[Signalduino] [gelöst] Deckenventilator Forrovenco QX-01-DE1 - Funkprotokoll-Findung
Begonnen von drhirn, 13 November 2025, 17:17:08
drhirn
Light on/off:
2025.11.15 13:58:30 4: Signalduino: Read, msg: MS;P2=-269;P3=230;P4=-781;P5=751;P6=-7890;D=363452343434343452343452343452523434525252345234343434345252343452;CP=3;SP=6;R=221;O;m2;
2025.11.15 13:58:30 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:58:30 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267419 length 32 RSSI = -91.5
2025.11.15 13:58:30 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010000011001, hlen 8
2025.11.15 13:58:30 4: Signalduino: Read, msg: MS;P2=-300;P3=228;P4=-785;P5=724;P6=-7907;D=363452343434343452343452343452523434525252345234343434345252343452;CP=3;SP=6;R=221;O;m1;
2025.11.15 13:58:30 4: Signalduino: Dispatch, P20#41267419, Dropped due to short time or equal msg
2025.11.15 13:58:30 4: Signalduino: Read, msg: MS;P2=-308;P3=210;P4=-814;P5=713;P6=-7895;D=363452343434343452343452343452523434525252345234343434345252343452;CP=3;SP=6;R=221;m0;
2025.11.15 13:58:31 4: Signalduino: Read, msg: MS;P2=-279;P3=234;P4=-784;P5=738;P6=-7911;D=363452343434343452343452343452523434525252345234343434523452345234;CP=3;SP=6;R=220;O;m2;
2025.11.15 13:58:31 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:58:31 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#4126742A length 32 RSSI = -92
2025.11.15 13:58:31 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010000101010, hlen 8
2025.11.15 13:58:31 4: Signalduino: Read, msg: MS;P2=-296;P3=235;P4=-783;P5=725;P6=-7896;D=363452343434343452343452343452523434525252345234343434523452345234;CP=3;SP=6;R=220;O;m1;
2025.11.15 13:58:31 4: Signalduino: Dispatch, P20#4126742A, Dropped due to short time or equal msg
2025.11.15 13:58:31 4: Signalduino: Read, msg: MS;P2=-288;P3=218;P4=-804;P5=714;P6=-7906;D=363452343434343452343452343452523434525252345234343434523452345234;CP=3;SP=6;R=220;O;m0;
2025.11.15 13:58:31 4: Signalduino: Read, msg: MS;P2=-297;P3=195;P4=-828;P5=720;P6=-7911;D=363452343434343452343452343452523434525252345234343434523452345234;CP=3;SP=6;R=220;
2025.11.15 13:58:32 4: Signalduino: Read, msg: MS;P2=-283;P3=233;P4=-777;P5=736;P6=-7899;D=363452343434343452343452343452523434525252345234343434525252345252;CP=3;SP=6;R=219;O;m2;
2025.11.15 13:58:32 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:58:32 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#4126743B length 32 RSSI = -92.5
2025.11.15 13:58:32 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010000111011, hlen 8
2025.11.15 13:58:32 4: Signalduino: Read, msg: MS;P2=-287;P3=223;P4=-789;P5=726;P6=-7901;D=363452343434343452343452343452523434525252345234343434525252345252;CP=3;SP=6;R=219;O;m1;
2025.11.15 13:58:32 4: Signalduino: Dispatch, P20#4126743B, Dropped due to short time or equal msg
2025.11.15 13:58:32 4: Signalduino: Read, msg: MS;P2=-290;P3=216;P4=-801;P5=716;P6=-7912;D=363452343434343452343452343452523434525252345234343434525252345252;CP=3;SP=6;R=219;O;m0;
2025.11.15 13:58:32 4: Signalduino: Read, msg: MS;P2=-293;P3=213;P4=-797;P5=726;P6=-7926;D=363452343434343452343452343452523434525252345234343434525252345252;CP=3;SP=6;R=219;O;
2025.11.15 13:58:33 4: Signalduino: Read, msg: MS;P2=-285;P3=226;P4=-784;P5=728;P6=-7901;D=363452343434343452343452343452523434525252345234343452343452523434;CP=3;SP=6;R=219;O;m2;
2025.11.15 13:58:33 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:58:33 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#4126744C length 32 RSSI = -92.5
