3=253;P4=-771;P5=750;P6=-7820;D=363452343434343452343452343452523434525252523434345252525252345252;CP=3;SP=6;R=223;O;m0;
2025.11.15 14:00:12 4: Signalduino: Read, msg: MS;P2=-260;P3=244;P4=-766;P5=759;P6=-7822;D=363452343434343452343452343452523434525252523434345252525252345252;CP=3;SP=6;R=223;O;
2025.11.15 14:00:12 4: Signalduino: Read, msg: MS;P0=708;P1=-295;P2=205;P3=-839;P4=-7868;D=242301232323232301232301232301012323010101012323230101010101230101;CP=2;SP=4;R=222;
time_2h:
2025.11.15 14:00:54 4: Signalduino: Read, msg: MS;P0=-7892;P2=-289;P3=227;P4=-797;P5=721;D=303452343434343452343452343452523434525252345234345252525234525252;CP=3;SP=0;R=219;O;m2;
2025.11.15 14:00:54 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:54 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412674F7 length 32 RSSI = -92.5
2025.11.15 14:00:54 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010011110111, hlen 8
2025.11.15 14:00:54 4: Signalduino: Read, msg: MS;P0=-8042;P2=-304;P3=221;P4=-795;P5=713;D=303452343434343452343452343452523434525252345234345252525234525252;CP=3;SP=0;R=219;O;m1;
2025.11.15 14:00:54 4: Signalduino: Dispatch, P20#412674F7, Dropped due to short time or equal msg
2025.11.15 14:00:54 4: Signalduino: Read, msg: MS;P0=-8063;P2=-304;P3=207;P4=-815;P5=711;D=303452343434343452343452343452523434525252345234345252525234525252;CP=3;SP=0;R=219;O;m0;
2025.11.15 14:00:54 4: Signalduino: Read, msg: MS;P0=-8073;P2=-318;P3=187;P4=-829;P5=700;D=303452343434343452343452343452523434525252345234345252525234525252;CP=3;SP=0;R=219;
2025.11.15 14:00:55 4: Signalduino: Read, msg: MS;P2=-300;P3=224;P4=-793;P5=727;P6=-8073;D=363452343434343452343452343452523434525252345234345234343434343434;CP=3;SP=6;R=220;O;m2;
2025.11.15 14:00:55 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:55 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267480 length 32 RSSI = -92
2025.11.15 14:00:55 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010010000000, hlen 8
2025.11.15 14:00:55 4: Signalduino: Read, msg: MS;P2=-313;P3=200;P4=-815;P5=713;P6=-8100;D=363452343434343452343452343452523434525252345234345234343434343434;CP=3;SP=6;R=220;O;m1;
2025.11.15 14:00:55 4: Signalduino: Read, msg: MS;P2=-309;P3=207;P4=-814;P5=715;P6=-8118;D=363452343434343452343452343452523434525252345234345234343434343434;CP=3;SP=6;R=220;m0;
2025.11.15 14:00:55 4: Signalduino: Read, msg: MU;P0=194;P1=-322;P3=-827;P4=698;P6=-8140;D=0103034141030341414103410303410303030303030306034103030303034103034103034141030341;CP=0;R=217;
2025.11.15 14:00:55 4: Signalduino: Read, msg: MU;P0=-1848;P1=-340;P2=665;P4=213;P5=-829;P6=140;P7=-8096;D=1214521454521454545456545454745214545454545214021454521214545214;CP=4;R=218;
2025.11.15 14:00:57 4: Signalduino: Read, msg: MS;P0=-7956;P2=-286;P3=220;P4=-792;P5=725;D=303452343434343452343452343452523434525252345234345234345234343452;CP=3;SP=0;R=220;O;m2;
2025.11.15 14:00:57 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:57 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267491 length 32 RSSI = -92
2025.11.15 14:00:57 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010010010001, hlen 8
