SolarForecast Fehlermeldung im Log ... has no Parameter or default value
Begonnen von Hackstall, 21 November 2025, 21:03:05
Hackstall
Hallo ich habe in meinem Log folgende Fehlermeldungen:
Kann mir hier jemand weiterhelfen was zu tun ist:
2025.11.21 20:57:44.317 1: Forecast - ERROR in Application - attribute ctrlSpecialReadings KPI '
conForecastTillNextSunrise' has no Parameter or default value set. Set the attribute again or inform Maintainer.
2025.11.21 20:57:44.318 1: Forecast - ERROR in Application - attribute ctrlSpecialReadings KPI '
currentRunMtsConsumer_04' has no Parameter or default value set. Set the attribute again or inform Maintainer.
daysUntilBatteryCare_01' has no Parameter or default value set. Set the attribute again or inform Maintainer.
runTimeAvgDayConsumer_01' has no Parameter or default value set. Set the attribute again or inform Maintainer.
runTimeAvgDayConsumer_05' has no Parameter or default value set. Set the attribute again or inform Maintainer.
2025.11.21 20:57:44.319 1: Forecast - ERROR in Application - attribute ctrlSpecialReadings KPI '
runTimeLastAPIProc' has no Parameter or default value set. Set the attribute again or inform Maintainer.
todayConsumptionForecast' has no Parameter or default value set. Set the attribute again or inform Maintainer.
2025.11.21 20:57:44.320 1: Forecast - ERROR in Application - attribute ctrlSpecialReadings KPI '
todayRemainingAPIcalls' has no Parameter or default value set. Set the attribute again or inform Maintainer.