2025.11.15 13:58:33 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010001001100, hlen 8
2025.11.15 13:58:33 4: Signalduino: Read, msg: MS;P2=-300;P3=226;P4=-791;P5=710;P6=-7910;D=363452343434343452343452343452523434525252345234343452343452523434;CP=3;SP=6;R=219;O;m1;
2025.11.15 13:58:33 4: Signalduino: Dispatch, P20#4126744C, Dropped due to short time or equal msg
2025.11.15 13:58:34 4: Signalduino: Read, msg: MS;P2=-300;P3=206;P4=-804;P5=717;P6=-7925;D=363452343434343452343452343452523434525252345234343452343452523434;CP=3;SP=6;R=219;O;m0;
2025.11.15 13:58:34 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:58:34 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#4126744C length 32 RSSI = -92.5
2025.11.15 13:58:34 4: Signalduino: Dispatch, P20#4126744C, Dropped due to short time or equal msg
2025.11.15 13:58:34 4: Signalduino: Read, msg: MS;P2=-309;P3=187;P4=-834;P5=719;P6=-7918;D=363452343434343452343452343452523434525252345234343452343452523434;CP=3;SP=6;R=219;
2025.11.15 13:58:35 4: Signalduino: Read, msg: MS;P2=-295;P3=233;P4=-776;P5=729;P6=-7902;D=363452343434343452343452343452523434525252345234343452345252523452;CP=3;SP=6;R=219;O;m2;
2025.11.15 13:58:35 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:58:35 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#4126745D length 32 RSSI = -92.5
2025.11.15 13:58:35 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010001011101, hlen 8
2025.11.15 13:58:35 4: Signalduino: Read, msg: MS;P2=-282;P3=231;P4=-782;P5=730;P6=-7901;D=363452343434343452343452343452523434525252345234343452345252523452;CP=3;SP=6;R=219;O;m1;
2025.11.15 13:58:35 4: Signalduino: Dispatch, P20#4126745D, Dropped due to short time or equal msg
2025.11.15 13:58:35 4: Signalduino: Read, msg: MS;P2=-302;P3=217;P4=-798;P5=709;P6=-7904;D=363452343434343452343452343452523434525252345234343452345252523452;CP=3;SP=6;R=219;O;m0;
2025.11.15 13:58:35 4: Signalduino: Read, msg: MS;P2=-327;P3=203;P4=-814;P5=706;P6=-7910;D=363452343434343452343452343452523434525252345234343452345252523452;CP=3;SP=6;R=219;
fan_1:
2025.11.15 13:59:33 4: Signalduino: Read, msg: MS;P0=244;P1=-275;P2=743;P4=-776;P6=-7908;D=060421040404040421040421040421210404212121210404040421210404042104;CP=0;SP=6;R=219;O;m2;
2025.11.15 13:59:33 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:59:33 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267862 length 32 RSSI = -92.5
2025.11.15 13:59:33 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100001100010, hlen 8
2025.11.15 13:59:33 4: Signalduino: Read, msg: MS;P0=231;P1=-299;P2=723;P4=-783;P6=-7908;D=060421040404040421040421040421210404212121210404040421210404042104;CP=0;SP=6;R=219;O;m1;
2025.11.15 13:59:33 4: Signalduino: Dispatch, P20#41267862, Dropped due to short time or equal msg
2025.11.15 13:59:33 4: Signalduino: Read, msg: MS;P0=223;P1=-299;P2=715;P4=-789;P6=-7918;D=060421040404040421040421040421210404212121210404040421210404042104;CP=0;SP=6;R=219;O;m0;
2025.11.15 13:59:33 4: Signalduino: Read, msg: MS;P0=209;P1=-313;P2=702;P4=-804;P6=-7927;D=060421040404040421040421040421210404212121210404040421210404042104;CP=0;SP=6;R=219;O;
2025.11.15 13:59:33 4: Signalduino: Read, msg: MS;P0=204;P1=-811;P2=701;P3=-306;P4=-8018;D=040123010101010123010123010123230101232323230101010123230101012301;CP=0;SP=4;R=219;m2;
2025.11.15 13:59:33 4: Signalduino: Read, msg: MU;P0=204;P1=-811;P2=701;P3=-306;P4=-8018;P5=-32001;D=04012301010101012301012301012323010123232323010101012323010101230105;CP=0;R=219;
2025.11.15 13:59:34 4: Signalduino: Read, msg: MS;P2=-279;P3=222;P4=-785;P5=736;P6=-7913;D=363452343434343452343452343452523434525252523434343452525234345252;CP=3;SP=6;R=219;O;m2;