2025.11.15 14:00:57 4: Signalduino: Read, msg: MS;P0=-8053;P2=-287;P3=229;P4=-781;P5=739;D=303452343434343452343452343452523434525252345234345234345234343452;CP=3;SP=0;R=220;O;m1;
2025.11.15 14:00:57 4: Signalduino: Dispatch, P20#41267491, Dropped due to short time or equal msg
2025.11.15 14:00:57 4: Signalduino: Read, msg: MS;P0=-8064;P2=-295;P3=216;P4=-794;P5=727;D=303452343434343452343452343452523434525252345234345234345234343452;CP=3;SP=0;R=220;O;m0;
2025.11.15 14:00:57 4: Signalduino: Read, msg: MS;P0=-8078;P2=-295;P3=221;P4=-795;P5=713;D=303452343434343452343452343452523434525252345234345234345234343452;CP=3;SP=0;R=220;O;
2025.11.15 14:00:57 4: Signalduino: Read, msg: MS;P0=700;P1=-317;P2=193;P3=-819;P4=-8108;D=242301232323232301232301232301012323010101230123230123230123232301;CP=2;SP=4;R=219;m2;
2025.11.15 14:00:57 4: Signalduino: Read, msg: MU;P0=-820;P1=205;P2=691;P3=-323;P4=-8088;P5=116;P6=272;D=01023141023101010101023105023101023231010236;CP=1;R=218;
2025.11.15 14:00:58 4: Signalduino: Read, msg: MS;P2=-287;P3=232;P4=-781;P5=727;P6=-8079;D=363452343434343452343452343452523434525252345234345234523434345234;CP=3;SP=6;R=220;O;m2;
2025.11.15 14:00:58 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:58 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412674A2 length 32 RSSI = -92
2025.11.15 14:00:58 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010010100010, hlen 8
2025.11.15 14:00:58 4: Signalduino: Read, msg: MS;P2=-281;P3=217;P4=-796;P5=735;P6=-8088;D=363452343434343452343452343452523434525252345234345234523434345234;CP=3;SP=6;R=220;O;m1;
2025.11.15 14:00:58 4: Signalduino: Dispatch, P20#412674A2, Dropped due to short time or equal msg
2025.11.15 14:00:58 4: Signalduino: Read, msg: MS;P2=-289;P3=221;P4=-788;P5=738;P6=-8086;D=363452343434343452343452343452523434525252345234345234523434345234;CP=3;SP=6;R=220;O;m0;
2025.11.15 14:00:58 4: Signalduino: Read, msg: MS;P2=-288;P3=220;P4=-796;P5=722;P6=-8089;D=363452343434343452343452343452523434525252345234345234523434345234;CP=3;SP=6;R=220;O;
2025.11.15 14:00:58 4: Signalduino: Read, msg: MS;P0=189;P1=-817;P2=688;P3=-321;P4=-8080;D=040123010101010123010123010123230101232323012301012301230101012301;CP=0;SP=4;R=220;m2;
2025.11.15 14:00:59 4: Signalduino: Read, msg: MS;P2=-289;P3=211;P4=-792;P5=729;P6=-8082;D=363452343434343452343452343452523434525252345234345234525234345252;CP=3;SP=6;R=220;O;m2;
2025.11.15 14:00:59 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:59 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412674B3 length 32 RSSI = -92
2025.11.15 14:00:59 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010010110011, hlen 8
2025.11.15 14:00:59 4: Signalduino: Read, msg: MS;P2=-315;P3=189;P4=-820;P5=702;P6=-8091;D=363452343434343452343452343452523434525252345234345234525234345252;CP=3;SP=6;R=220;m1;
2025.11.15 14:00:59 4: Signalduino: Read, msg: MU;P0=195;P1=-312;P2=706;P4=-827;P5=-8116;D=0121040421210504210404040404210404210404212104;CP=0;R=219;
2025.11.15 14:00:59 4: Signalduino: Read, msg: MS;P1=-321;P2=203;P3=-813;P4=697;P5=-8104;D=252341232323232341232341232341412323414141234123234123414123234141;CP=2;SP=5;R=219;m2;