2025.11.15 13:59:34 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:59:34 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267873 length 32 RSSI = -92.5
2025.11.15 13:59:34 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100001110011, hlen 8
2025.11.15 13:59:34 4: Signalduino: Read, msg: MS;P2=-281;P3=229;P4=-787;P5=724;P6=-7909;D=363452343434343452343452343452523434525252523434343452525234345252;CP=3;SP=6;R=219;O;m1;
2025.11.15 13:59:34 4: Signalduino: Dispatch, P20#41267873, Dropped due to short time or equal msg
2025.11.15 13:59:34 4: Signalduino: Read, msg: MS;P2=-280;P3=234;P4=-774;P5=739;P6=-7910;D=363452343434343452343452343452523434525252523434343452525234345252;CP=3;SP=6;R=219;O;m0;
2025.11.15 13:59:34 4: Signalduino: Read, msg: MS;P2=-287;P3=226;P4=-794;P5=729;P6=-7921;D=363452343434343452343452343452523434525252523434343452525234345252;CP=3;SP=6;R=219;O;
2025.11.15 13:59:34 4: Signalduino: Read, msg: MU;P0=668;P1=-345;P2=166;P3=-849;P4=-7926;P5=248;D=01232301012423012323232323012323012323010123230101010123232323010101232301012423012323232323012323012323010123235;CP=2;R=219;
2025.11.15 13:59:36 4: Signalduino: Read, msg: MS;P0=-7981;P2=-288;P3=230;P4=-783;P5=738;D=303452343434343452343452343452523434525252523434343434343434523434;CP=3;SP=0;R=219;O;m2;
2025.11.15 13:59:36 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:59:36 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267804 length 32 RSSI = -92.5
2025.11.15 13:59:36 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100000000100, hlen 8
2025.11.15 13:59:36 4: Signalduino: Read, msg: MS;P0=-7918;P2=-287;P3=236;P4=-780;P5=725;D=303452343434343452343452343452523434525252523434343434343434523434;CP=3;SP=0;R=219;O;m1;
2025.11.15 13:59:36 4: Signalduino: Dispatch, P20#41267804, Dropped due to short time or equal msg
2025.11.15 13:59:36 4: Signalduino: Read, msg: MS;P0=-7905;P2=-283;P3=243;P4=-779;P5=731;D=303452343434343452343452343452523434525252523434343434343434523434;CP=3;SP=0;R=219;O;m0;
2025.11.15 13:59:36 4: Signalduino: Read, msg: MS;P0=-7900;P2=-282;P3=218;P4=-797;P5=736;D=303452343434343452343452343452523434525252523434343434343434523434;CP=3;SP=0;R=219;O;
2025.11.15 13:59:36 4: Signalduino: Read, msg: MU;P0=161;P1=-939;P2=646;P3=-362;P4=-7943;D=010123010104012301010101012301012301012323010123232323010101010101010123010104012301010101012301012301012323010123232323010101010101010123010104012301010101012301;CP=0;R=220;
2025.11.15 13:59:37 4: Signalduino: Read, msg: MS;P2=-277;P3=235;P4=-780;P5=741;P6=-7894;D=363452343434343452343452343452523434525252523434343434345234523452;CP=3;SP=6;R=220;O;m2;
2025.11.15 13:59:37 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:59:37 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267815 length 32 RSSI = -92
2025.11.15 13:59:37 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100000010101, hlen 8
2025.11.15 13:59:37 4: Signalduino: Read, msg: MS;P2=-269;P3=240;P4=-777;P5=748;P6=-7909;D=363452343434343452343452343452523434525252523434343434345234523452;CP=3;SP=6;R=220;O;m1;
2025.11.15 13:59:37 4: Signalduino: Dispatch, P20#41267815, Dropped due to short time or equal msg
2025.11.15 13:59:37 4: Signalduino: Read, msg: MS;P2=-276;P3=236;P4=-775;P5=739;P6=-7898;D=363452343434343452343452343452523434525252523434343434345234523452;CP=3;SP=6;R=220;O;m0;
2025.11.15 13:59:37 4: Signalduino: Read, msg: MS;P2=-289;P3=225;P4=-791;P5=737;P6=-7901;D=363452343434343452343452343452523434525252523434343434345234523452;CP=3;SP=6;R=220;O;
2025.11.15 13:59:37 4: Signalduino: Read, msg: MS;P0=684;P1=-334;P2=187;P3=-826;P4=-7915;D=242301232323232301232301232301012323010101012323232323230123012301;CP=2;SP=4;R=221;O;m2;
2025.11.15 13:59:37 4: Signalduino: Read, msg: MS;P0=684;P1=-334;P2=183;P3=-863;P4=-7915;D=242301232323232301232301232301012323010101012323232323230123012301;CP=2;SP=4;R=221;m1;
2025.11.15 13:59:38 4: Signalduino: Read, msg: MS;P0=-770;P2=-285;P3=243;P4=738;P5=-7904;D=353042303030303042303042303042423030424242423030303030423030424230;CP=3;SP=5;R=220;O;m2;
2025.11.15 13:59:38 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 13:59:38 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267826 length 32 RSSI = -92
2025.11.15 13:59:38 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100000100110, hlen 8
2025.11.15 13:59:38 4: Signalduino: Read, msg: MS;P0=-793;P2=-284;P3=227;P4=728;P5=-7893;D=353042303030303042303042303042423030424242423030303030423030424230;CP=3;SP=5;R=220;O;m1;
2025.11.15 13:59:38 4: Signalduino: Dispatch, P20#41267826, Dropped due to short time or equal msg
2025.11.15 13:59:38 4: Signalduino: Read, msg: MS;P0=-783;P2=-290;P3=228;P4=723;P5=-7898;D=353042303030303042303042303042423030424242423030303030423030424230;CP=3;SP=5;R=220;O;m0;
2025.11.15 13:59:38 4: Signalduino: Read, msg: MS;P0=-783;P2=-282;P3=227;P4=731;P5=-7901;D=353042303030303042303042303042423030424242423030303030423030424230;CP=3;SP=5;R=220;O;
2025.11.15 13:59:38 4: Signalduino: Read, msg: MS;P0=208;P1=-866;P2=681;P3=-348;P4=-7940;D=040123010101010123010123010123230101232323230101010101230101232301;CP=0;SP=4;R=220;
fan_reverse:
2025.11.15 14:00:08 4: Signalduino: Read, msg: MS;P2=-253;P3=248;P4=-760;P5=760;P6=-7816;D=363452343434343452343452343452523434525252523434345234525252525252;CP=3;SP=6;R=225;O;m2;
2025.11.15 14:00:08 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:08 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412678BF length 32 RSSI = -89.5
2025.11.15 14:00:08 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100010111111, hlen 8
2025.11.15 14:00:08 4: Signalduino: Read, msg: MS;P2=-261;P3=252;P4=-759;P5=756;P6=-7824;D=363452343434343452343452343452523434525252523434345234525252525252;CP=3;SP=6;R=225;O;m1;
2025.11.15 14:00:08 4: Signalduino: Dispatch, P20#412678BF, Dropped due to short time or equal msg
2025.11.15 14:00:08 4: Signalduino: Read, msg: MS;P2=-259;P3=256;P4=-761;P5=760;P6=-7830;D=363452343434343452343452343452523434525252523434345234525252525252;CP=3;SP=6;R=225;O;m0;
2025.11.15 14:00:08 4: Signalduino: Read, msg: MS;P2=-259;P3=249;P4=-776;P5=748;P6=-7823;D=363452343434343452343452343452523434525252523434345234525252525252;CP=3;SP=6;R=225;O;
2025.11.15 14:00:08 4: Signalduino: Read, msg: MS;P0=698;P1=-318;P2=200;P3=-7870;P4=-833;D=232401242424242401242401242401012424010101012424240124010101010101;CP=2;SP=3;R=220;
2025.11.15 14:00:09 4: Signalduino: Read, msg: MS;P2=-271;P3=249;P4=-768;P5=743;P6=-7830;D=363452343434343452343452343452523434525252523434345252343452343434;CP=3;SP=6;R=222;O;m2;
2025.11.15 14:00:09 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:09 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412678C8 length 32 RSSI = -91
2025.11.15 14:00:09 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100011001000, hlen 8
2025.11.15 14:00:09 4: Signalduino: Read, msg: MS;P2=-271;P3=245;P4=-770;P5=745;P6=-7825;D=363452343434343452343452343452523434525252523434345252343452343434;CP=3;SP=6;R=222;O;m1;
2025.11.15 14:00:09 4: Signalduino: Dispatch, P20#412678C8, Dropped due to short time or equal msg