2025.11.15 14:01:01 4: Signalduino: Read, msg: MS;P2=-260;P3=247;P4=-760;P5=758;P6=-8043;D=363452343434343452343452343452523434525252345234345252343434523434;CP=3;SP=6;R=225;O;m2;
2025.11.15 14:01:01 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:01:01 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412674C4 length 32 RSSI = -89.5
2025.11.15 14:01:01 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010011000100, hlen 8
2025.11.15 14:01:01 4: Signalduino: Read, msg: MS;P2=-264;P3=254;P4=-758;P5=753;P6=-8054;D=363452343434343452343452343452523434525252345234345252343434523434;CP=3;SP=6;R=225;O;m1;
2025.11.15 14:01:01 4: Signalduino: Dispatch, P20#412674C4, Dropped due to short time or equal msg
2025.11.15 14:01:01 4: Signalduino: Read, msg: MS;P2=-271;P3=250;P4=-754;P5=753;P6=-8057;D=363452343434343452343452343452523434525252345234345252343434523434;CP=3;SP=6;R=225;O;m0;
2025.11.15 14:01:01 4: Signalduino: Read, msg: MS;P2=-264;P3=258;P4=-754;P5=755;P6=-8050;D=363452343434343452343452343452523434525252345234345252343434523434;CP=3;SP=6;R=225;O;
2025.11.15 14:01:01 4: Signalduino: Read, msg: MU;P0=258;P1=-755;P2=751;P3=-263;P4=-8036;D=01012301010401230101010101230101230101232301012323230123010123230101012301010;CP=0;R=223;
2025.11.15 14:01:02 4: Signalduino: Read, msg: MS;P2=-264;P3=254;P4=-773;P5=739;P6=-8052;D=363452343434343452343452343452523434525252345234345252345234523452;CP=3;SP=6;R=223;O;m2;
2025.11.15 14:01:02 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:01:02 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412674D5 length 32 RSSI = -90.5
2025.11.15 14:01:02 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010011010101, hlen 8
2025.11.15 14:01:02 4: Signalduino: Read, msg: MS;P2=-265;P3=252;P4=-758;P5=753;P6=-8065;D=363452343434343452343452343452523434525252345234345252345234523452;CP=3;SP=6;R=223;O;m1;
2025.11.15 14:01:02 4: Signalduino: Dispatch, P20#412674D5, Dropped due to short time or equal msg
2025.11.15 14:01:02 4: Signalduino: Read, msg: MS;P2=-259;P3=253;P4=-759;P5=757;P6=-8064;D=363452343434343452343452343452523434525252345234345252345234523452;CP=3;SP=6;R=223;O;m0;
2025.11.15 14:01:02 4: Signalduino: Read, msg: MS;P2=-257;P3=249;P4=-766;P5=754;P6=-8072;D=363452343434343452343452343452523434525252345234345252345234523452;CP=3;SP=6;R=223;O;
2025.11.15 14:01:02 4: Signalduino: Read, msg: MS;P0=740;P1=-276;P2=234;P3=-783;P4=-8058;D=242301232323232301232301232301012323010101230123230101230123012301;CP=2;SP=4;R=223;m2;
2025.11.15 14:01:02 4: Signalduino: Read, msg: MU;P0=740;P1=-276;P2=234;P3=-783;P4=-8058;P5=-32001;D=24230123232323230123230123230101232301010123012323010123012301230125;CP=2;R=223;
Ich hoff, es passt jetzt. Kann gut sein, dass die Fernbedienung beim Gehäuse öffnen etwas gelitten hat.
elektron-bbs
Die Fernbedienung tut es noch :-)
Ich muss für den Tastencode ein Bit mehr nehmen und dafür beim Counter eines weniger.
Intel(R) Atom(TM) CPU N270 mit 2 SIGNALduino nanoCC1101 + ESPEasy 2x serial server SIGNALduino nanoCC1101, Raspberry Pi 2 mit 2 CUL Stackable CC1101, Raspberry Pi 3 mit SIGNALduino radino + nano328 + 2 x SIGNAL-ESP CC1101 + 2 x rf_Gateway
drhirn
Mir ist das alles ja ein Rätsel...
Insofern: Danke, dass du dir das antust!