2025.11.15 14:00:09 4: Signalduino: Read, msg: MS;P2=-275;P3=231;P4=-791;P5=738;P6=-7830;D=363452343434343452343452343452523434525252523434345252343452343434;CP=3;SP=6;R=222;O;m0;
2025.11.15 14:00:09 4: Signalduino: Read, msg: MS;P2=-322;P3=199;P4=-845;P5=692;P6=-7833;D=363452343434343452343452343452523434525252523434345252343452343434;CP=3;SP=6;R=222;
2025.11.15 14:00:10 4: Signalduino: Read, msg: MS;P2=-279;P3=240;P4=-770;P5=739;P6=-7828;D=363452343434343452343452343452523434525252523434345252345252343452;CP=3;SP=6;R=221;O;m2;
2025.11.15 14:00:10 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:10 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412678D9 length 32 RSSI = -91.5
2025.11.15 14:00:10 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100011011001, hlen 8
2025.11.15 14:00:10 4: Signalduino: Read, msg: MS;P2=-272;P3=242;P4=-780;P5=746;P6=-7827;D=363452343434343452343452343452523434525252523434345252345252343452;CP=3;SP=6;R=221;O;m1;
2025.11.15 14:00:10 4: Signalduino: Dispatch, P20#412678D9, Dropped due to short time or equal msg
2025.11.15 14:00:10 4: Signalduino: Read, msg: MS;P2=-280;P3=232;P4=-776;P5=737;P6=-7831;D=363452343434343452343452343452523434525252523434345252345252343452;CP=3;SP=6;R=221;O;m0;
2025.11.15 14:00:10 4: Signalduino: Read, msg: MS;P2=-329;P3=210;P4=-848;P5=683;P6=-7835;D=363452343434343452343452343452523434525252523434345252345252343452;CP=3;SP=6;R=221;
2025.11.15 14:00:11 4: Signalduino: Read, msg: MS;P2=-255;P3=252;P4=-770;P5=753;P6=-7815;D=363452343434343452343452343452523434525252523434345252523452345234;CP=3;SP=6;R=223;O;m2;
2025.11.15 14:00:11 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:11 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412678EA length 32 RSSI = -90.5
2025.11.15 14:00:11 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100011101010, hlen 8
2025.11.15 14:00:11 4: Signalduino: Read, msg: MS;P2=-303;P3=208;P4=-805;P5=717;P6=-7831;D=363452343434343452343452343452523434525252523434345252523452345234;CP=3;SP=6;R=223;m1;
2025.11.15 14:00:11 4: Signalduino: Dispatch, P20#412678EA, Dropped due to short time or equal msg
2025.11.15 14:00:12 4: Signalduino: Read, msg: MS;P2=-257;P3=254;P4=-759;P5=756;P6=-7822;D=363452343434343452343452343452523434525252523434345252525252345252;CP=3;SP=6;R=223;O;m2;
2025.11.15 14:00:12 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:12 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412678FB length 32 RSSI = -90.5
2025.11.15 14:00:12 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111100011111011, hlen 8
2025.11.15 14:00:12 4: Signalduino: Read, msg: MS;P2=-250;P3=259;P4=-766;P5=767;P6=-7825;D=363452343434343452343452343452523434525252523434345252525252345252;CP=3;SP=6;R=223;O;m1;
2025.11.15 14:00:12 4: Signalduino: Dispatch, P20#412678FB, Dropped due to short time or equal msg
2025.11.15 14:00:12 4: Signalduino: Read, msg: MS;P2=-260;P3=253;P4=-771;P5=750;P6=-7820;D=363452343434343452343452343452523434525252523434345252525252345252;CP=3;SP=6;R=223;O;m0;
2025.11.15 14:00:12 4: Signalduino: Read, msg: MS;P2=-260;P3=244;P4=-766;P5=759;P6=-7822;D=363452343434343452343452343452523434525252523434345252525252345252;CP=3;SP=6;R=223;O;
2025.11.15 14:00:12 4: Signalduino: Read, msg: MS;P0=708;P1=-295;P2=205;P3=-839;P4=-7868;D=242301232323232301232301232301012323010101012323230101010101230101;CP=2;SP=4;R=222;
time_2h:
2025.11.15 14:00:54 4: Signalduino: Read, msg: MS;P0=-7892;P2=-289;P3=227;P4=-797;P5=721;D=303452343434343452343452343452523434525252345234345252525234525252;CP=3;SP=0;R=219;O;m2;
2025.11.15 14:00:54 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:54 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412674F7 length 32 RSSI = -92.5
2025.11.15 14:00:54 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010011110111, hlen 8
2025.11.15 14:00:54 4: Signalduino: Read, msg: MS;P0=-8042;P2=-304;P3=221;P4=-795;P5=713;D=303452343434343452343452343452523434525252345234345252525234525252;CP=3;SP=0;R=219;O;m1;
2025.11.15 14:00:54 4: Signalduino: Dispatch, P20#412674F7, Dropped due to short time or equal msg
2025.11.15 14:00:54 4: Signalduino: Read, msg: MS;P0=-8063;P2=-304;P3=207;P4=-815;P5=711;D=303452343434343452343452343452523434525252345234345252525234525252;CP=3;SP=0;R=219;O;m0;
2025.11.15 14:00:54 4: Signalduino: Read, msg: MS;P0=-8073;P2=-318;P3=187;P4=-829;P5=700;D=303452343434343452343452343452523434525252345234345252525234525252;CP=3;SP=0;R=219;
2025.11.15 14:00:55 4: Signalduino: Read, msg: MS;P2=-300;P3=224;P4=-793;P5=727;P6=-8073;D=363452343434343452343452343452523434525252345234345234343434343434;CP=3;SP=6;R=220;O;m2;
2025.11.15 14:00:55 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:55 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267480 length 32 RSSI = -92
2025.11.15 14:00:55 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010010000000, hlen 8
2025.11.15 14:00:55 4: Signalduino: Read, msg: MS;P2=-313;P3=200;P4=-815;P5=713;P6=-8100;D=363452343434343452343452343452523434525252345234345234343434343434;CP=3;SP=6;R=220;O;m1;
2025.11.15 14:00:55 4: Signalduino: Read, msg: MS;P2=-309;P3=207;P4=-814;P5=715;P6=-8118;D=363452343434343452343452343452523434525252345234345234343434343434;CP=3;SP=6;R=220;m0;
2025.11.15 14:00:55 4: Signalduino: Read, msg: MU;P0=194;P1=-322;P3=-827;P4=698;P6=-8140;D=0103034141030341414103410303410303030303030306034103030303034103034103034141030341;CP=0;R=217;
2025.11.15 14:00:55 4: Signalduino: Read, msg: MU;P0=-1848;P1=-340;P2=665;P4=213;P5=-829;P6=140;P7=-8096;D=1214521454521454545456545454745214545454545214021454521214545214;CP=4;R=218;
2025.11.15 14:00:57 4: Signalduino: Read, msg: MS;P0=-7956;P2=-286;P3=220;P4=-792;P5=725;D=303452343434343452343452343452523434525252345234345234345234343452;CP=3;SP=0;R=220;O;m2;
2025.11.15 14:00:57 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:57 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#41267491 length 32 RSSI = -92
2025.11.15 14:00:57 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010010010001, hlen 8
2025.11.15 14:00:57 4: Signalduino: Read, msg: MS;P0=-8053;P2=-287;P3=229;P4=-781;P5=739;D=303452343434343452343452343452523434525252345234345234345234343452;CP=3;SP=0;R=220;O;m1;
2025.11.15 14:00:57 4: Signalduino: Dispatch, P20#41267491, Dropped due to short time or equal msg
2025.11.15 14:00:57 4: Signalduino: Read, msg: MS;P0=-8064;P2=-295;P3=216;P4=-794;P5=727;D=303452343434343452343452343452523434525252345234345234345234343452;CP=3;SP=0;R=220;O;m0;
2025.11.15 14:00:57 4: Signalduino: Read, msg: MS;P0=-8078;P2=-295;P3=221;P4=-795;P5=713;D=303452343434343452343452343452523434525252345234345234345234343452;CP=3;SP=0;R=220;O;
2025.11.15 14:00:57 4: Signalduino: Read, msg: MS;P0=700;P1=-317;P2=193;P3=-819;P4=-8108;D=242301232323232301232301232301012323010101230123230123230123232301;CP=2;SP=4;R=219;m2;
2025.11.15 14:00:57 4: Signalduino: Read, msg: MU;P0=-820;P1=205;P2=691;P3=-323;P4=-8088;P5=116;P6=272;D=01023141023101010101023105023101023231010236;CP=1;R=218;
2025.11.15 14:00:58 4: Signalduino: Read, msg: MS;P2=-287;P3=232;P4=-781;P5=727;P6=-8079;D=363452343434343452343452343452523434525252345234345234523434345234;CP=3;SP=6;R=220;O;m2;
2025.11.15 14:00:58 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:58 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412674A2 length 32 RSSI = -92
2025.11.15 14:00:58 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010010100010, hlen 8
2025.11.15 14:00:58 4: Signalduino: Read, msg: MS;P2=-281;P3=217;P4=-796;P5=735;P6=-8088;D=363452343434343452343452343452523434525252345234345234523434345234;CP=3;SP=6;R=220;O;m1;
2025.11.15 14:00:58 4: Signalduino: Dispatch, P20#412674A2, Dropped due to short time or equal msg
2025.11.15 14:00:58 4: Signalduino: Read, msg: MS;P2=-289;P3=221;P4=-788;P5=738;P6=-8086;D=363452343434343452343452343452523434525252345234345234523434345234;CP=3;SP=6;R=220;O;m0;
2025.11.15 14:00:58 4: Signalduino: Read, msg: MS;P2=-288;P3=220;P4=-796;P5=722;P6=-8089;D=363452343434343452343452343452523434525252345234345234523434345234;CP=3;SP=6;R=220;O;
2025.11.15 14:00:58 4: Signalduino: Read, msg: MS;P0=189;P1=-817;P2=688;P3=-321;P4=-8080;D=040123010101010123010123010123230101232323012301012301230101012301;CP=0;SP=4;R=220;m2;
2025.11.15 14:00:59 4: Signalduino: Read, msg: MS;P2=-289;P3=211;P4=-792;P5=729;P6=-8082;D=363452343434343452343452343452523434525252345234345234525234345252;CP=3;SP=6;R=220;O;m2;
2025.11.15 14:00:59 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:00:59 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412674B3 length 32 RSSI = -92
2025.11.15 14:00:59 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010010110011, hlen 8
2025.11.15 14:00:59 4: Signalduino: Read, msg: MS;P2=-315;P3=189;P4=-820;P5=702;P6=-8091;D=363452343434343452343452343452523434525252345234345234525234345252;CP=3;SP=6;R=220;m1;
2025.11.15 14:00:59 4: Signalduino: Read, msg: MU;P0=195;P1=-312;P2=706;P4=-827;P5=-8116;D=0121040421210504210404040404210404210404212104;CP=0;R=219;
2025.11.15 14:00:59 4: Signalduino: Read, msg: MS;P1=-321;P2=203;P3=-813;P4=697;P5=-8104;D=252341232323232341232341232341412323414141234123234123414123234141;CP=2;SP=5;R=219;m2;
2025.11.15 14:01:01 4: Signalduino: Read, msg: MS;P2=-260;P3=247;P4=-760;P5=758;P6=-8043;D=363452343434343452343452343452523434525252345234345252343434523434;CP=3;SP=6;R=225;O;m2;
2025.11.15 14:01:01 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:01:01 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412674C4 length 32 RSSI = -89.5
2025.11.15 14:01:01 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010011000100, hlen 8
2025.11.15 14:01:01 4: Signalduino: Read, msg: MS;P2=-264;P3=254;P4=-758;P5=753;P6=-8054;D=363452343434343452343452343452523434525252345234345252343434523434;CP=3;SP=6;R=225;O;m1;
2025.11.15 14:01:01 4: Signalduino: Dispatch, P20#412674C4, Dropped due to short time or equal msg
2025.11.15 14:01:01 4: Signalduino: Read, msg: MS;P2=-271;P3=250;P4=-754;P5=753;P6=-8057;D=363452343434343452343452343452523434525252345234345252343434523434;CP=3;SP=6;R=225;O;m0;
2025.11.15 14:01:01 4: Signalduino: Read, msg: MS;P2=-264;P3=258;P4=-754;P5=755;P6=-8050;D=363452343434343452343452343452523434525252345234345252343434523434;CP=3;SP=6;R=225;O;
2025.11.15 14:01:01 4: Signalduino: Read, msg: MU;P0=258;P1=-755;P2=751;P3=-263;P4=-8036;D=01012301010401230101010101230101230101232301012323230123010123230101012301010;CP=0;R=223;
2025.11.15 14:01:02 4: Signalduino: Read, msg: MS;P2=-264;P3=254;P4=-773;P5=739;P6=-8052;D=363452343434343452343452343452523434525252345234345252345234523452;CP=3;SP=6;R=223;O;m2;
2025.11.15 14:01:02 4: Signalduino: Parse_MS, Matched MS protocol id 20 -> RCnoName20
2025.11.15 14:01:02 4: Signalduino: Parse_MS, Decoded matched MS protocol id 20 dmsg P20#412674D5 length 32 RSSI = -90.5
2025.11.15 14:01:02 4: Signalduino: SD_UT protocol 20, bitData 01000001001001100111010011010101, hlen 8
2025.11.15 14:01:02 4: Signalduino: Read, msg: MS;P2=-265;P3=252;P4=-758;P5=753;P6=-8065;D=363452343434343452343452343452523434525252345234345252345234523452;CP=3;SP=6;R=223;O;m1;
2025.11.15 14:01:02 4: Signalduino: Dispatch, P20#412674D5, Dropped due to short time or equal msg
2025.11.15 14:01:02 4: Signalduino: Read, msg: MS;P2=-259;P3=253;P4=-759;P5=757;P6=-8064;D=363452343434343452343452343452523434525252345234345252345234523452;CP=3;SP=6;R=223;O;m0;
2025.11.15 14:01:02 4: Signalduino: Read, msg: MS;P2=-257;P3=249;P4=-766;P5=754;P6=-8072;D=363452343434343452343452343452523434525252345234345252345234523452;CP=3;SP=6;R=223;O;
2025.11.15 14:01:02 4: Signalduino: Read, msg: MS;P0=740;P1=-276;P2=234;P3=-783;P4=-8058;D=242301232323232301232301232301012323010101230123230101230123012301;CP=2;SP=4;R=223;m2;
2025.11.15 14:01:02 4: Signalduino: Read, msg: MU;P0=740;P1=-276;P2=234;P3=-783;P4=-8058;P5=-32001;D=24230123232323230123230123230101232301010123012323010123012301230125;CP=2;R=223;
Ich hoff, es passt jetzt. Kann gut sein, dass die Fernbedienung beim Gehäuse öffnen etwas gelitten hat.
elektron-bbs
Die Fernbedienung tut es noch :-)
Ich muss für den Tastencode ein Bit mehr nehmen und dafür beim Counter eines weniger.
Intel(R) Atom(TM) CPU N270 mit 2 SIGNALduino nanoCC1101 + ESPEasy 2x serial server SIGNALduino nanoCC1101, Raspberry Pi 2 mit 2 CUL Stackable CC1101, Raspberry Pi 3 mit SIGNALduino radino + nano328 + 2 x SIGNAL-ESP CC1101 + 2 x rf_Gateway
drhirn
Mir ist das alles ja ein Rätsel...
Insofern: Danke, dass du dir das antust!
elektron-bbs
Ich habe eine erste Version fertig gestellt. Ein Update auf den neuen Branch kannst du mit folgendem Befehl durchführen:
update all https://raw.githubusercontent.com/RFD-FHEM/RFFHEM/master_RCnoName20_15/controls_signalduino.txt
Nach einem Neustart von FHEM sollte es dir nach Empfang mehrerer verschiedener Nachrichten von der Fernbedienung ein neues Gerät "RCnoName20_15_41267" anlegen. Bitte ausgiebig testen und berichten.
drhirn
Das sieht sehr, sehr gut aus! Hab alle Tasten durchprobiert. Und Abfolgen derselben. Hat alles geklappt wie es soll. Die _time Sachen konnte ich nicht wirklich testen. Der Ventilator empfängt sie, aber ob er dann wirklich ausgeht ist jetzt im Winter blöd zu testen. Das mit einer Stunde hat aber funktioniert.
elektron-bbs
Das freut mich.
Die Timer werden schon funktionieren. Die Fernbedienung startet ja den Vorgang nur. Das Abschalten nach Ablauf der Zeit erfolgt ja im Steuergerät des Ventilators.
drhirn
Ja. Ich meinte eher, ob ich vielleicht nicht Tasten vertauscht, falsche Codes geliefert habe oder so.
Danke für deine Arbeit! Freut mich sehr, dass ich den Ventilator jetzt über FHEM steuern kann.
elektron-bbs
Funktioniert alles wie gewollt?
Wenn ja, würde ich das Protokoll gerne in den Master-Branch überführen.
drhirn
Ja, danke! Er ist aufgrund der Temperaturen nicht oft in Betrieb. Aber ich teste hin und wieder weil ich so begeistert bin. Und da wäre mir jetzt nichts negatives aufgefallen.
elektron-bbs
Das Protokoll ist jetzt im Master-Branch auf https://github.com/RFD-FHEM/RFFHEM.
Die Installation bzw. ein Update erfolgt dann ab sofort mit diesem Befehl:
update all https://raw.githubusercontent.com/RFD-FHEM/RFFHEM/master/controls_signalduino.txt
